Hokieman Posted October 28, 2023 Posted October 28, 2023 Camping World description for Dometic Freshjet 3 states that Dometic heat strip accessory can be added with Universal ADB. It also mentions that Dometic SmartStart can be added to allow 2000W generators to be used. As already mentioned, the unit bolts right on without mods to the trailer body, uses the existing condensate drain lines, ADB, and thermostat, and is very quiet. Extensive dealer service network. I don’t need the heat strip as I use a small portable heater when on shore power. This checks all the boxes for me. Comments? Dometic Freshjet 3 7 1 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431.
CRM Posted October 28, 2023 Posted October 28, 2023 On 5/26/2023 at 1:46 PM, Frank C said: No heat strip in the new Dometic freshJet? I didn’t see it mentioned in the features. Our old Dometic has the electric heat strip which we use quite often for just getting the interior warmed up a bit on cold mornings when we are at a campground with shore power instead of burning propane to run the furnace. From Camping World- NOTE: For those who require a non-ducted heat strip application on the FreshJet 3 AC, it has been approved that you can use the Dometic Non-Ducted Heat Strip Kit (item 72431) installed in the Universal Air Distribution Box (item 69943). Camping World FreshJet 3 Series product info 1 4 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
CRM Posted October 28, 2023 Posted October 28, 2023 44 minutes ago, Hokieman said: Camping World description for Dometic Freshjet 3 states that Dometic heat strip accessory can be added with Universal ADB. It also mentions that Dometic SmartStart can be added to allow 2000W generators to be used. As already mentioned, the unit bolts right on without mods to the trailer body, uses the existing condensate drain lines, ADB, and thermostat, and is very quiet. Extensive dealer service network. I don’t need the heat strip as I use a small portable heater when on shore power. This checks all the boxes for me. Comments? Dometic Freshjet 3 Beat me to it! Sorry I missed your post... 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
dewdev Posted November 12, 2023 Posted November 12, 2023 On 7/28/2023 at 5:00 PM, rangered said: Happy to report that I have installed the Dometic FreshJet air conditioner on my Oliver this week. The install was fairly easy only taking a couple hours for two of us to complete. I rigged up a 3 to 1 pulley system in my workshop to lift up and remove the old noisey Penguin model. The new FreshJet is significantly lighter than the old unit, and a friend and I were able to stand on some scaffolding and lift it up and onto the Oliver. The wiring connections were easy to complete using the existing thermostat control box. I purchased the FreshJet 3 Series from RV Parts Country; $896.00 plus $124.00 shipping. So far my wife and I are happy with the performance of the FreshJet, it quickly brought down the indoor temperature and humidity on a hot Tennessee summer day. Best of all is the difference in the sound levels between the old and new units (69db versus 52db). Many thanks to @RoadLotus for researching the FreshJet and making everyone aware of this quiet AC option for the Oliver. In your picture the freshjet looks to be a lot taller than the original noisy Dometic. Is that correct? 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Roadlotus Posted November 12, 2023 Author Posted November 12, 2023 @dewdev Yes, it is taller than the original Dometic 2022 EII owner, Hull 1284, Tow Vehicle: 2021 Nissan Titan XD. 2022 lithium pro package which is 630 amp hours and 340 watt panels with a 3000 w inverter.
Geronimo John Posted May 11, 2024 Posted May 11, 2024 On 5/25/2023 at 9:27 AM, Roadlotus said: it would be an easier retrofit, and when I look it up on Amazon, it says the sound level is 58 dB. That is lower than Houghton, I think. Me thinks your sales agent was not informed on the Houghton sound levels. We run ours on low fan speed the vast majority of the time. It is ULTRA quiet. I believe that the FreshJet is Competitor A. This is from their web site: That said, until Houghton series we purchased has some specific disadvantages to some others: No internal drainage system. Fan runs continuously with adverse humidity control. The thermostat is not remotely located so it also contributes to cycling/humidity issues. Granted, a handy DIY owner can: Add a relay to fix the fan issue fairly easily if electrically inclined Reroute the thermostat function by getting a longer thermistor. Installation is tedious for an Oliver. After a couple of years effort, I and others have not posted a fix for the drain issue. So the condensate drains overboard the roof. There is some indication that this may be resolved by a remote electric condensate pump, but I have not found any info on it yet. So, from a sound perspective the Houghton appears to be a quieter unit. But without having to rework the Houghton, I would not recommend it to owners that are not DIY inclined. On the other hand, the above problems are well known to Houghton and when they have provided the American market with an internal condensate capability, remote T-stat and fan off when compressor is off program it will be a blockbuster unit. As a DIYer, yes I would purchase a Houghton in a heart beat. But may owners would not want the hassle of having to update/mod a brand new unit. Hopefully another reader will have updates to my dated info. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted May 12, 2024 Posted May 12, 2024 On 5/11/2024 at 1:40 PM, Geronimo John said: As a DIYer, yes I would purchase a Houghton in a heart beat. But may owners would not want the hassle of having to update/mod a brand new unit. D and I can attest to how quiet the Houghton unit operates. We did a side-by-side comparison last summer - first running the Dometic in "Zone-5 Afterburner" (its only mode) and attempting to converse inside with little luck. We then moved into John's unit a few yards away with his Houghton running - OMG, a significant drop in db level and we could actually communicate normally... My subjective appraisal as it is... Just say'n. 3 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Going Posted May 24, 2024 Posted May 24, 2024 (edited) Just read this thread and now I am really excited I have a far less expensive option than Truma. Thanks for the post! We were at the rally but did not attend the service question and answer with Jason. Was this topic discussed? It appears from this thread, the Dometic Freshet 3 is a direct plug and play to its noisy older brother. I did not see any posts saying anything electrical needed to change. I also never saw if anyone answered the wattage required to start/run with a generator. Does anyone know that answer? Hull #246. Edited May 24, 2024 by Going Phil Drye Hull #246, 2017 Elite II
Patriot Posted May 25, 2024 Posted May 25, 2024 (edited) 14 hours ago, Going said: Just read this thread and now I am really excited I have a far less expensive option than Truma. Thanks for the post! We were at the rally but did not attend the service question and answer with Jason. Was this topic discussed? It appears from this thread, the Dometic Freshet 3 is a direct plug and play to its noisy older brother. I did not see any posts saying anything electrical needed to change. I also never saw if anyone answered the wattage required to start/run with a generator. Does anyone know that answer? Hull #246. The FreshJet 3 was not discussed by Jason Essary during the service presentation at the rally. I bet if you reached out to Road Lotus with a PM she could provide you with further details on your questions. We had the Truma Aventa retro fit professional installed by Oliver absolutely zero regrets. Cheers! Edited May 25, 2024 by Patriot 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
theOrca Posted June 27, 2024 Posted June 27, 2024 Keep in mind that a 10db difference equates to 100 times the perceived noise level. Even a punk rock band member could distinguish that big a difference! theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
theOrca Posted July 11, 2024 Posted July 11, 2024 On 6/27/2024 at 11:18 AM, theOrca said: Keep in mind that a 10db difference equates to 100 times the perceived noise level. Even a punk rock band member could distinguish that big a difference! Yuk, bad math... Sorry! (And the Navy sent me to school on this stuff.) theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
theOrca Posted July 12, 2024 Posted July 12, 2024 On 6/6/2023 at 2:44 PM, Geronimo John said: The 2200 is only 7,500 BTU capacity. For an OE2, that would not be enough capacity for the majority of HOT weather areas. However, it would provide great de-humidificaiton as it would have very long run times between cycles or run all day long and be cycling off only at night. Would prefer at least 9000 BTU for an OE2, and 11,000 being the ideal selection. GJ That is the European model John. There are two models for here in the USA,, 15,000 and 13,500 BTU. 1 theOrca, 2020 Legacy Elite II, Twin, Hull 615 Tow Vehicle - 2016 Ram 1500, Hemi, 8 Speed with 1500# rear springs and Goodyear bags.
