I have a lot of stuff in my shop. I’m getting rid of a lot of it but I still have to put our Oliver in an exact place to maximize space and be able to move stuff around it. A few years ago I made marks on a line parallel to the side wall with a paint pen then placed soccer cones on the marks to guide me while backing, keeping the tires close to the line of cones. After the trailer is in place I store the cones an a shelf by the door. Saves a bunch of time when storing the trailer.
Bill and Martha
2019 Chevrolet 2500HD Duramax
I always like a "target" when backing my Ollie - makes good sense.
We've used a "target" for years with our SOB and now our OTT.  We only had approximately 9" of clearance on either side with the SOB, now much more with the Ollie.  Whew!
Parallel lines work for us - but the absolute game changer with when we added a front hitch to the TV...  The camper had to been consistently placed correctly in its "spot" or like, @Townesw mentioned, we can't move stuff around it with the bay door closed.  With the front hitch, you just steer the camper into place - no more "raised-voice" commands from Magnus and the lovely spouse.  HA!
  • Like 8
  • (SOLD) 2022 TUNDRA
I've had a front hitch on every one of the five tow vehicles we've owned and I've been preaching this sermon for years. Maybe folks will listen to you.
I totally agree.  Using the front hitch I can get the Oli within a couple of inches  most times on first try.
We have been considering getting an Oliver LEII (used) but our detached insulated garage clearance doesn’t look to be big enough
It is 9’7” high …….and only 22’ 7” deep back wall to garage door
Oliver shows the spec length of  23’ 6”
I am curious for storage if I could remove the hitch coupler and get the 11 inches needed to get the garage door closed
The 18 ft model with a single axle just doesn’t fit our desires
any ideas on this ?
Robert E
2022 LE II , LIthium Pro, 2018 F150 XLT 4WD 2.7 EcoBoost , 355 gears, tow package,36 gallon fuel, factory brake controller, transmission cooler
you could get a couple of inches by simply dropping the rear bumper.
Unfortunately, I do not presently have access to my Oliver in order to measure how much distance you'd get by removing the Bulldog assembly.
Obviously, you could either do a short (2 foot) "bump-out" at either the front or back of the garage to gain the extra room needed.
Good luck.
Tideline77. You should extend the garage and raise the door opening, not shorten the Ollie. You will never be happy otherwise - you risk damaging the trailer, damaging the garage itself, and you and your SO will be constantly frustrated. Plus you will not have any room for other stuff in there.
Ideally you need a foot of clearance at the coupler so you can easily maneuver around it with the door closed, and three feet on all sides and at the back. This allows you to open the trailer door and cargo/ battery access doors and actually get into them. For example, to slide out the batteries for service or winter storage.
One Ollie owner actually lowered his concrete garage slab rather that raising the structure. Radical, but it turned out well.
Our Ollie has been outside year round since it was new.
I do clean and wax in the spring (two coats) and fall because of the outside storage.
But then again, we are up north where the UV is not as hard as in the south.
Maine
@John E Davies is right on.   We've got 5 feet on the street side (wish there was 6) about 3 feet on the street side (wish it was 6!) that's the side where the work bench is located.   6 feet of clearance in the back but 18" of that is floor to ceiling shelving.  With the minimal clearances we have, equipment, bikes, folding tablesaw, etc. can barely be moved around with the rollup door closed.  Our hitch is only a couple inches from the rollup when closed - but we can step over it to get to the entry door.  Your detached garage needs to be bigger by the way you describe its size.  Get a CalMark cover and park it next to your "shop" - maybe add an over hang to the shop for added protection.
not able to enlarge the shop due to existing setbacks and our house foot print on our lot We just finished enclosing an existing detached pole barn carport for a workshop and we are about to wire it and insulate it.
Appreciate the help and suggestions, Thank You
Robert E
