jd1923 Posted December 23, 2023 Posted December 23, 2023 (edited) That's one way to say it. Another way is to say, "to winterize, expel all water from the plumbing system using compressed air." I do understand OTT does not advise this procedure, I've heard and read this several times, but I've never been very good at reading directions or listening to advice (some say an attribute of the good engineer). I have used this method for years in other RVs and just worked this yesterday on our Oliver. This is more complex in the little Oliver than say on our past Bigfoot Class-C RV, because of having four (4) hose water inlets. Please allow me to list my procedure and please comment if you believe I missed something, where there may still be some water in the system. I learned this from a Bigfoot owner, on the BOCI forum, who lives in Calgary BC Canada. He uses no antifreeze where of course lows are sub-zero for several months of winter. 1) Park your OTT nose uphill and start draining the Fresh Water tank. 2) Drain Hot Water Heater (HWH) and set HWH bypass valve 3) Reduce air compressor pressure to 50 PSI and use an air to hose fitting (see pic of one I built with spare parts). The fitting must be connect to the hose first, unless yours has a shut-off valve. 4) Turn your water system draw valve to the Winterize/Sanitize position. 5) Open the kitchen faucet both hot and cold sides 6) Connect the compressor airline to the rear Sanitation inlet (a few seconds is all required). 7) Change water valve back to Normal Camping Position. 8) Connect the compressor airline to the Fresh Water inlet (a few seconds is all required). 9) Connect the compressor airline to the City Water inlet (leave it connected). 10) Go inside and close the kitchen faucet. Then open each faucet separately. The toilet, then hot and cold, one at a time, for the bathroom sink, and kitchen again. Run the water pump at some point to expel internal water. Go outside and do the same for the outside shower. Go back inside and check each faucet again. They should all blow water mist when the lines are mostly empty (empty enough). 11) Close Fresh Tank drain when empty. Finish up with the HWH and reset the bypass valve. Get everything back to Normal Camping Position. 12) Empty Black and Gray tanks. Connect airline to Black Tank rinse, or at least remove cap to release water in this line. Edited January 16 by jd1923 Revised Jan-26 to correct steps 8-9, switched City/Fresh labels and removed step #13, no need to add antifreeze to the P-traps. JD 1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted December 23, 2023 Posted December 23, 2023 On 12/23/2023 at 4:07 PM, jd1923 said: I do understand OTT does not advise this procedure, I've heard and read this several times, but I've never been very good at reading directions or listening to advice Not advice 😄 I just never use compressed air. When we recently winterized, it took my wife and I maybe 20 minutes really taking our time. I think Oliver puts their winterization instructions in place to ensure that it’s easier for folks who might not own an air compressor and may not clearly understand that ALL water must be removed from the system lines or diluted with antifreeze. Side note: Tightening the white compression fittings is a regular inspection point for me. If one of those compression fittings is slightly loose, compressed air likely won’t get the rest of the plumbing clear of water. We don’t get long deep freezes here in Western NC, the land of long summers and short winters and I still use AF. All this said, I would never know that I have cleared every bit of water from my lines, so being risk adverse, I choose to use RV safe antifreeze and sleep really well. Surely others will chime in, and if compressed air works, I say go for it! Patriot🇺🇸 4 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted December 23, 2023 Author Posted December 23, 2023 16 minutes ago, Patriot said: When we recently winterized, it took my wife and I maybe 20 minutes really taking our time... We don’t get long deep freezes here in Western NC, the land of long summers and short winters and I still use the AF.... Because we live in the SW, we do more camping over the winter months, spring and fall of course, and none during summer (think Snowbirds RVing in Quartzite AZ). So, we don't truly "winterize" but live at 5400 FT elevation and it can get COLD overnight. Whenever the weather report forecasts several consecutive nights low 20s or in the teens, I'll blow out the water, but we could be heading out next week! This occurs often, 2-3 times a winter. I could not see adding antifreeze and flushing it clean on this basis. If winterizing the Oliver with antifreeze takes you 20 minutes, then using air should take 10-15 minutes. Yep, you need an air compressor. Mine has a 100' hose so I can fill RV tires all the way out on our road. Good time to check tire pressure and overfill your tires 10% for winter parking. This way when you are ready to leave again all you have to do is check pressure, let a little air out. The real difference is when we are ready to head out, everything is done and ready. No flushing antifreeze, just fill the freshwater tanks at home or at the campsite depending. 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Wandering Sagebrush Posted December 24, 2023 Posted December 24, 2023 When using compressed air, and have done that many times on other campers/trailers, I always worried about water left in the pump. With the Oliver, it’s just so easy to use the pink stuff. 4 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
jd1923 Posted December 24, 2023 Author Posted December 24, 2023 1 hour ago, Wandering Sagebrush said: When using compressed air, and have done that many times on other campers/trailers, I always worried about water left in the pump... Just run the pump while working the procedure. Only if a pump freezes filled 100% with water can it be damaged from the expansion of freezing water. BTW, when y'all get around to up grading your pump, most high-end pumps today can run dry for hours without issue. 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
GeoffChapman Posted December 24, 2023 Posted December 24, 2023 Does this clear the P-traps in the kitchen sink, bathroom sink and shower drains? 3 2 Geoff and Becca Chapman * Pittsburgh Legacy Elite 1 Hull #731 * TV 2024 Ford Ranger Turbo 2.7L Ecoboost V6
jd1923 Posted December 24, 2023 Author Posted December 24, 2023 22 minutes ago, GeoffChapman said: Does this clear the P-traps in the kitchen sink, bathroom sink and shower drains? Thanks Geoff! I was asking for holes in my procedure, and you found one. IMHO, I feel expansion in a P-trap goes 99% upwards, like an ice cube tray, and has not concerned me. We can add a step 13 to the procedure: 13) Add 3-4 OZ of RV antifreeze to each drain (bath, shower, kitchen) and in the toilet bowl (with water). There is no additional maintenance in this step, as p-traps do not need to be flushed and cleaned later like the freshwater plumbing system. You can drive on and use them as-is. Great addition! 5 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Patriot Posted December 24, 2023 Posted December 24, 2023 11 hours ago, GeoffChapman said: Does this clear the P-traps in the kitchen sink, bathroom sink and shower drains? Totally on point @GeoffChapman. 👍🏻 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted December 27, 2023 Author Posted December 27, 2023 On 12/23/2023 at 5:06 PM, Wandering Sagebrush said: When using compressed air and have done that many times on other campers/trailers, I always worried about water left in the pump. With the Oliver, it’s just so easy to use the pink stuff. When water freezes, it just needs a little room for expansion, a little and not a whole lot. Think if your freshwater tank was half full and it gets well below freezing. It would just expand upwards, say another 10%, a slight bulging upwards. Nothing bad will happen, the plumbing will exist as-is. Since there is nothing but air above, with an overflow tube to boot, nothing happens but water freezing to ice. If the tank was 100% full, then tank would fail. When small diameter pipes freeze, they freeze at the ends first. Once the ends have frozen, and the lengths of the plumbing freezes, there is nowhere for the expansion to move and hence the plumbing will crack. If your water pump is half full it can freeze without issue, even at 80-90% full! And btw, when you blow out the lines, running the water pump at least once, it is most likely empty or very close. Fear shall succumb to knowledge. Remember, my friend living in Calgary has worked this procedure annually for more than a decade, where their daytime winter highs are lower than our nighttime lows. Thanks ☺️ 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
SAR Posted January 20, 2024 Posted January 20, 2024 This is what I was planning to do with our new Ollie, same procedure I used with our Escape and Casita. Live in the South Texas, so we do get an occasional below freeze temp. 1. Drain all tanks (black, gray, fresh). 2. Turn the HW heater values to bypass, 3. Drain the HW heater. 4. Blow compressed air (40psi) through the lines to eliminate any water (taps, toilet, outside shower). 5. Run water pump for a few seconds to remove any water. 6. Pour small amount of anti-freeze in traps, including toilet (seal). Our Ollie will have compost toilet and Truma HW, so the process will change a bit. Still learning how to maintain lithium batt in cold temp. thanks 3 2024 E2 | Hull # 1527 |Truma | Lithionics (390Ah) |Compost |2024 Tundra| Airstream | Casita | Escape
Moderators SeaDawg Posted January 20, 2024 Moderators Posted January 20, 2024 Way back in the day, in our family's less complicated trailers and motorhome, winterizing in Minnesota was blowing out the lines. Thanks for the memories. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators topgun2 Posted January 20, 2024 Moderators Posted January 20, 2024 13 hours ago, SAR said: Blow compressed air (40psi) through the lines to eliminate any water (taps, toilet, outside shower). Be sure to pay "special attention" to those exterior ports when blowing out the lines. These have back flow prevention valves in them and it doesn't take much frozen water to destroy them. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted March 14, 2024 Posted March 14, 2024 On 1/19/2024 at 2:50 PM, SAR said: 4. Blow compressed air (40psi) through the lines to eliminate any water (taps, toilet, outside shower). One concern to keep top of mind when using air to purge our plastic lines is water hammer. At 40 PSI you can shoot a slug of water down a mostly purged line very very quickly. All will be fine on straight runs, but when they hit a 90 degree elbow or flat side of a T, it can, and has, blown off many a fitting. Personally I would consider regulating the air pressure down to 25 PSI vs. 40. May take a bit longer, but likely would result in less water leaks in the Spring. GJ 1 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Roger Posted January 15 Posted January 15 On 12/23/2023 at 4:07 PM, jd1923 said: ) Park your OTT nose uphill and start draining the Fresh Water tank. 2) Drain Hot Water Heater (HWH) and set HWH bypass valve 3) Reduce air compressor pressure to 50 PSI and use an air to hose fitting (see pic of one I built with spare parts). The fitting must be connect to the hose first, unless yours has a shut-off valve. 4) Turn your water system draw valve to the Winterize/Sanitize position. 5) Open the kitchen faucet both hot and cold sides 6) Connect the compressor airline to the rear Sanitation inlet (a few seconds is all required). 7) Change water valve back to Normal Camping Position. 8) Connect the compressor airline to the City Water inlet (a few seconds is all required). 9) Connect the compressor airline to the Fresh Water inlet (leave it connected). 10) Go inside and close the kitchen faucet. Then open each faucet separately. The toilet, then hot and cold, one at a time, for the bathroom sink, and kitchen again. Run the water pump at some point to expel internal water. Go outside and do the same for the outside shower. Go back inside and check each faucet again. They should all blow water mist when the lines are mostly empty (empty enough). 11) Close Fresh Tank drain when empty. Finish up with the HWH and reset the bypass valve. Get everything back to Normal Camping Position. 12) Empty Black and Gray tanks. Connect airline to Black Tank rinse, or at least remove cap to release water in this line. 13) Add 3-4 OZ of RV antifreeze to each drain (bath, shower, kitchen) and in the toilet bowl (with water). @jd1923 when you do step 10 do you have the air compressor attached to the Fresh Water inlet? Doesn't this go through the Fresh Water tank where it will need to build up pressure before it can blow out the lines. I don't see how it can build up pressure when the Fresh Water drain is still open? What am I missing? 2021 Elite II Twin Bed Hull #1023 - Kimba | 2025 Ford F-350 6.7 Diesel
Moderators Mike and Carol Posted January 15 Moderators Posted January 15 38 minutes ago, Roger said: @jd1923 when you do step 10 do you have the air compressor attached to the Fresh Water inlet? Doesn't this go through the Fresh Water tank where it will need to build up pressure before it can blow out the lines. I don't see how it can build up pressure when the Fresh Water drain is still open? What am I missing? When I blow the fresh inlet it’s just to clear water from the lines into the fresh tank. Then I switch to the city inlet and do step 10. I think he may have reversed fresh and city inlet his instructions. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Roger Posted January 15 Posted January 15 8 minutes ago, Mike and Carol said: When I blow the fresh inlet it’s just to clear water from the lines into the fresh tank. Then I switch to the city inlet and do step 10. I think he may have reversed fresh and city inlet his instructions. Mike That is what I was thinking. Thanks for the clarification. I live outside Atlanta and we occasionally get cold enough to need to winterize but I would prefer not to use antifreeze. I take trips during the winter months and it is a hassle to winterize and de-winterize each trip. 1 2021 Elite II Twin Bed Hull #1023 - Kimba | 2025 Ford F-350 6.7 Diesel
Moderators Mike and Carol Posted January 15 Moderators Posted January 15 20 minutes ago, Roger said: That is what I was thinking. Thanks for the clarification. I live outside Atlanta and we occasionally get cold enough to need to winterize but I would prefer not to use antifreeze. I take trips during the winter months and it is a hassle to winterize and de-winterize each trip. Same here for us in the San Antonio area. Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
jd1923 Posted January 16 Author Posted January 16 3 hours ago, Roger said: That is what I was thinking. Thanks for the clarification. I live outside Atlanta and we occasionally get cold enough to need to winterize but I would prefer not to use antifreeze. I take trips during the winter months and it is a hassle to winterize and de-winterize each trip. Yes, good catch Roger, and Mike is correct in his comment! I had many critiques, 2 years ago, when I wrote these instructions and nobody had noticed this before! Just ask @Geronimo John, as I sometimes have a left/right brain thing goin’ on! Directions I’ve written that state drive East as I was thinking West! 🤣 it should read like this: 8) Connect the compressor airline to the Fresh Water inlet (a few seconds is all required). 9) Connect the compressor airline to the City Water inlet (leave it connected) Then yes, work step #10 on City Water. I will revise the instructional thread and I’m also going remove step #13 which I added upon suggestion, but do not believe is necessary. No pink stuff will ever be in my Walmart shopping cart! 😎 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted January 16 Author Posted January 16 3 hours ago, Roger said: That is what I was thinking. Thanks for the clarification. I live outside Atlanta and we occasionally get cold enough to need to winterize but I would prefer not to use antifreeze. I take trips during the winter months and it is a hassle to winterize and de-winterize each trip. Excellent thinking as this is exactly my reasoning! Last week we got down in the low 20s three consecutive nights. If it’s high 20s for a night or two, I’ve learned not to worry. I have a Ruuvi temp sensor in the rear lower basement, under the incoming water lines to keep tabs. We had water in the plumbing, hot water heater, etc. I worked the procedure and we’re good. The other day, since the Oliver was already in our driveway, I worked all 12 steps in <5 min (from memory after years). We’re leaving Monday morning to Quartzsite. Thank goodness I only have to fill the FWT, prime the plumbing, fill the extra 35-gal FWT in the truck and we’re on the road! 😎 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
jd1923 Posted January 16 Author Posted January 16 16 hours ago, jd1923 said: ... should read like this: 8) Connect the compressor airline to the Fresh Water inlet (a few seconds is all required). 9) Connect the compressor airline to the City Water inlet (leave it connected) Then yes, work step #10 on City Water. I will revise the instructional thread and I’m also going remove step #13. I just corrected the original post. JD 1 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
