Snackchaser Posted January 1, 2024 Posted January 1, 2024 I pulled my propane tank out and was horrified at all the rust around the bottom ring of the tanks, and on the mounting tray. That area seems to attract dirt and it eventually wore away the paint and rusted. Sand paper and paint fixed the immediate problem, but I wanted to prevent it from happening again. I started looking for some sheet rubber on Amazon, but then I discovered inexpensive rubber rings by Mopeka Products for$ 7.99. They are designed to fit on the bottom ring of the propane tanks. They fit perfectly, and they also stop that cringe worthy grind when putting the tanks on pavement. 2 9
Rivernerd Posted January 1, 2024 Posted January 1, 2024 26 minutes ago, Snackchaser said: They fit perfectly, and they also stop that cringe worthy grind when putting the tanks on pavement. We bought a pair for installation when we took delivery in November, 2022. They have performed well. I expect they will last for many years to come, perhaps longer than the propane tanks. 3 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2026 Ford F350 Crew Cab with 7.3L gas engine
johnwen Posted January 1, 2024 Posted January 1, 2024 We lost one of ours and didn't realize until we saw the rust ring. Ordered 1 and will keep an eye out for future loss.. 2 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
MAX Burner Posted January 5, 2024 Posted January 5, 2024 They work great - makes for a bit of a "tight fit", but definitely serves their purpose well... 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Jason Foster Posted January 5, 2024 Posted January 5, 2024 On 12/31/2023 at 6:26 PM, Snackchaser said: I pulled my propane tank out and was horrified at all the rust around the bottom ring of the tanks, and on the mounting tray. That area seems to attract dirt and it eventually wore away the paint and rusted. Sand paper and paint fixed the immediate problem, but I wanted to prevent it from happening again. I started looking for some sheet rubber on Amazon, but then I discovered inexpensive rubber rings by Mopeka Products for$ 7.99. They are designed to fit on the bottom ring of the propane tanks. They fit perfectly, and they also stop that cringe worthy grind when putting the tanks on pavement. Good idea. Thanks. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderator+ ScubaRx Posted January 5, 2024 Moderator+ Posted January 5, 2024 On 12/31/2023 at 6:26 PM, Snackchaser said: I pulled my propane tank out and was horrified at all the rust around the bottom ring of the tanks, and on the mounting tray. That area seems to attract dirt and it eventually wore away the paint and rusted. Sand paper and paint fixed the immediate problem, but I wanted to prevent it from happening again. I started looking for some sheet rubber on Amazon, but then I discovered inexpensive rubber rings by Mopeka Products for$ 7.99. They are designed to fit on the bottom ring of the propane tanks. They fit perfectly, and they also stop that cringe worthy grind when putting the tanks on pavement. I bought a set of these about 4 or 5 years ago. I know they will outlast the expiration date on the tanks. Plus, they give you plenty of room underneath for the Mopeka sensors. 4 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
johnwen Posted January 5, 2024 Posted January 5, 2024 Good product and now I take them off to service as I lost one during a recent refill. John 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Doug S Posted January 5, 2024 Posted January 5, 2024 Thanks for info! You guys are great! 1 Doug & Jill - Wilson WY Ozzie and Ruby - 2 Havanese characters “Hull #1491” ‘24 LEII ’23 F-250 RapidRed KR 7.3 Godzilla
Geronimo John Posted January 5, 2024 Posted January 5, 2024 4 hours ago, johnwen said: Good product and now I take them off to service as I lost one during a recent refill. I would consider laying a silicone bead in the ring. That would likely keep it in place when servicing the tanks. GJ 1 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
johnwen Posted January 5, 2024 Posted January 5, 2024 1 hour ago, Geronimo John said: I would consider laying a silicone bead in the ring. That would likely keep it in place when servicing the tanks. GJ Thanks, GJ :) 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
MAX Burner Posted January 11, 2024 Posted January 11, 2024 On 1/5/2024 at 12:58 PM, Geronimo John said: I would consider laying a silicone bead in the ring. That would likely keep it in place when servicing the tanks. GJ @Geronimo John: FYI - after having serviced each of the 30# tanks 2 or 3 times since installing the "Halos" - keeping them in place is not an issue, a very tight fitment. My concern is getting them back into the cradle - it's almost a "press-fit", but once they're in and seated, they don't budge! Also, like @ScubaRx noted, they give a bit more recess for the Mopeaka sensors... Bottom line, the Halos should keep the steel cradle and bottom tank rings from rusting out and generally helps keep the compartment neat and tidy. 3 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Mountainman198 Posted January 13, 2024 Posted January 13, 2024 After seeing this thread I checked my tanks. Sure enough, a small amount of surface rust is forming along the bottom of the ring. I had some of thjs black rubber door edge guard left over from when I installed the screen bug covers on my water heater so figured I would try it on the tanks. Fits great, eliminates the metal on metal contact, stays on when removing tanks to fill and does not impact height of tanks and hold-down. can’t remember where I bought it but do recall it was about $10, maybe at TSC? 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW
