  2. The check valve is the second brass piece from the water heater, with two hex ends. If you magnify the photos, you can just see the directional arrow on the top side between the hex ends.
  3. Theres a lot of brass pieces there. I’m assuming you mean the check valve is the first piece attached to the upper port of the water heater? Guessing the next piece after that is just a coupling to join to the tee? I’m not caring for the “quality” or robustness of that bypass valve. I’m thinking that if it is a weak spot in the system, and the check valve apparently is also a failure point - that it might be an option to replace the check valve with a plain old valve, and rework the bypass with a Tee and two valves? Not sure I’m ready to install a whole recirculating system at this point. I’m leaning toward 120v AC point if use heater(s).
  4. Today
  5. We use our convection mode all the time. All parts are temp safe! The wire rack is used to hold items up off the glass turntable so hot air flows around the item being cooked. If you were put the item in the glass tray the bottom won’t be exposed to the oven heat…so Use the rack every time in convection cooking. (That would be like putting a pan on the bottom of a stove, not on the rack). The rubber feet are intended for high heat in the oven and are left on the rack. We bake things all the time in convection mode and they work well. For grilling we turn the rack so the tray is in the high position so what we broil is up high by the burner.
  6. Over 5 years of owning this Oli and we have never used the Convection Oven function of the microwave. Planing on going to an egg rally and wanting to try one of my dishes that requires an oven. So I have a couple of questions. I was worried about high temps on the stuff inside the microwave. I was planning on using the grill rack with the little rubber ends on it to hold the food in the middle to get even dispersal of heat around food. Do I have to use the grill rack? (The only thing I have used the grill rack is to letting dishes cool down in our house, Never even stored it in the Oli.) Are the following safe at high oven temps? glass tray, turntable ring, turntable shaft, and little rubber feet on the grill rack? The manual talks about preheating the oven and then just putting the food in. If you leave the glass tray in convection mode and place cool cooking dishes on the hot glass tray could it break the glass tray? Sorry about obsessing about this I just want to be safe and successful. Thanks for your input.
  7. https://www.rvtravel.com/resale-champs-top-5-rv-brands-hold-1271/ 009/26/2026 edition
      • 2
      • Like
  8. bugeyedriver I'm a bit unclear. Your pics appear to be hilighting the valve and your fix to be in an area at the rear of the trailer. Our 2023 Elite 1 has the black tank valve up front, street side just aft of the interior bulkhead in the bottom of the compartmet that also houses the furnace.
  9. I'm so sorry, that was not my intention! I just didn't want to see you treating them as non-maintenance sealed bearing hubs if they were in fact standard bearings.
  10. When installing a hot water recirculation system, I found that the isolation valve had pinched the heater duct and worn a hole through it. There is a check valve at the water heater and you can see it in the photo above -- it's the brass spool piece and mine was stuck open. I removed both of them because in the unlikely event that the hot water heater ever needed to be isolated, I'd just shut off the water instead. The hot water recirc system is a great modification that has served us very well.
  11. Yes... Saw the N R L on the dust caps for the axles. Whew... CRM... don't scare me like that! Scotty
  12. I must also admit to being a bit puzzled by the plumbing. Turning ONE valve isolates the water heater? I guess I’m thinking of typical household water heaters. If you shut off the inlet (or outlet) you get nothing out of the hot water taps. With this plumbing - the water heater is out of the circuit - and your hot water taps give cold water? I think I read that there’s a check valve on the “other side” of the water heater that keeps pressure in the hot water line from backing up into the water heater(?)
  13. Yesterday
  14. We have pics from our first visit too, 21 years ago.
  15. My wife would have made me stop for a pic for sure!
  16. You must not recognize the icon Flintstone metal statue built in 1972 near Valle AZ, road to the south rim of the Grand Canyon! It must have been pretty cool back in the day! We didn’t go in but backed in for this special shot. I’ll bet Fred would have loved an Oliver! 🤣
  17. Glad you got out! Situations like this is why having four wheel drive is at the top of my list for a TV. Won't go without a front hitch either.
  18. We generally avoid anyplace with a sign like that. “Yogi Bear’s Jellystone Park” is a “must avoid at all costs” kind of place. I may not be ready for the “55 and older only” places - but we do try to steer clear of the places that cater to kids. We have enough aggravation from the adults that act like kids!
  19. Hi all, For a change, I WAS able to use search and find a thread that addressed my issue. Anyway, when de-winterizing this past January, I found the bypass valve in the back of the Truma to be EXTREMELY hard to turn. Being buried under poorly-routed ducts in a tight spot where you can’t see didn’t help much. With what leverage I could muster using just my fingers got the valve -mostly- open and I was in business - sorta. We’ve been noticing that the ECO mode didn’t seem to work, and the normal/comfort mode only delivered lukewarm water. Finally getting around to what causes this, I learned that if that valve isn’t all the way open - it can cause the hot water to be diluted - causing our lukewarm water. Taking a pliers to the valve and much cursing of the brain surgeon who put that valve where he did, I got it to move a bit. But it’s clear that valve is toast and needs replacing. I’m not thrilled with replacing that valve with another one that is made so “well”. Anyone have leads for an upgraded one?
  20. True, going higher gets you cooler temps - about 3F per thousand feet. At least it does in free air - near the surface the difference is likely less dramatic. But the summer temp differences between Southern and Northern states without throwing in altitude already gives you 15-25 degrees F depending on which sources you believe. To get a 21F drop in temperature -just- from elevation will take climbing up about 7,000 feet. We did this on our past trip. It’s not an issue for our turbocharged engine, but folks driving naturally aspirated mills will definitely see a drop off in power. Same applies to humans. In the mountains above Santa Fe, just walking from the trailer to the washroom can get a flatlander winded. Sure, if you’re in generally good heath and have time to acclimate, this isn’t an issue. As for bugs - Northern Minnesota actually has it pretty good compared to the Everglades. Even running 20 feet from the truck to the camper gets you a half dozen mosquito bites - even on a “moderate mosquito threat” day. I can’t imagine what it’s like when they say it’s “bad”!
  21. Hokieman, This is good news. I didn't know about the type a pex, now I do. I'll probably do what you did and not worry about them coming loose again. Thanks for the help!
  22. thanks for the pics... looking good
  23. On the left are the standard D35 axles, 10" brakes. The hub is extended further out with the old standard bearings. On the right, we have Nev-R Lube axles with the flatter hub, protruding about as far as your lug nuts. Parts pic shoes the embossed Nev-R Lub dust cap and then before and after pics. With the Nev-R Lub bearings it makes sense to loose the big center caps which are no longer necessary, designed to fit over the original standard bearings. It would be nice if they made a flatter center caps, but emblems over the dust caps work fine.
  24. Good to know... Thanks. Thought they put that on the label from a prior discussion about the Nev-R-Lube axles.
  25. They also write Nev-R Adjust on the D52 axles with Nev-R Lube bearings. My label is similar except mine are SC = 50.00. The only hint of Nev-R Lube are on the bearing dust caps.
  26. @johnwen I’m wondering if there are some misunderstandings of your original question. I understand your issue is the connectors are shaking loose. Yes, that’s happened to me on my 2021 model as well. My pipes are white, Sharkbite brand PEX-b, with the same plastic connectors. I assume yours are too. The problem isn’t the pipe type, it’s the connectors. I have replaced many of my plastic connectors and used PEX copper crimp rings, because I already had the tool to do home repairs. This solves the loose connection problem, but sometimes the plastic elbows break. I’ve only had one break while camping, and fortunately a Home Depot was within an hours drive. .There are also other types of clamps such as stainless PEX clamps, which require a different tool. Since my crimp ring tool is really big and heavy, and I cannot get it into some small spaces, I leave it at home and carry a half dozen various Sharkbite push-in quick connects and a few spare pieces of PEX-b pipe for campsite repairs. There are threads in this forum where some owners have replaced elbows with brass, some have replaced all with Sharkbite quick connects, available in plastic or brass. There are several ways to fix your loose connection problem, just depends on your preference, but you should not need to replace your pipes.. All of these fittings and pipes are readily available at stores like Ace, Lowes, Home Depot, etc. Sometimes we are camping too far from such conveniences, which is why I carry the spares. I haven’t had any clamps pull loose yet, but that shouldn’t be difficult to repair on the road. It’s got me thinking about better ways to do it though.
  27. I used these to wire lights on a utility trailer. https://www.3m.com/3M/en_US/p/d/b10128463/ What would be wrong with using these instead of heat shrink butt splice connectors to make brake wire connections under the trailer? Notice that they are IDC (Insulation Displacing Connectors) and that they are water resistant (they contain what I think is dielectric grease). Notice also that they connect up to 3 wires, as in the situation encountered on the street side connections. I don’t care for the typical IDC connector (usually blue) with the fold over and snap down piece, but these are much better and they are made in the USA by 3M. EDITTED TO ADD: According to the 3M website the conductor is tinned brass. I took one apart and used a file to remove the tin. The blade is brass, or at least some kind of yellow metal. Bill
