  2. Alternatively, I bought three solar motion lights for camp security and general outdoor lighting. Once camp is setup, they are staged forward facing on the propane tank housing, rearward facing on the spare tire cover, and usually on a picnic table or other strategic location. I instantly have light when and where I need it, and a deterrent to unwanted visitors!
  3. At the time that we purchased ( Jan '23 ) Oliver sold a portable panel as an add-on. It's basically the same panel(s) that are on the roof but with a stand and controller / converter. We found them of little use other than as a battery maintainer during the winter. It also works great for charging tractor and trolling motor batteries when needed.
  4. For the do it yourselfers, you can buy 12” wide rolls of 3m clearbra and install it vertically on the lower front leading corners (below belly band) of the trailer hull. All you need is a spray bottle of soapy water, some spray alcohol and a squeegee. Since this area gets the most stones as it is directly behind the rear TV wheels, this is a simple and inexpensive way to protect your hull from a majority of debris kicked-up by the TV while towing. Mine has been installed since 2021 and is still in good shape and has taken a few stones along 40,000+ miles. Cost less than $40 in materials.
  5. I had just asked last week about what they are upgrading older units to now days at the factory, Dometic Freshet was the reply. Price was $4600.00 for upgrade.
  6. Today
  7. No - there is not a "web store". However, Oliver does have a number of items for sale via the Parts/Service department. These things include grills, outdoor rugs, chairs, outdoor firepits and portable solar panels. Every now and then they will advertise "specials" here on the Forum. Bill
  8. I read they resorted to the Dometic FreshJet, but not certain of the series model. That said however, in viewing the recently released ‘2027 Oliver Legacy Elite ll Platinum Model Walkthrough’ video, a Dometic is perched atop! AI states the Dometic FreshJet sits slightly lower on the roof than the Penguin ll. Dometic FrestJet (Series 5): Measures exactly 10.5 inches in height. Dometic Penguin ll: Measures 11.25 inches in height. When AI is asked is the FreshJet is quieter than the Penguin ll: Yes, the Dometic FreshJet is significantly quieter than the Penguin ll. I’m only presenting facts, not a personal recommendation.
  9. You are being well advised, refrigerator power supply. Many have experienced the fridge cord coming unplugged and thus, a simple fix is to secure it with a zip tie as illustrated in your pic.
  10. Owners/Moderators: I had heard a rumor that OTT is using/considering the Houghton 3400 on new builds. Can this be confirmed? If so: Does it have the fan on contineously issue resolved so that it can be set to turn off the fan with the compressor? Does it have remote thermistor? Does it condensate drain by tube option for those with no height concerns? Please advise. GJ
  11. Nice but too much luxury for my crusty 'ol a**. Couldn't take where I like to go either. Definitely not camping at this point.
  12. That's an excellent idea with the switch and 12V right there! You could remove the bubble level (for those of us who use LevelMate) and mount a post light top center.
  13. I've considered adding a forward facing light to the front jack housing using the existing light switch.
  14. Boy, i have repeatedly taken and not taken a small step ladder along. There are an awful lot of things that are unreachable without it including my truck oil dipstick. So far, i have never used it on the short trips we take and i kind of feel like a worry dork taking it. Maybe with your encouragement i will take it with greater confidence. Sorry to be off topic of the main thread.
  15. I have the zamp portable suitcase panel that I believe adds another 240 watts (this particular size is no longer available) Its awful heavy and the cable is just too short to be able to move it optimally with the sun on the streetside of the trailer. Several calls to zamp technical support did not result in being able to purchase a longer and heavier cable. When its only in the sun for a few hours the gain is not that great - we are typically in partial shaded sites. There is also the worry that someone will walk off with the panel while i am not at camp. Pulling it up and placing it back multiple times is a hassle. Finally even though we are at nonelectric sites most of the time, we typically dont need the portable unit. For all of these reasons, i find myself taking it along less and less. There are a few situations where i will be happy to have it but those situations are far and few.
  16. Finished my install on a front light, but won't be able to see how effective it is until it gets dark tonight (more pics after). My hope is that when the TV is attached, I can unhitch when getting to a campground after dark and see what's stored in the truck bed. I got this Docking Light on the same order as the Porch Lights. https://itcshopnow.com/products/exterior-led-flood-boat-docking-light I used 3M 4950 VHB tape to mount it the the top of the doghouse. There is of course a wire harness, so I drilled into the doghouse but not on top, just behind it where there is room and it's out of sight. I used a 13/64" drill bit which is a hair over the diameter of the wire loom. The picture shows the SAE disconnect wrapped up, only so it could be seen in the photo. Got to have a disconnect to fill the LP tanks. I tapped into the power for the emergency brake which is unfused 12VDC (the brake switch still has a direct connection). Added an inline 2A fuse and a switch in front of the doghouse. Added wire loom and tied up everything. Chose this location for an easy reach from either side, somewhere out of the way, and with a straight line for drilling the hole. The light draws 0.3A and provides 290 LM at 5000 K. Can't wait to see it at night! 😎
  17. Yesterday
  18. Eagle Nest State Park , New Mexico park has been remodeled and is very nice, sites are electric only water fill available, no dump station cloudy and rainy and cold weather has us a little wet super nice Vietnam War Memorial Park nearby Remembering all of the men that served and the young men that never came home 🙏
  19. … another idea, hard mount regular panels to the bed rails on the trick if you’re configured like that, and have that charge an Ecoflow. So top off the Ecoflow pro and use that to top off the house. That’s exactly what I do boondocking using the 220 kWh traction battery, minus the solar
  20. Don’t need it myself since I drive electric, but if I wasn’t I still I doubt I’d do it. A lot of bother, have to be around so sticky fingers doesn’t walk off with it, and as @jd1923 sez it’s just more stuff, and big clumsy stuff too. Getting this rig pared down to the essentials has been a major project. I’d do this instead Try to optimize the roof solar charging opportunities if possible Possibly upgrade the house batteries (you have a recent vintage but don’t know what you’ve got on board) Most likely would be to instead get a backup source, it’s awfully handy to just charge off the truck one way or another Ecoflow Delta Pro has a TT-30 plug so you can top off the house batteries directly Or just get one of the 120V regular versions and find some creative uses of it My 2c … Sells how, do they have a web store? Not coming up with anything …
  21. When Twist was in production I asked that the trailer be wired for a rear camera but I would supply and install my own camera. I decided that I would mount it in the spare tire cover. For security purposes this is a good place. However, for traveling down the road - not so much. The spray from wet roads makes this camera location virtually useless and even when its not raining it is difficult to use the camera in order to see beyond the vehicle that is directly behind me. Therefore, for driving, I now have another camera mounted in the usual high position (up near the marker lights) but still retain the lower camera too. If you decide to do as I did and mount a camera in the spare tire cover - PM me. The spare tire cover is NOT "in line" with the body nor the rear bumper. Because of this I needed to put a spacer in so as to compensate for the different angles. Bill
  22. Bill - Wonderful job - both on the install and the writeup! Almost makes me wish that my original fan would give up the ghost. 😉 Bill
  23. It actually looks very good in your pictures, so must look perfect from the ground. Job well done and an excellent detailed write-up! 😎 Too bad OTT doesn't make a small flat area for the bathroom fan in their fiberglass molds (inner and outer hulls). It would make for a better fit and make this job easier on all of us!
  24. With the inside work complete I went back to the roof area, trimmed the oozed butyl, wiped with isopropyl alcohol again, and taped the area to be caulked off leaving about a quarter inch gap from the edge of the flange in the front and rear and about an 1/8 inch gap on the sides where the caulk would be the shortest. I applied the caulk 3 times, wiping it off the first two times, reapplying the tape and recaulking each time because I didn’t like the way it looked. I finally left it alone because I decided that if I kept messing with it I would keep screwing it up and I was starting to get hungry and it was close to supper time. This picture shows the fan after the oozed butyl was trimmed back. It shows the built-up butyl in front of and behind the fan to keep the flange straight. This next picture is after the ASI 335 was applied. Notice that the black seal is straight, not bowed down at the front and rear due to having the flange pulled down to touch the roof. The black seal must remain straight so that the cover will seal properly when closed. I applied the ASI 335 to the screws but didn’t like the way they looked so I wiped it off. I had applied ASI 335 to the screw holes and the screws were twisted in through between 1 and 3 layers of butyl so I figured they were sealed well enough. The caulk job wasn’t perfect but it looks good from the ground. The ripples are from my hand shaking after going through the process 2 times before finally accepting that it wasn’t going to be perfect. I actually like the stepped edge of the caulk versus a feathered edge because I think the feathered edge of caulk doesn’t hold up well after repeated washing, drying, and waxing. We’ve pulled the trailer through wind and rain for 1350 miles and it has remained closed and hasn’t leaked. It is much quieter than the original Ventline fan. ASI 0240 https://meridianadhesives.com/products/asi-0240/ ASI 335 https://meridianadhesives.com/products/?product_search=335 It looks like ASI has two versions of the 335. The stuff I used looked like this Good luck on your installation. Bill
  25. I realized I did not take a picture of the installed Rear Porch Light in the daylight so I did that today. I kept the black rubber seal that OTT was removing since they were causing streaks with age. The rubber looks to be good quality, not like the rubber surround on the Furrion 30A receptacles that really streaked badly. If it streaks later I'll simply remove it then, but at this time I didn't want to mess with sealant. If I do add a rear camera, it would be for security purposes while camping vs. having eyes when backing up. I would not mount it rooftop where OTT did, but surface mount something below the OLIVER taillight and above the new Rear Porch Light. We usually have the TV down and the rear window shade closed, so it's not easy to look to the rear. Either way, it will be nice to have light back there when needed. Got my front light done today. Pictures coming soon! 😎
  26. We have only the stock panels (360W on our model year) and lithium batteries. We spend 3 weeks at a time at beach campsites with full sun and have no shortage of power. I suppose if we had portable panels we could run the A/C more, but probably not worth it in our use case.
  27. I like what you did Bill, with the rubber and polypropylene spacers. For sure it's filing the angled slot that truly helps the friction and noise in the up down movement. You got yours smooth and straight! Noticing in your pics the step material is coming up in the corners which will soon break off with use. I did a similar job but also sanded down and ceramic coated the aluminum steps and added new 3M Safety Walk 4" Resistant Tape. Our steps still look very good almost 2 years later! 😎
