  2. It is from the internal display. But the readings seem relatively accurate, since it shows as 40% when level, and as we raise the front of the trailer, a lot of gray water drains out and it reaches zero on the display after it finishes.
  3. Today
  4. Thanks JD... Good info on the Epoch batteries. I figured I was all square being that for this project I am "I F S L" rated. (that's I follow Steve Landrum for those of you not certified). Figured Inverter Services would be on top of their game but checked anyway and they did spec in the Essentials series. Currently trailer is getting the Furrion A/C upgrade and will be scheduled for the Epoch / Victron upgrade in November. We did a short trip out to "Land Between The Lakes" in KY a few weeks back and temps were in the 90's every day. We got by with the Penguin but I kept running into situations where it would be so much easier with the upgrades. Like being able to leave the dog in the trailer and go into a restaurant or store. Or, being able to stop at a harvest host or Walmart and not have the windows open and fan running and have to deal with any noise or bugs. Planning a big trip out west in spring to give it all a good workout. Hope to see you at the rally. Scotty
  5. How/where are you getting your percentage readings? The tank sensors can be inaccurate and/or in need of adjustment. Bill
  6. @jd1923 That looks really good! Nice and clean. It's on my very long list of things to do on our Ollie. I'm deciding whether to put the drip rails on over the windows or along the roof edge. We're in Kentucky so slightly more rain than Arizona. Maybe both locations since the roof edge isn't very noticeable. Also deciding whether to install before or after we have it ceramic coated but your post has helped me decide. Thanks for the post! Tony
  7. Since we started using our 2024 Oliver Legacy Elite II, the gray and black tanks won't drain fully unless we lift the front as high as it will go. If the camper is fully level, the gray only drains to about 40%. Anyone else have this issue?
  8. @jd1923 my screen was WAY up in the pipe, there was no reaching it with a finger. Only a bright flashlight revealed the screen up in the pipe. Not sure if they are all like that was products change constantly, but you'd think there would be a screen somewhere.
  9. First step was to talk to my ceramic coating guy. I knew that 3M VHB tape will not stick well to ceramic coating. It's 39" from the bottom of hull belly seam to the bottom of the drip rail in the original installation. On the scaffolding, the floor set only 3 ft high to work at eye level, I measured 39" up about every 18" left to right and placed a 1" piece painter's blue tape just where the new drip rail will be (this step not pictured). Then I ran the masking tape the entire length of the hull. Next step was to sand off the ceramic coating. I carefully hand sanded just <1" above the masking tape, first using a worn sanding sponge and then 400 and 800 grit paper. Smoothing it with acetone you could see the yellow ceramic residue on the rags. Final clean with 90% rubbing alcohol. I was careful, but should have been more anal, laid a second line of masking tape so to sand exactly a 7/8" strip. Then, game on, VHB tape doesn't fool around! I cut the ends angled back using a hose cutter. Stuck down the first few inches just above the masking tape. You pull the red backing tape off only for the next length. You keep the 25 ft length coiled ahead of you. With an 8 ft scaffold, you also move it 3x as you work left to right. The product is a very soft PVC that can bend in any direction and stretch. You have to stretch it to get it in a straight line and then you have to let some tension off as you lay it down. It's not that easy keeping a straight line that long. I think it came out pretty good. I'm happy. From the ground it looks straight as an arrow! I took the final picture from up on a ladder so we can see the line. It is straighter than the "professional" who did the there other side and it's a good product which allows for a straight installation. 😎
  10. This came up in another thread recently, but I didn't post my installation there since the title of the old thread was "DO NOT use this product." 🤣 Turns out with the help of @ScottyGS the best product is the Trim-Lok Drip Rail: https://www.amazon.com/dp/B01CJRH19Y/ We've had streaking down the hull exterior mainly from nightly condensate (not much rain here). Our nights year-round are a 30F drop in temps and condensation collects on the roof and after dawn it will trickle down the fiberglass making dirty striping all down the body. It seems even worse after we made the investment in a full detailing and ceramic coating (we just notice it more). The first picture is from 2023 when we purchased out Oliver. Prior owner had remove the original gutter from behind the awning and installed this drip rail, curbside only under the awning and this thread will show installing one on the other side. The new Trim-Lok I purchased looks to be the same. The issue is, except for the the curbside where drip rail was installed there is dirty striping, not easy to clean. The next two pictures show examples of the striping and the final picture shows a picture of the curbside which stays clean! Next posts will detail the installation...
  11. If using Baker's Hole call to find out the closure date, I think they said early October. We left there a week ago.
  12. Yesterday
  13. Sorry to hear of these issues. A couple of thoughts. Henrys Lake is more than any 20 miles from the West Yellowstone gate and it is west of there not east. Bakers Hole which is a USFS campground just a few miles north of the town of West Yellowstone is a decent campground. They have some electrical hookups but no full for sewage etc. There are also a few other USFS campgrounds in the general area, Beaver Creek and Fishing Creek but they are a ways out from the park. Figure at least 30-40 minutes drive to the west gate. Fishing Creek is very shady so if you need solar not an ideal choice, Beaver Creek and Bakers Hole are much better. Flagg Ranch on the Rockerfeller Road between YNP and GTNP also has RV sites but no experience there. There are book docking places around the West Yellowstone area but none of them are special by any means. Heading west out of town from WY there is a slew of USFS campgrounds on the Hebgen Lake, Lonesomehurst being the first one. Rainbow Point also on Hebgen Lake is a large USFS campground and not too far from the west gate of YNP. I haven't been out to Rainbow Point in a long time so not sure what the attributes are there in terms of hookups. FWIW in the conversation my wife and I toured the Fishing Bridge RV spot earlier this summer. Not our cup of tea, very tight crowded spaces and unappealing. I can't believe they charge that much money for such an abominable space. Much prefer the campground at Canyon by a huge margin. If you are not opposed to camping toward the north end of the park there are also a quite a few USFS campgrounds out from Cook City & Silvergate. Haven't been down to Cody in a long time so not familiar with that entrance but would imagine there are many USFS campgrounds and RV resorts along this route too. Cutting to the chase my top recommendations would be the YNP campground at Canyon or Bakers Hole just north of West. Canyon might be closing down soon though. Hope this helps
  14. @FloraFauna Thanks for the manual. Looks like the one I have. Our Truma equipment was installed in 2023.
  15. Yellowstone Grizzly RV park in west Yellowstone is $162/night for FHU pull thru. Henry’s lake sP is ~20 miles west of the west Yellowstone entry gate and is $30/night for water & electric
  16. Thanks JD. We are in the process of considering upgrading our Battleborn’s. Long term we would like to replace most of our electrical system, but want to start with batteries first. We have the PD converter and Zamp system with a 2000 watt inverter. Our course that means a new AC as well, since we have the original Dometic! Battery technology is evolving quickly, so it seems like we can get pretty robust storage, and hopefully it would last us for a while. Thanks again!
  17. Mike from Nashville was first to purchase Epoch (April 2024) and the Victron Multiplus II inverter/charger. He went with 2x 460 for 920 Ah in the Epoch Elite Series with Victron Comms. Two very large batteries just fit the battery bay without the Morryde tray which is not required, truly designed for watering lead acid batteries. The same two batteries today are listed at $5,200 (wow $2,600 each)! I believe the two were under $4K in 2024. I believe I was first to go with two 300 Ah Epoch Essentials for 600 Ah (mod link below). I purchased ours in July 2024 for $899 each. The list was $1,099 at the time, sale priced for $999, then 10% OFF for their 4th of July sale! Black Friday a year ago, I added a 3rd battery for $1,019 (ditched the tray, or you can keep it like Steve did). How did we ever do before 900 Ah? 🤣 When going Epoch you must consider the Essentials Series. The Elite is more expensive for "Victron Comms" and the PRO Series is a starter combo battery, no heaters or Bluetooth and you need a true Deep Cycle battery for power storage in an RV. Today the Epoch Essentials 300 Ah battery is up to $1,249! Epoch used to mark prices down and/or give 10% or 15% OFF. No more, look for their regular 5% off sale. However, last Black Friday gave 10% OFF and they could repeat that (just 2 months away). Also, if I was buying Epoch essentials today, they came out with a 334 Ah battery in the same case dimensions 2 lbs heavier for $1,299. This model is lower $/Ah ($3.89/Ah vs. $4.16). My first purchase was $3/Ah. If 334 Ah batteries were available previously I'd have 1002 Ah! Who will be first to break 1000 Ah? 🤣 Think that's too much? We run our variable speed A/C for days! https://www.epochbatteries.com/products/12v-334ah-lifepo4-battery Now with 2+ years experience, I will tell you the Epoch Bluetooth App really s#cks. Sometimes it sees my 3 batteries, sometimes 2 or none at all. Performance has gotten worse vs. better. I've uninstalled and reinstalled the app which doesn't help. I now count on my Victron Shunt and other Victron readings from the inverter, etc. The Epoch app sees all of my Ruuvi sensors and our Samsung products, so why in the world can their app not see their own products? 🙃 I've been the Epoch advocate for two years, but... This came up in another thread recently! I wrote a month ago that as their sales volume goes up, so will their price point! The price was $599 a month ago and now $30 more. give it a year and they will likely be $800 or more. https://www.vatrerpower.com/products/vatrer-12v-300ah-bluetooth-lifepo4-lithium-battery-with-self-heating-200a-bms-supports-low-temp-charging-4-f-5000-cycles-2560w-power I heard they have good reviews, from another Oliver owner, but do you own research on comparable LiFePO4 products today. If I was in the market, I would have jumped on 3 of these, 900 Ah for $1,800, or 600 Ah for $1,200 if that's enough for you. Just to be clear, I'm dissatisfied with the Epoch Bluetooth App, not the batteries. The Epoch Essentials have serviced us well for over 2 years, never a glitch. I have run them down under 20% SOC, down in the teens four (4) times and it no longer concerns me to do so (Chris worries a little). Via the Victron MP2 they perform as well whether full at 90%+ or low at 18% SOC and we run our inverter 24x7x365. For example, we just camped 10 overnights in SW Colorado, not once plugged in. We ran the Chill Cube A/C for 3 days, used everything 120VAC (oven, pressure cooker, induction plate, water kettle, TV/soundbar and modem/Wi-Fi). On day 10 we were down to 27% SOC of 900 Ah (which btw is equal to 81% SOC on 300 Ah Battleborn batteries). Got home with 40% SOC due to the Orion DC-DC charger while towing home (could have towed to another campsite with enough power for another 2 days). We have 320 rooftop solar and we setup our Renogy 400W suitcase on 4 of 10 days. The best thing you can do to your Oliver is get 2-3 times the Ahs in LiFePO4 batteries you'd ever think you'll need! 😎 Best wishes, JD
  18. Here is the Cp plus manual (2023 version - yours may be different). Although resetting is a recommended step, it has never resolved my CP plus issues. CP Plus Manual.pdf
  19. I have had this problem on and off. First time was a wiring problem from the factory which was resolved. With that resolved, if you forget that the inverter is off and you are not on shore power, of course, you wont see the ac unit. I find that sometimes it takes awhile after the inverter is on for the ac to "reappear". Must say i havent figured it out yet since it comes and goes. Certaintly a communication error is suspect and probably a connection or wiring issue up in the ac since the furnace and water heater are reliably present in cp plus.
  20. Out Truma CP plus 'sees' our AquaGo but doesn't see our Truma A/C. I've found other posts about resetting the CP using the procedure in the manual but I can't find the procedure in the manual we have. I think I remember reading it in another post but can't find it now. I'm not sure we have the complete CP manual so would someone please post a link to the CP manual which has this information or the post with the steps to reset the CP. Thanks, Tony
  21. I had Lew’s team at Alcan install these upgraded wet bolts during the 5 leaf pack install. Also made sure the zerks were facing inside the under belly for much easier access when servicing wet bolts. Also had Alcan HD shackles installed. Very happy with my Alcan running gear.
  22. @Steph and Dud B Thanks for the info, I’m one year in with the Bauer and no issues yet. But if I have a problem I’ll keep this in mind.
  23. It seems like for most people that move away from Battleborn batteries they go with Epoch. Is there a consensus on which series folks like, essential or pro? And I do notice Epochs are on sale periodically; any leads on discounts? Thanks in advance…
  24. Our daughter graduated from NAU in Flagstaff so we made many trips north from Sierra Vista/Ft Huachuca while she was there. We always looked forward to seeing her but also enjoyed the area around Flagstaff a lot. Walnut Canyon was worth the visit!
  25. We stayed at Henry’s Lake SP and had a very nice experience. Close to Yellowstone and a relaxing place to stay!
  26. Last week
  27. As mentioned earlier, we've had 2 RV Lock keyless locks on our 2022. Both failed, one possibly due to water intrusion because Oliver cut the latch hole in the door too big, leaving a gap next to the exterior portion of the lock where water could get in. OTT sent us a replacement and I caulked around it. Even so, the replacement failed after 3 years for unknown reasons, so we gave up on RV Locks. We were just at the Hershey RV Show and met a rep from Global Products Group who showed us their Ultra ES Pro lock. The first thing I noticed was that it was very substantial, all metal construction. It also uses a different handle configuration inside and out. We talked him down to a price we could accept and bought one. I just installed it with no issues. The first thing I noticed was that the exterior portion was larger than the RV Lock, so it covered the gap left in the door by OTT nicely. It also included a large neoprene gasket, which was nice. Installation was easy and it functions well. One interesting note: there is no separate deadbolt. The deadbolt function simply locks the single bolt in place, rather than extending a second bolt. It would still stop someone from jimmying it open, though. The second thing I noticed is significant for us. Even with the striker plate all the way out, our door never latched easily. We had to really slam it to get the RV Lock to engage (perhaps the cause of the demise of lock #2). This latch closes cleanly and easily using the original striker plate. Our sleeping neighbors will be much happier. OTOH, the Bluetooth app for the lock seems glitchy. It has trouble staying paired to my Pixel phone. Not a huge deal for me, but maybe for someone else. Time will tell if this lock holds up. Will update here if things change. Here's an Amazon link: https://a.co/d/0bzR8SDZ
  28. Almost forgot! Check out this horse ranch at the start of Winona Ranch Rd with views of the San Francisco Peaks! Flagstaff sits below the left end of this mountain range. Picture taken when leaving camp the next morning. Home in under 2 hours. “I’ll be back!” 🤠 Where are you camping or have recently visited? Please post!
  29. I posted something about this BLM dispersed camping site in another thread, "Oliver - Again?" But this reference should really be in our favorite thread, "Where' Ollie!" So here it is! So many of us drive by Flagstaff AZ, whether you're going to The Grand Canyon or Sedona, elsewhere in northern AZ or just traveling to or from California! Winona AZ is 16 miles east of Flagstaff and just east of Walnut Canyon, which is worth a visit (I posted pics from our visit here just a few weeks ago). Walnut Canyon and these boondocking campsites are only 10 minutes south of I-40. Drive south on Winona Ranch Rd and turn right on FS Road 128. These are well maintained service roads with some ranch traffic. Our campsite was 2.5 miles down and there are 100s to chose from! Camp another few miles down this road and you'd be a short hike to the western rim of Walnut Canyon. 🤠
