Since you had the latch pinned, I would assume that the issue was caused by the wire part that connected from the latch to the collar. I don't see how that collar can slide back allowing the coupler to open without some type of deformation to, or disconnection of, that wire. Let us know what Bulldog tells you.
Yes it is! Great fishing if you are so inclined. And not far away there are some sights to see. https://www.visitutah.com/articles/dinosaur-national-monument-flaming-gorge
Reset 2.0 (Hull 1364) just spent its first night (with us) in Utah. The Flaming Gorge area is absolutely beautiful. This trips pass list so far includes: Raton Pass (NM) 7,834 ft Monarch Pass (CO) 11,312 ft Douglas Pass (CO) 8,205 ft
Tom and Doreen replied to John Dorrer's topic in General Discussion
John, the 2-5/16 sounds like a safe bet. I doubt you'll have to worry after that. -
Apparently, the snow is in WY this June.... https://cowboystatedaily.com/2026/06/09/merry-christmas-yellowstone-to-get-june-snowstorm-as-cold-front-dips-into-wyoming/
John Dorrer replied to John Dorrer's topic in General Discussion
No pictures. Trailer is back in storage. After a day processing, we are sure the trailer was secure on the ball. My wife directs me back and when we have the ball where we want it under the hitch, I lower the hitch. Once I know it is seated, I squeeze the lever and slide the slide closed. With it closed, I turn to my wife and we give each other Knucks and she hands me the pin to insert. After the incident and getting the front raised, I pulled the pin and opened the hitch. The bridge joint was a hard impact. It must have shut our dash cam off, or leaving it on when I went to the store and left it on overnight may have errased it. I wonder if this was a combination of bad bridge joint, new Alcan 5-leaf springs, and wear or issue with the 2" Bulldog. I'm not willing to go through that again. Requested pricing from Oliver so I can have them ship the 2-5/16". When I pick up the trailer, I will be taking roads less traveled straight to my Truck Service place to get it replaced. I may ship to Bulldog to have them determine what may have caused the failure. -
DunnYet started following Reset 2.0 has started squeeking when backing up and Made in USA leaf springs
Reset 2.0 (Hull 1364 ‘23) has new Alcan springs! Even though I got mixed up on the drop off time and was late, the team at Alcan did a great job. Had an incredible breakfast at the Dream Cafe per several suggestions in this thread, then Rebecca and I went up through the Colorado National Monument with Reset 2.0 safely in the hands the Alcan team. Can’t imagine going over that Rim Road with the Ollie 😀 Adding to my list of “designations I never wanted to achieve,” they told me my springs were among the worst they had seen. Bushings completely shot and in terrible shape. That’s the joy of purchasing a used Ollie. At least we have solid records from the day we purchased forward. Now doing the enforced rest breaks under the trailer, a.k.a tightening the shackles and u-bolts.
Oliver no longer selling through dealers?
HDRider replied to DanielBoondock's topic in General Discussion
That would be great! I think Oliver is getting some name recognition, and if this was the place to find a used one, or even a new one sold at the factory, all the better. I say Oliver is getting name recognition because this week two sets of campers knew mine was an Oliver, and I have no decals on my trailer. Both commented on the reputed build quality of Oliver. -
Where's the snow in CO and where's the gator in MS?
Thanks for the detailed options. @jd1923 - Please rest assured - that was a “before” photo from my “replace the completely trashed factory shocks with bulldog shocks.” I should have cropped that out - I was just trying to get a reference for the axle type and that was the best photo I had in my library of the hub. Will put in some better photos this morning. I was so focused on getting a good clear hub shot that I didn’t see the “gorilla” in the background. Will report back on findings. Am also going to call the folks at Alcan for their thoughts. I just wanted to get the thoughts out of my head and into the forum brain before going to sleep last night. -
topgun2 replied to DanielBoondock's topic in General Discussion
AND - IF all of this is true (I suspect it is true), we just might get our "classified section" back here on the Forum. Bill -
You are correct. I know nothing. My original post includes the fact that 3 separate issues were found and corrected by the last mechanic involving both truck and trailer -- and the fact that the warning lights disappeared and my trailer brakes worked for 3 solid days. Maybe you didn't see that part of the post -- or maybe you have concluded that none of those 3 things contributed to the issues? I'm suspecting that the wires behind the vanity may have worked loose again, as I was traveling. I cannot be certain that any of these issues were even partly the cause of the warning lights or partly the cause of the intermittent loss of the trailer brakes. I'm going to remove that vanity panel again, and take a look at the junction box. And when I get to Lake Catherine SP, I will see if I can rent a U-Haul trailer in Hot Springs. It looks like one of them is open on Sunday and Monday. I will let you know the result.
Seems like they have tuned up customer service too. -
jd1923 replied to DunnYet's topic in Mechanical & Technical Tips
This could be nothing. Could be something squeaking from the new leaf springs. Alcan torque numbers are high. The springs or a very tight bolt can squeak. But to answer your first question, "should I be worried?" There are things you could look into... First thing you can do in the morning, parked at the campsite, is use your stabilizer jack to lift that side up. Spin both tires one at a time. Hopefully you do not here squeaking running this test because it would mean a Nev-R Lube bearing is failing. However, this is not a conclusive test, since when lifted there is no load on the wheel bearings. These bearings can last many years, warrantied for 5 years, but can fail at any time. A low probability cause since your Oliver is relatively new, unless a whole lot of miles have been towed. Also, with the wheels lifted do the 3 - 9 o'clock position pushing back and forth and 6 - 12 positions to see if there is any free play. If good, you should NOT be able to budge the wheels at all. After you break camp, do some slow towing forward and backing up in an open area where you can take your time. One of you driving, the other with ears close the Oliver wheels on the side it's squeaking. See if you can reproduce the sound and try to pinpoint the location if possible. Your shocks look terrible! The bushings were greatly over-tightened when installed (bushings flat and way too many threads showing above the top washer). Shocks can make squeaking sounds. This would be your best-case scenario as you can drive to Texas and back without shocks on an Oliver without causing harm. In fact, if you believe it is a particular shock, remove it to see if the squeaking goes away. At some point they should be replaced, but they are not critical in your getting home. If it gets worse and you're not too far already from Alcan Springs, it may be a good idea to go back. You're a customer. They have the tools and expertise and would certainly take the time to help you. If it is a bearing failure, they could change it for you, and likely under warranty on a 2023 trailer! They are a Dexter Authorized Reseller. At least call Lew or Tim. Let them know of your situation and get their advice and help if needed. If it doesn't get any worse, you could play it by ear and continue to Wyoming. Keep in mind a return through Grand Junction to Alcan Springs may be necessary if it gets worse. This sure beats being somewhere else in the country, far from home, not knowing where to go for service. Best wishes to you in your travels! JD -
Reset 2.0 (2023 Hull 1364 LE II) with Dexter Neverlube factory axles. We are on the road leaving Grand Junction with brand new Alcan springs and headed up into Utah and Wyoming. Yesterday after picking up and today backing into a site in Utah I noticed a slight squeak when backing up. (1) Should I be worried? (2) What should I look for while I am doing under trailer yoga tightening the u-bolts etc. Per the yellow sheet I tightened the bolts to proper torque at 12, 75 and will do in the morning before we hit the road. Also wheel lugs to 100 ft lbs based on the forum information. Brake test on leaving the park this morning worked fine, seemed to be more powerful so I reduced brake gain to 5 from normal 7. Attached a photo of the axle hub for reference - what should I be looking for? Let me make this clear - I don’t think that this is something from the spring install, but need to know what to look at. I don’t want to kill the brakes on the way back to Texas through ignorance.
I'm trying my best to help, reading your posts carefully, advising based on my experience. My written words are not always kind, but I am a caring person. I understand the frustration you have endured gets emotional. I remembered you are a woman traveling alone in your Oliver. I feel total respect for you since it takes Chris and I working together to do what you do alone. Love of your Oliver is likely equal to my love of ours with all I've put into its care. How is it you know this? Does "was" mean in the past? I believe the word AND to mean defects exist simultaneously in both truck and trailer. I cannot arrive at this conclusion from what you have written and it's more likely a one or the other issue. Before you do anything else, please pull another trailer that's not your Oliver. If you get the same error message, even once for a few seconds on your truck while towing an alternate trailer, then it's the truck's brake controller system that needs service and you Oliver is fine as-is except for wiring cosmetics. If you stay hitched to another trailer for most of the day, start and stop, tow it on and off several times and not a glimpse of the same error message, then Oliver service is required. You do not need garage or tools to rent a U-Haul trailer. Your issue is not likely the grommet on your brake backing plate, though yes there is a small chance it could be a brake wire shorting which the ammeter test could prove.
Hello to the Ollie crossing the Knik River bridge on the Glenn Hwy. in Alaska. Our son passed you southbound about 15 minutes ago.
This is in the beautiful US Choctaw Lake NF campground, located in central Mississippi. It is full of songbirds, lush and lovely.
Sold my emotional support tent to an outfitter 🙁🙁🙁 It was painful but the funds can go toward the Alcan upgrade where is everyone? we hiked some Crested Butte and Gothic Colorado trails today and the mountain flowers are just starting to bloom, July is the big blooming season they say Crested Butte is the Saint Moritiz of Colorado
Maybe JD will illuminate. It would provide access to those wires, without requiring disconnection at one end or the other, and that could be an advantage. Since I don't understand how they are connected at each end (or how to access where they are connected) I can't even guess how hard it is to .... access or replace them. Maybe it's not as hard as it seems.
Yes. I certainly did. And Yes it is my Oliver. And yes I love my Oliver. I'm trying to take care of her. There was a problem with the truck AND with the trailer. I wish I were an expert mechanic, but I'm not. I wish I had more space for tools, but I don't. I appreciate your posts -- they are usually very informative. I don't own the equipment, but I am trying to learn, and I lean on the forum members who have the expertise and/or experience to help me. I bought a caliper last year, but it wasn't very helpful to me trying to measure the size of that hole in the axle to figure out what size grommet I need, because the wires don't allow me to insert it fully. hahaha -- more wasted money, perhaps. Service Dept couldn't / wouldn't give me a clue. So I ordered a box of 200 grommets off Amazon that are shipping to New Mexico where I hope to make progress on this thing. Unfortunately, that is the way this issue has gone for me. If I knew a lot more about these systems, I might not have been taken advantage of by lazy or incompetent people. What's a girl to do? Learn. I'm learning.
