  2. Thanks - we did a lot of boondocking, and don't have a problem getting there, gravel, dirt, or whatever. Good point on the class b, 100 grand for a lot less capability. We usually carried extra 10 gal of h2o and had the composting toilet - still undecide on this going forward. The shoulder seasons will be targeted this time around, now that "work" is behind us.
  3. Yesterday
  4. I have a two Honda generator setup however in recent years I've just brought one when traveling to save space and weight. I have charged the batteries using the single Honda occasionally but it does obviously take longer (than if two Hondas are paired) and the Honda runs flat out. I do limit the Xantrex charge current. I believe that Honda now offers a single generator higher current solution that isn't too much bigger or too much heavier. If I were to do it these days I'd probably do that.
  5. We find it reasonably easy to escape crowds but it depends on your style and setup. A few of our rules that have led to success. We almost never camp on friday and saturday nights. We rarely hook up to anything ( water, electricity, etc). With these two alone we find crowds are easy to avoid. We purchased in 2023 and it was pricey then but its all a matter of perspective. Alot less than a class a, b or c and we already had our tow vehicle. So all in all the quality and manufacturer support structure make it worthwhile for us.
  6. We got our trailer in 2019 and feel like the crush of people in the outdoors was and is still significant. Our solution has been to spend most of our time off the grid, off paved roads and away from the national parks except for the off season. We have had fantastic trips Nov through Jan in the southwest the last couple of years. Count us out for mainstream campgrounds, state and national parks May through August. We must work to avoid crowds but have always found wide open space in the west side of the USA. Lots of BLM and other remote space to explore. If you are opposed to gravel roads and off-season travels, you will likely be crushed by the crowds. Yep, 100k for new trailer is a big bite. We found ours used in great shape. We did have to upgrade solar / batteries and few other things but got great value buying used. Water is the gating item for extended of the grid travel. We equipped our truck with an additional 30 gallon water tank enabling extend time off the grid. Best of luck. Hope to cross paths in the open spaces out west.
  7. It has been a long time since I have been on the forum. We had 359, 2018, and went a lot of places, really enjoyed the experience but other life choices got in the way, and we let it go to some good folks that were sure to enjoy it. One of the key reasons for selling was the crowds that seemed to be everywhere we went. A few questions for the forum - has the crowding subsided at all, and Wow, the prices now - seems $100k is the entry price for a II, - do the newer owners feel the value is still there from a quality and feature standpoint. I'm really liking most of the changes - and am actually looking at the smaller Elite - but not sure the price differential is worth the downsizing Thanks for any feedback..
  8. I'll help - but, it really is a very simple install. Bill
  9. Bill, if you offer free installation, I bet you'll have takers.
  10. Press and hold the OK button until it beeps. The display will show the Setting # on the left and its value on the right. Click the Up button until you reach setting 28, then press OK. The value will flash. Use the Up button to change the value (it maxes out at 50, then starts over again). Click OK to confirm the new value. Press and hold ESC to exit settings. (BE CAREFUL NOT TO ACCIDENTLY CHANGE ANY OTHER SETTINGS.)
  11. Last week
  12. It’s the Starlink router, RJ45. The dish came with a pretty long power cable and we got a similar length cable for the router. We ran the cable from the dish back to the trailer, through the dinette window (screen slightly open) to the router that we set on the dinette table. Beside the tonneau cover and tongue box we’ve used the picnic table to set the dish on, and we’ve also just set it on the ground. Just wherever has the best shot to a clear sky in the right direction. If we’re gone for the day I just bring it inside until we get back.
  13. I realized that you remove the antifreeze version of the filter by pulling down further on the lever. I removed the heater/screen filter and saw that the o-rings were fine and nothing was distorted. I put it back in carefully and that part no longer leaked. I can't see any obvious crack in the mixer, but the rear wall has obviously been sprayed. I guess it could be a leaky hose or the the mixer itself. It leaks about 5 ounces a minute - the pump runs, then turns off, then 20 seconds later it runs again for a few seconds, etc. Kind of interesting - the fellow who checked us out at Oliver on delivery day only said you "could" put the yellow plug in the flue when driving. It also says you can't use it below -4 °F. It must be winterized. The instructions are clear: you must put the yellow plug in.
  14. I don't yet have the mini, but I still use the Starlink Gen 3. I had purchased a tri-pod mount adaptor from Bantha Overland on Etsy. I just checked and he has a few 3D printed items for the mini as well. I'll use him again as the first mount was a good solid solution for my heavy-duty camera tri-pod. I like having items that are multi-purpose, to save weight & gear, i.e. a camera AND Starlink Tri-Pod, etc. Also with the mini, I want to check out all the cool cases/mounts available. Veritas Vans seems to have an interesting solution for the mini. I'm also thinking 3M tape magnets so I could put the mini on top of the Ollie, or on top of truck cap. Which ever works best at the time. Lastly, I think this is more true for the mini, but recently I took a chance and started pointing my Starlink Gen 3 in any direction in the opening of trees (within South Georgia). I was amazed that I did not see any speed test reduction compared to pointing dish North. Try that out. It sounds like the mini pretty much can point anywhere too these days.
  15. Thanks for the ideas. I had turned off the bypass last winter, but I didn't know there was a way to drain it. In any case, there was no obvious problem in August when I picked it up for the summer from storage (heated). I'm hopting the mixing chamber isn't cracked for whatever reason. I'll go after the strainer. I think the leak is a lot larger after I opened and closed the overpressure valve. I attached a photo. I haven't looked at their manual yet. Truma.docx
  16. I have a new set of rear wheel well liners that fit late model Ford F-150's. This includes all mounting hardware, instructions, and (of course) liners for both the passenger and driver sides. Price - FREE But, you need to let me know your interest or I'm not going to bring them to the Rally. Bill
  17. Yeah Toni, likely not ALL. Of course seasonal sites will be closed off-season. If they allow campers to show up and pay the host or at a kiosk (we paid the host $36 cash for 3 nights), then I believe the 4-day rule applies. This rule allows for drive-up pay cash locations. If the campground ONLY allows for online reservations then all available dates should be available to book online. It seems we've run into not being able to reserve tonight or next day at many locations we've stayed.
  18. John, you mean for that particular campground? I've found that it varies on recreation.gov from one campground to another, whether it's FCFS or reservable. Some have closed the reservation system for the season; some have closed the campground for the season. It's not predictable.
  19. Hello again Bob, and thanks! I merely purchased a 4 ft piece of 1 1/2" PVC (2" OD) and a coupler from Lowes. Sawed the PVC in two 2 ft sections and the coupler will join the two only in the truck installation (pic1). The lower 2 ft section is permanently mounted to our extra fresh water tank. This works in an open bed but the lower section could be bumper mounted or to the side of a truck cap or the Oliver front basket. For the "umbrella stand" option the set screws from the stand fit into the drill holes. There is also a 3rd drill hole up top (cannot be seen in pic) to hold the Starlink set screw. Half fill the umbrella stand with water and it's not going anywhere! Good sale price on this today at $27! https://www.lowes.com/pd/Patio-Premier-Patio-Premier-Square-Blow-Mold-Umbrella-Base-Black/1002629278 Starlink includes two mounts. Mike mentioned he would merely lay the Mini on a flat surface. He's using the simple base mount that has a kickstand to produce the correct angle. I started the same way but found often in the woods finding a flat spot to support the dish is difficult. Starlink includes a second mounting plate (pic2) which comes with the 2" mounting hole with set screw. Notice the two drill holes in the upper post. If I'm using the umbrella stand, these line up with those set screws. I love the 1 1/2" PVC mount and would not stray from this. If I was to buy a stand again, instead of the umbrella stand which is large to store, a folding tripod would be OK, if I could find one that would hold the 2" pipe. I wouldn't want to get into camera stands, 1/4-20 screw mounts with adapters. IMHO, a soft 1/4" screw should not be the only thing holding the dish, not in heavy weather. No skinny stands, no long poles, no suction cups, nothing fancy for me. Just open your compass phone app, mount the dish pointed north, check alignment on the Starlink app, just a one minute installation required with this setup! 😎 Sorry, acronym from eBay sales, means "New in Box."
  20. Note that the Mini came with two different socket sizes since its release. Pucks are not interchangeable between the early ant later versions. I use this to mount my Mini on an old unused camera tripod. https://a.co/d/00vsLugU
  21. Thank you so much. I will look into what I need to do in order to change that setting. I do have the xantrex inverter, so it should just be a matter of figuring out how to change settings!
  22. If you have the Xantrex converter/inverter in your Ollie you can change setting #28 to whatever amps number you want the converter to pull at max. The default is 25 for when hooked up to shore power, but you can make it 15 or less for running off a small generator. I often set mine to 5-10 to prevent my Honda from running at max capacity. Charging is slower, but the generator is much quieter.
  23. Correct. @2008RN, I have this adapter. https://www.amazon.com/dp/B0DP21TD7L?ref_=ppx_hzod_title_dt_b_fed_asin_title_2_0
  24. To dependably run Ollie's 1300 BTU air conditioner with a Honda 2200 requires installing a "soft start" to even the load (reduce the electical start up surge). I found this to be true to run when using 110 V as well. The devise is an easy installation and allows you to run your air condtioner with small generators or a 110 circuit. I have been running this setup for several years with a Honda 2200. and yes, these generators will charge your batteries. best of luck https://www.etrailer.com/RV-AC-Soft-Start/SoftStartRV/SSR54FR.html
  25. does your OE2 have the progressive dynamics converter (charger)? if so you can charge it with a single Honda 2000 or 2200 eu inverter charger. No need to parallel two of them. those generators will also run your a/c, but not much else. you need to be sure to turn OFF the electrical switch on your hot water heater and not be on AC or DC for your refer if it is a three way. GJ
  26. That is nice knowing you can still do some minimal data functions, like phone calls over wifi, and I am Assuming text, and emails in standby mod
  27. Was it the router a mini? Did you use the mesh wifi or did you do RJ45? If you used the mesh wifi where did you put the router. Living in Oregon we are often under a tree canopy, and the cell reception is very spotty at best on the coast, along the Cascade mountain range and in eastern Oregon prairie land. I still have a problem calling something a mountain range in Oregon after spending most of my life in Colorado Rockies. I do have a hard tonneau cover, but no tongue box . My preference would be to set it on the tonneau and then to disconnect it before take the truck on a outing and store it somewhere.
  28. That stand looks pretty cool. What parts did you use to make it work. Also the battery looks like a Dewalt 20V battery. How did you wire into the battery. I like the idea of not using cables if possible and if I use a cable I only what to use one. Either RJ45 or Power. I have a tonneau cover so placing it on the cover when needed would be great, when not possible I would like the stand instead of just sitting it on the ground, and the stand had weight in the base it would be even more stable on the Tonneau. Thanks for letting me know that you arrived at your current setup through a process. I liked to know that. I know your setup is more complex than I want now, though it works great for your needs and you arrived at that over testing and growth. Sorry but what is NIB"🤔 I have a question for you and @Todd B how can you mount the mini on a pole or a tripod, Most tripods are 1/4-20 threads and I have know idea what the pole size @jd1923 uses. Special Addapters or does the mini come with all of those mounting options? Sorry for basic questions, When I was a machinist/ automated equipment tech, and then IT, I usually tried to wrap my head around a situation before I would implement. I am kind of anal retentive at times. I like seeing things from different angles before I purchase something. I do not mind fabricating/ buy adapters to make things work, but it nice to have an idea which way I will move before I purchase something. Sometimes it works and sometimes it is working through a problem/situation to come up with a solution. If someone else has a good solution that works, I do not mind leveraging those solutions. Why reinvent the wheel if someone else has already done it. (Off topic) I built a 42' x 16' free standing awning off the back porch with plastic corrugated roof special ordered from the east coast( my wife's idea), I want a plywood with metal roof. The awning roof cantilevers over the roof on the house . Living in Oregon in with many trees and 90+ humidity in the winter I needed a way to clean the awning roof, because of the debris, moss and lichen growth. When I first tried to do this I made a 3 nozzle sprayer on rollers to hook to my pressure washer. It failed miserably. I ended up recruiting my son, and we both stood on our metal roof, one sprayed the roof with water as the other used a micro fiber mop head on a 16 ft paint roller pole to clean the roof. This worked but it was very labor intensive. I found an old high end pressure washer at an estate sale this year. My son and I made the base so I could tow it with the mower and put a removable hose real on the base. I went over every part of the sprayer. It looks like brand new accept for the dented Honda gas tank. It took a 3 iterations with the old 3 nozzle sprayer, but I got it working great, and at half throttle. Had some fun at full throttle where the sprayer was floating 4ft above the roof because of the spray pressure. When I got it dialed in it took 1.5hrs by my self without getting any over spray on the metal roof, as compared to 4hrs for 2 people and both of us getting wet on a metal roof. The point of the story I may be slow and with limited resources, but I never gave up on finding a solution.
