  1. Today
  2. We have the same model RM2454, and we've done the same thing! Chris says I hit the switch with my butt when making a drink. 🤣 I use the shelf above the fridge as a bar top. I've gotten up in the middle of the night and it's dark up that way with no lights on! If all the lights are off, then it got turned off accidently. Our fridge has been holding today on AC power, after it needed LP to cool it down at first. I also realized it was nowhere near level. Checked the LevelMate this morning and the front was almost 6" low! That's the way it is in my driveway, hitched with the truck parked in the garage. I raised the front about 3" this morning but can't get it higher because it has to stay hitched. Richard, I'm glad you are working on getting yours to perform again! I was looking at replacement fridges and they're either too small or too big and too much money. Thanks for the heads up on Dinosaur boards. Yeah, if the Xantrex is keeping Marianna up at night, just shut it down. I sleep above our Victron and if it's charging when I want to go to sleep, I'll turn it off. Lucky I can switch it off by the phone app. At some point I'll figure out how the AC/DC circuits work on our model and how to test them myself. This guy may be worth following.
  3. Yesterday
  4. JD1923: I should clarify my issue. We have a Dometic 3 way RM2454 refigerator. Out charger/inverter is a Xantrex Freedom XC 3000 Pro Inverter. So the situation was: After the 3rd day of camping, we left the campground to go to the fair and was gone 4 hours. Upon getting back to the trailer, the refigerator was off completely. I tried turning the unit on and it would not start up on AC. I then switched it on DC and the Xantrex started up (likely to charge the batteries) and did ot turn off. Since it is under my wife's bed, I know the noise would be too much for her. I then switched it to propane and it ran fine. The next day after I thought about it for awhile, I pushed the auto switch in and out for a few times, as it would not activate the first time and only run on propane. After working the Auto switch a couple of time it finally worked and switched to AC. So the moral of the story is.: 1. I think that one of us had accidently hit the on/off switch before leaving the trailer. The auto swtich had not been pushed for a couple of years, so the contacts may have been dirty. 2. I have always found the button operation to be difficult to get it to ingage, maybe due to dirty contacts. That would explain difficulity in getting the refig started again and switching to AC. 3. After discussing the siuation with a knowledgable friend, he suggested buying a new eyebrow board from Dinosaur Electronics who make a better board the Dometic, which I have ordered. I also ordered a new Dometic board (which includes the face plate) since the cost was less than $5.00. I will now have 2 back up boards when needed. Other explalination would be appreciated.
  5. Pulled our Oliver into the driveway yesterday, since we're leaving for SW Colorado tomorrow. Like Dewdev, I started our Dometic 3-way fridge on DC. It did not seem to work. On the Epoch and Victron apps you could see it was only pulling -4A total and our system pulls -2.5A with almost nothing ON! I think I had the Maxxfan on too, so the fridge switched on DC was not actually pulling any DC power from the batteries! Switched it to AC and the readings changed to -16A which is a good number showing the fridge is drawing amperage so should be running. Two hours later the freezer had cooled down to 26F, the fridge at 62F, ambient cabin temp was 79F. This was going nowhere fast! Later last night, I switched the cooling to LP and started the Beech Lane fan at 50%. I sat at the dinette for 5 minutes to hear the LP ignite. It took two tries because on the first try I had forgotten to first light a cooktop burner to bleed the LP lines. After the bleed, I could hear it go through the click pattern twice to ignite and then I could hear it burning, a soft smooth sound. This should be working now. Got up this morning to read the freezer at 8F and the fridge at 36F (Ruuvi sensors and app). We always keep the fridge cooling setting at #4 out of 5. So our fridge is hardly a 3-way anymore! I will try running on A/C (Victron inverter always ON) while we are towing. Maybe now that it's cool it can sustain running on electric. Last trip we were at 7600 ft elevation north of Flagstaff and the fridge had issues staying lit overnight at altitude. This trip we will always be above 7K+ ft. After all I've done to our Oliver, I'd hate to think fridge upgrade now, but it looks like it's coming soon. At least we have the 45L CFX5 fridge in the truck if all else fails. We're packing light on food with good local markets on the route!
  6. Welcome to the group and congrats on the new Ollie! Look forward to meeting you out there somewhere! Mike
  7. I think you forgot the golden rule of design," we gotta make money" which follows all of your design examples. Mossey
  8. Hi all, First off, thanks to all of the Oliver forum members who post comments and Q&As. The info we’ve gained from periodically checking the forum activity was incredibly helpful in our decision to buy an Oliver, and in figuring out which model and options would work best for us. Although it took more than a year of research, we finally made the leap this past June! We will be picking up our 2027 Oliver Legacy Elite II (Twin Bed floorplan) on September 8th — Hull #1735. We were tent campers for about 40 years and spent the last 8 years camping throughout the Carolinas and Virginia in a 15-foot Taxa Cricket. We are really looking forward to the next chapter of traveling and exploring the country in our Ollie. If anyone is around Hohenwald during our pickup week, say hello! Chuck and Beth Lexington, NC
  9. As @Steve Morris provided plus one extra 4’ pole section in my application.
  10. @Omward Bound Appreciate your post. Very nice looking ceramic application. We're in Lincoln County NC, will give Blake a call when we're ready for ceramic coating. Thanks, Bill
  11. I hear ya, but unfortunately I’m corrupted by spending the last 32 years continually discussing what ā€˜good design’ is šŸ˜… There’s many different types, ā€˜design for test, design for mfg, design for repair, design for usability … ā€˜ What you really mean is it has poor accessibility design. Agreed, or at least it’s not optimal. However it has excellent manufacturing, repair, and simplicity design. Also my post above points out it has excellent usability - once you get in the cabinets its easy to use, don’t need the documentation (diagram) most of the time. And it has the best aesthetic design. The layout is beautiful, and it doesn’t intrude into the cabin with ugly gubbins. So just back of the envelope, it wins in five categories and loses in one (accessibility). Hey, if you can get that kind of hit rate than yes it’s a good design! Design for repair, and design for repair documentation. You’re complaining about the latter. Basically nobody worries about that, it’s what repair manuals (or support lines) are for. I mean seriously, those fuses aren’t hard to find, I did it in my first trip when the composting fan went out. That fuse is in the same spot, I was glad it was so accessible. Turned out it just needed reseating. Anyhow I’ll stick up for Oliver here. One of the things I appreciate about this trailer is how well designed it is. Because they’re not changing the basic design every year! They have one body and frame - that’s been perfected within the form factor, and they just keep refining the interior components and layout. It’s always massive compromise and I love working on this thing, they’ve balanced it all so well after all these years. I absolutely love how neat and tidy it is, with automotive channel wrap on all the wires. Work of art … Ah sorry, been too long at the farm šŸ˜…
  12. We bought our used a few months ago. Went to Pennsylvania to pick it up. Love it. We have been staying on Oregon coast a bunch. We reside in Grants Pass Oregon IMG_0858.mov
  13. Last week
  14. Appreciate the info and thanks for being back to me.
  15. Ollie spotted traveling north on California 101 / Arcata, Ca 12 noon Sept 1st. Black graphics. Not many Ollies' located on the west coast but three known Ollie's are located Arcata/Eureka area.
  16. I’m not Ron, but I asked the same question before. It is from Flagpole Buddy, and you need the Airstream version with adjustable angle suction cups. They went on sale last Black Friday. https://flagpolebuddy.com/products/ols/products/airstream-suction-cup-mount-kit-g2-g3-g5-or-mini-adapter-poles-mounts-cable-clamps-pole-bag/v/106967-MN
  17. We get 100s of hummingbirds in Prescott, with the peak season during August. It just cooled off and the hot summer temps are gone 'til next season, thank goodness. They all know Chris as the bird lady. She puts out seed, water in the bird bath and gallons of sugar water in 4 feeders. She even had a couple hummers drink from a hand feeder! The hummers will start to migrate south in the next few days/weeks. We do have some winter hummers, but only a few. We spend an hour or so on the deck each evening. Soon we'll be wearing winter clothes and have the fire ring going! šŸ˜† Hummers in Prescott v2.MOV
  18. @ronbrink Which flagpole and suction cups setup is that on the Ollie? Thanks,
  19. "Well thought out?" Any need to move beds and bedding is not a good design. @ScubaRx was first to install motorized ball valves! I believe Steve has his switches outside somewhere. I installed them right under the bed, so Chris throws the switches after I run the hose (the third switch/valve is used to drain the fresh tank). Our 12" mattresses are quite heavy and Chris is particular about the sheets/bedding. I don't touch the beds when made, only when home for mods when the sheets are in the laundry! Notice the underbed duct delete too and the addition of a return duct air filter! šŸ˜Ž @Dennis and Melissa recently blew the fuse for their front jack. Seeing the (extra) fuse at the front jack, he didn't think about three fuses under the streetside bed. Who would? Honestly, only some book-smart engineer in China, that never in his life traveled in an RV, could find a more illogical place for these fuses! We have yet to have to move our beds while camping. See my mod post below. It's worth the work, at least it has been for us! šŸ˜Ž Some hand carry water jugs. But we always have an extra 35 gallons in the truck bed and we fill via the "boondocking" valve configuration about every other week when camping. I thought I was the only one who added this extra FWT, but recently @FloraFauna wrote, "wish I had opted for 40 or 45 gallons." I bring 25' and 10' hoses and together 35 ft will get from the truck bed to the Oliver rear while hitched. I could not see hand-carrying water (or moving the bed), for something we use so often when boondocking. As soon as one of us hears the water pump gurgle, start to take air, we'll pump in about 20 gallons, saving the remainder for a couple days later. Double your fresh water supply, will allow you to double your stay! šŸ˜
  20. I am looking forward to meeting you as well and 'the dog house' graphic may be gone by then. I need to get a replacement. Mossey
  21. Hi DanielBoondock, Blake works by himself and is the owner of Triple B Detailing. He works one project at a time so he’s 100% committed to the task at hand. I dealt with only him, start to finish and he was wonderful! We dropped our Ollie off on a Monday and picked it up on Wednesday. The wash, prep, and application was a full 10 hour day. We had everything except the awning coated, including the solar panels. He used Stark yacht products. It’s not really a double coat but is a double step process of base coat/prep, then topcoat. I highly recommend him! If you want more in depth information or have any other questions, reach out to Blake! He is passionate about his craft and I found him more than willing to help us by text/phone/email.
  22. I was corrected by my wife... the order of bedding components, starting from the "bottom", is as follows: (1) 1" pink foam insulation board, (2) Hypervent layer, (3) OEM Cushions, (4) 2" memory foam, (5) Wool topper, (6) Super Cool Comfort Mattress Pad, (7) Full-size fitted bottom sheet. The 2" memory foam was a hand-me-down from another family member. It is just a piece of uncovered, unlabeled, unbranded memory foam. We had to cut the two rear corners with a large pair of shears to match the curve at the back end of the Elite. The "Legends Hotel Wool Mattress Pad - Natural, Full" came from here a long time ago when it was significantly less expensive: https://www.thecompanystore.com/legends-hotel-australian-wool-mattress-pad/11027D-F-NATURAL.html The "Columbia Super Cool Comfort Ice Fiber Mattress Pad" came from here, also a long time ago and less expensive: https://www.kohls.com/product/prd-3044533/columbia-ice-fiber-mattress-pad.jsp?skuId=63361129 At least for our vintage of Elite I, the rear dinette/bed is an "RV Full" size, which appears to be just over an inch narrower than a standard Full size mattress, and has the 2 curved corners at the rear of the camper. We did not modify the sheepswool pad or the mattress pad; they just fit a bit sloppy on the slightly-less-than-full-sized "RV Full" bed. Clearly what is "comfortable" varies from person to person. This has been working for us; hope you can arrive at a bedding configuration that works for you.
  23. Take a look at Veritas Vans Starlink mounts, I have the magnetic mount version with bolt-on handle for the Mini and very pleased.
  24. Yeah pain to get to the valves for sure. In the ā€˜26 layout its well thought out at least. I think they designed it to easily switch between regular use (either city or pump) and boondocking mode (pull water from jugs into the tank). The two modes are reversals of the other, just switch all the valves to the other setting, don’t need the graphic. Winterizing/sanitizing are the oddballs but that doesn’t happen a lot They could do a Nautilus panel but it would involve a lot of extra plumbing which is more places for problems. I think it’s a fine solution, the bed is light.
  25. 189 here šŸ˜… If you have an Apple watch there’s an app that puts it up as a widget (complication?) At this point fun to watch it count down, very soothing …
  26. I’ve got dual awnings and am happy with the built in gutter system. This 8.5’ ladder is small and easy to work with, and is the perfect height for the Oliver. No problem to keep the gutters relatively clean, only bother is getting a pressure washer up there occasionally for the dirt. https://www.amazon.com/dp/B0BJF4PXM2 But the gutters do mean I get brown trails at the four edges. It took a bit of work to buff those out before clear coating, and I hope the oxide will make it a non issue now. Regardless I’ve been thinking if there was a way to have a kind of downspout on the edges. Maybe there’s a 3D part that could be put there while it’s stored. Probably over thinking it
  27. The few times so far when I had no connection was a blessing I have to admit šŸ˜…
