  2. Must have been getting tired last night! Truma in the title made me think HWH since there have been so many posts. Today I clearly see 'furnace' in title and body of post. There is something called a "wall cowl" and several flaps in this system. One of them is banging when it changes speed producing this sound.
  3. Today
  4. @Boudicca908 Check out this YouTube video by "The Trailer Smith". It's 1 of about 5 that he has put up. Then check out his other trailer video's, for instance, search for "brakes". All of his videos that I have seen have been very informative. Mossey
  5. Do you think this is the right one? https://www.amazon.com/gp/product/B008DREZYE/ref=sw_img_1?smid=ATVPDKIKX0DER&psc=1
  6. I agree this video illustrates a problem with the water heater; however it doesn't address the issue with the furnace.
  7. Will now has much better equipment for testing. It’s perfectly fine to like a product, but it’s also okay to discover it’s actually terrible through testing and share your honest opinion. Some unscrupulous scumbag individuals at Dragonfly Energy are hoping to profit before the company fails, but I suspect their plan will backfire, and the company will still collapse. It’s unfortunate for the hardworking people who work there.
  8. Additional information - Temp this morning is 40 F degrees in Rawlins WY so I have time to track the cycles of the VarioHeat while enjoying morning coffee. (1) Re-reading the VarioHeat manual from our Oliver year (2023) it appears that the "The appliance always starts at the lowest setting. If this is not sufficient to achieve the desired temperature in the vehicle, the appliance switches to a higher operating level after about 5 minutes." (2) The "basketball" sound appears to occur more frequently at the state transitions between the low to high and the high to low, not on the off to low state transition. (3) The sound seems to come from the outside wall area rather than from the point where the actual VarioHeat sits under the curb side twin bunk. After the completion of the laundry sorting process this morning I will pull the bunk apart and see if I can isolate further.
  9. I need to hit the road so don't have a lot of time to respond here, but will try to answer some of your questions. My photo of the junction box was made in a hurry, leaning over the mechanic's shoulder; didn't see exactly what he did to fix it (wishing I had inspected before he buttoned it up). When I open it back up (likely at Lake Catherine SP) I will take more photos. I don't know what that means. Many times, I have checked my lights by jumping in and out of the vehicle. Then I discovered the "Test Lights" function on the TV center console (how convenient!) and all lights function. A few times I have had someone around to just walk behind while I engage breaks, backup, running and signals and all lights seem to work all the time. I haven't seen any malfunction of the lights on TV or TT *** EXCEPT!! Shoot -- Did I fail to mention that when the TT is connected by 7-pin cable, even when the TV is turned off, the trailer lights SOMETIMES flicker? I made a video of that; sorry if I failed to mention it before. It stops when I use the key fob and LOCK the truck. One guy said it's just low power to features (like the lights for seeing the ground at night), other guys said it was something wrong. I described it as looking like a SHORT IN THE WIRING. *** ... so besides that detail, the only malfunction I have experienced (beyond the warning lights on dash) has been intermittent NO BRAKES -- I test this using the Brake Gain Control on the center console at low speed; it also brings up information on the driver dash location that shows +2.5 or +3.0 etc -- when the brakes are not functioning that information show dashed lines in lieu of the moving blue bar on the indicator (brought to us by human factors engineering, right? so we humans can trust that something is happening there, but not actually connected in any mechanical way). I am learning to feel whether the brakes are working or not. Quite a few times, they start out not working and then they kick in. It seems to be related to vibration; a lot of times the warning lights begin after I have come to a full stop (traffic light, railroad crossing) and then I start out again and they start dinging away. I have spare wago connectors (recommended for my tool kit by Mothership) but no butt connectors, on crimping tool. I will order a new 7 pin connector. ** somewhere online Chevy says to "be certain to use the correct 7 pin connector" for this vehicle. When I asked the dealership, they kept telling me they don't sell those. I said, I want the part number of the one installed by factory on my truck so I can find correct matching end; it took them 10 minutes to understand me. I don't know how important that is -- Non-Chevy people (including OTT) say it doesn't matter, but I wonder about the control modules and how persnickety they are ** HOWEVER, since my Oliver operated without a hitch for three years, I figure whatever OTT installed was fine. (haha pun intended) I agree. Nothing worse than a ghost. I plan to do the U-Haul test. Might not even need to leave their parking lot, but I hope to get some sightseeing in while there (if I can manage working around the deluge that is coming). I will also look for an ammeter; it might also be useful to me for radio work. There seem to be quite a few different types, so if you can, recommend some minimum qualities (clamp-on, I see). Will order this. I can ship to my friend (fellow Oliver owner) in Cimarron. Gotta go. Thanks to all for the continuing help.
  10. Thanks @jd1923 - We were outside the recall numbers on the water heater - now I have something else to look for (LOL) 🙂 However, this is the air heater rather than the water heater. Same manufacturing (lack of) procedures could apply. I'm going to try to find any diagrams to of the overall system so I can possibly get an idea of whats in the airflow path that could stick / fail and cause the thumping noise.
  11. What a bunch of clowns!
  12. ……and here. What a shitty company!
  13. Be very careful my friend! Certainly, take a look inside.
  14. Excellent work! You got a lot done today. 😎 I have no idea how long these bearings are good for once they give the first clue. We're going to find out though, yours being the first experience on our forum. Some of y'all who boo-hooed my bearing replacement thread, time to rethink your position. A little noise in reverse. I think that's better than noise going forward or both directions. I would continue on your planned trip. Every day or two when you're leveling, lift that wheel and give it another spin. You have pinpointed your issue and can see how it progresses with miles towing. Exactly, there is no need. My bet is you'll get back to Texas on that bearing! But what do I know? If it gets bad, the bearing is easy to source, and a good trailer shop can replace it. I'll link my bearing replacement thread below. An Authorized Dexter Reseller should be able to replace it under warranty. You have a 2022 date on that axle and given the 5-year warranty is correct, you should be covered. I do not believe there is an original owner clause but find the limited warranty statement online to understand your rights. OTT, another authorized shop or Dexter direct. Your choice, OTT will just take more time. I'd go with a local authorized shop, hopefully back in Texas. If it gets bad when you're still in Wyoming, you always have the Alcan option. I usually forget it's Saturday too! If needed, you could call ahead to order the part. If so, send them your label picture. BTW, Dexter may not provide warranty replacement for a minor squeal. It needs to get worse and truly fail, the noise will be somewhat louder! 🤣 Don't wait 'til you get home. Given they were correct and Alcan just reinstalled them a bit tight, they have not yet been damaged. Loosen them as soon as you get a chance. They're Nylok nuts and will stay put. You'll be under the trailer with your torque wrench anyway, LOL! The rubber should oval-out some but not mushroom over the support metal like in your picture. I see 7 threads on that stud and 4 +/- might be the right count. Make them all the same. Buy new bushing sets later if they get bad. Keep us posted and do enjoy your trip! So cool, you got this worked out quickly! 😎
  15. Sorry John, somehow I missed this when you posted this earlier! This is turning out to be my lamest mod! I usually do better. Dudley came up with the switch idea, and I didn't take the time to realize the light wiring would come in below the vanity countertop! So I have the doghouse mount with wires showing, new switch hole drilled... I'm bummed. 🙃 I was at first thinking of another porch light up front at the same height as the others. When that didn't seem right, I did not think of mounting something lower. Yes, for sure you can do your idea! You could pull power and put the lamp fuse inside the jack head. You would run the switch leg down the jack post, along the incoming line with the 30A fuse. Catch ground inside. Some kind of loom would make for a clean installation to cover the two wires and the jack fuse. You could use the same lamp as the porch lights. There is also a surface mount version of the light I purchased for the front. I just finished making my custom light bracket today. I'll post a picture when I get it installed.
  16. Yep - me again. Reset 2.0 / Hull 1365 2023 LE II. We are week into a two week loop, and I seem to be finding all the weird noises in the trailer. This one is the furnace. Rebecca describes it as "someone bouncing a basketball." When the heater first comes on - regardless of just being turned on or cycling based on the temp, there is a metalic flapping sound that repeats for a minute to two minutes under the curb side bed. It sounds like something flapping up and down to me, Rebecca is sticking with her basketball metaphor. It does not happen everytime, but I can't establish any type of pattern so far. Sometimes it happens as the furnace starts, just now it make two thumps as the furnace shut down. Any thoughts or suggestions on what to check welcome. It's a maintenance / laundry day tomorrow, so good time to look at it.
  17. I for sure know that "Duhh" feeling. Hope it works out well for you Monday. GJ
  18. Started calling at 7:30 this morning. Made three calls before I realized that in the real world it's Saturday.🤦‍♂️ Will try again on Monday.
  19. Test completed. All wheels turned silently, except the curb rear wheel. On that wheel forward rotation is silent, rear rotation (as in backing up the trailer) generates a dragging squeaking noise from the wheel. Performed this test on all four wheels, including the curb rear indicated above. No movement, and I gave it my best linebacker effort. Did not perform this test given that I had isolated it in the first test. @jd1923 based on my understanding of your troubleshooting matrix, this is pointing towards bearings. I did get a photo of the label on the rear axle and included it below. (I also took a shot of the bulldog shock attachments while I was down there. Thoughts? It looks like they were reinstalled a bit tighter than I had them originally. May pull and replace with new rubber bumpers when we get home. Given that we are second owners on Hull 1364, should I contact Dexter or Oliver about the potential warranty claim? Or am I out of luck on the axle waranty?
  20. The plot thickens. Louis Rossmann weighs in. https://youtu.be/lrORu-N6erY?is=OYjAWpKF-BPF1lrE
  21. Would be pure speculation. When we sold our previous LE I, the new owner got spreadsheets and the handwritten logbook that's like an airplane's log. We didn't receive anything like that, just some vague contradictory statements about how little the trailer had traveled and the distant places that they had visited. Based on several other items (shocks, refrigerator, plumbing) I have my opinions and speculations. I have tried to go through (with the help of the smart people on this forum) each system and bring it up to better than specs. Bulldog shocks, new refregerator, etc. I also try to give back with designs for installing the GasStop units on an LE I and will eventually get around to posting my refrigerator fan design that has a temp sensor to run the exhaust fans when needed. The reason we purchased an Oliver is the community, the bunch of experienced travelers and engineers that will see a panic message on a Saturday afternoon and start throwing out helpful and thougtful troubleshooting tips. Besides the incredible engineering and reliability of our trailers, it's the community that sets our Oliver apart from the Grand Design sitting across from us and the Apex next door. Wow - this response got off topic. Road brain, or possibly the wide open spaces of Wyoming out the window.
  22. That’s only three years old! Any idea why they got so bad, previous owner didn’t grease?
  23. We have a fairly steep driveway, and the front is way up to get the trailer level. It works fine. I ordered a new foot plate from Barker.
  24. Wow! Happy 10th and 50th Mike & Carol from your friends at Ollie-land! 🤗
  25. Yesterday
  26. Our Oliver turned 10 last month. We will celebrate our 50th wedding anniversary this coming Friday. Time flies. Mike
  27. Next time at your storage, take a good look at the jack post to see if it’s straight and can fully extend and retract. If you need a new post, I’ve got one, could ship to you. 😎
  28. Ball was greased. I used a grease remover and cleaned it completely up to a nice shiney chrome finish. I took a number of photos and sent them to a tech at B & W and he didn't see anything strange on the ball.🙃
