Last September (2025) I mentioned this issue in another thread, and said I would post a new thread when I had it resolved. The thing is -- I don't have it resolved.  I've been chasing this for months, unhappily. So I am going to share the saga, I will try to boil it down into concise bits, and maybe some of our more mechanically inclined members will have some ideas and suggestions.
TV is a 2023 Chevy Silverado HD 2500 diesel truck.  Oliver is a 2022 Elite 2, bought new from OTT.
In early September 2025 I needed new tires. I dropped my truck off in the late afternoon at a reputable place in Pinedale WY. I asked them to check the spare while they were working on it. The following morning they called to inform me that my batteries were dead, so I needed new batteries as well. The next afternoon I picked up my truck; by the time I arrived back at camp, it was getting dark. I shut off the truck and discovered they had turned on my overhead lights and left them on (hence my dead batteries?)... In the morning I hooked up to tow to my next destination, and began getting alternating warning messages on my dashboard and center console: "Check Trailer Wiring" and "Trailer Brakes Connected"
I pulled over (not 5 miles from camp) and checked my 7 pin connector; it looked clean, was firmly attached, my trailer lights all seemed to be working. But the messages continued.  I could 'dismiss' these messages from the steering wheel, but they would pop back up immediately and they interrupted my view of my map on the center console, making it difficult to follow. In Denver CO, I had 10 days with family. I was convinced that something had happened to my wiring under the truck near the spare tire (wires, modules all in proximity.)  I took my truck to two Chevy GM dealerships; neither had time for me nor would they allow me to bring the TT on site, but each ran their diagnostic and both came up with these history codes:
B1325 Control Module Power Circuit Low Voltage, failure code 0x03;  C1114 Trailer Brake Control Solenoid Valves Control Circuit, failure code 0x00; and P0562  Voltage Low, fail code 0x00.
I call ahead to Amarillo TX dealership, explain the situation, guy on phone says he knows exactly what is wrong. Make appt. They don't do anything on Friday except change the oil; then the electrical guy is off for the weekend. I finally get the truck the next week, with this description: "Verified concern. Connected scan tool, found DTC C114 set in chassis control module, Checked trailer 7 pin connector for signs of corrosion, none found. Removed connector x188 at trailer receptacle and inspected for worn and pushed out pins, everything OK. Placed test lamp at pic c to ground and commanded low to high percentage with scan tool. Test lamp followed command from low intensity to high intensity change in bulb. Internal malfunction in k133 trailer brake control module. Replaced trailer brake control module and cleared DTC. Test drove to verify message did not appear on dash."  (They did test drive the truck -- 18 miles worth.) $400 bill. I hooked up my Oliver to pull out, and the warnings continue. All during this time, my trailer lights and brakes seem to be working fine, but the warning messages continue.
Fast forward to February. I hooked up for a short camping trip in Florida and the messages return.  **I should note: I can't keep my OTT at home, and it's in a storage facility about 50 minutes north of my home. I'm not allowed to 'work' on it at the storage facility, and I can bring it on site to my neighborhood but only for a few days each year.**  I call OTT Service dept on May 3, to check their calendar in case I need to come up before I head west for the summer; they have openings both spring and fall. I am determined to dog this thing and to try to resolve it without having to tow 900 miles to Hohenwald before my trip west.
I have now taken the truck to 4 dealerships. They all say, "It's the trailer."  I take my truck to an independent mechanic and he says, "It's the truck, but the modules should be under warranty, so go back to the dealer for this."  Just to be sure, I find a Mobile RV Tech, tow the OTT to my neighborhood for one night, have him do his service (everything checks out fine on OTT, all working, but he finds something loose under the truck and the messages go away. But then they came back. This is exhausting.
May 2026 -- Issue was still there, and now my trailer brakes aren't working. That is a new symptom. I say not working, but it was really intermittent; I could test with the gain control on center console and sometimes working, sometimes not.
June 3, 2026 -- Back to dealer (45 minutes north of me), "It's the trailer."  This time they let me bring OTT in tow; but they still say, "It's the trailer."  A friend suggested another independent diesel mechanic that happens to be near the dealer.  From the dealership I towed OTT to Elite Diesel in North Fort Myers, it's 3:30pm. They make a cursory review for about an hour, and say they believe it's the truck.
June 4th, 2026 -- At this point, I am nearing departure date, so I haul trailer home, take truck back the next morning, get a ride home. Within 30 minutes they call me, "Can you tell us why your left side truck battery ground wire isn't connected? It still has the black cap on the end that it's shipped with, the cap on end of ground cable was never removed from the cable."  (I've made 5 visits to  Chevy dealerships citing need for regular service AND this electrical issue and NONE of them noticed this?)  My new mechanic thinks this has solved the issue. I get ride back up (45 min), retrieve the truck, drive home (45 min), connect the trailer, issue still there. I tow the truck and trailer both back to independent diesel mechanic (45 min).  I have work I need to do on my Oliver, so the mechanic agrees to let me do my work there (greasing my zerks in his parking lot) while they disassemble the spare tire, remove modules, check wiring in back of truck..... Now they are thinking something must be amiss in the trailer wiring. They don't stock that cable, so I might need to order one. I call OTT Service to inquire about what model or brand Oliver uses, since I've read that they are not all alike; Mike says he can't help me, transfers me to Tech Support.
Jerry at OTT Tech Support talks to me about the 7 pin cable. He says the 7 pin cables are really the same (but Chevy Service Manual warns to use the "right one" to correctly operate the Chevy.)  Jerry gives me some solid advice -- don't let them cut the head off the 7 pin connector; if head needs replacing, take it back to the junction box under the vanity, and other tips.  I have no idea about this junction box; I can't find it in my manual or wiring diagrams, but I'm not a mechanic or electrical engineer.  Jerry sends me a series of photos that show the route of the 7 pin cable in the trailer to a junction box inside the vanity cabinet. (see below)  He says "if it has to go farther back from there, it's a really big job."  (Oh boy.)
662E2D5C-2ED4-4BFB-9D2D-115CE0028D66.png.4b510f095974a99d55301428ea7db790.png    8ABA690D-B52D-4336-85E3-66CD7D01B74A.png.748283705a04efedf11d641996dbf25b.png
781A7255-AFCC-4B2C-9770-A4F0E88CB194.png.07d95353b60dceb3484a1caf78ff40e1.png    B25B8BBF-8BF1-408D-ACE1-856893D585E5.png.8fc1daefde0dff9e0c4aa3dc8d6ea1b3.png
F60B6C75-6DDA-4187-80E3-63CDEE4B8AA0_1_105_c.thumb.jpeg.3885dc9df3aa393041a21604fcd176b1.jpeg
My mechanic removed the vanity panel -- immediately saw two wire connections are loose though still have the nuts on the connection (below).  ** I need to find the correct caulk (and thanks again to Jerry for providing the name of it) Silicone: ASI 335 Advanced Adhesion 100% Neutral Cure RTV Silicone, WHITE.  Until that is fixed, I won't be using my shower, since it's open to this electrical junction box.**
51E227B7-E350-4A47-9168-731485DB1D6B_1_105_c.thumb.jpeg.da12159bafe8b8cfd6471f85f5e7142e.jpeg
He tightened that down. Then he tried to find the rest of the wire, crawls under the trailer, sees wiring going into the street-side front axle where the insulation has been rubbed off. I am dumbfounded, so I wriggle under there, stick my head around the corner; these are really small wires, going through a hole in metal without any protection; they rub on that hole in the metal axle, and I see there is no grommet on the hole. This doesn't seem right to me.
D975BE35-A233-4B62-950C-04ED1AF77270_1_105_c.thumb.jpeg.dd72ec5e6c1282623bfe88d38d67952d.jpeg
5826B7C6-50AB-4DDC-8BFB-C2ACB8CA5517_1_105_c.thumb.jpeg.cfdbaf3f192461eedf948b96c1ec4a0c.jpeg
He wrapped it with electrician's tape. I drove around, and the issue had cleared up. I drove around some more. No warning messages. I had not crawled all the way under my Oliver before, though I have been greasing my zerks regularly; I grease the zerks from the side, not from below. I gave my phone to the mechanic and he snapped a couple of photos that I shared with Jerry, before he put the tape on. I was ecstatic, and so happy that with 3 distinct wiring issues this mechanic was willing to dog it, find them and deal with them.
And THANK YOU JERRY.  This is June 4th. My reservations are all in place and I depart early on June 8th.
Yesterday June 10th, I called OTT Service again to inquire about whether there should be a grommet on that hole, and if so what size or could they ship them to me? Mike says he doesn't know if there should be a grommet, doesn't know the size and doesn't sell parts; transfers me straight to Tech Support.  I talk to Jerry -- my hero -- and I send Jerry the photo from my mechanic before it had electrical tape on it.  I had already purchased some Liquid Tape, extra electrician's tape and a box of Wire Conduit (that black plastic sleeve that is used all over the OTT).  At that point in time, I was not getting the warning messages any more, but I was not entirely convinced that the tape on the wires would hold up to thousands of miles of travel.  Jerry encouraged me to keep my eye on things, and I could get it repaired during my scheduled service in October on my way to the rally before I go back home to sw Florida.  Don't you know it, less than an hour later, the messages came back. My trailer brakes seem to be working, as well as my lights, but it's very disconcerting.
195FF61F-E241-407D-AF84-680A5C6AEDC8_1_105_c.thumb.jpeg.808f6c9a0e625f6e8608e50700743b3e.jpeg
I found a Walmart parking lot and spent about an hour crawling around under my OTT. I applied more tape, put on a piece of wire conduit (sleeve) and inspected the other 3 axles. (below - you can see OLD piece of sleeve on far right side, and my new piece of sleeve, and you can see Mechanic's tape and my additional tape which is shiny and not dusty.)
A5608E17-1F06-4259-B6FF-CAEEFC789EE0_1_105_c.thumb.jpeg.eb56c1b17056f83d3f63380a32ed0320.jpeg
61D91F56-3491-443F-85BC-450DD583D55A_1_105_c.thumb.jpeg.1dedf159384f0274281baa8414d26ee7.jpeg
Additional tape and new conduit sleeve (above) on the street-side front that the Mechanic repaired.
Other axels -- I added tape to one, shoved the grommet back into the hole on another (below).
56FF9D53-9A4A-4112-ACD6-A0C0152693DE_1_105_c.thumb.jpeg.61f12db50e9be45bb647b547b932d26b.jpeg
4DF3E2A2-A0B5-49D2-978A-4A1AC148811E_1_105_c.thumb.jpeg.c61119631b79b7c8ae9b74765c86ae95.jpeg
PHOTOGRAPHS & CREDITS:   Wiring into axle (2 photos by Elite Diesel in North Ft Myers);  Routing of 7 pin cable (5 photos by Jerry OTT Tech Support); the rest are my own photos, including my junction box with loose connections and my wire at axle with question about missing grommet (2 photos I sent to OTT); and then my 'discovery' of the grommets on the other 3 axles yesterday.
The warning messages continue though they are sporadic.  SO FAR the brakes are working (tested by using the gain control on my center console, when traveling slow speed).
I'm inclined to keep going on my travels. I have an appointment with OTT Service in October.
But I am interested in any additional input, and -- if for no other purpose -- I submit this for others who might have to figure out where that 7 pin cable goes and possible places to look. *I did try to search for other threads about this, but found none. I feel certain I've seen some comments about "usually trailer ground wire issue" but didn't find it.
Thanks to all who have been in touch, and especially JERRY at OTT Tech Support for his kind and timely service.
*** Please note: my wifi connection is via starlink and might be sporadic, and only when I'm not traveling. ***
Edited by Boudicca908
fixed dates
my Oliver has camped here
ALAZARCOFLGAIDILIAKSKYLAMSMOMTNENMNCNDOH
Certainly that hole where your brake wire exit the axel SHOULD have a grommet.  However, as a number of owners have found out - the brake wires that run through the axle can "short" due to the insulation wearing off INSIDE the axle where you simply can't see it.  Mike Thompson (among others)  experienced this.  The good news is that the fix is fairly simply and inexpensive - run a new set of wires on the outside of the axel(s).  I'm sure that Mike (or others) would be happy to give you the details.
Wow what a difficult time you have had.  Frustrating for sure.
I had a simular issue with my 2018 OE2.  Problem was the male 7-pin.  Art and I changed it out and it stopped the rogue errors like yours.
Many owners have had problems with the brake cable inside the axles.  John Davies used the cable protection like you used and ran the cables outside the axle with a bunch of zip ties.  He ran it on the back side to protect it some from flying stones.
One thing to try is to hook up your trailer to a different truck and see if they get a problem as well.  But finding someone willing to do that would be difficult.
Yes -- I have a friend at home who actually suggested that, but I didn't find a person available to test it that way. However, once I arrive in NM where I am meeting another Oliver owner, maybe she will be willing to test that out. No matter the cause, those wires being subjected to rubbing at the axles is ... no good. I will look for Mike Thompson (or a post, if he made one here on the forum?)  I am not on facebook.
Wow, so many variables and it's more difficult when you have to count on service technicians, to whom are not all created equal.
Yes, all 7-pin cables are the same. And yes, you can replace male head only (OTT is not always right). GJ did his and I did mine, been fine for 2 years. Changing out the whole cable is a bit of work. On my hull it's connected under the front dinette, past the wastewater plumbing (see pic). But who knows on yours since OTT hires random installers year-to year. In the picture you showed of a residential junction box, I don't see the trailer cable, the large black coupler cable, spliced down like you see in my picture.
If you want to be absolutely certain whether your issue is the truck or trailer, take your truck to U-Haul and rent the cheapest trailer with a 7-pin connector! There is a lot less liability in doing this than borrowing a friend's truck or trailer, and less money than an hour of labor, shop rate at the Stealership! 🤣
See if you get the error message when towing the U-Haul trailer. The logic is binary. If it still shows the error, then it's the truck. Tow the trailer long enough and if it doesn't display the error code, then you have a wiring problem with your Oliver.
So, if it's the Oliver, the next thing I would do is to test the brakes. Pull the pin on the emergency brake switch (the little cable you connect when hitching). Then take a clamp ammeter to the streetside, under the wheel well where you see two wires coming out of the hull, going to the brakes. Clamp onto only one wire, either wire of the pair. The ammeter should read about 6A on both sides (front and back axles). If it does, then all your brake wiring is good, so you can rule that out. (Don't forget to replace the safety brake pin when done.) If this test fails, then you have wiring issues at the axles, but don't waste time there unless you must.
If the above test is positive, then connect the 7-pin coupler to your truck and run the same test. If it tests bad, then the brake wiring from the coupler back is bad (open) somewhere. Your next step would be to replace the 7-pin male on the Oliver. This will likely fix any Oliver-side issues. You don't really want to replace the entire cable unless you have too and OTT would likely charge a fortune to do this job.
If towing the U-Haul trailer showed an error message, then it's your truck. What a shame 4 GM dealers cannot properly troubleshoot and fix the products they sell. If it was me, in a heartbeat I would disable the factory brake controller. Pull the fuses for it, buy an aftermarket Tekonsha controller and run new wiring to the female 7-pin outlet on your rear bumper (this is what I did from the start, since my older truck does not have a factory controller). This would cost about $200 in parts and likely 2 shop-hours to install, ANY trailer shop can do this, has the parts, maybe even the same U-Haul dealer could do it. I'd rather go to the dentist for a couple extractions than make a service appointment with an auto dealer, OMG! 🤣 And your story certainly shows why.
Keep us posted and let me know if you have questions on anything I suggested.
Best wishes, JD
Intermittent trailer disconnect messages have happened to a number of owners.  My problem was worn wires inside the axle.  Bryan @SNY SD UP in ND identified this issue first and shared his solution.  Simply replacing those worn wires fixed the issue.  I did go through months of troubleshooting and having my truck checked and tested at the dealer.  The thread below is one of several on this topic.
Trailer Brake Disconnect Message
Mike
Thank you very much for the linked thread!  Will read it when I get to my next destination later today. In process of breaking camp now and hitting the road. :)
It's interesting that my messages never reported Trailer Disconnected (except when I unplug the 7 pin connector, of course). My messages have always come as the pair:  Check Trailer Wiring AND Trailer Brakes Connected. Rewiring is sounding more and more likely to be on my plate in the near future, especially if it clears all of this up.
So, I read that link in the past and I have saved both of them for re-reading later. I will add a couple of notes:
Everyone associated with Chevy GM said "it's the trailer" and everyone NOT associated with Chevy GM said "it's the truck."
My 'last' auto mechanic was careful to check the ground connection at the bus bar (that was one of the first things he did). It all looked okay to him, and to me (though I don't know much about electrical).
I suspect the wires inside the axles are damaged, having seen the insulation rubbed near the wheels. And my mechanic said he found 'bare copper wire' which didn't make him very happy.
I'm surprised, given the issues encountered, that OTT hasn't changed the way they approach this brake wiring -- and maybe they have changed it? My trailer is four years old now.
Thanks to all for the help, links, comments, etc. I will be back.
My understanding is that the brake wires come that way from Dexter, Oliver just installs the axles as they receive them.  Mike
Edited by Mike and Carol
Knowing for sure is the first step and unfortunately nobody has helped you with this. Service companies often blame the other side to be off the hook, as they charge you an hour for nothing.
If your trailer is the issue, then you wasted time and money with 4 GM dealers. If tested properly, providing certainty "it's the truck" then you would be able to state this fact, not allowing them their BS. The U-Haul idea is a good one, though it seems perhaps you have dismissed the idea. There are other means, but since you are not an electrician it is a simple way for you to know whether your issue is in front of or behind the 7-pin coupler.
BTW, I've known great mechanics that can rebuild engines and transmissions, work perfect brake jobs but no way in the world do they know anything about a 12VDC system other than installing a battery, and you found a dealer that wasn't even capable of doing that!
Suspecting is not knowing! If you hire another tech to diagnose your Oliver wiring and this person does not test with an ammeter, then again you’re wasting more time and money!
If you are drawing 6A at the two main brake power feeds, then everything downstream is working. You only get a 6A reading if the two magnets on that axle are working, pulling amperage (power from the battery) and properly grounded. If you have frayed wires touching metal, you will read 6A. Instead, it could read zero amps if the circuit is open or read way high, live wire touching ground. Either condition is dangerous when towing.
It took me all of 5 minutes this morning to grab the ammeter out of my TV toolbox, walk to the edge of our property, pull the pin on the emergency brake, and connect the ammeter to run this test. Maybe the picture below will help in understanding.
Of course, on our Oliver it shows 6A (6.06 actual). I run this test every time I grease the Zerks and do any suspension maintenance. I also check to find 3A at each of the four wheels, so I know the trailer brakes are balanced, working evenly. But for you, if you get 6A on both axles, it shows you do not have a wiring problem below and must be in the trailer harness wiring.
I hope you try the U-Haul idea or in some way become CERTAIN in whether your issue is with truck or trailer. If it's the truck, you'e wasting a lot of time and money working on the Oliver, and vice versa.
The first mechanic you hired should have determined this months ago! Without knowing you will continue to navigate blindly. If it is your Oliver, I hope you finally find a tech that understands trailer braking systems and has some competency in troubleshooting 12VDC systems. Checking a ground is not enough and btw the brake wiring in your pictures all looks pretty good to me.
I'm sorry you have not found qualified help in so many attempts. Although, I understand you believe some of your service techs added value. Bottom-line it's been way too long!
I worked my way through college installing auto alarms, cruise controls, auto-start, keyless entry and high-end stereo systems back in the day (70-80s) when these accessories were all aftermarket additions. It provided me with a solid understanding of automotive 12VDC systems.
I've rewired EVERTHING in our Oliver for mods and to make many corrections where OTT wired things incorrectly. This post repeats a lot of what I wrote last night in my post above. I hope you take some of my advice to heart. In my shop, we'd be done with your issue in a weekend. I hope you take the proper next steps to end your living nightmare!
Edited by jd1923
I have no idea what gave you the impression that I have dismissed anything. I've done my best, given no space to "work" on my Oliver (not at home and not in storage) and given no tools (very few, I should say, because ALL of them have to be stored in the truck or the trailer, as I have no garage). I take everything here to heart. Please cut me some slack. I'm trying, believe me, to end my nightmare.
  • Sad 1
Yes. I certainly did.
And Yes it is my Oliver.  And yes I love my Oliver. I'm trying to take care of her.
There was a problem with the truck AND with the trailer. I wish I were an expert mechanic, but I'm not. I wish I had more space for tools, but I don't. I appreciate your posts -- they are usually very informative. I don't own the equipment, but I am trying to learn, and I lean on the forum members who have the expertise and/or experience to help me. I bought a caliper last year, but it wasn't very helpful to me trying to measure the size of that hole in the axle to figure out what size grommet I need, because the wires don't allow me to insert it fully. hahaha -- more wasted money, perhaps.  Service Dept couldn't / wouldn't give me a clue. So I ordered a box of 200 grommets off Amazon that are shipping to New Mexico where I hope to make progress on this thing. Unfortunately, that is the way this issue has gone for me. If I knew a lot more about these systems, I might not have been taken advantage of by lazy or incompetent people. What to do? Learn. I'm learning.
I have often wondered why JD and others have used "cable loom" for the trans axle brake connection upgrade.  I think a piece of 1/2 inch of CPVC (Hot Water, which is smaller in diameter than regular PVC) would work just as well, but give better stone protection.
Just musings from a RoF.
Maybe JD will illuminate.
It would provide access to those wires, without requiring disconnection at one end or the other, and that could be an advantage. Since I don't understand how they are connected at each end (or how to access where they are connected) I can't even guess how hard it is to .... access or replace them. Maybe it's not as hard as it seems.
I'm trying my best to help, reading your posts carefully, advising based on my experience. My written words are not always kind, but I am a caring person. I understand the frustration you have endured. Love of your Oliver is likely equal to my love of ours with all I've put into its care.
How is it you know this? Does "was" mean in the past? I believe the word AND to mean defects exist simultaneously in both truck and trailer. I cannot arrive at this conclusion from what you have written and it's more likely a one or the other issue.
Before you do anything else, please pull another trailer that's not your Oliver. If you get the same error message, even once for a few seconds on your truck while towing an alternate trailer, then it's the truck's brake controller system that needs service and you Oliver is fine as-is except for wiring cosmetics.
If you stay hitched to another trailer for most of the day, start and stop, tow it on and off several times and not a glimpse of the same error message, then Oliver service is required. You do not need garage or tools to rent a U-Haul trailer. Your issue is not likely the grommet on your brake backing plate, though yes there is a small chance it could be a brake wire shorting which the ammeter test could prove.
Edited by jd1923
You are correct. I know nothing.
My original post includes the fact that 3 separate issues were found and corrected by the last mechanic involving both truck and trailer -- and the fact that the warning lights disappeared and my trailer brakes worked for 3 solid days. Maybe you didn't see that part of the post -- or maybe you have concluded that none of those 3 things contributed to the issues?  I'm suspecting that the wires behind the vanity may have worked loose again, as I was traveling.
I cannot be certain that any of these issues were even partly the cause of the warning lights or partly the cause of the intermittent loss of the trailer brakes.  I'm going to remove that vanity panel again, and take a look at the junction box. And when I get to Lake Catherine SP, I will see if I can rent a U-Haul trailer in Hot Springs. It looks like one of them is open on Sunday and Monday.  I will let you know the result.
Don't be so hard on yourself. You have been dealt a bad hand and have done more on your own that most people are able or willing to do! This should not be the case on a 2022 Oliver and 2023 HD truck! Good thing you have a modern diesel truck. I imagine you are running the exhaust brake to compensate for the trailer brakes.
Taking another look at this photo, I don't see the large black cable coming from the hitch, but I do see all the wire colors associated with a trailer wiring harness. You can have an issue there, but there is no movement there like at the hitch or at the wheels.
Wago connectors covered with electrical tape, good work OTT! Wagos are not reliable. It makes sense the black is fused for the +12V (accessory or charge wire). This should be disconnected anyway.
The blue is for brakes. If you have a butt connector and crimp tool where you can reach in there, I would replace the Wago connector. I'd replace them all but not while on the road. So all trailer lights, turn signal lights, etc work except the blue wire? Again low likelyhood.
Intermittent loss is more likely either the electronics going bad in the truck brake controller, a loose connection at the 7-blade connector or a wire shorting on-n-off at the wheels.
The U-Haul rental is a pain but will give you a truck vs. trailer diagnosis. You may do this and find no error and then think you wasted more time, already thinking it was something wrong in the Oliver.
If you are able to test for amperage on the brake lines and found an error this would be easier with tool and testing knowledge. Problem with this option is it can test good when sitting/testing and then a bad wire can touch when moving, hence your intermittent issue. Nothing worse than intermittent issues.
I bought a truck NEW once in my life, the other 10 were all purchased USED. It had a bad trans, the torque converter would slip intermittently when hot. I took it to 3 different Dodge dealers for warranty repair. It always worked fine when at the dealer, at least that's what they said! Sound familiar to your experience? It lasted until it was out of warranty and then it failed on an AZ to TX trip. I was lucky to limp along on the final stretch, just barely getting to our Georgetown home.
You could stop at Harbor Freight in Little Rock and purchase a clamp-on ammeter. Test for amperage like in the picture I shared above.
I've got another idea. Forget about it for a while, use your exhaust brake and enjoy your trip. After you get to New Mexico drive another day to Prescott Arizona. I have an Oliver parking spot with a 30A hookup, good mountain water, free dump station down the street. I have the next 3 weeks off work and would work a couple days on your Oliver! We can tow my Oliver with your truck to see if we get the same error message. I will wire a new 7-blade connecter, new brake wiring at the axles or whatever is needed. I'm not kidding! I enjoy repair work and it's a genuine offer to help you. PM me if you want. If your issue is with the Oliver, I can and will fix it. Best wishes, JD
Boudicca:
JD is a outstanding standup guy.  Comes across some times a bit gruff (Don't we all?), but is pure of heart and giving to a fault.  And Chris can sure cook up a wonderfull mountain of pasta as well.
I went thru the same process as you, but had the tools and past knowledge to get to the bottom of it.  For grins I would suggest you purchase a new seven pin plug for spare parts or use with JD.   More than a few ownes like the one below.  With or without the cable.  It is one that John Davies suggested.  If you have a spare few inches in your existing you could just get the 7-pin end.  I had those inches and did just the end.  Next time I'll have to get the full cable shown below.  Amazon.com or Tractor Supply are both good sources for a lot of what we need.
The cable connections are easy, getting the "Right" wire into the proper peg of the cord is complex.  Having the same color to color at the box makes life a lot easier.
Good luck.
Edited by Geronimo John
I need to hit the road so don't have a lot of time to respond here, but will try to answer some of your questions.
My photo of the junction box was made in a hurry, leaning over the mechanic's shoulder; didn't see exactly what he did to fix it (wishing I had inspected before he buttoned it up). When I open it back up (likely at Lake Catherine SP) I will take more photos.
I don't know what that means.
Many times, I have checked my lights by jumping in and out of the vehicle. Then I discovered the "Test Lights" function on the TV center console (how convenient!) and all lights function. A few times I have had someone around to just walk behind while I engage breaks, backup, running and signals and all lights seem to work all the time. I haven't seen any malfunction of the lights on TV or TT
*** EXCEPT!! Shoot -- Did I fail to mention that when the TT is connected by 7-pin cable, even when the TV is turned off, the trailer lights SOMETIMES flicker? I made a video of that; sorry if I failed to mention it before. It stops when I use the key fob and LOCK the truck. One guy said it's just low power to features (like the lights for seeing the ground at night), other guys said it was something wrong. I described it as looking like a SHORT IN THE WIRING. ***
... so besides that detail, the only malfunction I have experienced (beyond the warning lights on dash) has been intermittent NO BRAKES -- I test this using the Brake Gain Control on the center console at low speed; it also brings up information on the driver dash location that shows +2.5 or +3.0 etc -- when the brakes are not functioning that information show dashed lines in lieu of the moving blue bar on the indicator (brought to us by human factors engineering, right? so we humans can trust that something is happening there, but not actually connected in any mechanical way).  I am learning to feel whether the brakes are working or not. Quite a few times, they start out not working and then they kick in. It seems to be related to vibration; a lot of times the warning lights begin after I have come to a full stop (traffic light, railroad crossing) and then I start out again and they start dinging away.
I have spare wago connectors (recommended for my tool kit by Mothership) but no butt connectors, on crimping tool.
I will order a new 7 pin connector.  ** somewhere online Chevy says to "be certain to use the correct 7 pin connector" for this vehicle. When I asked the dealership, they kept telling me they don't sell those. I said, I want the part number of the one installed by factory on my truck so I can find correct matching end; it took them 10 minutes to understand me. I don't know how important that is -- Non-Chevy people (including OTT) say it doesn't matter, but I wonder about the control modules and how persnickety they are ** HOWEVER, since my Oliver operated without a hitch for three years, I figure whatever OTT installed was fine. (haha pun intended)
I agree. Nothing worse than a ghost. I plan to do the U-Haul test. Might not even need to leave their parking lot, but I hope to get some sightseeing in while there (if I can manage working around the deluge that is coming). I will also look for an ammeter; it might also be useful to me for radio work. There seem to be quite a few different types, so if you can, recommend some minimum qualities (clamp-on, I see).
Will order this. I can ship to my friend (fellow Oliver owner) in Cimarron.
Gotta go. Thanks to all for the continuing help.
@Boudicca908 Check out this YouTube video by "The Trailer Smith".  It's 1 of about 5 that he has put up.
Then check out his other trailer video's, for instance, search for "brakes".  All of his videos that I have seen have been very informative.
Thank you very much!
On my way to UHaul place.
Update: I called before driving. Oh well… No trailers available today, but reserved for tomorrow. I think I’ll take a walk. Lake Catherine SP is gorgeous.
Update.
Lake Catherine SP is one of our favorites!  Mike
Doesn't matter. Your mechanic thought this was the correct junction box and all the right colors are there for a trailer wire harness.
This is referring to my comment on the black wire. The black provides constant 12V positive. In a cargo trailer that has no batteries it's used to power interior lights from the TV battery. In the Oliver and perhaps other travel trailers it uses the truck batteries to charge the house batteries. OTT disconnects it when installing LiFePO4 batteries. I believe it's a dumb and perhaps dangerous practice since a light gauge wire should never be used for this purpose. Anyway, this is not your issue.
The only thing that connects power from your TV brake controller to your TT brakes is the blue wire. Just check to see if the blue wire connection tight.
Do you think this is the right one?
No, the Amazon link you provided has both male and female ends, its listyed as an extension cord.
If you want to replace the male end, head only, get something like this. If the issue is at the truck to trailer connection only then this is the easiest route. Only takes an hour to replace this,
Amazon.com: MECMO RV 7 Pin Trailer Plug Splice-in Replacement Trailer Side Male End 7 Way Round RV-Style Trailer Light Wiring Harness Connector, Heavy Duty 7 Prong Trailer Wiring Tow Plug for RV Boat Trailer : Automotive
I like the idea of this one since it has a waterproof cable gland built into it, but it would be too long to fit on my truck.
Amazon.com: Oyviny RV 7 Pin Trailer Plug with IP68 Waterproof Seal, Detachable 7 Way Round RV-Style Trailer Side Connector 7 Point Trailer Wiring Plug : Automotive
If you need to replace the entire cable from the male 7-blade connector all the way back to your junction box under the vanity, you need something like this:
Amazon.com: CheeMuii 7 Way Trailer Cord Heavy Duty 8 FT Trailer Wiring Harness Kit 7 Pin Trailer Plug Inline Wire Harness Cable for Trailers RVs Campers : Automotive
Amazon links are to show examples. I'm not suggested these products specifically. No way you need a GM part and the picture of a part description you showed above is a combo 7-pin and 4-pin unit (4-pin for little trailers without brakes).
You asked RE the clamp ammeter? I purchased a more expensive Klein product, their rugged version, but any will do just as long as it reads AC/DC, for the 120VAC systems and 12VDC systems we have on the Oliver. This one looks decent.
Amazon.com: Klein Tools CL120 Digital Clamp Meter, Auto-Ranging 400 Amp AC, AC/DC Voltage, Resistance, Continuity, Non-Contact Voltage Tester Detection : Industrial & Scientific
Excellent - You'll know more tomorrow!
Not sure if we should be routing for the error to show with the U-Haul trailer or not! If it shows, then the issue is with your truck, and 4 GM dealers already couldn't figure it out.
If you do not get a trailer error, make sure you give it a fair test. Pull it out, down the road. Turn your truck on and off several time. Pull the 7-blade plug in and out a few times. Still no error? Then we must conclude wiring on the Oliver side is bad.
Most U-Haul trailers have a 4-pin cable since they have surge brakes rather than electric brakes. Will that matter in the pull test you are suggesting?
2020 OLEll, Twin, 579:
