Girard remote battery removal
srthomsen replied to Kathy Tewart's topic in Mechanical & Technical Tips
Took ours apart to install new batteries and could not figure out how to reassemble it ! -
Nice shower! Being a man, and given our usual boondocking spots, I'm out there showering in underwear without a curtain. Chris showers inside but I'm outside whenever possible so I don't get the entire wet bath wet! When I do shower inside, I empty the room and then end up hosing the entire wet bath clean too! Most people do not realize dumping grey water is allowed in the National Forests wherever dispersed camping is allowed and when 200 ft from a water source (see USFS Dispersed Camping publication). I'm not certain, but I apply this rule to BLM lands as well. The high desert critters and bugs eat it up and by the next day you wouldn't even know it was there. Drain slowly so not to cause erosion, and an outdoor shower is a small amount of grey water let go slowly. š USFS Dispersed Camping_stelprdb5196126.pdf
You probably already know this but that error code relates to fuel or power supply issue. The suggested remedy is a system reset.
Aloha from Hull #1730
Happy Hour is 1730 replied to Happy Hour is 1730's topic in Introduce Yourself
Thanks, we appreciate that! We feel like kids at Christmas. Thursday can't get here fast enough. š -
We live in Maryville, TN. (next to Knoxville) -
Sorry - no Ukelele - but I do play music and I have been known to make a Mai Tai on occasion. š -
Happy Hour is 1730 changed their profile photo
Made in USA leaf springs
It's not a complicated job to do on your own but will take a bit of time and it helps if you have someone to help. I replaced all of my springs and associated hardware as well as the shocks last spring by myself out of necessity, (one of my springs broke on my previous trip). It helps to have a good impact wrench with associated impact rated sockets. In addition to using the Olivers jacks it helps to have a couple of bottle jacks for supporting and manipulating the axles (when lining things up). I also had a couple of jack stands on hand for additional security but luckily didn't need them. Just take your time and you'll be fine. -
Hummers in Prescott.MOV
Thanks JD, yeah been busy, sandwich generation stuff ⦠Thanks for the reminder about your post, taking notes, Iāll probably PM you once Iāve compiled them if you donāt mind correcting my homework That sounds more like it! I donāt mind doing it, shouldnāt be hard for old engieās like us but Iām getting pulled in ten directions at the moment so just wanted to pay somebody. Anyhow Iām mooch camping supporting some family again in a couple weeks so Iām thinking Iāll just do it then. Yeah at this point itās been enough effort spent talking to people Iām ready to call it sunk costs and just git āer done. Iāve got a couple good jacks, stands, a DeWalt torque/breaker bar, and as JD says thereās the rear trailer jacks. And hey saving myself $400/$900 I can pop for another tool or two for āfreeā, hmmmm ā¦š -
Alcan quoted me $145/hr, 2-3 hrs max for installing entire D52 axle assembly, springs, shocks, equalizer, erc. Lots of folks have stated they were in and out of Alcan around 2 hours, with rave reviews about quality of service. I too am a retired engineer and I plan to do this myself first chance I get, because I don't plan to go to Grand Junction CO for maybe a year or more. Saves money, aggravation, is not difficult, and does not require any special tools. I look on the bright side and consider these tasks kind of fun. Iām just going to do the Alcan 4-leaf springs, U-bolts, & Bulldog shocks for now, Iāll replace the axles later when I need brakes. I am re-using my Dexter Shackles and wet bolts, and may keep the EZ Flex too if itās in good shape. I already replaced bearings with Timken.
Welcome back, Dan! Too bad the fires kept you away from getting to Grand Junction! Wow, labor cost more than the springs themselves! I did the axles too which makes it a different process. Doing one spring at a time should be easy enough. PLEASE don't let anybody here tell you not to use your rear jacks to lift the Oliver! Then use one jack stand on the axle end where you are working. Have the Oliver hitched to your tow vehicle on as level a spot as you have. I know Art @MAX Burner did his, springs only, first but I could not find his post. Best wishes, JD
OK, so I ordered the springs in springtime and made an appointment in July when weād be in Utah near Grand Junction. But then they got a series of wildfires all throughout that area, my wife has PTSD from us going through them at home, so we cancelled the trip. Alcan wanted steep fees for holding on to them until we could come again next spring, no good (I had already paid for the springs per their requirement when you order). So I paid to have them shipped out figuring a local trailer suspension shop would have no problem with it. Wrong - they wonāt install ācustomer supplied partsā. They want to sell you the parts themselves, sigh ⦠OK so then Iām trying my local garage, near where I store the trailer with easy access. Great folks, used them for lots of stuff, but they donāt normally do trailers. Gave them all the information, they thought it looked doable for $1500, but I should check if theyāre ballpark. AI search of this forum gave more like 300-500 or so. He said $900/minimum at a upcharge for (again), customer supplied parts and wouldnāt do it for less than four hours @ 250/hr. Grrrrrrr Thereās another shop I can try locally, or I could take them BACK to Alcan next year, but Iām getting frustrated and thinking about just installing the damn things myself. Iāll troll the (38 page!) thread for DIY install. Anyhow feeling down at the moment, looking for advice thanks - Yesterday
DCmomma joined the community
Hi Oliver Family.. Itās been quite a while since I last posted around here, but I just finished a quick little mod for the exterior shower station on the ILOVHER. I do use and absolutely love my wet bath inside the trailer! But before the forum gray-water police sound the sirens: having managed a National Forest campground for five years, I promise I know the rules about gray water and where it belongs. I know there are plenty of places out West that actually permit surface gray-water disposal (and, funny enough, with the wildfire season we're having, the ground could probably use every stray drop). For this upcoming trip, I'll be boondocking in a private field for 12 days, and the owner doesn't mind me showering outside. I'll be using organic, biodegradable shampoo, and with no dump station for miles, keeping gray tank fill to an absolute minimum is the primary mission here. I considered one of the standard pop-up privacy tents, but having used a bicycle tent for camping, I could already envision the poles, stakes, folding/unfolding and general tent wrestling that would be involved. I was looking for something much simpler ā something I could put up in a couple of minutes and take down just as quickly. I also wanted to avoid the usual problem of routing the shower hose into a privacy tent. You either have to run the wand through the main zipper opening, which can make the entrance/exit awkward, or start modifying the tent itself. Then I stumbled across these ratchet-style suction arms, and I immediately started thinking, "Oh, I can do something with these!" They reminded me of the SeaSucker-style mounting systems, and the Oliver's smooth, gelcoat fiberglass seemed like the perfect surface for them. I was so excited about the idea that I put the whole thing together and actually showered in my driveway last night just to test it out. š And honestly, I think these are going to work perfectly! The Setup: Ratchet-style suction arms: I found these folding rack arms on Temu. Say what you will about ordering direct from China, but the mechanical ratchet suction on these things locks onto the fiberglass extremely well. Theyāre designed to hold weight and, so far, theyāve been remarkably solid. DM me if you want the link to the product. Curtains & rings: I used standard shower rings through the cutouts and repurposed heavy shower curtains I already had from a previous project and the bar that goes between the mounts is a simple tomato stake zip-tied tight to the ends. (I may reconfigure that at a later date with tool clips) No modifications to the Oliver: Nothing is drilled, screwed, glued or permanently attached to the trailer. The whole thing takes less than two minutes to set up, packs down flat, provides total privacy (other than wind, LOL) and gives me direct access to the Oliverās outdoor shower faucets without having to wrestle with a tent or poles. I even have a suction mount for the shower wand. Please note that I have replaced the original ss shower hose with one that is 120" on my ILOVHER. Attached are the suction arms mounted to the Oliver and the full enclosure deployed. Iām pretty pleased with how simple this turned out!
Steph and Dud B replied to Kathy Tewart's topic in Mechanical & Technical Tips
I remember carefully prying it open. PITA and a poor design. -
On second look, the length is certainly different! Epoch 300 Ah L13.77" W7.59" H9.76" and 57 LBS Vatrer 300 Ah L15.12" W7.64" H9.76" and 55 LBS Given the length of the Vatrer and the 14" wide battery tray in our Olivers... Only ONE (1) Vatrer 300 Ah battery will fit in the battery tray, NOT two! This can limit upgrade potential, but you can just barely fit three (3) of these in the battery bay with the tray removed, like I did mine. 900 Ah heated with Bluetooth for $1,800 is an amazing deal GIVEN these prove to be of good quality with long life. I spent $2,817 total for 900 Ah Epoch but list price today is $3,747 plus tax (1,249 each). Epoch used to give 10-15% OFF, these days it's more often 5%. One 300 Ah battery is one thing, and sure beats 200+ LBS of old AGM batteries! Though I'd love to see an Oliver owner mount 3 Vatrer batteries, 900 Ah for only $1,800! Watch this item. When they get popular like Epoch, they won't be $400 OFF anymore!
Kathy Tewart started following Girard remote battery removal
Girard awning remote battery change-can someone tell me the correct way to remove the battery compartment cover in order to change batteries? I find it extremely difficult.
- Last week
LasVegasOllie joined the community
I have not seen this one on the forums before. I have a ticket out to Oilver support, but I thought I would post here in case someone has the "easy button." I also tried Truma, but they are closed for the weekend. At the very least, as I figure it out, it will be here for others to reference. E8H seems to be either a fuse issue or something off with the gas. I have checked the control panel fuse, and it is fine. I cannot find an inline fuse. I have turned the heater off and back on. I have also turned the gas shut-off switch off and then back on. I have even reset the CP control panel. So, no luck. I have verified that gas is flowing, as the water heater works and the stove does as well. I have also verified that the vent to the outside is not obstructed.
Looks like an Epoch clone from the outside, same casing and handles. But it's what's inside that matters and we won't know until Will Prowse cuts one open for review! 𤣠https://www.vatrerpower.com/products/vatrer-12v-300ah-bluetooth-lifepo4-lithium-battery-with-self-heating-200a-bms-supports-low-temp-charging-4-f-5000-cycles-2560w-power
Let us know how this lithium battery does for that price.. my AGMs are 4 years old now , might want to upgrade soon. Stay safe out there..
@skipster .. i have a Elite 1. Also. I cut a 6 inch opening, installed access hatch. Can get the bypass valve much easier. When i got our Oliver back in 2022 . I told them to move the hole they have back then closer to the valve.. dont know if was ever done. I know the pics i see of the LEII there is more room there, reaching from the top hatch panels under the bed.. i hope you get it fixed..
Scott_Kisling started following MaxxAir Fan Cleaning
Iāve noticed too.
water system leak at hotwater heater
Steph and Dud B replied to Skipster's topic in General Discussion
Glad you're getting it fixed. I have trouble reaching/turning the bypass valve, too. Very stiff.
