  2. Yesterday
  3. Just had our Alcan Springs installed today, along with Bulldog Shocks on our 2022. The Dexter Springs had started to flatten anywhere from 1/2" to 3/4". I had a spare Dexter 4-Leaf spring that the arch measured at 3-3/4".
  4. Same with us so we just put down the 21st in the oliver form.
  5. We just registered. FYI: The Oliver on-line registration doesn't accept arrival dates before the 21st. but we're arriving on 20 Oct.
  6. TECHNICAL SUPPORT TEAM answered my question -- I will leave it here, for others who might be asking the same. When you plan to decalcify the Truma AquaGo Water Heater AND Sanitize the plumbing system, there is a specific order that this should be done. It's logical, but I wasn't sure about any potential chemical reactions between the one (Truma Decalcification Tablets) and the other (a diluted water & bleach solution). FIRST -- complete the Decalcification process. Then flush the system with clean water. SECOND -- Sanitize the system. REMEMBER to put the system into BYPASS CONFIGURATION for the Water Heater during the Sanitization process. After Sanitization, flush the system TWICE with clean water. THIRD -- Fill the tank with fresh water Shout-out to Chris with Oliver's Technical Department for helping me out with this question this morning.
      • 2
      • Like
      • Thanks
  7. Thanks for that intel. Does anyone know if it’s the unit with heat pump, model # , btu rating, and if it’s a drop in replacement?
  8. I have been using the Cielo Breez Max smart thermostat for almost a year with no apparent issues, nor have I read any negative reports from other users (Oliver, as well as SOB owners) regarding potential harm to their RV air conditioners. Some have expressed concern with the power ON/OFF attribute of the Cielo and inherent longterm harm to electrical control and mechanical components. Proper configuration of settings to prevent ‘short cycling’ is paramount in avoiding said harm, whereby the compressor is allowed time to equalize refrigerant pressures and thus, significantly lessen subsequent strain on sensitive equipment. I am of the opinion 1) that Cielo has built in scheduling features by default to provide for necessary delays between compressor cycles, as do most RV thermostats, and 2) the soft start device pairs well with the Cielo to further lessen any longterm concerns I may have. I can honestly say that the Cielo has completely resolved the ‘humidity spike’ issues once experienced and exceeds my expectations as a replacement thermostat in our Oliver.
  9. I took a trip to Oliver on Tuesday with a prospective buyer. While we were looking at the 2027 model the salesman started the Dometic Freshjet, It was almost as quiet as the Truma AC in my Elite ll. We could easily converse with it running.
  10. One exception may be Dan. @DanielBoondock ???
  11. Last week
  12. If you are attending (or still thinking about attending) this year's Rally and have NOT reserved a campsite, be sure to do this ASAP. When I reserved my site a couple of months ago, there were not very many sites left to choose from. Bill
  13. Zane - Most of us do not have your type of shades on our windows. I'd either call and/or open a Service ticket. Both of these can be done by clicking on the "Service" tab located in the dark blue area at the top of this page. Good luck. Bill
  14. Rally Early Registration is open and saves you $ as price will go up later. Rally link: https://olivertraveltrailers.com/events/oliver-owners-rally/ See Jason on the Morning Coffee Youtube just released...he also discusses the Rally Registration and Fee's in the video.
  15. Thanks! Our 2010 did not come with a boondock connection and I'm going to have to build one of these before we start our big adventures.
  16. We have a new 2026 Elite II with the new pull down shades. One of our shades will only retract half way. The other three shades retract at least 3/4 of the way up. All of them are a bit finicky to use. Any advice on how to get the shades to retract properly? It almost feels like it a spring inside needs to be re-rolled to give it tension to roll up. Thanks-
  17. It had lost prime. I connected city water to boondock connection. Turned on water for 20 seconds or so. Connected my boondock hose to boondock port. Turned on pump. Sucked up a gallon of water lickety split.
  18. I carry a backup pump and have had to use it to fill through the normal fill port (not the rear suction port.) If you ever want to build a backup pump system...here's our article on that topic. Backup Water Pump Hope some of the comments like the one above about checking for air leaks have helped. Let us know your outcome.
  19. Assuming the valve set up is correct, and the pump screen is not plugged, them many have found that the boondock hose seal was worn or the boondock hose fitting was not FULLY and FIRMLY tightened. As a result, that connection sucks air and little or no water moves on board. Suggest double checking that connection and raising the boondock container as high as you can so reduce the hydrostatic head to the pump. This will assist in getting the pump to self prime. Ours takes about a minute a gallon to boondock onboard. Hope this helps GJ
  20. It is less than two feet.
  21. I suspect that is what happened.
  22. I've pumped from our 35-gal aux tank in the truck about 30 times. Only once it would not pump. My son was using the Oliver and he's new with RV stuff. He kept trying the water. Normally, when we here a first gurgle from the pump, we stop and refill the tank. Yes, when you loose prime, water will not pump regardless of the valve configuration. To fill water that one time, we had to tow to use a pressurized hose. I filled the FWT, then primed from the boondocking port and finally attached the hose to the City Water inlet to prime all faucets, the HWH and toilet. I wanted everything full! Also, we pump often when the truck is attached or at a distance, so I connect the 10 ft plus 25 ft hoses we carry, from truck bed to boondock port. Length of hose has not mattered in our case. However, OTT installs a basic water pump which we replaced with a REMCO US-made variable speed pump, with a little PSI and GPM bump over th OEM pump. 😎
  23. How long is the hose you're using to the container? It works best with a short piece of hose.
  24. Bolts and nico nuts installed and firmly tighten; problem solved. Much, much better than the couple of small wood (loose) screws as installed by Oliver...
  25. I assume you are trying to fill your fresh tank from a "container" using your rear boondocking port to suck in water through the on board pump. Q) Was the pump able to pump any water out of your tank before you started? It may have lost prime. If you lose prime you can often get it to reprime by either removing and checking the water filter (near the pump) or by opening and closing each of the valves and ending back on the boon docking configuration. Our 2019 Has this Valve Configuration...not sure if it's the same for you but just as a cross check for sucking in thru our rear port.
  26. It loaded about 1 gallon, but would not load more. Can someone suggest troubleshooting steps? The pump is running and the valves are properly set. Thanks
  27. I was thinking the same thing. You walk all over the “deck” then fold it up and it becomes an interior wall? I’ll pass.
