  1. Today
  2. I remember carefully prying it open. PITA and a poor design.
  3. On second look, the length is certainly different! Epoch 300 Ah L13.77" W7.59" H9.76" and 57 LBS Vatrer 300 Ah L15.12" W7.64" H9.76" and 55 LBS Given the length of the Vatrer and the 14" wide battery tray in our Olivers... Only ONE (1) Vatrer 300 Ah battery will fit in the battery tray, NOT two! This can limit upgrade potential, but you can just barely fit three (3) of these in the battery bay with the tray removed, like I did mine. 900 Ah heated with Bluetooth for $1,800 is an amazing deal GIVEN these prove to be of good quality with long life. I spent $2,817 total for 900 Ah Epoch but list price today is $3,747 plus tax (1,249 each). Epoch used to give 10-15% OFF, these days it's more often 5%. One 300 Ah battery is one thing, and sure beats 200+ LBS of old AGM batteries! Though I'd love to see an Oliver owner mount 3 Vatrer batteries, 900 Ah for only $1,800! Watch this item. When they get popular like Epoch, they won't be $400 OFF anymore!
  4. Girard awning remote battery change-can someone tell me the correct way to remove the battery compartment cover in order to change batteries? I find it extremely difficult.
  5. Yesterday
  6. I have not seen this one on the forums before. I have a ticket out to Oilver support, but I thought I would post here in case someone has the "easy button." I also tried Truma, but they are closed for the weekend. At the very least, as I figure it out, it will be here for others to reference. E8H seems to be either a fuse issue or something off with the gas. I have checked the control panel fuse, and it is fine. I cannot find an inline fuse. I have turned the heater off and back on. I have also turned the gas shut-off switch off and then back on. I have even reset the CP control panel. So, no luck. I have verified that gas is flowing, as the water heater works and the stove does as well. I have also verified that the vent to the outside is not obstructed.
  7. Looks like an Epoch clone from the outside, same casing and handles. But it's what's inside that matters and we won't know until Will Prowse cuts one open for review! 🤣 https://www.vatrerpower.com/products/vatrer-12v-300ah-bluetooth-lifepo4-lithium-battery-with-self-heating-200a-bms-supports-low-temp-charging-4-f-5000-cycles-2560w-power
  8. Let us know how this lithium battery does for that price.. my AGMs are 4 years old now , might want to upgrade soon. Stay safe out there..
  9. @skipster .. i have a Elite 1. Also. I cut a 6 inch opening, installed access hatch. Can get the bypass valve much easier. When i got our Oliver back in 2022 . I told them to move the hole they have back then closer to the valve.. dont know if was ever done. I know the pics i see of the LEII there is more room there, reaching from the top hatch panels under the bed.. i hope you get it fixed..
  10. And I took the King antenna to the OTTO rally and couldn’t find any willing taker’s, dang it! So I brought it back home and recycled it. Mossey
  11. Rifle State Park is nice too. There’s a smaller state park near the falls, looked quiet and peaceful.
  12. I’ve noticed too.
  13. Glad you're getting it fixed. I have trouble reaching/turning the bypass valve, too. Very stiff.
  14. Hey Everyone, I posed some questions about Alternator load with a DC/DC charger to Easton Ford at Inverter Services. Here is the info I got back from him: Q: When you install a DC/DC charger, what considerations should you have on the alternator in the Tow Vehicle? A: What I take into account is how much load you have on the alternator with all of your heavy electrical loads running, then I clamp the alternator wire to see how many amps it is pulling, I then Add 50 amps(DC/DC) and I see if that number is above 75% of the full capacity of the alternator. If its under everything is good. If it is over I would let you know that its over and if you didn’t want to do the DC/Dc I would take it off the ticket. If you still wanted the DC/DC it can be turned down to draw less from the alternator. Q: Can the Victron DC/DC charger be set to draw a certain amount of power. A: Yes, the Victron DC/DC charger can be turned down from 1 to 50 amps Q: My tow vehicle (2024 Nissan Titan XD) currently has a heavy duty 200 amp alternator. For me specifically, what would you recommend? A: For this vehicle I think one DC-DC would be fine no issues. If you want to have two DC-DCs I would want to clamp the alternator wire to make sure that we are not cutting it close. (2 dc/Dcs would equal up to 100Amps but it is highly programable to set it anywhere from 1-100) My plan going forward would be to have the alternator load tested and if it's within parameters, fine... if not, I will ask them to turn down the DC/DC charger to the appropriate number until I can arrange an alternator upgrade. Hope this helps to answer any Alternator questions anyone else may have. Happy Camping, Scotty
  15. Last week
  16. In Junei we enjoyed touring St. Elmo, Buena Vista, Leadville then up to Rifle CO. All were amazing. Oddly, the highlight was Rifle CO. For sure worth a few days to hike the Falls Trail and other smaller ones as well. Recommend staying at the Rifle City owned park for a couple of days. Not a bad drive to Grand Junction. Reservations recommend for weekends for sure. During the Monday to Thursday there are occasionally spaces. Primitive but nice camping for sure. It is full weekends by the rock climbers who call the area a meca for their sport. Be sure to hike down trail that follows the river to the Falls below. Explore the below falls areas for bear caves. Amazingly beautiful hike along the river. Takes about 90 minutes tops. GJ
  17. so after consulting my chat ai. i decided fixing it myself would be a big problem for me so i am taking it to bish rv repair in bozeman montana . also having them make it easier for me to access the inline valve for bypassing the tank. I cant get my fingers on it to turn it on and off. very tight. also anther problem is the black tank shut off valve does not close all the way and the dump hose is always full so hope they can repair these issues. so thanks and I appreciate the help and advice
  18. how do I access the fittings on tbe water heater. I can see a leak either the blue or red hose going into the insulated water heater. is there a utube video on how to get to those fittings. I have trouble turning the valve off for water going into water heater and now there is water spraying out of the blue hose connection.. how do I get to it to repair. my hands won't fit anywhere in there. do i take the styrofoam insulation off to get more room so I can repair the fitting. no idea. or should I take it to bish rv repair in bozeman,mt.. and let them repair it
  19. I noticed that Oliver is getting active on X.
  20. Lost Mine trail was our favorite!
  21. I got the Oliver into a tight spot on a rough road in this one...
  22. Problem solved! I took the Oliver to a highly-rated solar installer in our area and he solved our problem. Galway girl was correct, the internal fuses (there were two) in the Xantrex inverter were blown. The service tech had another identical inverter on hand (he had replaced it with a Victron) and used those fuses, since he didn’t have new replacements in stock. We also had him replace our AGM batteries with a Vatrer 12V 300AH Bluetooth LiFePO4 Self Heating battery (only $599) and a shut off switch, so I don’t repeat my reverse-polarity blunder when it goes in storage. Thank you all for your help. Heading up to northern MN for some mountain biking next week.
  23. Haven't bought anything yet, just still in the beginning of the planning stage. And that King antenna was removed within days of buying #45... Ended up bringing it to @mossemiwho also lives here in Tampa. Have to get my son off to college and complete the move to our new place in Floral City Fl, but once that's done, upgrades will be priority #1!
  24. The 3K model is enough, especially with your efficient Turbro inverter A/C (or your new Chill). I hope you bought one of the open box/used MP2s at half price! With the 4K model out, look for deals on the 3K models coming soon! I just looked again at the picture of your beautiful hull #45! Remove that king antenna and mount solar panels sideways. I'll bet today you can get near 800W up there! Install two drive motors so you can pitch the panels up on both left or righthand sides! Would be so cool. Consider my brain picked (just for now)! 😎
  25. Nice, though I'll probably stick with the 3k model for size and weight. I know it's not too much, but I don't think I'll ever need that much power in my rig. BTW, it won't be long now before I'll be adding solar and lithium- so be ready to get your brain picked! 😂
  26. Not that we need this much power, but a new Victron Energy MultiPlus-II 12/4k/160-50 120V just came out for $1,105 (no tax or shipping cost with this vendor). It's at a good price, having paid $997 for the 3K model July of 2024. Also, very good customer service with InvertersRUs. They serviced a warranty replacement for me on a small Victron MPPT SC. All I had to do was to email the pic of the Victron Connect app screen. They shipped a new one out immediately with return label. It provides 4KVA (3.4 KW) inverted power and can charge up to 160A. It's 2" longer, the same width and 3/4" taller, plus 7 LBS heavier than the 3K model that several of us have installed, so it will just fit in the streetside basement. With a whole lot of LiFePO4 Ahs, you could use this kind of power, if you're still running an ol' school single-speed compressor A/C and don't want to worry about what else you power up! No Soft/Easy Start needed with this bad-boy and you won't ever get stuck with a Multiplus failing for low voltage cutout. With required input as low as 9.5V your batteries may cutout before the MP2 ever will! Wow, checking my thread above on page 1, it was two years ago to the day, when I finished my installation. We are rarely plugged in and never turn it off, so our MP2 has run 24x7 for a full 2 years now, always providing service without issue. 😎 https://invertersrus.com/product/ve-multiplus-ii-12-4k/
  27. We also recently had Alcan upgrade our leaf springs and axles. Having a 2018 trailer we had the old 3000 lb axles and of course the 4 pack leaf springs installed by Oliver. It took us a while to decide to have the work done, but it was becoming obvious that we were due for a broken leaf spring or two without an upgrade. Upgrading the axles was an easy decision since the new axles provide better brakes and (hopefully) less maintenance. It’s a relatively quick process to have Alcan do the work; it takes about 2 hours. Lew told us his wife had worried about people driving to town to purchase a torque wrench and socket pulling a trailer so he now sells a decent torque wrench and the necessary socket to perform the required torquing for $50 dollars. He also provides a sheet with all the torque specs and is available for any questions. Tucker the technician who performed the work for us was available as well to answer any questions that we had. We did notice that the new running gear is much stiffer. We aired down our tires, and have done the preliminary torques. We would definitely recommend Alcan. Seems easier to have them do the work but as has been detailed by others, Alcan will ship so folks can do the work themselves or have a shop close to them do the work.Lew told us he is doing about 1 Oliver a week now, plus providing gear for the new Oliver Apex. I guess 38 pages of forum information pays off, for anyone who has the patience to read it all! Alcan suggested we go to Randy’s South Side Diner in Grand Junction while the work was being done. Decent local restaurant for breakfast!
