Entry steps steel rod, broken weld
srthomsen replied to Olive2Roam's topic in Mechanical & Technical Tips
Take both pieces to a muffler shop and have them weld them back together. - Today
Thanks SnackChaser! Hopefully this information will help me get my DC to DC charger working properly. I have been struggling with it since it was installed in May. I will try grounding to the body first versus to the negative battery cable. If this does not work, I will try using the 12V+ wire from the 7pin.
mossemi started following 2027 Florida Oliver Owners Rally
Krunch and I have reservations for 3-29 to 4-2. Thanks Toni, Mossey
Again Geoff, thank you so much for providing your electrical expertise and very well written, btw. I've learned a lot in reading your last two posts (reading them twice)! To extrapolate your math, the 50A Orion is therefore a 600W charger and should produce up to 42A (600/14.2). +42A output (+/-) is a number I've seen often (Orion on Victron Connect app). I've seen high 30s to low 40s regularly, with a high 40s number a few times. Our Orion is set on the full 50A output setting, wired with 4 AWG (I understand it's on the light side). To date I've counted on the fact that we get +40Ah for every hour towing. So, I recently have a different kind of issue... I installed our Orion 50 during March 2025. The TV alternator was also upgraded (output increased by 50A) and we're talking old-school alternator (not Smart). My truck gauges always show readings of 13.8 to 14.2V. We have traveled (exactly) 100 days in 1 1/2 years (LOL, checked the data) always DC-DC charging, always getting +40A until our last two outings. We ran a 5-day trip un-plugged needing a bit of A/C. Then we did a 10-day trip no hook-ups. Both trips we hovered around 50-60% SOC most of the time on 900 Ah total, by adding suitcase solar when camped and we ALWAYS have DC-DC cables connected when towing. We move around a lot, so DC-DC is usually all we need. We have rarely needed our suitcase solar since with DC-DC charging. Near the end of both trips we got down below 30% SOC, so I was checking the Victron app while towing which I had not done for awhile. No longer are we getting a 40A charge, instead recent readings were +29A +/-. I monitored it a few times while towing (didn't think to check history page). When our batteries were very low in SOC% and we needed DC-DC charging the most, it produced less. We used to get +30A sitting at idle, consistently and 40 when towing. Looking back, we only got this low in SOC% because the DC-DC charging was not performing to par! I thought loose connections or ground (because my installation has a truck frame ground), but I checked all connections and they were tight as when installed. It will be a while 'til I get to troubleshooting. We're not traveling until Jan. I need to just hook up, run it at idle parked at home and get the clamp ammeter out! It will be easy to read amps on the wiring from TV to TT (is this even a valid test? IDK). Testing ideas appreciated and thanks again. đ
My wife and I reserved a site. There are plenty available now, but considering itâs near Easter & Spring Break, it would be good to book it soon if you want to go. Looking forward to it!
Dean, I like that fan, it's a great idea and should greatly help the efficiency! I noticed that you're going with #4 AWG, which is undersized for 50 amps at the approximate 100â or more round trip cable run that you will need. You would be looking at about 1.3V of voltage drop, not including fuses, terminations and Anderson connectors that could add a few tenths more. #4 AWG is even marginal for a 30 amp charger. There is a common misnomer that #4 is the correct wire size because the Orionâs terminals are sized for #4. Thatâs because most of the installations are in boats, vans and motorhomes with much shorter runs. There are advocates for using smaller wire, but itâs not the best advice for a number of reasons, particularly if you're watching efficiency. You should be considering #2 minimum, 1/0 is ideal. You can terminate the 1/0 cable to a terminal strip on the negative and a fuse block on the positive, then use short #4 jumpers to the Orion. The jumpers wonât contribute much to the overall voltage drop. Cheers! Geoff
I must agree, I like my vintage gear onboard #110. I'm sure someday I may regret not being able to run my A/C off batteries, but I will still need a generator to re-charge those beastly batteries, or a truck that can do it IF I drive the next day. When these 2024 AGMs are used up, I'll upgrade the rig to all new Victron & good lithiums. We'll see how my retirement travels work-out for me.
Not that I saw, but the entire week for me was a blur.
Coddiwomple started following DC to DC troubleshooting
Boudicca908 started following RVera_10
The 2027 Florida Oliver Owners Rally will take place March 29 through April 2, 2027 -- 4 nights, checking out on Friday 4/2/27. This event is being organized by Jenni Rivera @RVera_10 and other Florida Oliver TT owners. The venue will be Salt Springs Recreation Area, located in central Florida. Salt Springs is a recreational jewel in the Ocala National Forest, and features pristine natural mineral springs. Activities at this location include swimming in the mineral springs, plus fishing, snorkeling, hiking and boating. Come join us for a friendly micro rally! Participants will need to reserve their own campground space through Recreation.gov found at this link: https://www.recreation.gov/camping/campgrounds/233920 Spaces are not being held for the event, so early reservations are recommended. Join the FL OLIVER TT MICRO RALLY Facebook group to find more details. This Oliver Forum Post is intended to mirror the information posted by Jenni on facebook, to serve those who are not on facebook. WHEN: 3/29/27 - 4/2/27 WHERE: Salt Springs Recreation Area campground, Ocala National Forest. Salt Springs is located 35 miles east of Ocala (I-75), 60 miles west of Daytona Beach (I-95) and 95 miles north of Orlando, Florida. CAMPGROUND RESERVATIONS: the window is now open for reservations at this location and winter is our prime season, so get your spots reserved now! https://www.recreation.gov/camping/campgrounds/233920 ** Please be sure to read about facility restrictions on their website before making your reservations. ** SCHEDULE OF EVENTS: look for future updates MONDAY 3/29 : REGISTRATION, campground checkin time begins at 2:00pm TUESDAY 3/30 thru THURSDAY 4/1 : group activities TBD FRIDAY 4/2 : checkout Improved venue map, courtesy Jenni. (The black and white PDF is from National Forest website.) Please note: @Boudicca908 does not monitor the OTT forum on a daily basis, and does not have any active notifications for incoming messages. Salt Springs facility map 73853_SSRA.pdf
Sorry, I do not have any pics.
While gathering information for this project, I also discovered that Victron has introduced a new Orion XS 12/12-70A model. It has the same footprint and mounting pattern as the 50A version but adds integrated cooling fans. Victron also slightly increased the terminal size, which should make it much easier to terminate 4 AWG wire. Getting 4 AWG wire into the terminals of the 50A version can be a challenge, so that is a welcome improvement for higher-current installations. It is pricey and I just recently purchased my 50 amp version, so not for me at this time.
Accidental duplication.
Thanks, Geoff. I appreciate all the information you've shared. I'm in the process of installing my DC-to-DC charger now, but I haven't begun working on the tow vehicle portion of the project. Your comments about the cabling requirements and the tow vehicle current sensor gave me some useful information to consider before I get started on that part of the install. I agree that the 50A Orion XS is significantly more efficient than the 30A version. Even with the improved efficiency and reduced heat output, I plan to mount my Victron Orion XS 12/12-50A DC-DC charger on top of Mobile Solar Consultingâs Orion Fan Module, which features temperature-controlled cooling. If youâre not familiar with this option, there are several YouTube videos that demonstrate the noticeable reduction in operating temperatures when using the fan module. For me, the added cooling is inexpensive insurance for a component that will often be operating under heavy load. Dean
Gj, the short answer is probably not, at least not directly. The smart alternator issues I described above tend to make the Orion cut in and out. A steady maximum of 22 A from a 30 A charger likely has a different cause. However, if your chargerâs negative cable goes straight to the battery post and bypasses the current sensor, then itâs worth correcting. Without a record of the current over time, itâs hard to know what your charger is doing at any given moment. Iâm assuming that the wiring is properly sized for minimum voltage drop, and that the battery was low enough to accept full charge. A nearly full battery wonât draw as much current and excessive voltage drop can cause other problems with the settings that I touched upon above. So even without knowing your exact conditions, it sounds like a heat issue. The Orion reduces its output when it gets hot. I had this with mine. Even with two cooling fans, my old 30 A ran scary hot at full load (running the trailer air conditioner while driving). Thatâs why I upgraded to the 50 A Orion XS, which is far more efficient and makes much less heat. Hereâs the math. Your 30 A Orion is a 360-watt charger at a nominal 12.2 V output But a lithium battery charges at about 14.2 V. So 360 W Ă· 14.2 V is only about 25 amps (at 104°F). Above that temperature, Victron derates it 3% per degree C. So with the air around the charger at 113°F, youâre down to about 22 A. See what I mean? Of course, this is all conjecture. First, Iâd recommend swapping the 30 A for a 50 A and turning its output down to match your cable size and length. I sold mine on Craigslist to a guy with an Explorer van, where it was better suited. Second, if you want to see whatâs really going on, run a load with engine running above idle, such as a small heater on low through the inverter. That keeps the Orion working at full output even if the battery is nearly full. Then put an inexpensive clamp-on DC ammeter on the Orionâs output cable to see the real output. The shunt only shows the net current in and out of the battery. It canât separate the chargerâs output from trailer loads or solar. Hope that helps! Geoff
DUSTOFF started following Twin Bed Conversion
RB, just catching up on this. Looks like yourâe waiting for a new hull. So this may not be a reasonable request. Do you happen to have any photos of this set up? Particularly the aluminum hangers?
Geronimo John started following DC to DC troubleshooting
Geoff: Could this be the reason that I don't see a charge rate at via the Ollie's Victron shunt more than 22 amps despite having a 30 amp Orion in play? GJ
Antifreeze CO2 & Propane Alarm
Geronimo John replied to HDRider's topic in Mechanical & Technical Tips
As have we. Not sure I could blame their demise on our winterization using Super Tech though..... -
Geronimo John replied to Olive2Roam's topic in Mechanical & Technical Tips
typo - Last week
remember story game
Going through what few pics that I took at this year's Owner's Rally, I was reminded of a visitor that was there each morning as I drank my hot chocolate.
that hopefully will
Bob, as you already figured out, conventional alternator voltages canât be applied to a smart alternator. They use a current sensor on the batteryâs negative cable that signals the engine computer, which throttles the alternator down once the TV battery is charged. That saves fuel, and 12.4 V while driving can be perfectly normal. Based on what youâve described, there are several possible causes for your problem. First, Iâd verify that the DC-DC chargerâs negative cable isnât connected directly to the TV battery post. If it is, the Orionâs current bypasses the current sensor, the computer never sees the extra load, and it never raises the alternator voltage⊠unless for other reasons such as a low TV battery. Some manufactures specifically say to ground accessories to the body for this reason. Many vehicles have a ground stud on the far side of the sensor for accessories, otherwise use the chassis ground point where the batteryâs negative cable attaches. Even if it worked before, it could be because the current sensor was seeing other TV loads that caused the alternator to increase voltage, and it wasnât noticed when it stopped charging. If the truck can see the chargerâs load independently from the truck loads, then the alternator should keep the voltage raised well above all of the thresholds. So it could have been charging when the truck called higher alternator voltage, but not otherwise. Second, the Orionâs engine shutdown detection works on voltage. My abridged explanation is that with the default âsmart alternatorâ settings, it starts charging at 14.0 V. A smart alternator idling at 12.4 V never gets there, so the Orion thinks the engine is off. Thereâs also a separate input voltage lockout setting (default 12.5 V) below which charging stops. At 12.2 to 12.4 V, youâre under that too. These thresholds are adjustable in VictronConnect, but thereâs a limit. Set them too low and the Orion can stay on and drain the truck battery when parked. Every vehicle is different, so some trial and error may be needed. It sounds like the Nissan system might have some unique quirks, but disabling the voltage control might be extreme. If fine-tuning doesnât work, an âengine-runningâ signal on the Orions Remote L Terminal will force the Orion on. Itâs there for this very reason. You must leave engine shutdown detection enabled when you do this, so it still turns the charger off when the engine stops. Victron describes several signal sources and recommends a true engine-running signal over a plain ignition wire. For your situation, a wire that goes dead with the key off is the best approach. In a trailer setup, this gets more complicated because it needs a third wire between the truck and trailer. Fortunately, the +12 V wire in the tow harness should work in most cases. Check it with a meter. It must be dead with the key off, and must not be live from the trailer battery with the truck off. Oliver doesnât connect this wire on lithium systems so you should be okay. Ideally, it would also be off with the key on and the engine not running. Otherwise it could drain the TV battery if key is left on. This wire is usually capped off near the inverter and itâs typically a #10 or #12 wire. Also be aware that undersized cables, poor terminations, and corroded Anderson connectors can cause âadditiveâ voltage drops that only show up when the charger is pulling heavy current. Corrosion builds over time, which could explain why it worked for a year and then stopped. This is where the âInput Voltage Lockoutâ setting comes into play. Itâs set it so that Vlock-out †Vshutdown â Vcable. The Vcable is the voltage drop in the wiring at full current. Victronâs manual provides an example voltage drop at 50 amps over a specific length of heavy cable. Itâs a surprisingly high voltage drop, so if you add any additional resistance from undersized wire, corrosion or poor connections, you can add tenths of volts more, and that can push you under the set point where charging stops. You or your installer can measure your actual Vcable with the Orion running at full current (Turn on Oliverâs air conditioner and use a temporary +12V signal on the remote L trigger). Confirm its running full amps on the App. Vcable is the truck battery voltage minus the Orionâs input voltage. Many people wing this and get lucky, but it can become a latent problem especially with marginal wire sizing. Another way to get around this it is to de-tune the Orions maximum output amperage. For example: I have wiring sized for an old 30 amp charger based on the length of the run. When I upgraded to a new 50 amp charger, I reduced itâs power output to 30 amps to match wire size, otherwise Vcable could be too high. Mine actually worked at higher amps, but the wire was getting warm which meant the efficiency was suffering and I was burning more fuel. Finally, itâs worth load-testing the alternator. Turn on all the big loads (headlights, rear defrost, blower on high) and check that voltage climbs to around 14 V and holds. An alternator shop can do a more definitive carbon pile test. Also do a ripple test, which detects a burned diode that would reduce output. You can check it yourself with a meter on AC volts, with the loads on. There are YouTube videos showing how. If the voltage wonât rise even under heavy load, a Nissan dealer can scan for codes to tell whether the problem is the alternator or the current sensor. Again, it might be true that the Orion has never worked to full capacity and it was just not noticed. It probably worked periodically over long drives enough to charge a partially drained battery. The Victron has a history function where you can verify its performance over time. It's a good tool for problems like this. Anyway, itâs been fun trying to write this out in layman terms. I hope it helps, Geoff
ScottyGS replied to Olive2Roam's topic in Mechanical & Technical Tips
Let me guess..... The person you spoke to has the initials MS...
