Sea Biscuit Rear Basket and Storage Boxes
John and Jodi replied to Steve and MA's topic in Ollie Modifications
@Steve and MA Steve, our last trip we did need to use our spare so we are re-evaluating our tools and the location of those tools and are considering a Sea Biscuit solution (front or rear, not decided yet). I hear you say that the basket does not need to be removed to remove the spare tire cover, but how difficult is handling the spare with the basket now extended an additional 4-5 inches? The spare tire and wheel is pretty heavy. It seems like the basket would be sticking out quite a bit and you'd be trying to lift the tire off and then put the bad tire on with all arm strength (a recipe for a bad back). Can you get close on the sides? Anyone else with a rear basket had to change a tire? -
Last week we were camping at a TX state park for our first outing since April. Around mid day the temperature was well over 93 degrees and we decided to turn the AC on. Had forgotten how loud this thing was but we had no other choice. Shortly thereafter a family with 3 children camped next to us in a tent. The next morning the neighbor ( visiting from Holland) came over, introduced himself, very polite and very respectful and asked if we could turn off our AC because they did not sleep the night before because of the noise. In desperation I started looking for options and decided to go to a close by Walmart store. They had a 6000 btu portable unit and looking at the size and measurements looked OK to me. Installed it at the very back between the two beds with the air exhaust and the moisture drain through the back bottom door, plugged in and it was an instant relief, noise level was very low, low enough to have a conversation and listen to the radio. Next morning my Dutch neighbor came over to thank me for not using the AC. Will try to improve the installation by building a removable “door” for the left rear storage compartment with an opening large enough to accommodate the AC exhaust and prevent potential critters coming in.
- 1
@Patriot thanks for the suggestion, here you go: https://www.campingworld.com/bauer-bluetooth-keyless-rv-entry-door-lock-124590.html?objectID=124590&queryID=46bc1a32228c9fdf516d0676ebf18aca&indexName=production_na01_campingworld_demandware_net__CampingWorld__products__default Also, E-trailer has a nice video review here: https://www.etrailer.com/RV-Door-Locks/Bauer-Products/BA53UR.html E-trailer also has spare keys for the lock too.
srthomsen started following Improved Service: Phone Support & Service Now Have Dedicated Teams
Important Update: Customer Support & Service/Parts Department Changes Dear Oliver Travel Trailer Family, As we continue to grow, we are making important changes to better serve you. Beginning September 5th, our Customer Support Department will be relocated to our production facility and will now be managed by our Plant Operations Team This change allows us to dedicate resources more effectively, ensuring you receive the specialized support you deserve. What’s Changing Customer Support Managed by our Plant Operations Team Primary Contact: Brett Johnson Handles phone support, warranty questions or warranty parts requests Additional team members will be added to strengthen support capacity Phone: 888-526-3978 (select Option #2 - Technical Support) Email: support@olivertraveltrailers.com o Hours of Operation for Phone Support Monday - Thursday: 7:00 am - 4:30pm CST Friday: 7:00am - 11:00am CST Closed Saturday & Sunday Service & Parts Remains at our Sales & Service facility Primary Contact: Mike Sharpe Handles service scheduling and parts purchases Phone: 888-526-3978 (select Option #3 – Parts & Service) Email: service@olivertraveltrailers.com Hours of Operation for Inside Service remains Monday - Friday 8am - 5pm CST Important Notes Starting September 5th, the Phone Support Department and Service & Parts Department will be completely separated. Mike will not be taking phone support calls, and Brett will not be scheduling service. Emailing either department will automatically create a ticket in their system. However, tickets are not shared between departments. Why the Change? As Oliver Travel Trailers continues to grow, we want to provide a better experience by having team members focused on specific tasks rather than managing multiple roles. This separation ensures that your questions and needs are addressed by the right people more efficiently. We appreciate your understanding and support as we take this step forward. Thank you for being a valued part of the Oliver Travel Trailers family.
- 5
Maybe post up a link to the exact model Bauer lock you purchased. It would help others if they decide to purchase. 👍🏻
Doesn't she look pretty?! 🤣 We ran two 30 mile test runs, U-bolts torqued now 3 times. Before the test drive today, I manually pushed the little self-adjuster gears on all 4 wheels. She was braking quite well today, so very nice after so little mileage. New D52 axles, new HD leaf springs, new EZ Flex equalizers, new wet bolts and HD shackles, totally new suspension! 😂
Re-attaching Aluminum Support Blocks to Propane Dog House Lid
Rolind replied to 2008RN's topic in Mechanical & Technical Tips
Sorry to reanimate an old thread, but my large support block fell off the propane cover on our last trip and by some miracle was balanced on one of the cross members on the bottom of the propane enclosure. I’m planning steps to reattach it and had some questions for those who have done this before. It seems that everyone has used epoxy but has anyone used a methyl methacrylate adhesive instead? It seems as if surface prep doesn’t need to be as meticulous if MMA is used instead of epoxy. For those that used epoxy, how rigorous does the surface prep need to be? I plan on removing all the old adhesive, lightly sanding both surfaces and then washing with water and the isopropyl alcohol. Would this surface prep suffice for epoxy use? Thanks in advance for the help and safe travels. - Yesterday
No complaints EVER on the LevelMatePRO+! Make sure you get the '+' model. Batteries, big batteries, we don't need no stinkin' batteries! You hardwire the + model to 12V in any easy location, like under dinette seat where 12V connections are right there. Know you'll never have to touch it again, leave it always ON, always working, always active when needed! 🤣
We moved back to our AZ home seven years ago after living for 12 years back and forth between two homes, where my tools were spread between the two and my truck. On Craig's I found large stand-up Snap-on toolbox and was lucky to find a huge, well made workbench setup that Adam and I disassembled to move and rebuilt it to fit a custom L-shaped layout around 2 stalls of our 3-car garage, the center stall being my workspace. I also found a used Tuff Shed for storage, so my garage would be solely an auto workshop, not junked up with storage items. I installed other standing toolboxes and cabinets, enough room for a major 45-year collection of hand tools and spare parts. Then I emptied every hand-carry toolbox into the larger stationery toolboxes. During a winter cold-spell I spent days sorting our every box and package I hade with nuts & bolts, auto parts, electrical and plumbing parts. , etc. I bought a case of blue plastic single-gang electrical boxes (cheap effective storage bins) to hold all the small screws, nuts & bolts, nails, crimp parts..., drawers full of them in mounted file cabinets. For years now to the present, I know where every tool and most spare parts are located. I return all tools to where they belong daily, unless I'm in the middle of a job I will continue the very next day. Spending considerable time in organizing your tools is well worth it. I get repairs done now in half the time, not having to hunt for parts and tools! In getting ready to work, climbing under truck or trailer, I think a hard 5-10 minutes and collect part & tools needed in flat plastic trays that I lay on the ground where I'm working. The other thing I bring, since I/we will always forget something is my phone. With Chris' office just inside our home from the garage entrance, she's nearby and often happy to help. 😂 She'll come out to hand me a tool or two, knowing its easier for her to do so vs. what it takes me to get off a hard garage floor, and then climb down again. I do mean the word 'climb' as the downs and ups are not as easy as they used to be! 🤣 We all prefer to work preventive maintenance at home vs. getting stuck on the road. I have enough extras that I've assembled a small dedicated toolbox and a plastic parts box for the Oliver. They sit in the bottom of my large truck toolbox along with a 3/4" breaker bar, cheater bar and other long items. Proud to be keeping our truck and trailer in good maintenance so that these tools just sit ready, and have not been yet needed, 124 overnights in two years with our Oliver! Hope to never need them, but I have what we need to change tires, bearings, leaf springs or do a truck repair, like replacing an alternator or water pump on the road. Now that we've upgraded to Alcan Leaf Springs, I just removed the spare set of 1750 LB springs from the TV. The Alcans are not going to fail in my lifetime, though I do have tools with to replace wet bolts/bushings or most anything else!
ToddNorthCoast changed their profile photo
Yeah, I learned of others that had issues with their LevelMate and disappointment with the Max upgrade; fortunately nothing major with my Pro, only minor regarding battery life. I’m one to hang onto an investment and make do, so changing out the battery seasonally resolved that issue. Guess I’ve been lucky!
Rivernerd started following Electronic Tongue Jack
For what it's worth, we "bit" last year on an "upgrade" offer from a Levelmate Pro to a Levelmate Max, because of battery issues with the Levelmate Pro. But the Levelmate Max has unreliable connectivity and the software is "buggy". It became so frustrating we reverted to 2-person campsite setup, with a torpedo level. Having now used both the Levelmate Pro and the Levelmate Max, we wish we had instead purchased the Beech Lane (as suggested by Patriot, above).
Agree. Levelmate works well and another benefit over using bubble levels is that you can monitor the trailer degree of level while moving into the campsite. I camp in boondocks sites where the gravel/dirt is uneven and I can monitor from the drivers seat while moving back or forward to find best level spot.
karitommypaddock joined the community
The Collar, ABUS lock with 2” de-shanked hitch ball locked in the jaw. If leaving for extended period, will remove safety chains. If they want it, they will find a way to take it, merely deterring honest and lazy thieves is the goal. Buddy had SOB trailer stolen from his drive by thief merely wrapping safety chains around hitch and dragging it off, sparks flying down the road.
I certainly suffer from the same issue. There would be fewer ˋget up'ś and trips to the garage if the only tools I had were a rock and a sharp stick! Mossey
I use this and it works flawlessly. Super simple set up and dials XPLOR in dead level. Strong reviews and the price is reasonable. I would buy again without hesitation. I mounted it on the inside of the closet wall out of sight. Tested, Manufactured and made in the USA! 🇺🇸 https://www.amazon.com/gp/aw/d/B0C28VJLG5/?_encoding=UTF8&pd_rd_plhdr=t&aaxitk=d3c72cff5eef1b3a98013caddad9f9dc&hsa_cr_id=0&qid=1757682231&sr=1-1
I found the 11K Dometic Penguin ll, originally installed in my 2020 OLEll, to be lacking in cooling efficiency with our Texas heat; a 15K replacement proved to be a better unit for my needs. If you don’t plan to camp in extreme heat or cold, perhaps an 11K/4500 BTU unit will suffice, but why limit yourself? Regardless of action taken, having the existing heater for backup may be a better plan over removal. With regards to installing a DC unit, you may first want to try to fish a path for the larger wires required before making that investment. Also, one would think a larger battery bank and even max solar necessary for this “new package for Oliver Boondockers”; added cost that doesn’t seem to be factored into the equation.
@JMSpoff I still use air tags not as much for a security measure, but a recovery/tracking device. I have one buried deep in my Honda 3200i generator, TV and of course our Oliver. I replace the 2032 batteries yearly. See the attached link. I think I have only read about one theft of an Oliver Elite 1 during my time on this forum and the Oliver FB page. It was recovered pretty quickly from what I recall.
Many use the LevelMate products for front/back and side/side adjustments with use of a phone app. Leveling blocks/ramps can also be used to lift one side and rear stabilizer jacks then to fine tune. Front jack used for front/back leveling often with a block to reduce jack extension. Perfect leveling made simple!
Boilermaker Chemist started following New Keyless Door Locks
I just installed a Bauer Bluetooth Keyless Entry Door Lock. Currently on sale at Camping World for $217.
The original unit was replaced without the 3 way float level. I have the side/side level in the basement. Suggestions on location and product that can help with my front/back level needs? Will it now have to be a 2 person operation? Thanks, Pat and Amy Radack Hull # 1189 - 2022 LEII, Twin, Lit Pro Pack, Out Pro Pack, Convection Microwave, Composting Toilet, Truma Aquago, Cradlepoint WAN, Added Truma A/C w/ CP Plus, Midea 20 pint, Foibles. Black 2019 RAM 2500, Cummins 6.7L, Limited, Crew Cab, 4 x 4, 6’ bed w/Rambox
SDG air conditioner installation
Pat Radack replied to mountainoliver's topic in Ollie Modifications
I think I understand. Perhaps it is time to think about a 12 - 24 - 48 VDC unit that rates at 11K BTU and also heats at 4500 BTU. If you care so much less about heating, what could you do with the space once the existing heater is removed. Surely the 8 AWG couldn't be that hard. A second DC bus bar and a lot fewer Ah for under $1K material. Pipe dream or a new package for Oliver Boondockers... Thoughts? -
Got an email from RVlock today. They are trying to get me the correct battery for the single, non-functional FOB I have. They stated quite clearly that their keys are laser cut and can not be copied. Perhaps that is what they are currently using. The key I have was just duplicated by my locksmith. He wouldn't, however, duplicate the key that locks/unlocks the FT. Knox Locks puck that covers/secures the bulldog on the # 1189. I will ask again and send a photo.
Make a checklist, like a pilot, and stick to it. Failure to follow my own list has led to a could of expensive mistakes over the years.
- Last week
@Pat Radack We all started somewhere with regard to learning and towing our Ollies around the country. You can ask away and we will glad help you out. Not sure if you use social media such as F/B? Oliver has a great Oliver Owners FB page as which also a wealth of information. We still use our checklist when we set up and break camp and my bride and copilot truly is my second set of eyes!👀 Pro tip - Never be in a hurry when settling up or breaking camp and packing up. Take your time and it will become second nature. We are on the road right now headed to the Great North Woods! Enjoy that Oliver and go camping! 🍁 Patriot🇺🇸
