Jim and Chris Neuman
Here in the Northwest our "cascade concrete" can weigh up to 20# per cubic foot. Wet, dense snow / ice a foot or more in depth can mean the equivalent of a couple of heavy guys standing on your panels. Best to keep it brushed off. Lot's of snow weight computers on the web for the interested.
I would not let snow build up on the solar panels. The panel frame is supported only out on the edges with no center support and the panels themselves are supported only around the perimeter.
A stand alone GPS / mapping unit which does not require an active cell signal is a must in many areas ... particularly in the west. Garmin makes many good units aimed at RV'ers. We use a Garmin Overlander and, as we do a lot of our travel and camping off the beaten track, we feel it is worth the relatively high price. A paper map is always a good backup and will astound your children and grandchildren!
There are foil tapes made just for this - ask you local hardware store. Standard duct tape will age and powder out over time especially in the presence of heat. Some brands, like the Gorilla tape, will last longer.
We have the Norcold in our Oliver 2 (hull 770) with the lithium package. Running the fridge on 12 volt the batteries run down very fast. We recently ran the fridge on 12V on an 80 + degree day and found after about 8 hours the fridge drained the 390 amp hour battery bank to about 65%. I do not believe his rate of power consumption is sustainable in our Northwest climate if you are off the grid as the solar will not keep up. After 8K of travel in the five months we have owned hull 770 we find we use propane to power the fridge all the time unless hooked to 110. There have been no issues so far. The inability to charge the lithium batteries from the tow vehicle is a serious issue for those of us who live in the Northwest and camp off the grid. I went with the lithium package despite my misgivings in the hope Oliver will work with Lithionics and come up with a TV charging option which they both support and which we owners can confidently implement. As I am unaware of any progress being made in that direction, I question whether I made the right choice going with the lithiums. In the defense of the system, we have found that given mild temps and a reasonable amount of solar gain, the panels will keep up with our electricity demands if we stick with propane to power the fridge.
Many people mistakenly attempt to lighten tongue weight by loading their trailer toward the rear. This is a recipe for sway. Stay with Oliver's tongue loading recommendations and you will be very unlikely to see any issues, however, if you heavily loat the aft end of the trailer your potential for severe sway increases greatly.
To get all of the chips out of the frame box beam, particularly one which is open only on one end, Oliver would have to turn the finished trailer on end and shake it in order to get the machining debris to fall out. That or try to snake a vacuum hose past all the through bolts, etc that intrude on the interior of the box beam. This metal debris is likely largely 6061 aluminum and unlikely to cause any harm if left in place. I would not worry about it. As a side note I have seen this often during the fitting out of aluminum sailboat masts. Every fastening operation will drop a bit of debris in the mast interior which is virtually impossible to remove except when the mast is hoisted vertical when being stepped in the boat. At that point the crane operator can give a few shakes and lots of metal debris will drop out. Upending and shaking your trailer may be less practical.
Uncertain which way to go.
Jim and Chris Neuman replied to sbuchanan25's topic in Introduce Yourself
We just sold our 2013 Tacoma and bumped up to an F150 FX4 with max tow package in order to better handle the weight of the LEII. We are extremely happy we did given our travel will be primarily in the mountainous Western US, Western Canada and Alaska. I am certain the Tacoma would have handled the LEII adequately on the flats but have found the brakes marginal for towing our far lighter previous trailer which weighed under 3000# loaded. The far smaller tank on the Toyota was also an issue ... not of safety but of convenience. The F150 with the 3.5 Ecoboost has far more power than the Tacoma and gets better MPG. We were amazed at the price we got selling our Tacoma ourselves ... within 6K of the Tacoma's new purchase price despite 96K on the odometer. Made purchasing a heavier TV easier to justify. -
Bullards State Park Fiberglass Rally
Jim and Chris Neuman replied to Ray and Susan Huff's topic in Events & Rallies
What are the dates? -
Having spent my working years in manufacturing I am convinced competition serves to make us better and is to be embraced, not feared. Chopper gun layup as used by Oliver can produce a strong, relatively economical structure. It is however very, very heavy. Higher tech materials and technologies now make it possible to produce a far stronger, far lighter and far better insulated hull than is possible using an older technology such as the chopper guns primarily used by Oliver. The drawback is cost as newer composite technologies tend to be more labor intensive and require far more sophisticated and costly equipment to produce. Oliver deserves high credit for raising the quality bar as high as they have and I doubt that they are done yet. We will all be better off for it.
If you are concerned about potential toxicity take a look at the MSDS (material safety data sheet) published by the manufacturer of the resins used in the construction of Oliver trailers. Oliver can provide this document at your request. You will find no formaldehyde in the formulation. Over time, ventilation will take care of the new fibreglass smell. Open windows and mechanical air exchange will speed up the process. We picked up our oliver in late May of this year. The new trailer odor has largely disapated at this point - if left tightly closed in hot weather, the resin smell increases until ventilated. To Oliver's credit our trailer was delivered clean and largely free of construction dust and debris.
Badlands-Cedar Pass Campground
Jim and Chris Neuman replied to Townesw's topic in General Discussion
We camped there on our return from picking up hull 770 in mid May. Nice campground .... in season. Come summer temps it would be a cooker. No significant shade but that is to be expected in the badlands. Lots of great hiking and large numbers of bighorn sheep, antelope, bison and prairie dogs. The badlands are high on our "We gotta come back here" list. -
Roof Mounted Solar Panels
Jim and Chris Neuman replied to fairmontrvpark's topic in General Discussion
Am confused by your comment that the Oliver is 100% gelcoat. What are you referring to? The gelcoat is only a thin layer, maybe 20 - 30 mils, sprayed up against the release coat in the mold. -
We went with the stock mattresses in our standard layout at the recommendation of Oliver sales. The reasoning was that the center cushion, if KTT, would be so bulky and heavy that it would make changing to the dinette setup a challenge. My wife Chris put together two 2" memory foam toppers to which she fitted sheets. These are rolled up and stuffed in the backseat of our pickup when not in use. It takes only minutes to switch from full bed to dinette set-up or back using this system. The two toppers, laid over the stock cushions, makes for a very comfy bed.
Much depends on how much of you there is to squeeze in there 🙂 We have the standard bed setup. I am 5'9" and carrying about 15# too much weight but have no trouble sliding into the dinette area from either side. We recently had six adults around the table for dinner on a windy night in the Steens and there was room for a couple more.
Andersen Weight Distribution Hitch
Jim and Chris Neuman replied to topgun2's topic in Towing an Oliver
Nice video - Thank you Jason! Through trial and error while bringing our new trailer back to WA state, we sorted the Anderson out (aided by James input during our delivery walk through). We did polish out some burrs on the hitch and pin which took just minutes and made hookup go smoother. Despite very heavy head and cross winds encountered across the prairie, we found the Oliver II towed extremely well behind our F150. The trailer has exceded our expectations and our thanks go to the Oliver team. -
Years ago I learned the hard way about metal hooks on bungee cords. John is right, please avoid them if possible.
Oh, yes it is! Visiting from the states, you need to look at the whole picture. That includes traveling one of several routes through BC and the Yukon before you set foot in Alaska. There is also a great deal of off-pavement exploring to be done on AK roads that can be quite good. I have made the trip eight times and do not feel I have scratched the surface of all that can be seen and done in Alaska.
Terrible installation. Backing board material is too fragile as evidenced by fracturing at the screwhole, the screws are too small (make them the diameter of the mounting holes), too short (should be as long as backing material is thick, and too few (screws top and bottom). It would be a simple matter to drill a few more holes in the mounting flange of the unit allowing for more fasteners. Also, the holes were located too close to the edge of a backing material which, again, seemingly fractures easily. You can take it a bit further by taking an appropriate length of threaded rod, drilling and tapping backing material at the appropriate sites, and injecting a bit of epoxy resin in the tapped hole before seating the rod, leaving enough threaded shaft sticking out to hang the unit and fasten in place with nylock nuts.
Does the new 630 lithium option provide for charging from the tow vehicle?
HOW TO: Build or shorten a battery cable
Jim and Chris Neuman replied to John E Davies's topic in Ollie Modifications
Another vote for a hydraulic hex crimper. I have used both stab and hex crimpers extensively in boat building and am convinced the results from a hex crimper are by far superior. Coupled with a good adhesive / heat shrink tubing will give you a really fine cable. I do not remember the brand I purchased but it was under $100. -
How much wind can the awning handle
Jim and Chris Neuman replied to Donna and Scott's topic in General Discussion
REI's poles are available. I just ordered up a set and received them in a couple days. They look sturdy.
