Jim and Chris Neuman
Prospective new owners of the legacy ll from Ohio
Jim and Chris Neuman replied to Mark willett's topic in Introduce Yourself
We now have towed our Legacy II over 22,000 miles since we picked it up in May of '21. Our tow vehicle is a 2021 canopied shortbox F150 FX4 3.5 Ecoburst with max tow package. This truck has plenty of power and has pulled several 11,000' plus passes as recently as last month. The truck has yet to struggle on any thing we have taken on in every lower 48 western state. Your 2.7 will not have the pull of the 3.5 but I doubt you will find traffic stacking up behind you. The only thing I have beefed up was the rear suspension with the addition of air bags to cut down on porposing as we anticipate a trip to Alaska in the near future. Our truck is rated for about twice the weight of a loaded Legacy II and is set up a bit beefier than many F150's and we make it a habit not to load the Oliver heavily or carry too much heavy junk with us in the pickup bed. We do use an Anderson as the hitch load is North of 500 pounds. I believe you will find your truck is very well matched to the Oliver II. -
No power to Tongue Jack
Jim and Chris Neuman replied to wolfdds's topic in Mechanical & Technical Tips
Just today I lost power to the rear / streetside jack on our Oliver. Checked fuses & found them all good. A close look revealed a wire had come loose from the back of the switch. Crimped the female fitting on the loose positive wire a bit to increase tension on the switch as it was still a bit loose when re-attached and now all is well. -
Bulldog coupler destroys Anderson ball
Jim and Chris Neuman replied to John E Davies's topic in Towing an Oliver
Those AlCan frost heaves are a real joy, aren't they? Spoke with a friend today who recently had the frame of his trailer (conventional construction) break in the yukon. Put a set of air bags on my F150 FX4 and am pleased with the result. Set at about 50#, they tame the porposing greatly. -
I have been using zip ties for years on my sailboat. They are a fine way to make a light fastening but do have the drawback of degrading in sunlight to the point where, after a season or two, their resistance to abrasion and breaking is seriously compromized. Replacing these plastic ties would be on my annual to-do list. I have looked for UV restant zip ties but no luck so far ... would like very much if someone here could post a source. In this application stainless or monel seizing wire would be a superior option.
Doghouse Attachment Bolts Loose
Jim and Chris Neuman replied to Hokieman's topic in Mechanical & Technical Tips
No need to replace the bolt if you bugger the bolt threads, it is a simple matter to run a thread die down the bolt to clean up the mess. On stainless it is helpful to coat threads with an antisieze (I use lanolin) in order to help eliminate the galling that is common between stainless bolts and nuts. -
Towing an Oliver 2 with a F150 V8 2WD
Jim and Chris Neuman replied to Imelda's topic in Towing an Oliver
I have an F150 with the 3.5 Ecoburst. It gets an average of 12 mpg highway in the mountain west while towing the Legacy II and 21 - 22 mpg highway sans trailer. Owners of F150's with the V8's I have spoken with report about the same while towing and less without trailer. What kind of milage do owners of diesel pickups tend to get while towing the Oliver? The Ecoburst requires 87 octane gasoline which is an upgrade from the 85 octane standard in many states. It would be hard to believe significant money would be saved with such a switch. -
Been over the Beartooth many times with no issues. Twice with trailers lighter (3000#) and shorter (20') using a Dodge Dakota and a Toyota Tacoma. Both times were coming in from the north and were a breeze. I have seen larger, heavier trailers towed over the pass but do not know if the drivers regretted their choice in retrospect. Am not sure I would be concerned making the uphill pull coming in from the North towing our Legacy II with our F150 but would try to do it at off-peak travel time of day. Snow or heavy precip would cause me to re-route. Heading North out of YNP would involve a lot of elevation loss and give the brakes a serious workout. Would think twice about traveling that direction on the Beartooth without a heavy, capable TV.
Hot Water Heater (Truma) Bypass Valve Issue
Jim and Chris Neuman replied to Frank C's topic in Mechanical & Technical Tips
Thank you for the heads-up! -
Finally saw a bear(s) in the wild!
Jim and Chris Neuman replied to NCeagle's topic in General Discussion
Bears are a lot less likely to cause trouble than people. I fear for this mama and her cubs if she is teaching them to seek out food in campsites. Hope it does not turn out badly for them. -
Seeking repair advice for a small roof crack
Jim and Chris Neuman replied to Sak's topic in Mechanical & Technical Tips
Unlikely that there is any leak potential unless the shell is seriously damaged. If there is just a gelcoat flaw, water will not penetrate further into the chopper gun layup. If there is structural damage under the gelcoat you can often tell by taking a small brass hammer and lightly tapping the area surrounding the crack as well as the cracked area itself and listen for a change in tone. Hard to explain the sound but fractured fibreglass has a distinct (hollow) sound as opposed to undamaged glass. It is really not too hard to repair a damaged section of glass and there is a ton of how-to info available on the web. It is very difficult to get that repair to exactly match the original color unless you can get Oliver to send you a bit of the gelcoat they use in manufacture. My first step would be to talk to Oliver for their recommendation. Your 2021 Oliver layup should still be under warrantee. -
Suitable for 7 months in Alaska?
Jim and Chris Neuman replied to Beaver Pilot's topic in Welcome to the Oliver Forums
Today, getting to Alaska is a snap as the roads are pretty good. I have made the trip eight times from the West Coast and, while it was a bit of a challenge many years back when most of the route was gravel, today the entire route is paved with the exception of short sections on the Cassiar and even that is not a problem if your tow vehicle is up to the task. On the last trip I did not even lose a windshield, which was a first for me! By all means take your Oliver to Alaska. Think ahead, make sure you are prepared and then enjoy yourself ... the trip is spectacular. -
Just discovered the beginnings of a single-occupant wasp nest under the rear streetside compartment where the stabilizing jack lives. A bit of looking around revealed a gap in the inside of the jack post alongside the mounting bracket where it pierces the outer hull. This gap is just short of 1/4" wide between the jack tube and mounting bracket which has not been completely sealed against bug / water entry. There is sealant going part way around the post on the outside of the jack tube but the median (more difficult to access from inside the trailer) portion of the tube was unsealed leaving a gap of about 1/4" wide x 3" long which allows easy bug access. Turns out both rear jacks share this bug access point due to a lack of sealent. Easy fix from underneath the trailer - just forced up silicone caulk from below. Any other entry points anyone is aware of on the Legacy II's? Screens over fridge, heater & water heater vents are obvious and screens are available at the Oliver service dept. - we had them put on when we picked up #770.
- 1 reply
- 2
Vancouver Island - Suggestions, Tips, Advice Wanted
Jim and Chris Neuman replied to ShallowGal's topic in Campgrounds & Parks
When you get to the beautiful Provincial Park on Boya Lake, check out the amazing beaver dam to be found at the end of a short hike out of the park. It is amazing... massive - makes me think beavers must use backhoes and bulldozers. -
Vancouver Island is spectacular! Living literally within view of Vancouver Island, we have had the opportunity to visit the island a great deal, both by boat and by land. With only a week available you will only be able to scrape the surface. Victoria is a must followed by a visit to the outer coast near Tofino - great camping but weather is likely at that time of year ... luckily you have an Oliver. Vancouver Island is big - the largest island in North America. Those two areas will give you a feel of the island but there is so much more. -
I looked at this when I bought our 2021 F150. Came to the conclusion that, given the very small battery storage of the hybrid, you would probably not see much highway MPG help from the electric motor. I have not read any reports from actual users as to whether or not my concern is valid. The hybrid would give you more horsepower but that is kind of unnecessary as the standard 3.5 Ecoburst has more than enough power to handle the Legacy II. For what it is worth, I get about 11 to 11.5 MPG on average in the mountainous west where I live. The big tank is a plus and, at the time I was researching this issue, the hybrid had a somewhat smaller tank than my standard FX4 max tow package. A GREAT truck. Have been very pleased. The only downside is that the softer suspension, as compared to 3/4 tons, results in a bit of squat in the stern and some porposing. A set of air bags cured that issue.
I just measured the plate on my Legacy II - it measures .125".
I like John's idea of fabricating a larger plate. I would go much thicker than .032" (which is more like a foil than a plate). A 1/8" (.125) plate would be more appropriate and although 6061 is an excellent alloy for the application, it is a bit overkill and difficult to obtain in small quantities. Easily found 6063 or a variant is more common, less expensive and very much up to the task.
Packing the wheel bearings
Jim and Chris Neuman replied to Imelda's topic in Mechanical & Technical Tips
I can confirm this ramp will not work with the Legacy II. I tried mine out with no luck - one tire on ramp & the other stayed on the ground. -
Battery Compartment Air Vents
Jim and Chris Neuman replied to aaronorange's topic in General Discussion
Yes they do. Our 2021 has the vents even though we chose lithiums. I would think, from a liability standpoint, it makes sense to leave them in place. If a change is made to standard wet cells, lack of ventilation could result in an explosion. Easy to add a layer of insulation inside the cover panel eliminating the ventilation and providing additional insulation to the lithiums in freezing weather. My plan is to use closed cell foam insulation attached to the cover with velcro so that the insulation can be easily removed. Our low temp over the winter was in the mid teens F and the battery temp never got below 40 degrees F. That with a small space heater set on low in the main cabin. We powered up the battery heating pad although I do not know if the BMS ever sent power to the pad. Also kept the Truma heater on during cold weather. -
Fridge cold at pickup?
Jim and Chris Neuman replied to Steph and Dud B's topic in Delivery Day Photos
770 was not flushed, filled with fresh water nor was the fridge running when we arrived for PU last May. Expect to have to perform all this stuff upon delivery. It was however, very clean and otherwise ready to roll. -
If you are willing to invest a week or two in a low-impact fix, try Kroil, repeatedly applied over a couple weeks. Amazing stuff and worshiped by folks who work in corrosive environments like salt water boat yards. Re-install with a quality anti-sieze. Not as much fun as the "bigger hammer" approach but more likely to leave you with functioning components. You can always bring out the bigger hammer later.
The chain provided by Anderson is too short and will require additional links to fit the Oliver ... at least the Legacy II - someone else with knowledge can chime in on the Legacy I. If you buy the Anderson from Oliver, they will set it up for you, including providing the extra necessary chain links. I also needed to lengthen the emergency brake cable by several inches to fit my 2021 F150. A bit more money buying from Oliver but, I think worthwhile in easing the workload during pickup day.
OnX also sells chips containing 24,000 (7.5 quad) topo maps of entire states. These chips can be utilized by devices, such as the many handheld Garmin GPS units which allow you to switch out micro sd cards. While quite spendy, about $100 per state when I bought WA and OR a couple years back, these cards give you seamless, high resolution topo map coverage for an entire state. As you move from one state to another you must change out chips as you go. As John Davies stated, you can download maps by region on both GAIA and also OnX. These maps are available in resolution from high to low depending on the size of the area covered - higher resolution comes at the cost of a smaller geographical area covered . This is fine if you have access to internet but is slow or impossible to update on the fly if done over cell signal. If you have marginal or no cell coverage, the option to download maps simply goes away. Files are quite large which means you either have to spring for a device with a great deal of memory or delete files when not in use to make space for new regions. I like using my I Phone or I Pad for day trips where cell signals are strong but find these devices lacking when signals are weak, non-existent or when your device has limited battery life ... these programs are energy hogs. When seriously hiking, I carry maps, compass and a dedicated backcountry GPS unit like the Garmin 66ST with pre-loaded, high resolution maps aboard.
