Stevon
    845
1,975 profile views
Stevon's Achievements
Explorer
Explorer (4/14)
60
  1. I found the slightly longer fasteners at my local Ace hardware.
  2. You don’t need to disconnect any cables, or do anything complicated. Your Lithionics batteries have an on/off switch on them (Push button on the top). For storage just draw them down to 50% and turn them off.
  3. We’ve been to Organ Pipe several times and there have been other Olivers there every time.
  4. I had a spring fail, so I decided to replace all four springs. In the process of replacing springs I realized that all four of my shocks had failed. I have about 35k miles on the trailer and was surprised that all four shocks had failed. Has anyone replaced the stock shocks with a higher quality product?
  5. Just my luck. I had a spring fail so I replaced all four just last month I wish I had known about the US made springs then. Oh well I’ve got all new springs now anyway, and I’ll be keeping an eye them.
  6. Thank you. I have it apart and I think I have it figured out.
  7. I know that this is a very old thread, but I have to replace a cord in a shade. It seems that the string is fastened inside the horizontal frame rail. Can someone tell me how to access where the cord is fastened inside that frame section. Thank you.
  8. Did you use any adhesive with this or just a friction fit?
  9. No pans come with the oven. I have 8”, 10”, and 12” cake pans one of each. Also a pie pan and a 12” pizza pan. These all nest together quite well. I have silicone muffin cups that I use with the pizza pan. I like to bake. Well actually a more accurate statement would be “I like to eat baked goods”.
  10. I have the same three batteries. One always seemed to never discharge or charge as fast as the other two. A physical check of my battery bank revealed the + connection on the offending battery was loose. I couldn’t tell by trying to wiggle it as the short cables are too stiff. But a wrench quickly found the issue. Since it’s been snugged up they all stay very close on charge/ discharge rates.
  11. How do you cook at home? Do you frequently use your oven at home? If you do you will like having the convection feature. We spend a lot of time in our EII, and we rarely go to restaurants. That we were ordering the convection / microwave was a given. In the past two weeks I’ve made: Muffins, biscuits, a whole chicken, and a loaf of whole wheat sourdough bread. We use it both on and off grid.
  12. Thank you for your reply. Please let me know what your eventual solution is. As there is always more to learn.
  13. What was the battery voltage reading before you hooked up shore power? I would suspect low battery voltage. The inverter will not turn on if the battery voltage is below a set threshold. The interior lights run on 12v they do not need the inverter to function. Any 12v digital device can exhibit strange behavior with low voltage. Leave it plugged into shore power for a few hours. Then try the lights again.
  14. If a modern tank is functioning correctly it can not be overfilled. Modern tanks have a internal shutoff valve that only allows a specific liquid level. Of course there is always the possibility that it is not functioning correctly.
