ScottyGS last won the day on October 23 2025
ScottyGS had the most liked content!
145
2016
ScottyGS's Achievements
Andersen WD Hitch Friction Cone Noise
ScottyGS replied to Tony and Rhonda's topic in Towing an Oliver
I remember when that happened with the old style cone. Sounded like Sasquatch was trying to rip the bumper off. -
Dometic D21 Cooktop Ignitor Doesn't Spark
ScottyGS replied to OffWeGo's topic in Mechanical & Technical Tips
The ignitor not working is a useful feature of the Oliver.... It explains why you always need to keep a lighter in the kitchen drawer. If anyone has an explanation of why a cigar cutter needs to be in that drawer too... I would appreciate your passing the information along. Scotty -
Towing with a Chevy Colorado Tow package 7500 pound
ScottyGS replied to jgilliam1955's topic in Towing an Oliver
The First place to start is the driver side door of the Colorado. The payload of the truck will be listed there. This is the maximum weight allowed to be carried by the truck. Next... Start adding the weight you will be putting into / on the truck. Start with the tongue weight of the Oliver (650 lbs.) Next would be the passengers (be honest). Then account for anything you have added to the truck as an aftermarket accessory.... Bed Caps typically weight about 300 + lbs. Finally any camping equipment that will go in the truck... stove, generator, camp chairs, tools, etc. Subtract that number from the max payload capacity limit. If you still have a positive number, you have passed the first test. (you still have more math to do) I would be interested to see how your numbers work out if you would be kind enough to share. Also would strongly advise against the Chevy Colorado ( or any other medium size truck ) as a TV. Best of Luck, Scotty -
Use space heater when below freezing???
ScottyGS replied to Dennis and Melissa's topic in General Discussion
I have been using a Sensor Push (https://www.sensorpush.com/) for some time now. I keep it under the port side bunk near the controls for the outside faucet. There have been times when I did not winterize because our trailer is kept inside a large unheated garage. Temps rarely go down below freezing but to be safe we use a large oil filled heater with the hatches blow. I have also monitored the temp without the hatches blown and was surprised to find the difference in temp was only about a degree or two. This would be inside the trailer vs. in between the hulls with temps close to where you would worry about freezing lines. So my conclusion would be that even down to the 20's using a cube heater you should be fine. "SHOULD BE".... I would still monitor and use the on board heat if the between hull temps started to show a drop. When I first got the ceramic cube heater and I wasn't familiar with it I woke up around 3am and the temp inside was 85 degrees. Not fun but no broken pipes. The Sensor Push has provided a LOT of peace of mind for the last few years. Of course all the other advice like pulling in the outside faucet and insulating the inlets apply. YMMV... Good Luck Scotty -
Dubbed "The Flying Sea Turtle" by my wonderful wife in summer of 2016. By next Summers camping season we will have had 10 years with her. Truly a unique Oliver for both the Logo... (many people remember the Turtle) and the unique stripes that no other Oliver has. They were a test pilot by Oliver but they decided to stay with the original "swoosh" design. I have to say I am still very proud to own her. See you on the road! Scotty
Speaking of Dash Cams.... this happened a couple years back. GRMN-2023-06-16_17-23-51-exportedVideo.MOV
Remember the black streaks that came from the black gaskets drying out. And the solution was to paint them with Capt. Tolleys Creeping Crack Cure. Took a while to get Oliver to even look for another material but they finally did it. Scotty
Andersen WD Hitch Periodic Maintenance?
ScottyGS replied to Galileo's topic in Mechanical & Technical Tips
I did this for years when I had an F150.... Over time I noticed that the receiver developed what I thought was an excessive amount of play. So much that I started to get a clunk sound every now and then when stopping. Now I have a new TV and generally just use a ratchet to tighten the chains. I think the 2" method would be better and am tempted to try again... Has anyone else experienced the receiver developing excess play? TIY, Scotty -
Anderson did replace my WDH that came with my trailer in 2016. The issue was water getting into the cone and destroying it. Made one helluva racket too. The replacement came with a ring fastened to the top that kept water out. I think those days are gone. -
That is a shame. Our preferred method of keeping cool is to use the maxxfan set on out and open the windows. We always kept the rear window closed and never thought about it. But since installing the fan.... I am a big FAN of using the rear window to pull in fresh air... especially since it opens on my side. Of course the more windows open the lower the airflow through any one of them... Let the window negotiations begin!
John, On our trailer (2016 model - hull 145) there was a cigarette lighter receptacle on the left wall in the attic. Had to remove the wall to do the installation and I just tapped into the back of that plug. Very easy and you can test it by holding the wires on before you install. Good Luck
OK... so sorry to be late the to the party and sorry for the ICE truck joke... (it would be cool in the summertime though) BUT.... The idea of using the BW continuum hitch is intriguing. The Bulldog hitch is about 16 inches long and there is another 10 inches of tongue after that. Appears there would be more than enough room to mount the actual hitch. Now the pump handle thingamajig is another matter. I don't think it's possible that future iterations of the hitch would allow that part to be smaller, but some enterprising individual might find some work around other than (heaven forbid) cutting the fiberglass shroud. If you could find an alternate way of mounting that pneumatic box it might could work. Scotty
Is this what you are talking about?
JD.. Yes that is the fan I installed. No, it's not whisper quiet... but it is pretty quiet when set on low. We like the maxxfan a lot when sleeping... provides just the right amount of white noise to cover any other sounds. The Sirocco is about the same as the maxxfan but it's a lot closer. Still not annoying and should not interfere with sleeping. I posted a video of the fan on the facebook page... you can look for it there. I cycled through the 3 speeds so you can hear how loud each is. Steve, Have not travelled with it at all but plan on leaving it in the down position. I think it would stress the fan especially on bumpy roads. Will probably leave it in the down position all the time. Thanks, Scotty
