John E Davies
John E Davies last won the day on September 29 2023
John E Davies had the most liked content!
    218
    2017
18,655 profile views
John E Davies's Achievements
Grand Master
Grand Master (14/14)
  • Well Followed Rare
6.8k
  1. “Towing with electric vehicles is a fraught conversation even though only a minority of Americans actually use their vehicles for towing on any regular basis. Regardless, it has become a goalpost for EV acceptance in the market for some people. By now, it shouldn't be news that towing with an EV reduces range, just as it does when towing with a combustion-powered vehicle. It shouldn't surprise you, then, that our new Tesla Model Y doesn't go very far when towing a trailer.” 2023 Tesla Model Y Long Range Yearlong Review: How Far Can You Tow With a Tesla? Nothing earth shattering in the article, but they do provide some interesting range figures. John Davies Spokane WA
  2. Nice, a lot of people just cannot fathom how much force 6 gallons of water inside a steel tank can generate when moving on rough surfaces! Mine never failed, but I never towed with hard tires either. What straps did you use? Regular ones? Those have some stretch which in this case is probably not a bad thing to have, but for other applications such as battery tie down straps, you don’t want to have any at all, so you should seek out mil-spec zero stretch webbing. This is excellent, with a footman loop at the bottom on each side, you can position the buckle up top where it is easy to reach and inspect. These straps will stay dead tight, they actually “twang” when you flip one with a finger, very excellent stuff! https://raingler.com/products/blockoff-kit For a lithium battery upgrade, consider adding these to keep them secure and safe. https://olivertraveltrailers.com/forums/topic/5356-how-to-fabricate-battery-hold-down-straps-and-anchors/ John Davies Spokane WA
  3. Bump for a OLD thread. John Davies Spokane WA
  4. FYI slightly related topic: https://olivertraveltrailers.com/forums/topic/3330-how-to-remove-modify-the-cover-over-the-waste-storage-bay/ Check your clearance the next time you are poking around under the frame. John Davies Spokane WA
  5. We need to understand if the strips were supposed to be glued down to the frame rails, with VHB tape for example, prior to mating the frame to the hull. If that step were omitted, intentionally or by Covid accident, then that could be the root cause of the slippage. Oliver Service will certainly be able to clear that up. If there is indeed supposed to be something binding the strips to the frame or to the hull, then an easy field repair would be applying beads of a good adhesive/ sealer to the edges along the accessible areas. That should suffice to hold everything in place. And it will help to keep road grit out which is very destructive (in the long term) to fiberglass that is under a load, but always flexing a little. It acts just like grinding compound. John Davies Spokane WA
  6. It is not the fiberglass hull that is affected, just its connection to/ interface with the frame. My hunch is that the “forever hull warranty” applies just to the molded part. Have you noticed how old fiberglass boats never die? The attached parts rot off fairly fast, but the hulls themselves stay intact forever, which is a huge problem in terms of recycling. Ollie hulls are also forever parts, which is why they get that great warranty. John Davies Spokane WA
  7. Bump, added a link in the first post to the Oliver Service page about this toilet. https://olivertraveltrailers.com/forums/topic/6720-natures-head-compost-toilet-troubleshooting-user-guide/ John Davies Spokane W/
  8. Interesting, I haven’t heard of this problem before. Thanks for posting the pics.., Could you use a big piece of wood, like a 2”x4”, and a hydraulic jack under the fiberglass to very carefully take the load off the rubber to allow you to push it back into place? Also, some soapy water, applied liberally to flush out the dirt, would act as a lubricant to perhaps help them move a little easily. Did you check all the big hull mount nuts to see if any were loose? They do loosen, the ones at the jacks especially, and below the propane compartment... I am having a hard time visualizing a situation where these rubber pads would drift out of place if all other factors were normal. This could just be a visual symptom of another problem that remains to be corrected. I suggest that you file a Service Report - they may have other cases like this, and the extra info might lead to a a new technical bulletin. John Davies Spokane WA
  9. Assuming you are going to reinstall the fridge, maybe use some real insulation like the pink Owens Corning 1” foam board, that is rated R5. I am not sure if regular styrofoam has that high an insulation value. The pink stuff is fire retardant and will not absorb moisture at all. Lots of aluminum HVAC tape will hold it in place and hopefully seal the gaps. The idea is to stop outside air entry. I sure would be reluctant to foam it back like yours is now, with the spray stuff…. https://www.homedepot.com/p/Owens-Corning-FOAMULAR-NGX-F-150-1-in-x-4-ft-x-8-ft-SSE-R-5-XPS-Rigid-Foam-Board-Insulation-20WENGX/315197840 You can also use that board to insulate bare spots like under the bathroom vanity. … https://olivertraveltrailers.com/forums/topic/9039-how-to-bath-sink-compartment-mods-duct-rework-insulation-disconnect-flush-line/ Please start a complete thread on your job, I don’t recall seeing one for the Norcold unit. Good luck! John Davies Spokane WA
  10. They flop around inside the unpainted inner diameter of the axle tube and eventually wear through the insulation. It isn’t anything that you can see without pulling them out completely. If the wires were protected by split loom in there, it would most likely be an OK practice. But not for loose wires… those axles hop around constantly and chafing is the result. Here is one reference. https://www.mortonsonthemove.com/fixing-the-rv-brakes/ John Davies Spokane WA
  11. I have never seen a chart, here is some info claiming 4000 rv fires per year and the absorption fridge is the number 2 cause. https://www.arprv.com/rv-fire-cause-and-prevention.php And this article: FYI, if yours is in great shape, (which I would doubt), installing a Fridge Defend system makes a lot of sense, but it cannot be installed into an early hull Dometic fridge without removing it completely from its compartment. John Davies Spokane WA
  12. Well, I never said that, but use common sense, have a person inside turn on battery power while you watch outside. But seriously, the fridge needs to be inspected by a pro, and that requires it to be removed to the interior of the trailer at least. Don’t discount the fire hazard, many RVs burn to ash from these absorption fridges. Dometic requires that the working parts be inspected ANNUALLY, but the Oliver factory installation is very poor, to say the least, and you cannot even see some of those critical areas with a mirror. The fridge has to be taken out of its cavity for that. John Davies Spokane WA
  13. My guess is an electrical short, most likely triggered by, but not actually caused by your water ingress. You could use an air compressor to blow out the lower area, and apply power again, but I really think it needs to be inspected by a pro. Do not be at all surprised if the fridge is scrap. https://olivertraveltrailers.com/forums/topic/8865-fridge-fires-if-you-have-an-older-hull-you-really-need-to-pull-out-that-fridge-now/ FYI, a how to remove that unit link, some of the pictures show the electrical connections of concern. https://olivertraveltrailers.com/forums/topic/9040-how-to-dometic-3-way-fridge-removal-and-demolition/ The entry door and its frame will have to be removed entirely to get the fridge out of the interior, unless you do as I did and dissect the fridge with a power saw… FYI the cooling section is hazmat and cannot be recycled, I paid a local place $75 to take it. If you live in the country, a bullet, fired from a fair distance back, will work well to remove the ammonia, and then you can recycle the remaining scrap steel. (This is comment direct from the guy at the appliance recycler.) A new DC/ AC (2 way) compressor fridge, should you go that direction, should be chosen with care, so that it will go in and out without any further trauma to the doorway. The ones presently being used in new Ollies will fit through the entry with a little care, I believe. Do not quote me. John Davies Spokane WA
  14. Bumping an older thread, look at this one too: https://olivertraveltrailers.com/forums/topic/9807-manual-leveler-device/ John Davies Spokane WA
  15. Possible source for a square (aka 4-point) socket, Grainger carries these in various standard SAE sizes, I do NOT know what size the jack driveshaft is, probably metric. If somebody figures this out, please start a new thread about it. My gut feeling is that you won't find 4-point sockets on Amazon... 😉 One from this set might possibly fit: .... Stanley Proto J52109 3/8-inch Drive 5-piece Socket Set- 8-point ... you could return the set at no charge if you don't like it. I researched this years ago, before I eventually decided that the cost effective solution was to just to lengthen the handle shaft. John Davies Spokane WA
