Steve Morris last won the day on June 4 2025
Steve Morris had the most liked content!
Location
Northern Ohio
- Website
1360
2023
Hiker 5X8 Highway Deluxe Squaredrop
11,167 profile views
Steve Morris's Achievements
Maximizing amp hours for boondocking
Steve Morris replied to Olive2Roam's topic in General Discussion
We have the 640A/h Lithionics batteries, and in addition to the 400W of solar on the roof, I have three 200W folding panels. While 1000W of solar sounds like a lot, you'll quickly realize that (at least here in the eastern US) the roof panels are frequently shaded, the portable panels are sometimes a nuisance to move around, and that even on a perfect sunny day and constantly moving the panels, it would take 8-10 hours to completely recharge a battery from zero. The only time I've gone this route was in the heavily wooded Adirondacks last year when we were seven days without any hookups, and I don't have DC-DC charging. I only had two panels then, and the only AC we used was the microwave occasionally and the coffee maker once a day. Mid day, there were times that with 800W of panels exposed, I was getting less than 100W into the batteries. Driving home and one rainy night in a Harvest Host, we arrived at the house with somewhere around 46% state of charge. I thought that was pretty great! We didn't try to conserve power use. We just didn't need much. The biggest power draw was out fridge/freezer in the truck, which I had plugged into an Anderson Powepole outlet on the trailer. -
Inspectable Item: Propane Area
Steve Morris replied to Wayfinder's topic in Mechanical & Technical Tips
Hank White has made some fabulous modifications to their Oliver, including the propane setup. He’s mounted a block on the inside wall of the housing where a manifold and regulator are located. Stainless covered hoses go to each tank, eliminating the need for the OEM regulator mount on the threaded rod. Low pressure gas is sent to the two LP ports, and two full pressure lines go out; one to the Oliver’s interior and one to a high pressure port for devices that have inbuilt regulators such as a fire pit or grill. I didn’t take any photos… -
We were in Hohenwald today, and signs of how severe this storm was are everywhere! We came into town from the east on 412, and saw broken trees and power poles by the hundreds. There seemed to be a pile of debris collected along the road every quarter mile or so, some as big as cars. Then we left to the north on Rt 48, and it made the eastern side look like a teaser. Thousands and thousands of downed trees for miles! The worst ice damage I’ve ever seen. Hopefully, no one was injured and folks are somewhat back to normal now.
Removing shelf under bathroom sink for plumbing access.
Steve Morris replied to Mroth's topic in Ollie Modifications
Our 2023 is the same, and we were surprised to see it in the middle of the compartment, especially after seeing older models with the vacuum formed tray in there. But I suspect it is to ease the cable angle as much as to prevent using the bay for storage. Our TP and paper towels get stored in there. -
“Curiosity” is currently parked next to “Dickens” at CGI Detailing’s shop in Murfreesboro, Tennessee. Getting the shine even shinier!
Our first day in a week without being sub-freezing overnight. 52 and sunny. Despite being chilly, this Florida sun is hot when sitting in it! Wide brimmed hat and sunblock required for my pale complexion. Fort Pickens Campground on Gulf Islands National Seashore.
Home in northern Ohio. That mailbox is about 30” off the ground, and you can’t even see the road our daughter says 12-14” reported. Here on Gulf Islands National Seashore in Florida’s panhandle. Lunch
- 88 replies
- 10
For those camping in chilly conditions, here’s what we did to avoid bumping a bare leg, butt, or shoulder against the trailer wall. I got a 30”x84” yoga mat, cut it in half lengthways, and tuck it between the mattress and wall. This is more comfortable, and has the added benefit of allowing any moisture from condensation on the window to run between the wall and the mat, and then under the Hypervent, keeping the mattress dry. The 84” length doesn’t quite cover the entire side and end of the wall, coming up short by about a foot. We have that gap next to the nightstand. https://a.co/d/eJCYCXD
Here’s the usage chart this week. Orange is heating and red is emergency/auxillary electric heat strips. Temp has been single digits to the 20s, with wind chill as low as -10. The thermostat is set at 63 degrees. It’s a comfortable 71 degrees here in the Florida panhandle. 😁
Actually, thinking back to when we had the heat pump installed, it could not be under any structure. The original heat pump was installed on the edge of a patio, and then some time later the owners added an aluminum awning. When we replaced the heat pump, we couldn’t put in in the original location because code said it couldn’t be under the awning several feet overhead, even though it was right at the edge of the awning. So we had to pour a pad to the side for installation.
We have a 15 year old heat pump in northern Ohio w/5000W heat strip auxiliary. I don’t remember the SEER number, but it was an average unit when installed, not a high efficiency model. We’ve had snow piled on and around it, coated with freezing rain, ice, etc., and have never had an issue. Ours has a reversing valve that sends heated coolant back through the heat exchanger to help with ice buildup, but it’s not a complete solution. Very rarely do I need to go out and break ice off, more for my own satisfaction than a real need. It just keeps on chugging.
You said that last year! 🤣 Will we see you next week in Live Oak? We'll be on site 10 again.
