Moderators mossemi Posted July 27, 2024 Moderators Posted July 27, 2024 On 7/16/2024 at 9:06 PM, rideandfly said: If the axle label is missing, Dexter engraves the axle serial number on each axle. I gave Dexter the serial number off of one of Ollie's axles a few years ago and Dexter emailed this axle spec sheet back to me. With this information a Dexter dealer should be able to supply an axle built to original specifications. It took awhile, but I finally found pictures of my axle label and although I had several pictures I wondered why they all had the same serial number. I went under the Ollie and found that I only had 1 label and it was on the rear axle. I then found the engraved SN for the front axle and it was the same as the rear, which I thought was weird. So I emailed that information to Dexter asking for an as built sheet and if tandem axles should have the same SN. Dexter sent back a single build sheet and never addressed my question about the same SN on both axles. So the question that I now have is if anyone else has the same SN's on both axles and if that is Dexter's standard practice? The attachment is for 2017 LE2 #193 which has the original suspension equipment Mossey ö 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
rideandfly Posted July 27, 2024 Posted July 27, 2024 (edited) Mossey, I only looked at one axle and assumed 🫤 they had two different SN's, never thought two axles would have same serial number. 😐 Will check my axle SN's during the first part of August, making one more modification to the F-150 before towing Ollie during the first part of August. Updated: 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2014 LE2 #50 SC 50.5" D52 Original axle capacity & Alcan spring & Disc Brake upgrades 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts) 2016 LE2 #113 SC 50 “ D35 Original axle capacity 2017 LE2 #193 SC 50.5" D35 Original axle capacity 2017 LE2 #208 SC 50.5" D35 Original axle capacity 2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity & Alcan springs 2020 LE2 #579 SC 50.5" D35 Original axle capacity 2021 LE2 #898 SC 50.5" D35 Original axle capacity & Alcan springs upgrade 2023 LE2 #1386 SC 50.5" D52 Original axle capacity Please me know if information needs to be added/changed for a hull # and can also add additional campers including LE1's. Edited July 27, 2024 by rideandfly 2 2015 LE2 #75 / 2024 F-150/5.0L
Wayfinder Posted July 28, 2024 Author Posted July 28, 2024 My axle labels are nearly destroyed by road & weather. I'll see what numbers I can see engraved somewhere. Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Moderators mossemi Posted July 28, 2024 Moderators Posted July 28, 2024 4 hours ago, Wayfinder said: My axle labels are nearly destroyed by road & weather. I'll see what numbers I can see engraved somewhere. I found the SN engraved on the rear side of the axle near the center. Take a damp rag and a flashlight with you and wipe the axle down, it should be visible. Mine was close to where the label used to be. Mossey 1 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderator+ ScubaRx Posted July 29, 2024 Moderator+ Posted July 29, 2024 On 7/27/2024 at 8:48 AM, rideandfly said: Mossey, I only looked at one axle and assumed 🫤 they had two different SN's, never thought two axles would have same serial number. 😐 Will check my axle SN's during the first part of August, making one more modification to the F-150 before towing Ollie during the first part of August. Updated: 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2014 LE2 #50 SC 50.5" D52 Original axle capacity & Alcan spring & Disc Brake upgrades 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts) 2016 LE2 #113 SC 50 “ D35 Original axle capacity 2017 LE2 #193 SC 50.5" D35 Original axle capacity 2017 LE2 #208 SC 50.5" D35 Original axle capacity 2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity & Alcan springs 2020 LE2 #579 SC 50.5" D35 Original axle capacity 2021 LE2 #898 SC 50.5" D35 Original axle capacity & Alcan springs upgrade 2023 LE2 #1386 SC 50.5" D52 Original axle capacity Please me know if information needs to be added/changed for a hull # and can also add additional campers including LE1's. 2014 LE2 #50 SC 50.5" D52 Original axle capacity & Alcan spring & Disc Brake upgrades This is my trailer but I went out and measured the spring centers as 50.0" 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
rideandfly Posted July 29, 2024 Posted July 29, 2024 10 hours ago, ScubaRx said: 2014 LE2 #50 SC 50.5" D52 Original axle capacity & Alcan spring & Disc Brake upgrades This is my trailer but I went out and measured the spring centers as 50.0" Updated: 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2014 LE2 #50 SC 50" D52 Original axle capacity & Alcan spring & Disc Brake upgrades 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts) 2016 LE2 #113 SC 50 “ D35 Original axle capacity 2017 LE2 #193 SC 50.5" D35 Original axle capacity 2017 LE2 #208 SC 50.5" D35 Original axle capacity 2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity & Alcan springs 2020 LE2 #579 SC 50.5" D35 Original axle capacity 2021 LE2 #898 SC 50.5" D35 Original axle capacity & Alcan springs upgrade 2023 LE2 #1386 SC 50.5" D52 Original axle capacity Please me know if information needs to be added/changed for a hull # and can also add additional campers including LE1's. 4 2015 LE2 #75 / 2024 F-150/5.0L
Wayfinder Posted July 30, 2024 Author Posted July 30, 2024 @jd1923 has shown me the trees beyond the forest. I was not "getting it". Now I think I do. So maybe OTT can special order the size of axles for my trailer and install them getting all the upgrades I want at once. Hmmm. I will get my serial numbers off my axles soonest. 2 Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia
rideandfly Posted July 30, 2024 Posted July 30, 2024 8 minutes ago, Wayfinder said: @jd1923 has shown me the trees beyond the forest. I was not "getting it". Now I think I do. So maybe OTT can special order the size of axles for my trailer and install them getting all the upgrades I want at once. Hmmm. I will get my serial numbers off my axles soonest. That would be very convenient if Oliver will order your axles! Please post your axle build sheet when you get it! I can update the list, if needed. 3 2015 LE2 #75 / 2024 F-150/5.0L
jamesgang Posted February 12 Posted February 12 (edited) On 7/29/2024 at 8:53 AM, rideandfly said: Updated: 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2014 LE2 #50 SC 50" D52 Original axle capacity & Alcan spring & Disc Brake upgrades 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts) 2016 LE2 #113 SC 50 “ D35 Original axle capacity 2017 LE2 #193 SC 50.5" D35 Original axle capacity 2017 LE2 #208 SC 50.5" D35 Original axle capacity 2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity & Alcan springs 2020 LE2 #579 SC 50.5" D35 Original axle capacity 2021 LE2 #898 SC 50.5" D35 Original axle capacity & Alcan springs upgrade 2023 LE2 #1386 SC 50.5" D52 Original axle capacity Please me know if information needs to be added/changed for a hull # and can also add additional campers including LE1's. looks like mid 2016 LE2 was a changeover time for the hanger width - mine was born in July 2016 and is 50.5" - so you need to measure to make sure oliver was able to upgrade my LE2 hull #157 to all new running gear (D52s etc) side note - my original truma was also compliant with the recall / had all the tabs bent over! Edited February 12 by jamesgang 3 2017 F250 Platinum D6.7L 2016 LE2 #157 with all options // Upgrades: Truma CP Plus and A/C, D52 Axles, Windows, Bath Fan, 4xTrojan AGM AES (-40F)
rideandfly Posted February 12 Posted February 12 (edited) Jamesgang, Thanks! Updated: 2010 LE2 #45 SC 50.5" D52 Original axle capacity 2014 LE2 #50 SC 50" D52 Original axle capacity & Alcan spring & Disc Brake upgrades 2015 LE2 #75 SC 50” D52 Original axle capacity 2016 LE2 #110 SC 50” D35 Original axle capacity (Gathered from Wayfinder's posts) 2016 LE2 #113 SC 50 “ D35 Original axle capacity 2016 LE2 #159 SC 50.5” D52 Upgraded axle capacity 2017 LE2 #193 SC 50.5" D35 Original axle capacity 2017 LE2 #208 SC 50.5" D35 Original axle capacity 2017 LE2 #226 SC 50.5” D52 Upgraded axle capacity & Alcan springs 2020 LE2 #579 SC 50.5" D35 Original axle capacity 2021 LE2 #898 SC 50.5" D35 Original axle capacity & Alcan springs upgrade 2023 LE2 #1386 SC 50.5" D52 Original axle capacity Please me know if information needs to be added/changed for a hull # and can also add additional campers including LE1's. Edited February 12 by rideandfly 1 2015 LE2 #75 / 2024 F-150/5.0L
Geronimo John Posted February 12 Posted February 12 Anybody know the actual differences between the D35 and D52 axles? GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rideandfly Posted February 12 Posted February 12 (edited) John, Here's how I understand it: D52 is 5200 pound axle and D35 is 3500 pound axle. The D52 has larger brakes and larger spindle that requires larger bearings and probably other different parts. Believe when an axle label says "D52 capacity: 3500 pounds" meaning the axle assembly came with a 5200 pound axle with 3500 pound springs, 4 leaf, the assembly is rated at 3500 pounds. Our LE2 came with axle labels "D52 capacity: 5200 pounds" meaning the axle assembly came with a 5200 pound axle with 5200 pound, possibly higher rated capacity springs, 5 leaf, the assembly is rated at 5200 pounds. Believe Mountainman198 posted about this in another thread, too. Edited February 12 by rideandfly 4 1 2015 LE2 #75 / 2024 F-150/5.0L
Geronimo John Posted February 12 Posted February 12 (edited) Would love to have been one of the luck owners to benefit from the 3500 pound axle shortage and got the super duty 5200 pounders. I believe I remember that they can be upgraded to disk brakes which is an option that OTT really should consider for new trailers. Thanks for the low down Bill! GJ Edited February 12 by Geronimo John 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted February 12 Posted February 12 On 7/30/2024 at 9:46 AM, Wayfinder said: @jd1923 has shown me the trees beyond the forest. I was not "getting it". Now I think I do. So maybe OTT can special order the size of axles for my trailer and install them getting all the upgrades I want at once. Hmmm. I wish I needed new axles. So I could dream about getting 5200 axles with disk brakes and springs of my choice (written so as not to kick the sleeping Spring Bear topic). Bullet Proof! But then I would need to ask Crazy Horse to rob a bank to pay for it.......... GJ 2 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
rideandfly Posted February 12 Posted February 12 (edited) Yep, they ran out of 3500 pounds axles when building our LE2 is my understanding, so they installed 5200 pound axle assemblies with 5 leaf springs. Steve installed disc brakes on his LE2 5200lb axles and Pete installed disc brakes on his LE1. The larger drum brakes on the D52 5200 pound axles are very effective and durable. When I need to rebuild the axle assemblies, disc brakes would be nice. Edited February 12 by rideandfly 5 2015 LE2 #75 / 2024 F-150/5.0L
MAX Burner Posted February 14 Posted February 14 On 2/12/2025 at 12:02 PM, Geronimo John said: I believe I remember that they can be upgraded to disk brakes which is an option that OTT really should consider for new trailers. 100% concur, @Geronimo John, John! We've got the disk brake upgrade on our radar and will likely drop the hammer on them when our current 12" drums need replacement...FYI 1 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Wayfinder Posted June 7 Author Posted June 7 Well, I know I dropped off for a year. It's been busy. I can't wait to retire. I just opened a ticket with OTT to see if they can custom order the axles with the SC=50" measurement. I will triple check tomorrow as I'll get under the trailer again. We'll see what they say. Thanks to all for all the great information. Priceless. Chris Chris 2016 Legacy Elite II o--o Hull #110 o--o Wayfinder o--o Twin Bed o--o 2020 RAM 1500 Limited 5.7L Augusta, Georgia
Geronimo John Posted Tuesday at 07:10 PM Posted Tuesday at 07:10 PM Chris: I have CONFIRMED that Dexter does make the D60 5200's with the SC of 50". They have been in use at OTT in some hulls under #100. GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted Tuesday at 09:48 PM Posted Tuesday at 09:48 PM On 7/16/2024 at 1:27 AM, Wayfinder said: 23I asked Jason about that very thing, moving the hangers. He was not keen on that idea at all in fear it would not, or could not easily, be done well enough. I suspect that he is concerned about needing to do an absolute clean off of the HDG material for a critical structural weld. The threshold for "Well Enough" in this case needs to be very very high. Axle Info: 2018 LE2 #342 SC 50.5, D35 Original axle capacity 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
