Moderators SeaDawg Posted February 15 Moderators Posted February 15 We I installed the little orion in the boat this week. It's a great little piece of equipment. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Ronbrink Posted February 16 Posted February 16 On 2/10/2025 at 9:30 PM, jd1923 said: Either way, mounting under the bumper was the mistake made. Besides the greater chance for damage, it makes it hard to reach. I'm thinking the cables and SB175 will come out somewhere between the bumper and license plate. Recently completed the cable transfer from my former TV to the Savana van for the DC-DC setup. On the former, the 7-pin outlet was well protected on the bumper next to the license plate and at the recess designed for a ball hitch mount, the receiver hitch being below the bumper. The van however, came stock with the trailer cable connections affixed to the receiver hitch cross beam, underneath the bumper. That being, I mounted the DC-DC Anderson connection likewise. My hope is the rather robust receiver hitch cross beam will serve as a skid plate and protect said connections! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
Ronbrink Posted February 16 Posted February 16 (edited) On 2/10/2025 at 9:30 PM, jd1923 said: For the DC-DC charger, I'm not going to pop the hood and throw a switch every time we hitch and unhitch. Much too much bother. You may recall, I installed a solenoid to activate power to the DC-DC cables leading to my rear bumper-mounted Anderson when the motor is running and thus, no power when off. That said, I also do not want these cables powered while running and not trailering, unless the Anderson is needed for others purposes like the VIAIR or an alternative Dometic fridge/freezer power source. Therefore, I installed a toggle switch for the solenoid trigger wire, which leads into the van interior for convenient toggle activation, as needed. Edited February 16 by Ronbrink 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
Ronbrink Posted February 16 Posted February 16 (edited) On 2/10/2025 at 9:30 PM, jd1923 said: Admin, please remove this, I inadvertently made a duplicate post. Thanks Edited February 16 by Ronbrink Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
jd1923 Posted February 16 Posted February 16 1 hour ago, Ronbrink said: You may recall, I installed a solenoid to activate power to the DC-DC cables leading to my rear bumper-mounted Anderson when the motor is running and thus, no power when off. Agreed Ron, you have automated this with an ignition circuit solenoid and if I though it was more important, your design is the way I would go too. I was referring to others who have mounted a manual switch under the hood. Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ronbrink Posted February 16 Posted February 16 (edited) 43 minutes ago, jd1923 said: Agreed Ron, you have automated this with an ignition circuit solenoid and if I though it was more important, your design is the way I would go too. I was referring to others who have mounted a manual switch under the hood. Understood, I was simply reinforcing your thoughts about having an on/off switch under hood and sharing an alternative to others on the matter. Originally, I installed a circuit breaker fuse with manual reset to serve as an on/off switch as well, but added engine temps during extreme heat conditions would cause it to trip. No bueno! I replaced it with an ANL fuse holder/60A fuse for cable protection and the toggle switch for manual on/off capability; again, information for those that may not be in the know. Edited February 16 by Ronbrink 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Hughes Autoformer, dual Lagun tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, Dreiha Atmos 4.4 A/C upgrade. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone Refrigerator and Freezer; pending transfer of Mechman 320A high output alternator from former TV.
Geronimo John Posted February 16 Posted February 16 3 hours ago, Ronbrink said: Recently completed the cable transfer from my former TV to the Savana van for the DC-DC setup. On the former, the 7-pin outlet was well protected on the bumper next to the license plate and at the recess designed for a ball hitch mount, the receiver hitch being below the bumper. The van however, came stock with the trailer cable connections affixed to the receiver hitch cross beam, underneath the bumper. That being, I mounted the DC-DC Anderson connection likewise. My hope is the rather robust receiver hitch cross beam will serve as a skid plate and protect said connections! Your logic line is the same I used. I also figured that there was no way that the ground would ever get in the way of my Anderson that I had mounted below and in front of the rear bumper on our F-150. But alas a young driver on a very tight mountain switchback trail road proved me wrong. He unknowingly backed my TV into the sloped side of the mountain and crushed my TV Anderson plug. No electrical problems as I always turn off power at the battery circuit breaker when not towing. Experienced as your are, I know that you'll be wise when backing back up to bumper blocks and curbs. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
jd1923 Posted February 17 Posted February 17 (edited) Yay, wired our Oliver for the DC-DC charger today! (TT side only, wire lengths installed hitch to buses, no connections made yet) An injury and then rebuilding the waste valves took precedence. But after Reading @Ronbrink's comment (thanks Ron) about running the wires around the toilet and not having to remove the vanity shelf, I thought since I have the waste valves removed under the front dinette seat, I should get this done before putting them back in. I pulled the two valves yesterday and then thought, a couple of hose clamps and I could pull it all out and inspect for condition inside and clean the area. Good thing I rinsed the toilet 4 times when we dumped tanks. The 4 AWG wire is now laying across the floor in the picture. It made the wiring soooo easy! I stuck my head down where the waste valves were installed and looking forward I could see the OEM installed cables coming through the hull. I'll see if I can take a picture of it. If they truly sold me 65 ft and I have 28 left, then I used 37 ft for the round-trip in the Oliver (2 x 18.5 ft). I ran it as straight as can be leaving some extra length where the buses are located under rear dinette seat, and outside I made it 5" longer than the trailer cable to be safe. The amount left over is enough for the + run to the starter battery (~20 ft) with 8' left over for rear and front frame grounds, and a 4 AWG straight run from battery to alternator. We're leaving to Catalina State Park and the Coronado NF a week from Monday, so completing the DC-DC charger installation is second to getting the waste valves finished. So glad, I got this wiring run today. I'll be happier when the plumbing is done! Edited February 17 by jd1923 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
