A few (basic?) Xantrex Inverter/charger questions. I had some recent battery charging issues which are hopefully resolved and I want to check related items to make sure settings and software status were not changed by mistake during the process.
1. Where do I find the recommended settings to confirm/adjust my current settings on the Xantrex Inverter/Charger? I have the 3000 model.
2. Any advice/warning on the potential setting adjustments related to #1 above?
3. Where do I find the recommended/current Firmware versions? (Mine currently displays U1 03 19, U2 01 28 & U3 01 07).
4. Where do I find instructions on how to download/update the firmwares if required?
Thanks.
this table shows settings for various lithium batteries.  The red is for 2 large Lithionics using the 2000 watt inverter.
Hope this helps.
One tweak to the above settings if you experience low battery shutdown when using the 3000-watt inverter to power high-wattage appliances (like the microwave) with some later 2022 Elite II hulls: reset setting No. 02 for LBCO (Low Battery Cut Off) voltage to 11.5V rather than 12.1.  Our Hull #1291 has the "new" 12V bus bar, which Jason Essary advised requires that LBCO be set to 11.5V.
  • Thanks 5
See my post on refining the settings on the Xantrex. Not sure how to link, here is the reference.
Edited by Ronbrink
The only settings that I change on the Xantrex phone app are the "breaker rating" and "charger current". If I'm at a site with a good 30a outlet, I'll turn the breaker rating all the way up to 25a or 30a, but if I'm using a little 120v outlet (like at a friend's house) I dial that back to 10a or even 5a to make sure I don't trip their breaker. The charger current gets dialed back accordingly. A third thing I've changed is the "custom absorption voltage". I was having a hard time getting the batteries all the way up to 100% SOC. They seemed to stop at 97% or 98%. I contacted Lithionics and they told me to change the custom absorption voltage to 14.6v, which I did, and haven't had that problem since.
3 hours ago, Ronbrink said:
See my post on refining the settings on the Xantrex. Not sure hoe to link, here is the reference.
@Gliddenwoods Here’s the link to above post.
**Sold😞**
I recently updated my firmware on my xantrex 3000 because I was have issues with frequent error 20 messages.  One thing I found interesting is that the xantrex instructions do not recommend updating firmware unless you are having issues. I used instructions from both the Oliver knowledge base and the xantrex page to download all three firmwares and update.
Robert and Cheryl, Louisville, KY, Legacy Elite II 2023 Hull #1390 Oliphino, TV F250 Tremor
Maybe a case of "If it ain't broke, don't fix it!" Just in case it would brick the inverter. Oh! I should install the firmware upgrades over and over until I *do* brick it. Then I'll have an excuse to swap in the Victron unit. 😉
Steve - Northern Ohio, USA
Facebook - Instagram
If you haven’t already done so, I recommend downloading the FXC Xantrex Control app. It makes it much easier than using the remote display to check or change the settings.
Mike
  • 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler
  • 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
  • 5 months later...
On 10/22/2024 at 9:51 AM, Galway Girl said:
Following this as I’m about to buy the Xantrex Freedom XC PRO to go with my 2 new 300 ah Lithiums. Thanks for posting this info.
2017 Oliver Elite II Hull 292
2018 Nissan Armada
Tampa, FL
Thanks.
This was meant for Teaney Hull 292
I suggest you reach out to Xantrex. They have great custer and technical support.
I would also reach out to Oliver to get the chart for the Xantrex Settings. support@olivertraveltrailers.com
Oliver might be able to provide for firmware update info as well.
Submit a service ticket to the above email.
Edited by John Dorrer
Updated Comment
