2008RN Posted July 7, 2025 Posted July 7, 2025 (edited) We are just getting to washing the Oli after our 48 day trip. When we pulled the mattresses up we found signs of water under the condensation mats. So when we washed the Olivers outside. We pulled up the mats and mattresses and put them in the isle. When we sprayed the windows to wash of the soap both bed windows, kitchen window, and the bathroom window screen track over-flowed with water and ran down the wall. I removed the outside rubber and cleaned the out track and insured the weep holes were clean. I had my wife spray the windows at about 10 feet away with a 2ft pattern. The water went around the window and felt(?) in a couple of seconds and start filling up the screen track. In the past I never had problems with leaking when washing the windows. The outside rubbers are tight against and the end of the fixed window and there is about 1/2 space at the top of the window where the rubber stops. ie: the Rubber is short. I found the felt track was cover a weep hole between the window track and the in the street side bed window. I also noticed there was a big different between the felt/gasket in the exit window was much different than in the windows. I tried to get one end of the felt out in the street bed window, but it seemed like it was going to rip so I stopped. We never use the exit slider. We use the others window sliders constantly. The chalking around the windows appears to be in good all around? Questions. 1. Is it alright for the weep hole between the window track and the outside track to be covered up by the felt? 2. If the water leaking through/over/under the window and felt in seconds are the felts worn out? If it is can it be easily replaced? Does the Track under the felt need to be cleaned? 3. Is the outside rubber suppose to be tight against the window? Three pictures of close up of the felt are attached. one is the curb window showing the partial weep hole, the other is the street side bed window. The last in the exit felt which felt more like the rubber bump that sticks up 1/16" more and is plump and is tight against the slider then it opens. Thanks for your help, Bob Curb side with partial weep hole street side Exit window Edited July 7, 2025 by 2008RN Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Patriot Posted July 7, 2025 Posted July 7, 2025 (edited) 3 hours ago, 2008RN said: 1. Is it alright for the weep hole between the window track and the outside track to be covered up by the felt? Bob, Any time your weep holes are blocked by felt or debris, water cannot flow and escape/drain. My weep holes are not blocked by felt and are clear. We have never had an issue with water intrusion on our 2020. I am meticulous about keeping the window tracks clean after every trip. I use compressed air from a can on trips or my air compressor at home. On much longer trips I will still periodically check my window tracks for dirt and debris to prevent this exact issue. Along with window gutters which do a good job of redirecting light rain off our windows, I have found it’s really critical to have our Oliver dead level when set up. When level even in a hard rain I have watched my window tracks slowly fill up with water and drain out the weep holes as designed, but the trailer must be level. We have been through some really hard “car wash” side way rain type thunder storms as recently as the last Oliver Rally and have not had any water intrusion. I attribute this to clean windows tracks and a level rig. I am not sure you can replace the felt, I think not. The exterior rubber seal covering your window track should be snug tight against the window glass and seated in the window track. When I reinstall the seal after cleaning the tracks, I install it with a slight angle from the glass to the edge of the frame. You also do not want any gap in this exterior seal along the track. A gap in the seal will allow in more water than the window track can handle and this will result in a trickle or overflow into your interior wall. Not the best window design IMO as it requires regular inspection and cleaning. Hopefully Oliver has addressed the window design with new tilt out windows which hopefully completely eliminate this issue. Others will surely chime in with their thoughts and suggestions. The above process has worked for me since we purchased our Oliver new in 2020. Patriot 🇺🇸 Edited July 7, 2025 by Patriot 4 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John Dorrer Posted July 7, 2025 Posted July 7, 2025 (edited) We use a vacuum and check the tracts daily. We also have compressed air (used for computer keyboards) that we are going to try. We have knotted rope weeps that are in each window weep. They draw the water out of the track. You have inner and out window weeps that need to be cleaned and completely open. Edited July 7, 2025 by John Dorrer Typo 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Galileo Posted Sunday at 09:49 PM Posted Sunday at 09:49 PM Maybe it’s been addressed in another thread, but I have a “detail cleaning” of our windows in my schedule for tomorrow. we’ve had several days of very heavy rain here (Chicago area) and the whole bed was pretty soaked. The folks at the delivery “event” with us were adamant about keeping the drain holes clear - but the didn’t mention the drains in the slider tracks - which - if clogged - will let water drain into the interior. Pretty poor design IMHO. 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Steph and Dud B Posted Sunday at 11:20 PM Posted Sunday at 11:20 PM Yep, we just had a window leak on our last trip that soaked my bed. Found one of the interior track drain slots clogged. I carry a small length of trimmer line in my toolkit to run down under the track liner and through the drain slots. Also, a little water bottle - like a squirt ketchup bottle - for flushing. Having a wet bed isn't fun. Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
2008RN Posted Monday at 06:30 AM Author Posted Monday at 06:30 AM (edited) I don't know if it is going to help but I use a Dremel bit and increase the Drain slot height from about 3/32 to a little over 1/8' on both the inside and outside drain slots. I also put gutter "J" tracks over the windows, mostly to help the street side windows. We did have a couple days of rain in Yosemite in April, and no leaks. They weren't flooding rains though. There are other threads about window leaking, I also cleaned all tracks throughly inside and out. Good luck. Edited Monday at 06:32 AM by 2008RN Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
Galileo Posted Monday at 12:43 PM Posted Monday at 12:43 PM (edited) I don’t know if this is a revelation or if somebody else has figured this out - or if I’m completely wrong - but - Unless the drain holes - inner and outer - are blocked so badly that the window tracks overflow entirely - there’s no reason why water would leak inside the trailer. From what I could see there was only a tiny bit of water in the bottom of the tracks that was visible through the holes in the plastic track guide. However - there’s IS a stop/bumper at the forward travel of the lower window track. It’s a rubber “foot” like you might see on the bottom of an appliance to keep it from scratching a countertop. On my leaky window - this screw was quite loose. I noticed when I removed it to try to clean out the track. The stop (hole in the frame) does happen to be right above where the water is leaking into the trailer. The leak is between the window frame and the inner wall of the trailer. As I say - I might be smoking something, but I’m thinking this is the only(?) place where there is a hole low enough in the track to leak water inside the trailer unless the track is filled with water. I plan to dry out the track, make sure that hole is clean, then reinstall the number and screw with some sealant in the threads. Update to follow. added: Looking at the frame and inner plastic track/guide - I can’t tell if the hole for the screw actually goes through the frame. I figured that for the stop/bumper to have any strength, it would have to. And the screw looks long enough. There’s also a coloration difference at the tip of the screw that indicates it was into the aluminum frame. Either way, drilling a hole through the bottom of the frame is a pretty dumb way to add a window stop. Edited Monday at 01:01 PM by Galileo More information. 1 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
Galileo Posted 11 hours ago Posted 11 hours ago Though I’ve cleaned and dried out the hole where this screw/bumper go, and re-installed it with some sealant, I won’t know until the next rain if it fixes the problem. Upon looking closely at the window, I discovered that the center muntin (divider between the fixed and moveable window) is held in place by screws through the bottom - and I assume - top of the window frame. It’s just as likely that the screw in the bottom of the window frame is a source for the leak as this number. If that turns out to be the case, the whole window will likely need to come out to remove, clean, seal, and re-install the window. That should be fun (not). 2022 Oliver Legacy Elite II Hull #1029 King Bed Floorplan electronics package Truma Aqua-Go LOUD Dometic Penguin A/C LevelMate Pro+ Valterra Electric Black Tank Dump Valve TV - 2025 GMC Sierra 1500 Denali, 3.0l Duramax Diesel, Crew Cab 4WD RealTruck hard tonneau cover Rove R2-4K DashCams Canada: New Brunswick, Nova Scotia, Prince Edward Island
2008RN Posted 1 hour ago Author Posted 1 hour ago (edited) On 6/22/2026 at 5:43 AM, Galileo said: Either way, drilling a hole through the bottom of the frame is a pretty dumb way to add a window stop. I totally agree. During my intense cleaning this winter. I removed the bumper and slid the tracks around to get things clean. That was one of the first things I noticed that it was a leak point. Secondly the stopper clamps down enough on the track that it would probably that it would stop the flow of water out the weep holes. I have thought about leaving the stopper out and plugging the hole with chalk. Edited 1 hour ago by 2008RN Early 1999 Ford F250 SD 7.3L Diesel 2020 Elite II Twin - Hull # 648
