We are just getting to washing the Oli after our 48 day trip.  When we pulled the mattresses up we found  signs of water under the condensation mats.  So when we washed the Olivers outside.  We pulled up the mats and mattresses and put them in the isle.
When we sprayed the windows to wash of the soap both bed windows, kitchen window, and the bathroom window screen track over-flowed with water and ran down the wall.
I removed the outside rubber and cleaned the out track and insured the weep holes were clean.   I had my wife spray the windows at about 10 feet away with a 2ft pattern.  The water went around the window and felt(?) in a couple of seconds and start filling up the screen track.  In the past I never had problems with leaking when washing the windows.  The outside rubbers are tight against and the end of the fixed window and there is about 1/2 space at the top of the window where the rubber stops.  ie: the Rubber is short.
I  found the felt track was cover a weep hole between the window track and the in the street side bed window.  I also noticed there was a big different between the felt/gasket in the exit window  was much different than in the windows.   I tried to get one end of the felt out in the street bed window, but it seemed like it was going to rip so I stopped.  We never use the exit slider.  We use the others window sliders constantly.
The chalking around the windows appears to be in good all around?
Questions.
1.  Is it alright for the weep hole between the window track and the outside track to be covered up by the felt?
2.  If the water leaking through/over/under the window and felt  in seconds are the felts worn out?   If it is can it be easily replaced?  Does the Track under the felt need to be cleaned?
3.  Is the outside rubber suppose to be tight against the window?
Three pictures of close up of the felt are attached. one  is the curb window showing the partial weep hole, the other is the street side bed window.  The last in the exit felt which felt more like the rubber bump that sticks up 1/16" more and is plump and is tight against the slider then it opens.
Thanks for your help,
Bob
Curb side  with partial weep hole
street side
Edited by 2008RN
Bob,
Any time your weep holes are blocked by felt or debris, water cannot flow and escape/drain. My weep holes are not blocked by felt and are clear. We have never had an issue with water intrusion on our 2020. I am meticulous about keeping the window tracks clean after every trip. I use compressed air from a can on trips or my air compressor at home. On much longer trips I will still periodically check my window tracks for dirt and debris to prevent this exact issue.
Along with window gutters which do a good job of redirecting light rain off our windows, I have found it’s really critical to have our Oliver dead level when set up. When level even in a hard rain I have watched my window tracks slowly fill up with water and drain out the weep holes as designed, but the trailer must be level. We have been through some really hard “car wash” side way rain type thunder storms as recently as the last Oliver Rally and have not had any water intrusion. I attribute this to clean windows tracks and a level rig.
I am not sure you can replace the felt, I think not. The exterior rubber seal covering your window track should be snug tight against the window glass and seated in the window track. When I reinstall the seal after cleaning the tracks, I install it with a slight angle from the glass to the edge of the frame. You also do not want any gap in this exterior seal along the track. A gap in the seal will allow in more water than the window track can handle and this will result in a trickle or overflow into your interior wall. Not the best window design IMO as it requires regular inspection and cleaning.
Hopefully Oliver has addressed the window design with new tilt out windows which hopefully completely eliminate this issue. Others will surely chime in with their thoughts and suggestions. The above process has worked for me since we purchased our Oliver new in 2020.
Patriot 🇺🇸
Edited by Patriot
We use a vacuum and check the tracts daily. We also have compressed air (used for computer keyboards) that we are going to try.
We have knotted rope weeps that are in each window weep. They draw the water out of the track.
You have inner and out window weeps that need to be cleaned and completely open.
Edited by John Dorrer
Typo
  • 11 months later...
Maybe it’s been addressed in another thread, but I have a “detail cleaning” of our windows in my schedule for tomorrow.
we’ve had several days of very heavy rain here (Chicago area) and the whole bed was pretty soaked.
The folks at the delivery “event” with us were adamant about keeping the drain holes clear - but the didn’t mention the drains in the slider tracks - which - if clogged - will let water drain into the interior.
Pretty poor design IMHO.
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
(17.9mpg towing, 35mpg clean)
RealTruck hard tonneau cover
Rove R2-4K DashCams
Yep, we just had a window leak on our last trip that soaked my bed. Found one of the interior track drain slots clogged. I carry a small length of trimmer line in my toolkit to run down under the track liner and through the drain slots. Also, a little water bottle - like a squirt ketchup bottle - for flushing. Having a wet bed isn't fun.
I don't know if it is going to help but I use a Dremel bit and increase the Drain slot height from about 3/32 to a little over 1/8'  on both the inside and outside drain slots.   I also put gutter "J" tracks over the windows, mostly to help the street side windows.    We did have a couple days of rain in Yosemite in April, and no leaks.  They weren't flooding rains though.    There are other threads  about window leaking,  I also cleaned all tracks throughly inside and out.
Good luck.
Edited by 2008RN
I don’t know if this is a revelation or if somebody else has figured this out - or if I’m completely wrong - but -
Unless the drain holes - inner and outer - are blocked so badly that the window tracks overflow entirely - there’s no reason why water would leak inside the trailer. From what I could see there was only a tiny bit of water in the bottom of the tracks that was visible through the holes in the plastic track guide.
However - there’s IS a stop/bumper at the forward travel of the lower window track. It’s a rubber “foot” like you might see on the bottom of an appliance to keep it from scratching a countertop. On my leaky window - this screw was quite loose. I noticed when I removed it to try to clean out the track. The stop (hole in the frame) does happen to be right above where the water is leaking into the trailer. The leak is between the window frame and the inner wall of the trailer.
As I say - I might be smoking something, but I’m thinking this is the only(?) place where there is a hole low enough in the track to leak water inside the trailer unless the track is filled with water.
I plan to dry out the track, make sure that hole is clean, then reinstall the number and screw with some sealant in the threads.
Update to follow.
added:
Looking at the frame and inner plastic track/guide - I can’t tell if the hole for the screw actually goes through the frame. I figured that for the stop/bumper to have any strength, it would have to. And the screw looks long enough. There’s also a coloration difference at the tip of the screw that indicates it was into the aluminum frame.
Either way, drilling a hole through the bottom of the frame is a pretty dumb way to add a window stop.
Edited by Galileo
More information.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Though I’ve cleaned and dried out the hole where this screw/bumper go, and re-installed it with some sealant, I won’t know until the next rain if it fixes the problem.
Upon looking closely at the window, I discovered that the center muntin (divider between the fixed and moveable window) is held in place by screws through the bottom - and I assume - top of the window frame. It’s just as likely that the screw in the bottom of the window frame is a source for the leak as this number. If that turns out to be the case, the whole window will likely need to come out to remove, clean, seal, and re-install the window.
That should be fun (not).
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
I totally agree.  During my intense cleaning this winter. I removed the bumper and slid the tracks around to get things clean.  That was one of the first things I noticed that it was a leak point.  Secondly the stopper clamps down enough on the track that it would probably that it would stop the flow of water out the weep holes.    I have thought about leaving the stopper out and plugging the hole with chalk.
Edited by 2008RN
Well - so far - the window leak appears to have been fixed.
Been raining here for a couple of hours - not heavy - but it didn’t have to be to leak.
I can see a trace of water through the holes in the plastic track - which is what I had seen previously - but none is leaking down the wall.
That said - I’ll have to keep an eye on this as if I should open the window fully and it hits the stop - it may break that seal. I suppose that this winter I’ll have to put a slightly longer, thicker screw in to get a better grip as I think that only the first few threads of the existing one engage the metal of the frame.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
Well, I appear to have spoken too soon.
We’ve had several days of torrential rain and some pretty intense thunderstorms with high winds and flood warnings here in Starbuck, MN. Through the first few deluges it seemed we were all set.
Last night - another wave of storms came through and I’m seeing a trickle of water now and then. It’s coming from between the frame of the window and the inner shell of of camper body - so it’s not filling and overflowing the track. It’s leaking out the bottom of the track.
Perhaps the repair I did to the window stop screw wasn’t sufficient, or perhaps that screw holding the center muntin in through the bottom of the window frame is the culprit.
Either way, I’m getting a little fed up with the lack of care that goes into building at $65,000 (at the time) trailer. It’s making it very difficult to answer the question: “So, how do you like your Oliver?” when people approach us at campgrounds…..
  • Sad 1
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
I think I would remove the stopper, then pump some caulk down the screw hole and the level it off on top so it does not impede the draining of the tracks.  What a Pain.
That’s kinda my next thought.
With the inner/plastic “track” in place, you really can’t get too the hole where the screw holding the stopper is. Unless you’re an endodontist and used to working down inside small, wet areas. 😂
I figured I could cut off that end of the track as the stopper & screw fit down inside of it. That would give me a better look at the hole in the frame and the option of either replacing the stopper & screw and having better access to seal it and having the screw length be able to get a better grip. Or - just doing as you suggest with some waterproof sealant.
And a pain? By all means. These windows are a disaster from design to operation. WHY in heaven’s name would someone design a window that is so fussy that a little dirt or some bits of tree cause it to leak? Even worse - making holes in the wet part of the frame to install things that are GOING to get bumped and dislodged. (Slide the window a bit too far open? You just compromised that weak seal.
It really makes me wonder about Oliver’s selection of these windows - and some other accessories as well. The fiberglass hull is great - but not many of the things bolted onto it are equal to the hull.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
On my Oli, I removed the rubber track cover and exposed the end of the felt track insert.  I used two picks from my small O'ring pick and hook set to loosen the sides of the track and lifted one side of the track and then gently pull the one side up and rotated the track out of the slot.  I was able to exposed the track bottom within about 3-4 inch of the center divider.  I was then able to enlarge to drain holes and completely clean the inner track  bottom.
If you can get the Felt track insert up, then you will have a lot more room to get a small tube of chalk in the area and force it through the hole.
My windows may be a bit different.
Mine font really have much of a “felt” liner. They have a rigid plastic inner track that is inside of the frame channel. I tried to (gently) pry it out, but it started to crack.
I do have the pick set similar to what you used. I guess I could see if I can draw the sides of the plastic track in, the whole thing may lift out of the channel. It isn’t a “U” channel - more of a squared off “C”
Edited by Galileo
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
When I first tried to get one of my track liners out  with a small screw driver it also started to crack.  I was extremely paranoid to continue on.  I tried other things to clean the tracks.  Then I final gave it another shot.  when I loosen the sides with the picks I do at least 6-8" ahead. Then using the 90 degree pick I place it under the bottom side of the where I am trying to pry that side out.   Since I get it out far enough to grab with my fingers I pull it up a little then continue to work it  with the picks while slowly rotating the side side out.    I still had one side start to crack.
I have no idea if those track liners can be purchased to replace the old ones.   I did get daring on one window a slide the track liner one way be a few inches.  It was snug so I stopped not wanting to any more damage to the fragile track liners.
I do agree, these windows suck!  What happens when these windows fail completely?   Is there a way to salvage this expensive shell to make it back into a usable camper???
I know that components in the camper are going to fail.  There are things that will be hard to replace,  Like the bathroom door/ handle, the fridge, all of the windows.  I know  that many Camper Trailers with 22K miles and 6 years old would have started to fall apart already.  But these are not a cheap A-- Trailers.  I bought Oliver for the quality and longevity and not an Airstream.    Sorry for the rant.
I’ve only had one window leak, my fault all it needed was a go cleaning of the track..  I use old shoe laces in the the weep holes there work great..No more leaks.. just cut them about 2 - 3 inches and a slight tilt to the rear of the camper..  Try to stay cool out there..
2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Yep and Yep.  At least for our older trailers, annual cleaning (or more often in some locations) and gutters are the only fixes that worked in our case.
We use a compressor and small nozzle at the end to blow out the track drains.
Also have used pipe cleaners and wire in the past.
The window design is pretty much window industry standard. My home windows also have weepholes.
If drains/weephole are clear, you have other issues. Definitely eyebrows/gutters help, but is there another issue?
Edited by SeaDawg
Spelling
Anywhere and any time there is heavy dust -- in other words, places that are dry (the west in general) and places that have heavy farming and/or ranching and places with a lot of pollen. I find that it takes a lot more than an annual cleaning to keep these clear, but it's not hard or too time-consuming, and well worth it. I just use the pipe cleaner method and hand wiping, I don't have a compressor, but I might try canned air (like the kind used for darkroom photography, to clean the film).
my Oliver has camped here
I rarely have access to a compressor with a tank large enough to be effective in blowing out the Ollie window tracks.  But when I do, I use a LOT of air.  Hence, if you are thinking of going the canned air route....... I suggest you get a case (or two) of them.
Get one of these instead. 😎 Price dropped $12 since I bought one in May!
https://www.amazon.com/dp/B0DHNG4DL8/
Oh!
Edited Thursday at 06:26 PM by SeaDawg
Spelling
Yep - our drain holes are clear, tracks are clean, and rig is level.
Almost certain our issue is the way they mounted the window stop/bumper by drilling a hole through the bottom of the frame. Anything fit a perfectly dry track equated to a steady drip of water between the shells - or into the interior.
Only other suspect is a similar hole drilled through the bottom of the frame to hold the center vertical muntin in place.
Both really terrible design & construction.
King Bed Floorplan
electronics package
Truma Aqua-Go
LevelMate Pro+
Rove R2-4K DashCams
The wide outside seals can also cause issues.
