DWR Posted July 12, 2025 Posted July 12, 2025 Fresh water tank full. All lines full of water. Unhooked City water connection. Valves in normal mode. Turn pump on. Opened all faucets one at a time. Pump works fine. Shut off faucet, pressure builds and pump shuts off. Travel to boondocking site., and the pump runs and doesn't build pressure and shut off. Not sure why. Checked connections. No leaks. Any thoughts? Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
johnwen Posted July 12, 2025 Posted July 12, 2025 Try opening a faucet for a few seconds...usually you can hear a change of the pump sound as it primes. Then close the faucet and see if the pressure builds. You may have lost the prime as you traveled. 4 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
DWR Posted July 12, 2025 Author Posted July 12, 2025 I have gone through all faucets and opened them and closed them. I can hear changes in the sound of the pump. Always keeping under the 2 minute recommendation for pump run time. Does not improve. Still stumped...... I have cycled through 4 minutes of cracking open faucets. Seems like a lot of air in lines. Perhaps I am leaving the faucets open to long. More than a few seconds....... Pump runs very quiet compared to when all is working properly........ Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
Steph and Dud B Posted July 12, 2025 Posted July 12, 2025 We've had this problem repeatedly in the exact scenario you describe. The "solution" was to open the hot and cold outside shower until the air purged from the system, which could take a couple of minutes. (Don't worry to much about the 2 minute limit. I once accidentally left the pump on for 20 minutes after draining the water from an old trailer and there was no harm done. 3 or 4 minutes is probably OK.) After that we'd be fine until the next stop when we'd have to do it again. Seemed like an air leak on the pump intake side, but I couldn't find one. I recently replaced the pump. One thing I noticed while doing that was that the pump filter didn't seem very tightly screwed onto the pump, something I had never thought to check, so look at that. Now the new pump is in. We'll see what happens next. Also, can you include your Oliver model and model year in your signature line? Makes it easier to help people sometimes. 1 5 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
jd1923 Posted July 12, 2025 Posted July 12, 2025 (edited) 1 hour ago, Steph and Dud B said: Also, can you include your Oliver model and model year in your signature line? Makes it easier to help people sometimes. Yes, this is certainly a must! (at least your hull #) After I fill the FWT, I put the hose on City Water and fill the 6-gallon Suburban HWH (we don't know if you have this or the Truma on-demand model). Then bleed the air out of the toilet first (if you have a standard model) then all faucets. Yes, good idea to also bleed the outdoor shower as it can be forgotten and you're right there when filling water! We have never run into the issue of air in the lines later (how does air appear out of nowhere?)! OTT installs bare minimum water pumps! Fancy hulls, bottom-end pump that could use more PSI and GPM! Maybe we never have this issue due to installing a high-end US made variable-speed pump? This pump can run dry for days! Highly recommended. 😂 Edited July 12, 2025 by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
DWR Posted July 13, 2025 Author Posted July 13, 2025 I have gone through all faucets and opened them and closed them. I can hear changes in the sound of the pump. Always keeping under the 2 minute recommendation for pump run time. Does not improve. Still stumped...... I have cycled through 4 minutes of cracking open faucets. Seems like a lot of air in lines. Perhaps I am leaving the faucets open to long. More than a few seconds....... Pump runs very quiet compared to when all is working properly........ Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
DWR Posted July 13, 2025 Author Posted July 13, 2025 Oliver haul #1619, 2025.Legacy Elite 2. Thank you.... I will did follow the de winterization procedure. Thinking going back to a known starting point would be prudent. I will continue and let every one know how it works out.... Again thank you so much for your responses. I absolutely love this travel trailer. But I do have a learning curve to work through. Worked all day, and am "home" for the night. I did have a concern about the trauma water heater with so much air in the lines...... Did not want to harm that in any way. Any thoughts on that? Again thank you all ....... Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
Tom and Doreen Posted July 13, 2025 Posted July 13, 2025 (edited) You can try setting your valves to the normal position, turn your pump on, then turn the valve circled in the picture below 'on' briefly. You will hear water rushing into your fresh tank. What this does is pump water from your fresh tank back into your fresh tank. This will purge the air out of the pump and associated components. This has happened to me many times after traveling and arriving at a site, somehow air gets into the system. Edited July 13, 2025 by Tom and Doreen 5 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
DWR Posted July 13, 2025 Author Posted July 13, 2025 thank you.... will give it a try........ Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
DWR Posted July 13, 2025 Author Posted July 13, 2025 I see there is no teflon tape where the screen attaches to pump. Made me raise an eyebrow. That connection might not be the best without it..... Just thinking out loud..... Thanks again..... Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
Steph and Dud B Posted July 13, 2025 Posted July 13, 2025 Now that you mention it, ours doesn't have Teflon tape there, either. Anyone have Teflon tape at the connection between the pump and its filter? Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Tom and Doreen Posted July 13, 2025 Posted July 13, 2025 I believe that the filter / screen utilizes an 'O' ring for a seal and it's on the low pressure / suction side of the pump. 4 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
johnwen Posted July 13, 2025 Posted July 13, 2025 Yes... only an o-ring on ours as well...no Teflon tape. 1 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
DWR Posted July 15, 2025 Author Posted July 15, 2025 Just to follow up on post. What I found ...... No oring, where screen housing connects to pump. Flexible line attached to screen housing did seem a little loose, snugged it up. One of the "quest fittings (unsure if that is the brand) was loose enough to allow air to draw in ....... After correcting these issues, all works great. Small issues easily remedied..... Thanks for the conversations. All tips used and helpful...... 2 4 Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
DavePhelps Posted July 15, 2025 Posted July 15, 2025 Glad you discovered the problem. Regarding the water filter o-ring, I like to lube it with a small amount of silicone based plumber's grease. It helps with the seal and keeps the o-ring in good shape. Also, don't over tighten the filter screen housing. Firm hand tight is all that is needed. No tools! Cheers, Dave 1 3 2015 Oliver Elite 1, Hull 107 2025 GMC Sierra HD 2500 AT4, 6.6 L8T (gas)
DWR Posted August 9, 2025 Author Posted August 9, 2025 O Ring size: 9/16 x 3/4 x 3/32 seems to work fine....... Just thought I would throw that out there in case any one runs into the same issue...... 1 Dan and Elise. 2025 Legacy Elite 2. Hull #1619. 2025 Chevy Silverado 1500, North Central Pennsylvania
John Dorrer Posted August 9, 2025 Posted August 9, 2025 (edited) On 7/12/2025 at 1:39 AM, DWR said: I have gone through all faucets and opened them and closed them. I can hear changes in the sound of the pump. Always keeping under the 2 minute recommendation for pump run time. Does not improve. Still stumped...... I have cycled through 4 minutes of cracking open faucets. Seems like a lot of air in lines. Perhaps I am leaving the faucets open to long. More than a few seconds....... Pump runs very quiet compared to when all is working properly........ Is you outdoor shower knobs closed tight? Open outdoor faucets have caused similar issues. Update: I was replying to the original post and didn't see the complete thread🙃 Edited August 9, 2025 by John Dorrer Updated Comment 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Geronimo John Posted December 24, 2025 Posted December 24, 2025 (edited) On 7/12/2025 at 7:26 AM, jd1923 said: We have never run into the issue of air in the lines later (how does air appear out of nowhere?)! It doesn't. It is often sucked in. For example, It often is a "Sucked In" by the pump from a loose or faulty fitting on the draw side. If boondockng mode, it is ususally your hose bibb connection having a bad hose rubber gasket or is not tight. Such conditions will really slow down the transport of water from your gerry can into the pump and FWT. Just one example. Another is having a loose connection sucking air in the line that runs from the FWT to the pump. Etc. GJ Edited December 24, 2025 by Geronimo John typos 3 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderator+ ScubaRx Posted December 24, 2025 Moderator+ Posted December 24, 2025 (edited) On 7/11/2025 at 9:34 PM, DWR said: Fresh water tank full. All lines full of water. Unhooked City water connection. Valves in normal mode. Turn pump on. Opened all faucets one at a time. Pump works fine. Shut off faucet, pressure builds and pump shuts off. Travel to boondocking site., and the pump runs and doesn't build pressure and shut off. Not sure why. Checked connections. No leaks. Any thoughts? A broken or loose connection anywhere in the entire plumbing system will cause a loss of pressure. Begin at the pump. Check connections there and make sure the filter bowl is tight. Work outward from there. If you have an accumulator tank you may need to pressurize it also. Edited December 24, 2025 by ScubaRx 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Buddhabelly Posted January 9 Posted January 9 I know this is late but, I had that problem and found that the pickup tube in the tank must have a screen on the end and it can get plugged up some reason. Pumps works but, low flow. Took the hose off where it hooks to the filter and blew air in the tank direction and that cured the problem until it gets debris collected again. Takes time for the line to plugged again. I've always used a filter when filling up so I think somethings was inside the tank from new. Hiroshi 2023 Oliver Elite #1299 2024 Lexus GX550 Overtrail
Steph and Dud B Posted March 28 Posted March 28 Also a late follow-up: Like others, our filter assembly was missing the o-ring where it connects to the pump inlet. 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Geronimo John Posted November 7 Posted November 7 On 3/28/2026 at 11:39 AM, Steph and Dud B said: Like others, our filter assembly was missing the o-ring where it connects to the pump inlet. Sometimes "air sucks"....... GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
