Pat Radack Posted September 10, 2025 Posted September 10, 2025 Anyone tried the Onnais version 3 keyless locks? Anyone express any issues with the RVLock V4 keyless locks? One being more or less keyless than the other... Any issues or concerns with customer service available from either? Neither uses laser cut keys or other types of keys that most locksmiths will not duplicate. I wonder if either allows you to select your own frequency for communications between your FOB and the lock wireless receiver (I wouldn't enjoy the door unlocking during the night when a neighbor is locking/unlocking their unit). Failing that, will either allow you to turn off the FOB functionality? I wonder how many possible frequencies these FOB have the ability to use? Thoughts? Pat and Amy Radack Hull # 1189 - 2022 LEII Black 2019 RAM 2500, Cummins 6.7L, Limited, Crew Cab, 4 x 4, 6’ bed w/ Rambox 2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189 Pat and Amy
Patriot Posted September 10, 2025 Posted September 10, 2025 (edited) We have had the RVlock V4 lock on our Oliver since we purchased new and this is year 6. It has worked flawlessly since I installed it post purchase. Just make sure you replace the batteries timely. The lock will let you know when the batteries are getting low with a lower tone or faint beep. RV lock was very responsive the one time I needed to replace our key pad with the new and improved silicone key pad. The RV lock key fobs are ok. We primarily use the key pad. RV lock is a Chi/com product and you get what you get. If someone really wants in your trailer the door lock is not going to stop them. You might want to call RVlock and ask about frequencies. No, you cannot turn the fob off unless you remove the battery. The fobs are hit and miss…some work well for a long time and some don’t. We keep a spare set of keys locked up in our TV should we misplace or loose our keys. The key pad has worked great for our needs and I would replace our RVlock with the same model given our field experience. 2 hours ago, Pat Radack said: Onnais version 3 keyless locks? I have never heard of this key lock. Do you have a link? Enjoy your Oliver and go camping! Edited September 10, 2025 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
johnwen Posted September 10, 2025 Posted September 10, 2025 David, Do you by chance have a link to the one you bought? How was the blueberry crop this year? Leaving Ellsworth tomorrow trekkin back to SC :) John 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Pat Radack Posted September 11, 2025 Author Posted September 11, 2025 https://onnaisafe.com/ 1 2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189 Pat and Amy
Patriot Posted September 11, 2025 Posted September 11, 2025 20 hours ago, johnwen said: David, Do you by chance have a link to the one you bought? How was the blueberry crop this year? Leaving Ellsworth tomorrow trekkin back to SC 🙂 John Hey John, Here is the link for RVlock.com - https://www.rvlock.com/?utm_source=google&utm_medium=paid&utm_campaign=1748190371&utm_content=69572607838&utm_term=rvlock v4&gadid=392517272318&gad_source=1&gad_campaignid=1748190371&gclid=Cj0KCQjw5onGBhDeARIsAFK6QJYJgFt5RvAk6-wVwyX33R2FaM6mQ2LRvyTXSJpmPQMbw1L02n294R8aAvwnEALw_wcB As for the specific model I believe it is the V4, but if you give RVlock a call I am pretty sure they can get you the exact model you need, they have sold a lot of locks. It’s been a long time since purchased and I installed ours. Blueberries were at rest this season. We pruned heavily last fall. Next summer we hope for a good crop! 😊 Safe travels as you make your way back to SC! Hello to Wendy! 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Tom and Doreen Posted September 11, 2025 Posted September 11, 2025 We've had two RVLocks fail, on the first one a circuit board failed, the second one had a mechanical failure which we were advised (by the manufacturer) to loosen the internal screws that held a metal plate in place; I don't have a lot of confidence in the second fix but it seems to be working for now. Lot's of people seem to have this lock and are happy with it though. 2 Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Steph and Dud B Posted September 11, 2025 Posted September 11, 2025 We've also had 2 RVLocks fail. Will install something else next time. 2 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Pat Radack Posted September 12, 2025 Author Posted September 12, 2025 Got an email from RVlock today. They are trying to get me the correct battery for the single, non-functional FOB I have. They stated quite clearly that their keys are laser cut and can not be copied. Perhaps that is what they are currently using. The key I have was just duplicated by my locksmith. He wouldn't, however, duplicate the key that locks/unlocks the FT. Knox Locks puck that covers/secures the bulldog on the # 1189. I will ask again and send a photo. 2019 RAM 2500 Limited 4x4 Crew Cab Black. Hull # 1189 Pat and Amy
Boilermaker Chemist Posted September 12, 2025 Posted September 12, 2025 I just installed a Bauer Bluetooth Keyless Entry Door Lock. Currently on sale at Camping World for $217. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Patriot Posted September 13, 2025 Posted September 13, 2025 On 9/11/2025 at 10:21 PM, Boilermaker Chemist said: I just installed a Bauer Bluetooth Keyless Entry Door Lock. Currently on sale at Camping World for $217. Maybe post up a link to the exact model Bauer lock you purchased. It would help others if they decide to purchase. 👍🏻 1 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Boilermaker Chemist Posted September 13, 2025 Posted September 13, 2025 (edited) @Patriot thanks for the suggestion, here you go: https://www.campingworld.com/bauer-bluetooth-keyless-rv-entry-door-lock-124590.html?objectID=124590&queryID=46bc1a32228c9fdf516d0676ebf18aca&indexName=production_na01_campingworld_demandware_net__CampingWorld__products__default Also, E-trailer has a nice video review here: https://www.etrailer.com/RV-Door-Locks/Bauer-Products/BA53UR.html E-trailer also has spare keys for the lock too. Edited September 13, 2025 by Boilermaker Chemist Added photos 1 1 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Rivernerd Posted September 15, 2025 Posted September 15, 2025 On 9/11/2025 at 6:07 AM, Tom and Doreen said: We've had two RVLocks fail, on the first one a circuit board failed, the second one had a mechanical failure which we were advised (by the manufacturer) to loosen the internal screws that held a metal plate in place; I don't have a lot of confidence in the second fix but it seems to be working for now We opted for the manual door lock in our 2022 Elite II based on reports on this forum of folks getting locked in or out of their Olivers by failed RV Lock units. No issues with key duplication. We keep a spare Oliver door key in a compartment in our tow vehicle. Low tech, but so far, no issues. 6 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2026 Ford F350 Crew Cab with 7.3L gas engine
jd1923 Posted September 15, 2025 Posted September 15, 2025 (edited) 38 minutes ago, Rivernerd said: We opted for the manual door lock in our 2022 Elite II based on reports on this forum of folks getting locked in or out of their Olivers by failed RV Lock units. No issues with key duplication. We keep a spare Oliver door key in a compartment in our tow vehicle. Low tech, but so far, no issues. Our Oliver came with the Lippert chrome manual lock. We also read here regarding many failures to the touch pad and batteries loosing charge at just the wrong time. $220+ for keyless entry, sorry no thank you. Our hull being 10 years old, the door lock is still working as designed but gear mechanisms and striker parts do wear out over time. I found this on Amazon and at the time it was only $50, same lock in a nice white powder coat. It's for when we need it or when we may upgrade our entrance door. And yes, extra keys are easy to have on hand too! Just match the code on your key to your order. https://www.amazon.com/dp/B00S2IELG6?ref=fed_asin_title https://www.amazon.com/Pair-Keys-Global-Link-Precut/dp/B0BQWVR6YP/?th=1 Edited September 15, 2025 by jd1923 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Moderators Mike and Carol Posted September 16, 2025 Moderators Posted September 16, 2025 9 hours ago, Rivernerd said: We opted for the manual door lock in our 2022 Elite II based on reports on this forum of folks getting locked in or out of their Olivers by failed RV Lock units. No issues with key duplication. We keep a spare Oliver door key in a compartment in our tow vehicle. Low tech, but so far, no issues. Our manual lock has been reliable, not fancy but it works! 6 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Boilermaker Chemist Posted September 18, 2025 Posted September 18, 2025 On 9/15/2025 at 12:19 PM, jd1923 said: $220+ for keyless entry, sorry no thank you. I get that. On the other hand, I had to replace the lock anyway, so keeping in mind resale, I decided to upgrade to the keyless entry lock which many people like. When I sold my previous camper, the buyer told me that all the accessories that I had added was a key factor in their purchase. Plus the lighted keypad looks really cool! 😂 1 Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Steph and Dud B Posted September 19 Posted September 19 As mentioned earlier, we've had 2 RV Lock keyless locks on our 2022. Both failed, one possibly due to water intrusion because Oliver cut the latch hole in the door too big, leaving a gap next to the exterior portion of the lock where water could get in. OTT sent us a replacement and I caulked around it. Even so, the replacement failed after 3 years for unknown reasons, so we gave up on RV Locks. We were just at the Hershey RV Show and met a rep from Global Products Group who showed us their Ultra ES Pro lock. The first thing I noticed was that it was very substantial, all metal construction. It also uses a different handle configuration inside and out. We talked him down to a price we could accept and bought one. I just installed it with no issues. The first thing I noticed was that the exterior portion was larger than the RV Lock, so it covered the gap left in the door by OTT nicely. It also included a large neoprene gasket, which was nice. Installation was easy and it functions well. One interesting note: there is no separate deadbolt. The deadbolt function simply locks the single bolt in place, rather than extending a second bolt. It would still stop someone from jimmying it open, though. The second thing I noticed is significant for us. Even with the striker plate all the way out, our door never latched easily. We had to really slam it to get the RV Lock to engage (perhaps the cause of the demise of lock #2). This latch closes cleanly and easily using the original striker plate. Our sleeping neighbors will be much happier. OTOH, the Bluetooth app for the lock seems glitchy. It has trouble staying paired to my Pixel phone. Not a huge deal for me, but maybe for someone else. Time will tell if this lock holds up. Will update here if things change. Here's an Amazon link: https://a.co/d/0bzR8SDZ 1 4 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Boilermaker Chemist Posted September 20 Posted September 20 @Steph and Dud B Thanks for the info, I’m one year in with the Bauer and no issues yet. But if I have a problem I’ll keep this in mind. Mike 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
