15 hours ago, Mark Meadows said:
Merry Christmas all.
Does anyone know where to get replacement hub caps for my 2023  Oliver Elite ll ?
Oliver, I had one knocked off (Plastic Cap on the hub cap).
 Forget the price. I got it within a few days of reaching out Oliver.
Edited by John Dorrer
Updated Comment
Give Mike a call at Oliver Service $3.00 plus shipping.
Hello @Mark Meadows,
Just search for “trailer center caps” on Amazon, eBay or anywhere. They are all aftermarket, no diff OEM except costing more.
https://a.co/d/3c9VPWV
If you need Oliver center emblems go to them.
Many of us go no without center caps at all. Then with an infrared temp gun you can read hub and bearing temps. You might say it even looks better without.
I have a full set with Oliver emblems, very good condition if you like! 😎
Edited by jd1923
Mark -
Do you really mean "hub caps" like the ones jd1923 is referencing or do you mean "trailer hub dust caps" like THESE?
The reason I ask is that it is rather difficult for the  "hub caps" to fall off but (obviously) they are rather easy to "dent" and/or that disk with the Oliver logo that is normally in the center can fall out.
Ok thanks maybe I’ll just remove the others. I wasn’t sure if they had a purpose.
Thanks
Mark Meadows
2023 Oliver Elite II
Ford F-150 Powerboost (hybrid)
On 12/26/2025 at 5:48 AM, topgun2 said:
Mark -
These plastic caps that seem to come off once a year
Mark Meadows
Thank you
Mark Meadows
As John D said above - a quick call to Oliver will get you these disks.  If/when you re-install them , you can make sure that they will never again "pop" out if you place a bead of something like "E6000" (THIS STUFF) (which is available at WalMart, Amazon, Ace Hardware, etc.) all around the back side of the disk.  Unfortunately, this requires that you remove each wheel in order to get to the back side, but, you will only have to do this once.  Mine are going on ten years since I did this and I've not lost a single one since.
I took off my 2019 SS Hub XX + the small round pieces to look like John Davies for the express pupose of maintenance and using a IR thermal gun for brake temp measurements. One less thing to clean or worry about.
I have at least two of them that I can donate for thh cost of shipping to any that would like mine.  I used them for 2 years.
I'll be back to Ollie in June and can inventory and ship then.
Geronimo John.
image.png.586becf054b038551983913a0376b8b1.pngimage.png.453a864d03c8633d82195f4e8fc1b53e.png
Price hard to believe! Mike asked $150 plus shipping to send me a new DOT label for our hull! Ours is faded, hard to read. I had to reply no thank you, close ticket. My thinking is it should have been a no cost item!
@Mark Meadows I have a deal for you! Just PM me with your shipping address and I'll send you mine, no cost. I have 4 good used and 2 brand new. If you want the full chrome centers, NP just let me know but shipping would be a little more. Mine living in the SW all look better than yours.
Next time, perhaps add sealant like @topgun2 suggested. Mine were on for years NP, so perhaps yours are brushing on something.
Or maybe you just take them off as I did. I'm thinking I can hammer the Nev-R-Lub bearing caps to remove the embossing, smooth the surface. Then mount some really cool emblems. The Oliver emblems are boring and these tall centers were designed for the old-style conical bearings that stuck so far out.
Edited by jd1923
I like the idea of running without to test for heat with an  infrared temp gun.  This said, we run a lot on dirt/gravel and it's called a dust cap. Shouldn't you keep the dust caps on for the obvious reasons?
Fieldbrook, Ca
The true "dust cap" is the cap pressed into the hub of the brake drums (as pictured). Yes, the outer center caps can help in deep mud but are more for cosmetics.
@Mark Meadows as to your first post.
For all the nonbelievers out there.  😄
Here are the plastic caps that I ordered from Mike Sharpe as a replacement. As mentioned, I think they are like $3 plus shipping.
If this is what you are looking for, Oliver Parts usually keeps them in stock.
Cheers & Happy New Year!
Edited by Patriot
Thank you
Mark Meadows
There are a lot of us towing without the center caps for this reason, starting with @John E Davies who suggested it many years ago.
I wish they made flatter centers for Nev-R Lube axles. The standard centers stick out 4 1/2" made deep for the old-style conical bearings. I believe they detract from the look of most mag wheels.
I just added these emblems to dress ours up a little! I won't have to read "Nev-R Lube" anymore. Just search for "70mm emblems" and there are hundreds to chose from.
Good idea.  That does look better than the Nev-R Lube caps.  Time to go shopping….
  • 1 month later...
On 1/1/2026 at 4:11 AM, Mark Meadows said:
Thank you
I called Oliver and was quoted $48.12 for a set of four, shipping included.
Mark Meadows
I'd be a bit careful here!
Sure - either way its not a bunch of money but .....
I'd make very sure that everyone is talking about the exact same part(s) before placing the order.  It appears to me that the "hub cap" plus the "little disk" that goes in the center of the "hub cab" sells on Amazon for about the same price that Oliver is quoting -
But, the "little disk" that goes in the center of the "hub cap" costs about half that on Amazon as per jd1923's post above.  Or, as per Patriot's post above, these "little disks" are available from Oliver (with the appropriate Oliver logo installed) for only about the $3.00 that Patriot mentions.
It should also be noted that all of this is different from what is called a "dust cap" that is the part that is tapped into the end of the axle in order to keep dust and dirt from reaching the axle bearings.  Examples of these "dust caps" can be seen in jd1923"s post above (for the never lube axles) and in my post above for the regular axles.
Hope this helps and saves you some coin.
Edited by topgun2
Thanks Bill,
Every picture tells a a story. 👍🏻😄 🇺🇸
Here’s an improvised cover that anyone can make when out on the road….
Edited by Mike and Carol
  • Haha 4
Sorry, still not a believer. 😎
I do believe the quote Mark just received which seems realistic.
Edited by jd1923
Believe whatever you choose - I only wanted to clear up the definitions that were being tossed around along with the associated prices.
