On 5/6/2026 at 5:02 AM, CRM said:
I had high hopes that the Chill Cube would do a better job than most with temp control since it had the "follow me" thermostat feature built into the remote.
So, I had the one overnight mentioned above, where the Chill Cube made the cabin much colder than the set temp. This was a one-off, not experienced again. I had it on AUTO MODE and AUTO FAN that time. I noticed it switched itself to DRY MODE during the night. We were in the desert valley at 20% RH outside and a very comfortable 40% RH inside.
When we got home, I ran the Chill Cube 24x7 for 8 days and nights unplugged, on batteries/inverter only! This time I set to COOL MODE, fan in AUTO MODE. The cabin started at 90F and it was 88F outside. I set temp on the Chill Cube at 76F and the Chill Cube kept the cabin at 76F daily for most of the week, got down to 74 on day 7 and 72 on day 8, as ambient temps got lower. I ended the test after 8 days, since it got cold again up here again (highs low 70s, lows high 40s). We're having a wonderful long spring in the AZ High Country!
In the first 24 hour period, we used 60 Ah. This would be -10% SOC only for those of you with 600 Ah. Day two was about the same. Ambient temps lowered a little and on Day 3 we ONLY used net -15 Ah! These numbers include the 320W rooftop solar adding about 12 Ah every sunny hour of the day. The next few days were the same, only using about -2% SOC per day. I believe the Chill Cube will get colder than set temp ONLY when A/C is not really needed, like overnight in the desert where it gets cool outside. Next time when sleeping on a cooler night I should just turn it off.
Our lovely spring temps will end soon. I'll run a similar test in 60-90 days when it gets very hot even at high elevation. Last 3 summers, I had the Oliver plugged in with the Dometic P2 set at 80F. It would run nonstop during afternoons with near 100F highs. Without A/C the Oliver could get to over 110F sitting in the sun outdoors, not good. We could hear the LOUD P2 from our deck 100 ft away.
Last week while the Chill Cube was running, I thought once Chris had turned it off. I was outside walking around and behind the Oliver and I could not hear the A/C running at all! When I entered the cabin, I could hear the Chill Cube on its very lowest fan setting. In Auto FAN it will run slower than the LOW FAN setting, very low and quiet! 😎
Received an email from Fogatti today. Got on their list when I was looking at their tankless HWHs. Looks like this unit, advertised "18K BTU" dual variable-speed fan motors and small footprint, could be a Chill Cube clone. They have a heat pump version too.
https://fogattiliving.com/products/fogatti-instacool-pro-18-000-btu-rv-rooftop-air-conditioner/
Edited by jd1923
  • 1 month later...
On 4/13/2026 at 4:45 AM, OffWeGo said:
The big trip this summer starts out with a week in Cade's Cove, TN, where there are no hookups.  This will be the real test of running the Chill Cube off the inverter.
Did you do this trip yet? Any feedback on the Chill Cube in hot humid weather? Does it keep up with the heat. Is power consumption doable on your batteries? 😎
If your trip is still on the horizon, let us know afterwards. Thanks!
I guess I’ll have to look into the lower-profile/heat pump variants that have been mentioned.
We’re still suffering with the original Dometic P2 jet engine sitting on the roof - which means we either endure noise or heat/humidity.
A version with heat pump would be nice - but I’d opt for the heat strips if that were the only option.
Id prefer low-profile - but I don’t know if 3” higher is gonna affect mileage that much - and pretty sure our storage unit has 12 or 14 foot high roll-up, so likely not a factor.
Thanks for all the data and tips @jd1923 and others!
I have a few months to sift through the data. I watched the (whole) video - so just what’s changed since then is the big question.
And yes - it seems that waiting a bit opens up more and better options!
King Bed Floorplan
electronics package
Truma Aqua-Go
LOUD Dometic Penguin A/C
LevelMate Pro+
(17.9mpg towing, 35mpg clean)
RealTruck hard tonneau cover
Rove R2-4K DashCams
Yep, louder than the 2nd Gen Cummins on my Ram! 🤣 So thankful it's gone!
Chill Cube now has a heat pump version. One Forum member has showed it installed. Heat strips are like lead acid batteries; no manufacturer uses them anymore.
I'd prefer low-profile...
That's everybody's first thought!
I love a sleek 2-door hardtop sportscar, low profile like my '92 SC400!
Low profile ON the roof means the air handler is protruding a few inches below the ceiling. Low profile means lower efficiency and more noise inside.
Edited by jd1923
Performance update =>
I was able to run the Chill Cube 24x7, thermostat set at 74F, for 4 days producing this data. Data was recorded each day later afternoon 5PM +/-. The Chill cube did not quite produce the set temp in the heat of the day but did so the rest of the day. The high of 76F was still quite comfortable in the cabin.
Off course our Oliver was unplugged, but in addition to battery power, our 320W rooftop solar was adding power consumed by the A/C.
The table shows Ah used daily. Keep in mind this is with the A/C running 24x7 which is rarely our use case! Having 900 Ah it appears I can count on running the A/C 24x7 for 3 days, 4-5 days if it’s off during portions of the days. With 600 Ah you could truly count on two full 24 hour days.
The picture below shows cabin and outdoor temps one afternoon during the test at 4:30 PM. The cabin temp is read by a Ruuvi sensor mounted above the kitchen sink. The sensor titled Oliver Trunk is positioned in the rear basement, near the incoming water lines down by the 4" drain plumbing. For "Oliver Roof" I placed a sensor rooftop under the solar panels so that it is in the shade. If I took this picture 1-2 hours earlier in the day the roof temp would certainly be above 110F!
I had no idea these results would be so positive and being the avid boondocker, it's great to know we can now count on A/C cooling anytime/anywhere! When you have the old-school A/C, with the basic single-speed ON/OFF compressor (Dometic, Truma, Tosot, Houghton, etc.), you will use approx. 100 Ah per hour in the heat of the day (assuming 1400W while the compressor is ON). The inverter or variable-speed A/C will consume in 24 hours what the standard A/C will consume in just 2 hours, OMG! (BTW, the Dometic P2 will produce worse results since it uses 1800W when ON, or 150 Ah/hour).
The technology capability today is amazing. Time to stop waiting on the next great product. We’re not getting any younger! 😎
Edited by jd1923
Very nice, especially at your elevation. Probably losing 15% or so efficiency up there in the clouds!
That is correct. However, solar is more efficient at elevation and we had full mid-summer sun every day of the test.
I'd like to measure the amount of Ah produced by solar over a 24-hour period. I believe the IPN Remote on our old Blue Sky SC has a display variable for that can be reset to zero. But without an app interface it's truly painful to kneel down there and go through the menus!
Edited by jd1923
Was reinstalling our blinds today after cleaning them, so working inside the Oliver. Set temp was 76F and I lowered it to 68F and turned on the Turbo setting which activates the evaporator fan at the high setting. Outdoor temp was 94F, 110F on the roof, 104F in the basement under the streetside bed where the Victron MP2 is installed (see temp reading on picture).
After I heard the compressor ramped up, I took this screen print. About 620W was the highest number I could see. The picture shows wattage inverter out and the A/C was the only 120VAC appliance on.
The Chill Cube is rated at 18K BTU which we know is BS since the compressor rating is about half that. The Chill Cube night not be the best choice for those who plug in regularly and live where you need powerful cooling. The Tosot may a better choice for those who plugin at campgrounds, but we rarely plug in even when parked at home. The Chill cube in Turbo mode is not real quiet, but still less than half the noise of others. It's whisper quiet when sleeping at night when cooling needs are lower.
I remember reading in the "Morton's on the move" blog that BTU output was about half it's actual rating but didn't think that would be a problem since my old 9.2k Coleman worked just fine at cooling in our Ollie, and it worked better than others I've used at controlling humidity due to longer run times. I bet you'll get better performance when traveling at lower altitudes.
Bottom line, none of these units are perfect, but if you need A/C off-grid inverter compressor units are really your only choice and the Chill Cube seems to be a great one. Only question is durability, which is the same question I have for my Turbro.
It will be of interest to eventually learn how the Chill Cube handles cabin humidity in very hot climates with high RH. A cabin temp of 76° can be comfortable only if interior humidity is kept below 50%. Perhaps some other ‘Chill Cuber’ can share their experiences regarding this matter. @jd1923, your test results are very impressive!
We actually tested this in Florida this past April. Outside temps were low 90s with 80%+ RH. With the Chill Cube in Dry Mode, the highest we saw inside was high 70s and 55ish% RH.
So it didn’t quite get below 50% humidity, but it made a huge difference. At 77°F/55% RH it was comfortable enough to hang out in. In those conditions I’d say 55-60% RH is probably the realistic best-case without adding a separate dehumidifier. Bear in mind our Brinkley 5th wheel is not as “efficient” as an Oliver.
We love the Chill Cube, the variable speed compressor is very efficient, we have seen similar numbers than @jd1923
Edited by rich.dev
**Sold😞**
Thanks Rich! Does your Brinkley 5th-wheel have 1 or 2 Chill Cubes. I guess a small one could have one. Big 5th wheels have two A/Cs, one bedroom and one for the living area.
At Quartzsite, Art @MAX Burner fired up the Chill Cube (on battery) in his smaller Brinkley TT and it cooled nicely. Hope to see you this winter! 😎
2 ACs, a chill cube in the living area and diesel sounding 1910 style Furrion up front!
But the 2027 Brinkley models Zs now include dual Furrion Chill Cubes. The new 15k low-profile up front, and the std 18k in the living room.
Maybe, with the gas prices we might end up in Texas this year.
**Sold😞**
Excellent point Ron. A person can almost be comfortable when 90F in the shade in Phoenix, where 80F in Houston might feel hotter!
As you know, that's a test I cannot do out here. Note the Ruuvi screen print above. On the roof of our Oliver, at 104F the RH was only 17%. Trunk temp was 91F at 27% RH and inside the cabin 76F was very comfortable at 38% RH.
Rich added comment on his experience with the Chill Cube in Florida.
We lived in WPB Florida for three years. When we ran our home A/C 24x7x365 and RH would be in the high 40s. Of course outside it was 60-80% RH. Taylor Guitars states 47% RH is perfect for fine acoustic guitars (good for humans too). In Florida with A/C running, I could leave the guitars hanging on wall hooks. In Prescott, I converted a hutch into a cabinet to store 4 guitars. I keep sponges in trays of water wicking moisture to keep RH in the high 40s! In the dry season (spring-early summer) we run 3-4 large capacity humidifiers in our home.
We all know the Oliver can get humid/wet inside. That works out perfectly in the dry SW. It's often 20% RH outside but 40% RH inside. Highest ever I've seen winter camping is 58% RH in the Oliver Cabin. Then open up windows on a sunny afternoon and the extra moisture will evaporate. We don't worry if an RV A/C adds to cabin humidity like most do. 😎
I see an upgrade mod in your future! 😃
I remember when we still had the DPll, cabin humidity reaching 80-90% some nights with the a/c running on low; contributed by the a/c, as well as our respiration. The dehumidifier we had at the time could not compensate for the excessive moisture. As you know the Atmos is much quieter and efficient in cooling, but it also handles excessive moisture much better with dedicated modes. And then with the Cielo Breez Max thermostat addition, humidity spikes are a thing of the past.
@Boudicca908 would you mind sharing your impressions of the Chill Cube A/C in our Oliver? What was the sound level like outside when we were working next to it. What was the sound like on low when we went inside, and then when I lowered the thermostat and turned it up on high?
So far, Forum Members have only read my opinion. There must be a lot of Oliver owners running the Dometic P2 this summer wishing they didn't have to! Thanks.
FYI, a Brinkley owner installed/tested the new Chill 15k low profile inverter AC.
**Sold😞**
Looks like they modified a Turbro unit like I have and fixed most or maybe even all the features I don't like about it.
When I entered John's Oliver, I was interested in seeing some of the modifications he has made. First I wanted to see his electrical area under the aft dinette seat, as I am trying to learn how to find specific parts. Then I checked out the air fryer (where a microwave used to be) and his controls (mostly different due to the age of his unit, but also because he has changed out a lot of the systems.) It was probably 10 minutes later when I looked up and commented on how shallow the Chill Cub air conditioner was -- almost flush with the ceiling, making a sleek surface. What I did NOT notice was that it was turned on. I couldn't hear it at all. He lowered the setting to make it blast and I believe my impression was that the noise was less than 30% of the noise of my Dometic. I rarely run my AC, mostly because it hurts my ears. On the outside, it's boxy. But on the inside, all I can say is "Wow".
my Oliver has camped here
ALAZARCOFLGAIDILIAKSKYLAMSMONENMNCNDOHOK
