ripple963 Posted January 29 Posted January 29 Picking up a Legacy Elite II at the factory in March. We live in Maine, and will need to store the trailer outdoors in the winter. Any recommendations on covering the trailer for the winter? I’ve read that it’s controversial, but the Oliver seems more like a nice boat than other trailers; our 28’ powerboat stays outdoors at a boatyard under shrink wrap, and with proper preparation does well - no mold or mildew issues as long as she’s cleaned up nicely in the fall. Any suggestions appreciated - thanks! 1
Moderators topgun2 Posted January 29 Moderators Posted January 29 I'm not experienced with "shrink wrap" - particularly on a fiberglass RV. CalMark covers are relatively expensive but are used by many of us. I've used a CalMark cover for the past ten years and have had zero issues with mold, mildew, scratching, etc.. There are a number of threads and posts here on the Forum in this regard. Good luck. Bill p.s. Perhaps additional information might help in any advice you might receive here - is your storage near the water (salt water)? Is it protected in any way from the wind, is the storage in a "dry" area , on pavement or on gravel or grass? Is there electric available - for heat and/or dehumidifying? 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
jd1923 Posted January 29 Posted January 29 (edited) 5 hours ago, ripple963 said: Picking up a Legacy Elite II at the factory in March. We live in Maine, and will need to store the trailer outdoors in the winter. Any recommendations on covering the trailer for the winter? First year recommendation, stay south until May! Enjoy camping on the Gulf Shore or in the Smokies or somewhere else nice and get past this first winter! 😂 I’ve not had good experiences with covers and prefer going without. Put a cover on our tow vehicle, a couple summers ago, to get rub marks from the wind and the Pack Rats were thankful for the dark space. Never again! Our Ceramic Coating professional said the same without me asking. Our Oliver, now freshly polished and coated will live outdoors in the Arizona sun and elements. An indoor space would be nice, but not happenin’ for us either. I sold the Calmark cover that came with our hull used to @grweber1 in Minnesota where I guess a cover is needed for lots of ice and snow! Maybe Gary can chime in. I imagine his covered Oliver is deep in snow by now! I like the idea of shrink wrap. It will not blow in the wind and scratch the gelcoat. You’d winterize first, have your LiFePO4 batteries at 60% SOC and disconnected. If you’re getting your 28’ boat done, ask for a package deal to include your new 19’ rolling hull! 😎 Edited January 29 by jd1923 1 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Todd B Posted January 30 Posted January 30 We live in North Idaho, where we experience snow and ice. We use a Clamark cover for our Oliver, and it has been excellent. Our Oliver is parked on the side of the house next to the garage and fence, so it doesn't get much direct wind. To protect against any potential damage, we place padding on the sharp corners, such as the bumper and solar panels, ensuring that nothing gets scuffed. I haven't noticed any signs of the fiberglass being scratched since we have a ceramic coating. If it were exposed to more wind, however, that could be a concern. Putting the cover on can be a challenge, but we've developed a great system that makes it relatively easy. When we take the cover off, we roll it up so that it fits in a plastic tote. We roll it in a way that allows us to simply lift it out at the end of the season and place it on top of the Oliver. Then we roll it forward and let it drop off the sides. This method is much easier than the first time we rolled it on on the ground and tried to lift it up and over. 4 Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
grweber1 Posted February 1 Posted February 1 As jd1923 stated, his Calmark cover he sold me is a great investment. Here in Minnesota the summers are hot and humid, winters are cold and with lots of snow. We keep the Calmark cover on the Oliver when not in use (only takes 10 min max to cover it by my self, not afraid of ladders!) It keeps all of the nasty green pollen off in the spring and summer, Keeps the oak leaves and what ever wants to fall on the Oliver safe and clean. Never any mold and the cover breathes plenty good. When there is an abundance of snow on top I just use a soft floor brush to push it off. Also the cover has a nice zipper spot at the door so you can get into your Oliver to do a winter check if you want. 4 1 Gary & Sandy / 2001 silverado 2500hd 8.1L-Allison / Fridley MN, Hull # 994
Patriot Posted February 2 Posted February 2 (edited) @ripple963 We have used a Calmark cover since we took delivery of our Oliver in 2020 and still do along with our “Ollie Hangar”. Keeping the weather and especially the UV rays off the ceramic coat treated gelcoat and caulked areas is highly recommended when storing your Oliver. We have never experienced any gelcoat damage using our cover. The Calmark cover with a zippered entry door allows us quick and easy interior access where shrink wrapping your entire Oliver may or may not. If you opt not to cover your Oliver, you may want to consider buying a cover for your Truma AC to keep birds from nesting in it. I will say that it sure is nice to remove the cover in the Spring to a clean and polished Oliver. All the best with your decision. We use the Little Giant ladder/plank system which makes covering and cleaning our Oliver much safer and easier than hanging off a ladder. Edited February 2 by Patriot 2 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators Wayfinder Posted February 2 Moderators Posted February 2 I'm not sure if this is still the case, but in summer of 2024 while I was at Oliver for service, Jason E. said CalMark no longer made the covers "specifically" for Olivers and he could not get more either. I was hoping to purchase one then. I have since purchased a non-CalMark cover from another Ollie owner at the Hiawassee, GA Egg rally in 2025. The previous owner built an aluminum cover for his Ollie. Honestly, I have not yet taken it out of the bag it came in - I camp too often during the winters. 1 Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
Moderators topgun2 Posted February 2 Moderators Posted February 2 2 hours ago, Chris Scarff said: I'm not sure if this is still the case, but in summer of 2024 while I was at Oliver for service, Jason E. said CalMark no longer made the covers "specifically" for Olivers and he could not get more either. I was hoping to purchase one then. Curious - I sent CalMark an email asking if they still made covers for the Oliver Elite II and what the pricing might be. Below is the reply I just received back from them: Dear Bill Thank you so much for reaching out and requesting a quote from us. We truly appreciate your interest in our covers and the opportunity to be considered for your cover needs. We wanted to share a quick update on timing. Our current production schedule is already fully booked through the end of February. At the same time, we’re in the process of improving and expanding our cover product line, with new options and updates launching in March. Because these changes may affect both available choices and pricing, we aren’t issuing new quotes right now—we want to be sure anything we provide reflects the most accurate and up-to-date offering. We absolutely don’t want to leave you waiting, though. As soon as our March details are finalized, we’d be happy to reconnect and provide a Fast quote customized to your needs. If you’d like, we can keep your request on file and reach out right away when the updated information is available. Thank you again for your patience and understanding. Please feel free to reply with any questions in the meantime. Natalie Miller President/Owner CalMark Cover Co. Inc. (800) 838-7236 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted February 2 Posted February 2 (edited) 1 hour ago, topgun2 said: Curious - I sent CalMark an email asking if they still made covers for the Oliver Elite II and what the pricing might be. Below is the reply I just received back from them: Dear Bill Thank you so much for reaching out and requesting a quote from us. We truly appreciate your interest in our covers and the opportunity to be considered for your cover needs. We wanted to share a quick update on timing. Our current production schedule is already fully booked through the end of February. At the same time, we’re in the process of improving and expanding our cover product line, with new options and updates launching in March. Because these changes may affect both available choices and pricing, we aren’t issuing new quotes right now—we want to be sure anything we provide reflects the most accurate and up-to-date offering. We absolutely don’t want to leave you waiting, though. As soon as our March details are finalized, we’d be happy to reconnect and provide a Fast quote customized to your needs. If you’d like, we can keep your request on file and reach out right away when the updated information is available. Thank you again for your patience and understanding. Please feel free to reply with any questions in the meantime. Natalie Miller President/Owner CalMark Cover Co. Inc. (800) 838-7236 Bill, I just spoke with Deanna at CalMark who basically said everything you mentioned above. She also added that Oliver TT has opted to no longer stock and sell CalMark covers. Deanna also said that they are “in a restructuring pause right now”. My SWAG is that there will be a price increase. -David Edited February 2 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
Moderators topgun2 Posted February 2 Moderators Posted February 2 1 hour ago, Patriot said: My SWAG is that there will be a price increase. You can almost bet on that one. 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Wayfinder Posted February 2 Moderators Posted February 2 Good luck to the future Oliver orders. We'll keep others in the "know" as we also learn . Thanks Bill & David for doing leg-work. Chris o-o 2016 Legacy Elite II (demo) - Hull #110 -"Rock'in 110" o-o 2024 Ford F-250 Lariat, 7.3L Godzilla gasser o-o Augusta, Georgia
ripple963 Posted February 3 Author Posted February 3 On 1/29/2026 at 10:41 AM, topgun2 said: I'm not experienced with "shrink wrap" - particularly on a fiberglass RV. CalMark covers are relatively expensive but are used by many of us. I've used a CalMark cover for the past ten years and have had zero issues with mold, mildew, scratching, etc.. There are a number of threads and posts here on the Forum in this regard. Good luck. Bill p.s. Perhaps additional information might help in any advice you might receive here - is your storage near the water (salt water)? Is it protected in any way from the wind, is the storage in a "dry" area , on pavement or on gravel or grass? Is there electric available - for heat and/or dehumidifying? Additional info: the trailer will be stored in a paved parking lot that gets plowed, but the trailer would still have snow piled around it from time to time. Expected storage time each year would start sometime between November and early January; we would start using it again late March to sometime in April. It's Maine, so it gets windy... No electric available at the lot. The lot is on the mainland; we live on a nearby island, but we go to the mainland a few times per week, so we can check on the trailer from time to time. We used to have an Airstream Basecamp 20x; it was stolen, which has led to our purchase of the Oliver. On occasion with the Basecamp we would use the trailer for an "on the mainland overnight" if our plans didn't line up with the ferry schedule to get home. It would be nice to be able to use the propane heat on such occasions, but the plumbing will have all been winterized. My thought is that if I can design a flow thru into the shrink wrap and just wrap the top half of the trailer, then that would be adequate protection from any snow damage / snow and ice accumulation on the roof. Ventilation would be 2" foam blocks spaced around the lower edge of the shrink-wrap, with 5 or 6 rain protected vents towards the top of the wrap. There would also be a "boom" to hold the top of the wrap above the a/c, vents, etc - which would allow us to crack the vent in the trailer to help avoid condensation.
ripple963 Posted February 3 Author Posted February 3 On 2/2/2026 at 10:43 AM, Chris Scarff said: I'm not sure if this is still the case, but in summer of 2024 while I was at Oliver for service, Jason E. said CalMark no longer made the covers "specifically" for Olivers and he could not get more either. I was hoping to purchase one then. I have since purchased a non-CalMark cover from another Ollie owner at the Hiawassee, GA Egg rally in 2025. The previous owner built an aluminum cover for his Ollie. Honestly, I have not yet taken it out of the bag it came in - I camp too often during the winters. Thanks for the info. I reached out to Calmark last week. They said they're not taking new orders right now, but are expanding their capacity and hope to take new orders soon. I plan to reach out to them in the spring to learn more about what they might have to offer. 1
tallmandan Posted February 3 Posted February 3 (edited) In April of 2025 I asked for a quote from Calmark for a cover. I was quoted $1450 including shipping and also informed that they changed their fabric resulting in cutting the warranty from 6 years to only 3 years. I spoke with Natalie on the phone and she was very nice. They were not able to source the same fabric anymore (as of then) and could no longer warranty it for 6 years as on previous covers. I told her I live at 6300ft elevation in Colorado and the UV sun exposure is absolutly brutal. I store the trailer at an RV lot where it is uncovered and it takes the sometimes intense wind and wind gusts we have here. I'd like to have a Calmark cover but just couldn't stomach almost $1500 with only guarantee for 3 years. I decided to contiue with the much cheaper cover I have been using. It's good quality compared to most of what's out there, which is a lot of cheap junk. I do think it's caused light rub marks on the fiberglass in a few spots from the whipping wind even though it does secure down pretty tight. They seem to buff out with some McGuires one-step compound and wax, but it's obviously not ideal. I decided this was the lesser of two evils compared to the damaging sun exposure. The 15-18 foot size fits the LEII pretty well even though it's cut for a trailer 8ft wide. It reaches to cover all the way up over the front jack. Hopefully Calmark will be able to revise it's offering. But in the meantime, this is an alternative with caveats... IMG_3362.HEIC https://www.amazon.com/gp/product/B01KHX27HS/ref=ox_sc_saved_title_6?smid=ATVPDKIKX0DER&th=1 IMG_3362.HEICIMG_3362.HEIC Edited February 3 by tallmandan 3 2020 Elite II #627, 2021 Silverado 1500 3.0L Duramax, Colorado
DUSTOFF Posted March 23 Posted March 23 Great thread. Picking up tomorrow from Hohenwald (HULL: 1688)! I'm in North AL and will be storing on a lot for the next year or so. Have been keeping up with all the cover threads and this one appears to be the most current. Does anyone have an update on CalMark newer that ripple963's 3 FEB post? If not, I plan on calling this week. I'll share the latest. 2 2026 LE II. TWIN FLOOR PLAN. PLATINUM PKG. STREETSIDE AWNING. HULL #1688. 2019 F-150 LARIAT MAX TOW PKG NORAL
dewdev Posted March 23 Posted March 23 @ripple963 We live in Maine and I store our 2018 Elite II outside without any cover and have not had any problems. I do clean and wax the Olie prior to storing it for the winter. In the spring, I do have to remove some rain stains on the side. I use a fiberglass soap which removes the stains. I then put on 2 coats of wax (wipe on wipe off) which generally lasts for the summer. A friend of mine who also owns a Ollie and lives in Maine stores his ouside without any cover. If I lived in the south, where the sun is strong all year long, I would invest in a cover. 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
ripple963 Posted March 25 Author Posted March 25 Thanks all. Will continue to ponder as we gather bugs and pollen on the current post-pickup Southern trip.
DUSTOFF Posted March 27 Posted March 27 (edited) UPDATE FROM CalMarK: Bottom line. There are two new fabrics that come in at $ 1608.00 + Shipping + Tax if applicable and $ 2464.00 + Shipping + Tax if applicable. Please see below for details from CalMark and attached photo taking instructions for ordering. I'm in NORAL. I will keep my new LE II on a storage lot for at least the next year. I WILL wax it at least twice a year (if not more) to protect the investment. Here's the ask to the forum. To anyone that has not covered their trailer and had success keeping the exterior in great shape: what products are you using and at what frequency? For SA. It's highly likely that I will pull the trigger on some sort of cover. **********************************************************************************************************************************************************************Dear Alec, Thank you for your patience - your Custom Cover FAST QUOTE is ready. We’ve just completed exciting upgrades to our Premium Custom Covers, elevating fit, finish, and durability across the board. Enhancements include a refined tailored appearance, reinforced tie-down points, upgraded zipper flap protection, and premium-grade components—every detail designed for superior performance and long-term protection. We’re also pleased to offer two exceptional fabric options, both selected for their durability, elegance, and all-weather performance: Hydrofend® CVR A lightweight yet exceptionally strong performance fabric that delivers reliable protection in all conditions. Distributed by Trivantage®, the distribution arm of Glen Raven—makers of Sunbrella®. Hydrofend® CVR offers excellent tensile strength, tear resistance, UV protection, fade resistance, water resistance, and resistance to mold, mildew, and cold cracking. Available color: Cobblestone Beige. Hydrofend® Soft A customer-favorite premium upgrade, Hydrofend® Soft pairs the proven performance of Hydrofend® with a soft knit backing for added surface protection. Ideal for all covers—especially those with specialty finishes—this fabric delivers a refined feel with up to six times greater water resistance than uncoated alternatives. Available color: Desert Beige. Your *Estimated FAST QUOTE includes pricing for: • A Hydrofend® CVR fabric cover for your Oliver II $ 1608.00 + Shipping + Tax if applicable • A Hydrofend® Soft fabric cover for your Oliver II $ 2464.00 + Shipping + Tax if applicable Confirmed price quotes are valid for 90 days. Please let us know how you’d like to proceed and which fabric option you prefer—we would be delighted to craft a custom cover tailored precisely to your needs. If you would like to explore the fabrics in person before deciding, simply reply with your postal address and we’ll be happy to send a sample right out. *If you are ready to get started: Step 1: We have the pattern for your cover order, however, we still need photos for our fabrication team to accompany each order. Each fabricator requires photos to reference when sewing the covers. (See photo taking instructions below) Starting February 2026, CalMark has partnered with a premium quality custom fabricator in Minnesota. Your cover will start its custom process in California and will be expertly completed and drop shipped from Minnesota. California will no longer have a pick up option. If you have any questions at any point, feel free to email —we’re friendly, knowledgeable, and always happy to help. We look forward to creating your custom cover! Natalie Miller President/Owner CalMark Cover Co. Inc. (800) 838-7236 (805) 486-3863 Edited March 27 by DUSTOFF 1 2026 LE II. TWIN FLOOR PLAN. PLATINUM PKG. STREETSIDE AWNING. HULL #1688. 2019 F-150 LARIAT MAX TOW PKG NORAL
DUSTOFF Posted July 31 Posted July 31 Update. I've been in touch with the owner for the last several months. She has a new manufacturing process/team. I've been patiently waiting on Calmark to start manufacturing covers again. The date gets pushed right every month and my OTT is in the sun (with a good coat of wax). I'm moving on from the wait list and going to go with another manufacturer. Any recommendations of good quality non-Calmark covers? 2026 LE II. TWIN FLOOR PLAN. PLATINUM PKG. STREETSIDE AWNING. HULL #1688. 2019 F-150 LARIAT MAX TOW PKG NORAL
FloraFauna Posted July 31 Posted July 31 It may be overkill but similar to @Patriot , I use the Calmark cover inside. Keeps the dirt off during storage so come season everything is clean and ready to go. Glad I bought one at the price I did when OTT still had them even though I don't desperately need one. My most desired Oliver upgrade is to get a ceramic coating - someday. 1 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Ronbrink Posted August 1 Posted August 1 20 hours ago, FloraFauna said: I use the Calmark cover inside. I like looking at mine! 1 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
jd1923 Posted August 1 Posted August 1 (edited) Would love indoor storage but only if it could be on our property. Not happening for reasons or cost and building codes! I'm not a cover guy, too much hassle and cover inside a building, really? Any dust will blow right off next time out or with a good rainfall! But to each their own... With our Oliver outdoors, the rooftop solar will return the batteries to full charge when not in use. When it's this hot, high 90s this week, we run the Chill Cube A/C 24x7 so I'll change the inverter setting to recharge once a week. Hull #113 has not been "in storage" the 3 years we've had her. Put a cover on the TV two summers ago, to keep the sun off, and the pack rats read it as an open invitation. I caught it just in time but could have lost the entire truck interior vs. just some HVAC vacuum lines and part of the dash cover. I'm never using a car cover again. I'll take a little sun fade over this and rub marks from wind. We had a Class-C before where the pack rats one winter built a nest in the intake trough of the Ford V-10. Chewed all the Bilstein shock boots too! So grateful they're too big to get into any of the small openings bottom of the Oliver. I'm looking at ours now and do so everyday! I'm always doing something. This week she's in the driveway behind the TV since we just got back home. Working on replacing the outdoor shower assembly and will add a drip edge on the streetside of the roof (and rear) to match the one on the curbside (we get drip marks everywhere else but soon will not! 😎 First pic is a rare cloudy day early June on our 3-year anniversary! Then after a light snow last winter. If she was back there today, the whole yard is foot high green grass form monsoon rains and not a drop inside the Oliver! She's had all the elements and always comes out just fine. All pics taken from a living room window. I did a bit of weed-whacking yesterday and more today! Edited August 1 by jd1923 3 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Geronimo John Posted 11 hours ago Posted 11 hours ago On 2/3/2026 at 1:17 PM, tallmandan said: The 15-18 foot size fits the LEII pretty well even though it's cut for a trailer 8ft wide. It reaches to cover all the way up over the front jack. Sounds like my Apco Cover. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted 2 hours ago Moderators Posted 2 hours ago At this year's Rally several owners asked me about Ollie covers. Hopefully they will see (and read) this thread. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
