Dave and Kimberly Posted February 3 Posted February 3 It's been a while since I've had to ask for some help... but here we go tonight! Prior to putting our Oliver away for the winter... the CO/LP detector seemed to be getting more and more "hyper sensitive" to the point where it finally just wouldn't go off. I reached under the front dinette seat and had to cut the positive wire to stop it. Plan was to simply replace it with a new one. I get the new one and now I find that the wires going to the detector (the ones I cut) do not have voltage. I had a friend confirm my findings and we checked every 12 volt fuse and everything was fine (there is no fuse specifically marked for the detector). Everything else, 12 volt in camper seems to be working fine... including the little USB plugs and all the lights. Anyone have any experience with changing out the CO/LP detector? Clues or ideas? I did try to jump start the the new detector just to confirm that it works but was unsuccessful in that. It seems highly unlikely that the brand new detector is "bad".... especially considering the OEM installed wires going to the old detector appear to be dead. 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Moderators topgun2 Posted February 3 Moderators Posted February 3 Dave - Did you "trace" that positive back to its bus bar? While you are in the :tracing" mode, I'd also trace the negative back to its bus bar - the connections at each bus bar just might be loose. Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Dave and Kimberly Posted February 3 Author Posted February 3 I couldn't exactly trace the very specific detector wire... but I did check the wires going into the back of the 12 volt panel... and also checked each ground wire on the bus bar to ensure they were all good and tight. I'm a little bit out of my "lane" doing electrical work... so I called an electrical inclined neighbor to confirm my steps and he was stumped as well. Side bar: It's good to hear from you Bill... you are still looking good! 🙂 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Galway Girl Posted February 3 Posted February 3 48 minutes ago, Dave and Kimberly said: cut the positive wire to stop it If you follow that cut wire back you'll eventually find an in line automotive style 1 AMP fuse in a holder nearer to the area where the 12v lines go to buss bars etc (Under the street side bed). It's that fuse you could have pulled instead of cutting the wire. You may have inadvertently popped that fuse. Hope you find the fuse and that it helps. (This is a 2019 trailer so your wiring may be different.) 6 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Dave and Kimberly Posted February 4 Author Posted February 4 Thank you! I did find exactly that 1 amp (black blade type) fuse. Mine isn’t marked or anything obvious like yours but I will find a replacement 1 amp fuse for it. If that’s it, I’ve found it, but didn’t know it! Patriot pointed me in that General direction too… I’ll report back anything I discover. 2 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
John Dorrer Posted February 4 Posted February 4 This time last year I replaced ours with a new one sent to me by Oliver. I used Wago connectors. Inadvertently I must have touched wires. Got done and the CO Detector didn't lite up. We had our service done the next week, and Oliver found that I blew the fuse. They replaced the fuse and all was good. When the bare wires touch, there were sparks, and that apparently blew the fuse. 3 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Moderators topgun2 Posted February 4 Moderators Posted February 4 It is seldom that sparks are a good thing. 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Steve and MA Posted February 4 Posted February 4 A couple of weeks ago we had to replace the CO/Propane alarm in our 2022 like @John Dorrer and @Dave and Kimberly, also 2022 models. Is there something about the original alarms that's causing them to fail at only ~4 years time? In our case the unit was going off even though the propane was off, there was nothing nearby generating CO and the batteries were charged. Like @John Dorrer, when I clipped the wires to replace the unit, I shorted the circuit when the + wire dropped and made contact with the foil insulation. I would have pulled the fuse first but didn't know where it was. I went through earlier threads on this topic to find its location. It's easy to replace, but hard to find if you don't know the area to search. If I hadn't found it, I would have run a new + wire to an empty slot in the 12v fuse panel. That would probably violate some RVIA code, but it would make it easier to shut it down the next time it starts to fail (would not do for a potentially valid alarm). The replacement unit came with Wago type connectors, so disconnecting will be easy if the need arises. 4 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Moderators topgun2 Posted February 4 Moderators Posted February 4 (edited) 16 minutes ago, Steve and MA said: Is there something about the original alarms that's causing them to fail at only ~4 years time? Let's see - My Ollie is ten years old and I'm on my third alarm. Perhaps these things are junk? 16 minutes ago, Steve and MA said: If I hadn't found it, I would have run a new + wire to an empty slot in the 12v fuse panel. There are a couple of threads here on the Forum that detail the installation of a simple "on/off" switch for this alarm. If anyone installs one of these switches they should - in some way - make sure that it is known when the alarm is in the "off" position. Bill p.s. it seems that these alarms always go off in the middle of the night. This makes finding and pulling that fuse a bit difficult. Therefore, a switch makes this process much easier. "side bar": Dave - in my mind I don't look any different than I did about 50 years ago.🫠 Edited February 4 by topgun2 2 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Steph and Dud B Posted February 4 Posted February 4 We replaced our 2022 detector last fall for the same problem: hypersensitive, going off for no apparent reason. I also used Wago connectors to make the next replacement easier. I think the RV environment is especially hard on these detectors, especially in small campers like ours, where they're often exposed to low levels of various chemicals: propane from the stove, exhaust from the fridge coming in the screen door, even hair spray. Not to mention temperature extremes while in storage. On another note, always disconnect power before cutting or splicing wires. It's easier to find and pull the fuse than to repair whatever damage you might cause with a short. 3 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Dave and Kimberly Posted February 4 Author Posted February 4 (edited) So… first thanks to each of you that responded! The CO/LP detector fuse is easy to find and get to (under street side bed)… IF YOU KNOW WHERE TO LOOK! I put a tag on it similar to what Galway girl did (Good idea!) I added another 1 amp fuse to my box of emergency fuses and also realized I only had one 30 amp slow blow inline fuse (for the three electric jacks)…. So ordered some more. The new detector looks good and the fun thing is it adds to my collection of little lights that reflect all around inside the camper when I find myself wide awake in the middle of the night. I like to think of them as “stars”. Edited February 4 by Dave and Kimberly 1 5 2022 Elite II, Hull #1097 Elli Rose 🌹 and she has the solar panels with the 390Ah lithium batteries. Our tow vehicle is a 2025 Ford Lariat F-250 Super Duty 4wd, 6.7L Diesel with the Max tow package. Elli Rose also has the street side awning and several walnut and cherry mods on the inside.
Patriot Posted February 4 Posted February 4 2 hours ago, Dave and Kimberly said: So… first thanks to each of you that responded! The CO/LP detector fuse is easy to find and get to (under street side bed)… IF YOU KNOW WHERE TO LOOK! I put a tag on it similar to what Galway girl did (Good idea!) I added another 1 amp fuse to my box of emergency fuses and also realized I only had one 30 amp slow blow inline fuse (for the three electric jacks)…. So ordered some more. The new detector looks good and the fun thing is it adds to my collection of little lights that reflect all around inside the camper when I find myself wide awake in the middle of the night. I like to think of them as “stars”. David, great detective work. A little pro tip, you can add a tiny piece of black electrical tape to that light if you choose to see that little star. 👍🏻😄 Talk to you soon brother! 2 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted February 4 Posted February 4 (edited) 12 hours ago, Dave and Kimberly said: The CO/LP detector fuse is easy to find and get to (under street side bed)… Nothing easy about moving beds in the middle of the night while an alarm is sounding (or for any other reason)! You're not the first to cut these wires. It's a shame a bad practice OTT started years ago, is still how they do things today! How does it make sense to need to move a bed to change a fuse? The wires for the CO Monitor, the three 30A fused lines for the jacks and a couple other circuits, start under the dinette. Why is the positive bus under the bed when the negative bus and 12VDC fuse panel are under the dinette? Edited February 5 by jd1923 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Steph and Dud B Posted February 5 Posted February 5 For all those bright LEDs: https://a.co/d/02j1OZft 1 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
