What a scare that must have been. Glad you are ok. I wonder if it helps that attaching an Andersen anti-sway hitch requires me to lock the coupler on the ball and then raise the ball quite a ways in order to get the hitch attached? If the coupler were not secure on the ball I would never be able to connect the Andersen,.
2024 Legacy Elite Platinum, Hull #1465
2024 Nissan Pathfinder, Rock Creek Edition
Lithium Batteries (260AH),
240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter.
Victron Orion XS 50A DC-DC Battery Charger
ALAZARCTDEFLGAILINKYLAMEMDMAMIMNMSNHNJNM
On 6/12/2026 at 8:02 AM, CRM said:
I can't even visualize how this can happen if the latch is locked/pinned unless the wire part that attaches from the latch to the collar is bent or broken. Do you have any pics from the topside?
First, I would suggest a serious de-greasing:
So much gunk in any hitch can cause it to stick when hooking up.
  • 3 weeks later...
Anybody notice that they appear to be using a different coupler on the new Apex X23?
Mike
  • 2021 Tundra DC SR5, Improved Racing MHX-514 transmission cooler
  • 2023 LE II - Hull #1420 - "Hank the Tank", Truma A/C, Furnace and WH package, AGM/solar
Yes, you are correct. Oliver has had to source another coupler supplier. Bulldog is supposedly in bankruptcy proceedings as of Oct of 2025. Hopefully they will restructure.
Pic of new coupler -
Edited by Patriot
On 6/13/2026 at 6:07 PM, DavePhelps said:
You didn't show the ball in your pics, but I would have a close look at it for clues, including the possibility that it was out of spec and not the correct size. Or that from lack of lubrication, it was "ground down" to be out of round.
Just a note for those who are using the Anderson WD hitch - you are not supposed to lubricate the ball. It has to swivel with the trailer, otherwise you interfere with the anti-sway function.
Mike
@John Dorrer did I miss this info in the thread?
What type of hitch do you use on the truck?
I just upgraded my hitch on my new truck to a Shocker hitch, but I only have two long test drives under its belt. I was just wondering if a shocker-like hitch could reduce any excessive bouncing when hitting bridges or other repetitive oscillations on the rig.
Chris
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
B & W stow and go, 2" and 2-5/16". I just got a new Bulldog 2-5/16" that I will be installing this week. I don't think I will ever know whether I didn't have the ball fully captured, or whether this was the perfect storm, bad bridge joint and new Alcan 5-leaf springs.
That new hitch is interesting. What is the cost of the Shocker Hitch?
Edited by John Dorrer
Yes you are correct, and that is for the VAST majority of trailers/TV's that use the Anderson.
But....
The vast majority of OEII's just don't sway, even under extreme circumstances.  Properly loaded they just don't sway.  For that reason, many of us have no need for that great feature of the Anderson "system".  Starting with John Davies, we lube the ball to reduce the wear.
I am not suggesting that all new owners assume the same is for their setup.  Get some experience and then decide how your rig handles under extreme conditions.  If after a few years you figure it out, then join the "Don't lube your balls" team.    LOL
Oh thanks for asking?  I was okay not thinking about the price of it. It’s over $760 for the 14K, but I think many move up to the 20K. I will not use the capacity of the 20K. I only own one trailer.
I also ordered their locking pins for $63. They are the highest quality pins I’ve ever seen. I’m truly amazed. All three are keyed the same for convenience.
Chris
Augusta, Georgia
