Citrus breeze Posted Saturday at 08:37 PM Posted Saturday at 08:37 PM Today, my unit suddenly indicated through the Xantrex solar unit that the batteries were dead! New batteries as of last year! Circuit breakers checked out fine. Why is the system apparently draining the batteries? 1 Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Steph and Dud B Posted Saturday at 10:44 PM Posted Saturday at 10:44 PM More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter? 1 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Moderators topgun2 Posted Sunday at 12:16 AM Moderators Posted Sunday at 12:16 AM 1 hour ago, Steph and Dud B said: More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter? Also - do you have solar panels? Do you have a solar panel cut-off switch? do you have an inverter? Is it on or off? do you have a fridge that runs off DC power (i.e. a three way fridge)? If yes then what setting is the fridge on (a/c, d/c, or propane? Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Citrus breeze Posted 50 minutes ago Author Posted 50 minutes ago I have AGM batteries that test with my multi tester as having full power. However, the Xantrex indicates “dead batteries”, even though the voltage reading on it says 11.7V. It seems to indicate that the Xantrex is not reading the batteries correctly. Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Tom and Doreen Posted 39 minutes ago Posted 39 minutes ago What is the voltage measured directly on the battery terminals with a DVM? Tom & Doreen • 2023 Elite ll • Hull #1321 • 2023 Tundra Platinum Crew Max • Cheshire CT
Citrus breeze Posted 19 minutes ago Author Posted 19 minutes ago The voltage directly from the batteries with my multi tester is reading 12.7 V. My Inverter is on. My 3 way refrigerator is not turned on and is therefore not drawing any power. My maxi fan is running on a slow setting. The solar Xantrex controller is showing that I have the 11.7V right now, and is indicating that solar is sending current into the unit. They are new batteries. You see, I’m preparing for our next camping trip this coming Thursday. Does any of this make sense? Charlie Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
Citrus breeze Posted 2 minutes ago Author Posted 2 minutes ago The readings are as follows: IMG_1306.mov Charlie Hull 734 - 2021 Oliver Elite II pulled by F-150 Out of Florida
