Today, my unit suddenly indicated through the Xantrex solar unit that the batteries were dead!  New batteries as of last year!  Circuit breakers checked out fine.  Why is the system apparently draining the batteries?
  • Sad 1
Charlie
Hull 734 - 2021 Oliver Elite II
pulled by F-150
Out of Florida
More info please. Type of batteries? What voltage do you see when you press the Battery button on the SeeLevel monitor? Are you plugged into shore power or running off batteries? Do your interior lights work? Do you have a multimeter?
Also -
do you have solar panels?  Do you have a solar panel cut-off switch?
do you have an inverter?  Is it on or off?
do you have a fridge that runs off DC power (i.e. a three way fridge)?  If yes then what setting is the fridge on (a/c, d/c, or propane?
I have AGM batteries that test with my multi tester as having full power.  However, the Xantrex indicates “dead batteries”, even though the voltage reading on it says 11.7V.  It seems to indicate that the Xantrex is not reading the batteries correctly.
Charlie
pulled by F-150
Out of Florida
The voltage directly from the batteries with my multi tester is reading 12.7 V.  My Inverter is on. My 3 way refrigerator is not turned on and is therefore not drawing any power.  My maxi fan is running on a slow setting.  The solar Xantrex controller is showing that I have the 11.7V right now, and is indicating that solar is sending current into the unit.  They are new batteries.
You see, I’m preparing for our next camping trip this coming Thursday.
Does any of this make sense?
Charlie
Charlie
pulled by F-150
Out of Florida
I'm not sure how the 2021 trailers are configured for power, mine is a 2023, but if you have an Optifuse circuit breaker on the input side feeding the Xantrex the Optifuse may be dropping some of the voltage.  Mine was problematic, the symptom was a low indicated voltage at the Xantrex and when I would run high current devices such as the microwave the Xantrex would shut down. The solution for me was to replace the Optifuse with a marine switch.
I would give Oliver a call and they can help to zero in on the issue.
First thing I see is your batteries are below 12.2. All it takes is one time to damage AGM's. They are unforgiving.
Street side, at the front next to the actual inverter should be the inverter breaker. If it is tripped you can't charge the batteries. It is also possible that it is bad, and/or the cables are loose. Must be off shore power, solar off, inverter breaker tripped and then batteries off before touching the breaker. I have a 2022 and have had to replace the breaker twice.
Charlie,
Based on your measured values, I’d first look at the battery cable to battery post connection(s):
1.  If the 12.7 volt measurement was taken directly from the battery posts, then the battery is not dead.
2.  The solar directly feeds the battery via the Zamp controller.  It does not pass through the inverter or the main battery breaker.  So the 11.7 voltage read from the Zamp controller is more likely a voltage drop through the battery post connection(s), not the main breaker.
3. The inverter also shows 11.7 volts, with no load, so it could also be reading a voltage drop through the battery post connection(s).
That’s a reasonable analysis, and battery post corrosion is a common problem with AGM batteries.  Sometimes the lead battery posts become oxidized.  Although they appear fine, oxidization is a poor conductor.
Having said all that, you possibly have a different setup or a poor main ground connection.  Some simple voltage tests at various connection points would quickly isolate the problem if cleaning the battery posts does not fix the issue.
Hope that helps.  Cheers, Geoff
Wow, twice in 2 years that is not very comforting.  I wonder how bad is their failure rate?
11 hours ago, Tom and Doreen said:
I wish my main electrical setup looked this clean. My 2020, is all over the place.
Yeah but...
Given the pics above, we see 11.2V, then 11.1V, then 11.2V which average with great precision in the range of a dead lead acid battery. The OP posted both 11.7V and 12.7V numbers without supporting pics, no mention of the voltage numbers displayed in the pictures. Lead Acid batteries will go to zero, more load-more quickly.
In my understanding of statistics (I used to teach stats), given 3 independent readouts from 3 independent vendors; read from Zamp, Xantrex, and SeeLevel devices,  displaying the exact same number? (within only a 0.1V deviation on 1 of 3 devices).
Not likely at all. The batteries are reading near dead.
Check the multimeter again as wired and check it again with battery cables all detached. It cannot correctly read 12.7V when 3 simple BMS systems are agreeing to 11.2V. The likelihood is the11.2V is correct and the 12.7V reading is wrong. Measure again.
Then connect to shore power and charge your batteries for 24-48 hours asap.
And perhaps it's a blessing, time to scrap the AGMs! In another OTT Forum thread there is a link to well-featured 300 Ah LiFePO4 sale priced at $600. It's a good time to buy lithium. One of these should provide 50% more SOC% than what you have today. Most who install the LiFePO4 upgrade today go with 600 Ah which will deliver 3x the power of the large 4 battery AGM installation.
When concerned, replace your DC circuit breakers with ANL or MRBF fuses.
You simply know when a fuse burns and there is always a reason behind it. Fuses protect overloads in both directions on the circuit. Simple DC breakers are directional, will protect power to ground faults on one side of the breaker. An issue on the other side of a DC breaker is not covered.
I've kept two DC breakers that OTT installed (30A rooftop solar and 40A for jacks, etc.) When I rework something or add a new accessory, I prefer to add a fuse holder over a breaker (only in 12VDC systems).
Just keep those breakers/fuses and switches out from under your spouse's bed! 🤣
Edited by jd1923
