Ronbrink Posted November 7, 2023 Posted November 7, 2023 On 7/18/2022 at 10:18 AM, Frank C said: I’ve been using this grease from Reese. Seems to work well so far. But any white lithium grease would probably work just as well. Reese Towpower 58117 Hitch Ball Lube https://a.co/d/ijYGGoO I soiled my myself and clothing many times from residual grease on the hitch ball before addressing the issue. I really, REALLY like this product, mostly because it is clear and won’t stain! 3 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
MAX Burner Posted November 9, 2023 Posted November 9, 2023 On 11/7/2023 at 6:01 AM, Ronbrink said: I soiled my myself and clothing many times from residual grease on the hitch ball before addressing the issue. We modify a Truly can (or other narrow beverage cans, Red Bull works) by cutting off the top half of the can and placing the bottom piece over the hitch ball when not connected. Just pinch the bottom and voila - it stays in place and will aid in keeping one from soiling yourself with ball grease... 2 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators topgun2 Posted November 10, 2023 Moderators Posted November 10, 2023 20 hours ago, MAX Burner said: We modify a Truly can (or other narrow beverage cans, Red Bull works) by cutting off the top half of the can and placing the bottom piece over the hitch ball when not connected. Would a "Stella" can work too? Got plenty of those! 😁 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted November 10, 2023 Posted November 10, 2023 4 hours ago, topgun2 said: Would a "Stella" can work too? Got plenty of those I think that MaxBurner pegged just right for me. The Red Bull! Geronimo John 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Geronimo John Posted November 10, 2023 Posted November 10, 2023 On 11/7/2023 at 3:01 AM, Ronbrink said: I’ve been using this grease from Reese. Seems to work well so far. But any white lithium grease would probably work just as well. I use a spray can of white lithium grease instead of any "Water Proof" grease. Reason is that I had not discovered the "Red Bull" can approach (Max Burner's post). So my use of use axle grease (Pretty much water proof and permanently staining) came with time consuming challenges. Not to mention that I kept finding myself using Borax abrasives to sand off the grease (and a layer of skin) that always seemed to appear about 24" above ground. Or the buckets of Dawn dish soap trying to remove those stains from my 7-pocket shorts. At least lithium white grease is only water resistant and getting stains of me and my shorts is a lot less time consuming when I forget the Red Bull can! GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderators topgun2 Posted November 10, 2023 Moderators Posted November 10, 2023 4 minutes ago, Geronimo John said: At least lithium white grease is only water resistant and getting stains of me and my shorts is a lot less time consuming when I forget the Red Bull can! Try a few of the Stella cans and you probably won't care. 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Geronimo John Posted November 10, 2023 Posted November 10, 2023 Pretty amazing that this six year plus thread is still a valid topic. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
John Dorrer Posted November 10, 2023 Posted November 10, 2023 Will this do the job? John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Ronbrink Posted November 10, 2023 Posted November 10, 2023 1 hour ago, Geronimo John said: At least lithium white grease is only water resistant and getting stains of me and my shorts is a lot less time consuming when I forget the Red Bull can! Good one GJ, go Red Bull! Actually your quote credited to me, “I’ve been using this grease from Reese”, is that of Frank C. I’m advocating the Mission Automotive Hitch Ball Lubricant. The ‘soiling’ issue as subsided since picking up a trailer ball cover from Academy, works great! 2 Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
Moderators SeaDawg Posted November 10, 2023 Moderators Posted November 10, 2023 Water bottle, yellow microfiber cloth, etc all work, too. Though stella or yuengling cans are more available. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderator+ ScubaRx Posted November 11, 2023 Moderator+ Posted November 11, 2023 7 hours ago, Geronimo John said: Pretty amazing that this six year plus thread is still a valid topic. GJ Yeah, but this thread lost all its focus before the end of the first page. Now it's a "What grease is best for my ball" or a "What beer can should I cover my ball with" question. If anyone wants to continue this line of inquiry, please start a new thread. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
