Woodrow_apples Posted January 15, 2019 Posted January 15, 2019 Anybody towing a Legacy Elite II have experience with tow mirrors? Would you say they are necessary? I am going to be towing a Legacy Elite 2 with a Tundra. Thanks y'all!
donthompson Posted January 15, 2019 Posted January 15, 2019 I tow with a VW Touareg TDI and would not be comfortable towing without towing mirrors. Without them, you really can't see behind the camper. The ones I've used successfully for a number of years are Dometic DM-2912 Milenco Grand Aero3 Towing Mirrors. You can purchase on Amazon and other places. They are easy to attach and give you a good field of vision. 1 Don 2020 Kimberley Kruiser T3 2019 Ram 2500 Diesel States I visited with my Ollie (Sold October, 2019)
John E Davies Posted January 15, 2019 Posted January 15, 2019 I tow with a 2013 Land Cruiser and don’t need extra mirrors. However I think a trailer backup camera that is NOT wired into your backup lights is mandatory. I turn it on when in heavy traffic to watch for tailgaters or idiots. It is extremely helpful! When I towed with a Ram 3500 with wide mirrors it was certainly nice, but I don’t have a problem with the 200’s stock ones. I suspect your Tundra is a few inches wider, so no worries. Since you are getting an Elite II, I hope you have the 5.7 engine. If so you definitely have the needed power and those wonderful 4.30 axles. My 200 has 3.90 axles and with my Plus 2 tires it struggles a little at high altitude. I may regear them, eventually, maybe go all the way to 4.88.... so I can tow in fifth instead of forth. If you have stock tires or up to 33” ones you should have no difficulties. John Davies Spokane WA 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Maverick Posted January 16, 2019 Posted January 16, 2019 Our tow vehicle is a Toyota Tundra with the standard mirrors and we have no issues with towing the Elite II. The Tundra has the 5.7 L engine with a 4.30 axle and have had no problems towing anywhere in the country. Good luck and safe travels. 1 Horace & Dianne Chesapeake, Virginia 2016 Toyota Tundra Crewmax 4x4 Limited 2015 Oliver Legacy Elite II - Hull # 93
Moderators topgun2 Posted January 16, 2019 Moderators Posted January 16, 2019 When I towed with vehicles other than a 1/2 ton truck I felt the need for rear side-view mirrors. But, since the Oliver is just about the same width as my F-150, I can see behind it just fine. Like John, I too turn on my rear camera when I'm in heavy traffic and/or am backing up - think safety here. That camera also helps avoid the bozo who is right on your bumper and just about the time you decide to move right, they jump out trying to get one car ahead. If you decide to get the mirrors anyway, don't get the kind that "strap" onto your existing mirrors. Those rubber straps are difficult to deal with and do not last more than a couple of years. Nor would I purchase the type that just "clips" onto the existing mirrors. This type that "slides" over the existing mirrors is better: https://www.amazon.com/CIPA-10700-Custom-Towing-Mirrors/dp/B000CISLSI/ref=sr_1_18?ie=UTF8&qid=1547649821&sr=8-18&keywords=slide+on+towing+side+view+mirrors Of course, mirrors that can be "tilted" back alongside your vehicle are great in that you can swing them back when getting into tight spaces and then back out when the area opens back up. I've never owned a vehicle that had mirrors that can be extended while towing since I've always thought that most of these were a bit ugly. Hope this helps. Bill 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
rideandfly Posted January 16, 2019 Posted January 16, 2019 Woodrow_apples, We tow Ollie with a 2016 5.7L Tundra. No issues with stock Tundra mirrors over 20,000 miles, so far. 2 Bill 2015 LE2 #75 2024 F350 6.8L
Overland Posted January 16, 2019 Posted January 16, 2019 Agree with the above. I had planned to swap out tow mirrors on our Raptor, since they're not available from the factory, but found the stock mirrors to be perfectly fine. Tow mirrors are really only necessary when what you're towing is wider than your truck. Having said that, bigger mirrors are always nicer. I also agree with John D. An always-on rear view camera (I use a wired system from RVS) is a big asset, for backing up as well as keeping an eye on what's coming up behind you. 2
Woodrow_apples Posted January 17, 2019 Author Posted January 17, 2019 Thanks Y'all. John I do have the 5.7 L engine. Thinking I will hold of for a while and maybe upgrade to proper towing mirrors if I feel they would be really beneficial, but seems like a number of y'all have had success with standard 150 mirrors. Bill, I decided to go ahead and get the back mirror installed for traffic, bozos, backing up etc. Y'all are the best! Thanks!
Mainiac Posted January 18, 2019 Posted January 18, 2019 We have just standard mirrors on our Ram 2500. We can see down both sides of the Oliver without a problem. We use the rear Oliver camera when passing another vehicle. With a reach over to turn on the camera we know when it is safe to pull back in. We also turn it on in heavier traffic to watch the 'zip zips' trying to gain an extra foot in the right lane, or the tailgaters. We do find to leave the camera on all the time is a distraction. 1
Spike Posted January 19, 2019 Posted January 19, 2019 We too tow with a Tundra. I bought the extended snap-on mirrors but took them off. They are unnecessary, and I found that they blocked too much of the view to the sides of the truck. 1 Onward through the Fog! EarthPicks of Cochise County
