Kgeb Posted January 20, 2020 Posted January 20, 2020 So we have used our awning maybe 5 times since we purchased 441 less than a year ago. We were camping locally this weekend when my husband said the awning is sloping left. We got home and opened the awning and it really slopes and doesn’t close completely on the left. We have used this sweet camper only 4 times due to a hectic 2019. Take a look at this video and tell us what you think? Oh we never noticed a sloping before. IMG_7484.MOV
Overland Posted January 20, 2020 Posted January 20, 2020 (edited) I assume that you’ve checked for any obviously loose bolts or screws. If no one can provide you with a quick fix, I’d give Oliver a call on Monday. I’m certain that they’ll take care of it. Edited January 20, 2020 by Overland
Kgeb Posted January 20, 2020 Author Posted January 20, 2020 Thanks for the reply...all is tight no call back from Jason yet. But we have had a time with mud daubers. I don’t see anything but they can surly make a mess of equipment. Karen
Geronimo John Posted January 21, 2020 Posted January 21, 2020 The angle of the awning is dependent upon the supporting structure. You may want to extend it and then measure the sides and compare the results. The locking tabs for the side structural (supports) can be adjusted to increase or decrease the side supports.. Generally it is a good idea not to have it flat in either the side to side or the fore and aft directions. By having transverse slope both ways, heavy rains are handled with less force on both the fabric and the structural members. This may be what you are seeing. TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Trainman Posted January 28, 2020 Posted January 28, 2020 (edited) I have not seen an Oliver awning that didn't slope some, at least on the newer ones that don't have the support poles. I purchase the Green Elephant Tent Poles form Amazon for $49.00. They do telescope way down and come with a bag for storage, plus two different top post for different uses. I did drill a small hole in each end of the awing and put in a rubber grommet with a 1/4" hole in the center, just the correct size for the GE Poles to fit into. These poles allow you the level your awing and also help stabilize your awning in the wind, they can also be staked if needed. I'm totally happy with the results and have showed this mode to other Oliver owners at rallies and camp grounds. https://www.amazon.com/s?k=green+elephant+telescoping+tarp+poles+set+of+2&ref=nb_sb_noss trainman Edited January 28, 2020 by Trainman 1 2019 RAM 1500, 5.7 Hemi, 4X4, Crew Cab, 5'7" bed, Towing Package, 3.92 Gears. Oliver was sold.
Galway Girl Posted January 29, 2020 Posted January 29, 2020 (edited) We picked up our Oliver Hull 505 in Aug 2019. It has on the Dometic 9500E Electric Door Side awning. Oliver University, and my physical user manuals didn't match the remote we have. Our remote looks like this below and the correct (3/2019 version) awning installation and operation manuals are attached. The installation manuals show how to adjust the slope of the awning, and also how to make sure the front of the awning is parallel to the main body of the awning. (That's very important to make sure the awning rolls aligned and smootly). I'm dealing with a different problem where the awning won't fully retract. It sticks out about 1/2 in from fully seated as in the pix below: There are motor adjustment screws at the front of the awning that are hard to reach and require a special hex tool. These are used to adjust the motor close point. (In previous generations of the case awnings this was done via "remote control button pushes.) I'm working with Service to figure this out...and I may need to build a special hex tool for this by modifying a standard hex key. The clearances to get in to this adjustment are VERY tight as the adjustment holes actually are facing the body of the trailer when mounted. More if I succeed. Hoping to NOT have to take it to a Dometic repair dealer, as the first one I was referred to by Oliver Support said they were "frankly not interested working on a trailer not bought at their dealership." 9500E Operation 3316982.000.pdf 9500E Case Awning Install 3316981.000.pdf Edited January 29, 2020 by ctshort09 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Moderators SeaDawg Posted January 29, 2020 Moderators Posted January 29, 2020 Wow, Ct, that's sad. I suspect Dometic wouldn't be very happy to hear that an authorized warranty repair facility didn't want to work on your trailer. Frankly, I've never heard that response before. My local Dometic dealer, Campingworld in New Port Richey, was really gracious and thorough in working through my Dometic fridge issues years ago. So sorry. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Galway Girl Posted February 3, 2020 Posted February 3, 2020 (edited) I'm taking the trailer to a local repair facility today Poulsboro RV in Everett WA. They are one of the largest RV and Dometic dealers in the area and said they would work on the issue for us. I'll coordinate between Oliver Factory Support and the local service center on this one and report back results. *Results* - Took trailer to a local dealership Poulbro RV where they successfully did the awning motor adjustment for free. The awning now retracts fully into the case. That dealer also did the Dexter Axle recall for free. I had them do my wheel bearing repack since it was time for that to happen. Hunting the Mystery Dometic TOOL = The dealer said that Dometic Awnings motor adjustment require a flexible tool with hex key end. They also said that tool was provided to dealers by Dometic within the installation kits of awnings. I'm trying to find out what tool that actually is...and get one so if this happens again I don't have to drag the trailer to a dealer. I put the question to Jason in service. I'll update this if I find the answer to the mystery. If anyone is doing a factory tour...see if you can spot one during the tour and take a picture. Edited February 7, 2020 by ctshort09 Added follow on text. 2 3 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine Aug 2024 on way to Nova Scotia.
Kgeb Posted April 6, 2020 Author Posted April 6, 2020 Just an update since I have seen the above posts. It was a screw adjustment and it works like a charm now 1 1
Landrover Posted April 6, 2020 Posted April 6, 2020 9 hours ago, Kgeb said: Just an update since I have seen the above posts. It was a screw adjustment and it works like a charm now Question which adjustment screw? And how many turns in or out? I have the manual awning with the same problem. I found that when it closed I retract it 1-2 turns then back in. Awning closes completely. Grant 2022 GMC Denali 2500 HD 2019 Elite 11😎
Moderators Mike and Carol Posted April 6, 2020 Moderators Posted April 6, 2020 On 2/3/2020 at 11:13 AM, ctshort09 said: *Results* - Took trailer to a local dealership Poulbro RV where they successfully did the awning motor adjustment for free. The awning now retracts fully into the case. That dealer also did the Dexter Axle recall for free. I had them do my wheel bearing repack since it was time for that to happen. It sounds like you have a really good local dealer! Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
