Its getting to be that time of year when we are starting to think about winterizing the Ollie.  Certainly it is easy to winterize using the port at the rear of the Ollie but an often overlooked past of the process is putting a bit of antifreeze in the other three ports - City Water, Fresh Water and Black tank flush.
This is also easy if you use a hand pump - https://www.amazon.com/Horusdy-transferencia-combustible-multiuso-líquidos/dp/B075C3NNZF/ref=sr_1_7?crid=1TBR3DRPDJK7&dchild=1&keywords=liquid+transfer+pump+manual&qid=1598820277&sprefix=liquid+tran%2Caps%2C180&sr=8-7
But, these pumps come with both the intake and output hoses simply cut off at the ends.  Buying a plastic fitting with one end barbed and the other end compatible with the ports on the Ollie really simplifies the entire process.  Simply insert the barbed end of the fitting into the output hose on the pump, secure it with a clamp and you are ready to go.  Screw the fitting onto the Ollie port, place the other end into the antifreeze, give the handle a couple of pumps and you are done with that port.
Great suggestion Bill,
Another hand pump option from Harbor Freight - $5 with a 20% off coupon. And Super Tech RV safe anti freeze- $2.58 a gal at Wally World.
We’ve got 12 months of camping left before we winterize.  Will re-assess in 12 months, but will probably go for another 12 months!  I think I know quite a bit about my Oliver, but since we’ve never winterized I don’t have a clue how to do that.  Mike
  • Haha 2
Good one Mike,
What ya just gotta love about Texas! We miss our days living there...oh Rudy’s BBcue! 😋 😄
Edited by Patriot
Another winterization tip:
In order to help prevent that "dreaded fridge odor" from developing during winter or other storage of the Oliver; simply empty, clean and dry the fridge and then place several sheets of crumpled newspaper inside both sections of the fridge.  Also then prop both doors (the freezer and the main door) slightly open.
When it is time to take your Oliver out of storage all you have to do is remove the newspaper, close the doors and turn it on.  There will be no odor at all.
Edited by topgun2
The fitting that I mentioned in the first post above is a bit hard to come by.  Even though these are a bit more expensive, another way to "skin that cat" is to get what is called a "RV Blow Out Valve/plug"
https://www.amazon.com/Valterra-P23518LFVP-Blow-Out-Plug/dp/B00HSO2T5A/ref=sr_1_39?crid=29XWEBY27PKZB&dchild=1&keywords=rv%2Bblowout%2Badapter&qid=1600366608&sprefix=rv%2Bblow%2Bout%2B%2Caps%2C179&sr=8-39&th=1&psc=1
Don't forget to remove the valve stem from inside the plug/valve prior to using for the winterization purpose.  These valve stems simply screw out (lefty loosey to take it out) or (righty tighty to put it back in).
Could someone post a link to the proper fitting used to attach pump hose to the city water, fresh water and black flush tank.  I'm thinking it's probably a threaded male hose fitting; any drip irrigation supply vendor would have this (though I don't know the size of the hose that attaches the pump).  We might even have one in our drip system "toolbox" , as well as the necessary barbs.
Isn't there also a pressure relief valve somewhere in the utility area of the Oliver that must be winterized?  And are the tank dump valves vulnerable to freezing weather?
I have way too much time to think, sitting at home waiting for our Oliver to go into production :classic_biggrin:
Ray and Susan Huff
1UP-USA Heavy-duty bike rack
During our wait time my wife and I hit the books....and so glad we did. The more you read the better it gets! 😉
Here- https://olivertraveltrailers.com/oliver-university/
Edited by Patriot
5 hours ago, Mainiac said:
Edit button disappeared. Hate spell correct: available not avatar...
It’s the three dots on the right side corner now. I preferred the button too.
I didn't see anything about a pressure relief valve or winterizing the holding tank valves . . . . . so I guess they are fine?
When is Oliver going to get info in the University for 2021 changes?  And I'd like to see a video tour of the same.
Ray and Susan Huff
Great questions to consider emailing and asking your sales rep. 👍🏻 I am sure they would gladly assist you if given the opportunity.
Adding it to the list . . .
Ray and Susan Huff
Found this winterization transfer pump.  It has the threaded fitting.
Ray and Susan Huff
Susan -
For that price you can buy a bunch of the Harbor Freight pumps and a couple of the more expensive threaded fittings I mention above.
The hose fittings are all just standard fittings.  Any old hose will work.  Not sure what you mean by “pump hose”.  The procedure I use is I take my hose, screw it into the water source and then screw the other end into the connection on the trailer.  Mike
I was referring to using a transfer pump to put antifreeze into the city water, fresh water, and black flush ports as mentioned by the OP, @topgun2.  The "pump hose" I mention is the hose that attached the hand pump to the aforementioned ports, which would be the same as the threaded fitting on the end of a hose.  However, the transfer hand pump pictured in the OP does not come with that fitting.  This pump, however, does:
https://www.westmarine.com/buy/camco--hand-pump-winterizing-kit--329179?recordNum=21
3 hours ago, topgun2 said:
Susan -
I agree . . . . just wanted others to know they can buy the whole works in one, if so desired.
Edited by Susan Huff
Ray and Susan Huff
  • 3 months later...
We have a freeze warning for tonight - temps predicted at 27 degrees.  We have our fresh and waste tanks drained, but have not winterized, a an oil filled heater running in the cabin and leave the basement access door open.  Temperature sensors in the cabin read from 58-66 degrees; in the basement 39-48 degrees with nighttime temps at near freezing.
Is it necessary to hand pump antifreeze into the outside ports, in anticipation of temperatures in the upper 20's tonight?    If yes, would we just follow the winterization plan as listed in the Oliver manual, steps 20-27?  We have not drained the water heater (Suburban) and it is not turned on.
Ray and Susan Huff
All should be Ok - given your heating the interior. I would have drained the WH,
RB
Cindy,  Russell and  "Harley dog" . Winchester TN
2027 EII on the production board. "Ramble On"
2026 Chevrolet 2500 ZR2, 6.6L L8T gas V8
The only things I worry about with short freezes are the check valves at the fresh and city inlets, since it's metal to metal and in a small unheated space.  A little antifreeze in those, or blowing them out with an air hose, might be prudent.
The water heater is very close on the list, but moreso with the Truma, and that's super easy to drain or set to antifreeze so never a big deal.
The rest of the plumbing is unlikely to freeze if the trailer is heated.
Edited by Overland
Thanks for the advice. . . . . . I'm ready for Springtime weather 😎
Ray and Susan Huff
