Geronimo John Posted December 13, 2021 Share Posted December 13, 2021 NOTE: This thread is not about how loud your OEM A/C is. Please go to the "Got Ear Plugs" or other threads for those discussions. This thread does seek info from OEII (TWO) owners who have used their trailers in hot conditions. INTRODUCTION: During the past four model years, the BTU (British Thermal Unit) capacity rating for our OEII's have been reduced. It would be beneficial to know what owners think about the cooling capacity of various A/C units running in very hot conditions. From Oliver University, I gleamed the below BTU capacity of the OEM units. These OEM A/C capacities have been verified by Jason. 2018 Domenica 13,500 BTU unit used this model year 2019 Domenica 11,000 and 13,500 BTU units used for this model year 2020 Domenica 11,000 BTU unit used this model year 2021 Same as 2020 SURVEY QUESTIONS: What is your user name, OEII model year, and it's Hull Number? What A/C do you currently have and what is it's BTU rating? While using shore power, what was the max outside temperature you have stressed your current A/C? How well did it perform? Other comments you would like to add? +++++++++++++++++++++++++++++++++++++++++++++++++++++++ SAMPLE desired SURVEY RESPONSE FORMAT: (Happens to be my response for my unit) Geronimo John, 2018, Hull 342 Domenica 13,500 BTU I have run my unit at 100 degrees conditions under mostly direct sunlight. It cooled very well. Generally I think my unit is oversized. When I replace it, I will seek a smaller capacity model that uses less power; such as an inverter compressor with variable speed fans for evening use. +++++++++++++++++++++++++++++++++++++++++++++++++++++++ Again please don't respond with comments about how loud your unit is. We have beaten that horse enough. However how quiet yours runs is fair game for owners that have replaced their unit. Such experiences will help other owners in selecting a future replacement A/C 's so both size and quiet experiences are encouraged. I'm looking forward to reading your "Cool Experiences" . Thank you, GJ 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
Overland Posted December 13, 2021 Share Posted December 13, 2021 Good topic - I’m interested in the results. Something to keep in mind, which I just mentioned in another thread, is that I believe that Oliver increased the insulation a few years go. I was thinking 2020, but it may have coincided with the switch to the smaller AC. Regardless: 2017, #256 Dometic 13.5 85 degrees full sun - cooled very well but cycled a bit more than I thought it would, maybe a 75% on / 25% off ratio. I too think mine is a bit oversized, and if/when I replace it with a quieter model, will likely size down a good bit, especially since we rarely use it at all and when we do it’s usually only on a warmish spring or fall night. 1 Link to comment Share on other sites More sharing options...
Moderators Mike and Carol Posted December 13, 2021 Moderators Share Posted December 13, 2021 Mike and Carol, 2016 #135 Dometic 13.5 106 degrees in full sun on low kept us cool My next AC will not be as large. 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Link to comment Share on other sites More sharing options...
Mcb Posted December 14, 2021 Share Posted December 14, 2021 Mcb 2020 685 Dometic 11k Mid 90s, full sun…. Kept us cool We will replace it with something quieter in the future. 2 Mark & Deb..2020 Elite II..Dearie..Hull #685..2016 Tundra Link to comment Share on other sites More sharing options...
Hokieman Posted December 14, 2021 Share Posted December 14, 2021 Mike D, 2021, Hull 797 Dometic 11k BTU I have run my unit many times in mid 90’s temps, high humidity, under mostly direct sunlight. It cools very well. I think the cooling capacity is adequate at 11k. The unit does cycle frequently, but we run the fan on Low, not Auto, so it is satisfactory. If I replaced it, I would consider a smaller capacity unit. 2 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250 Link to comment Share on other sites More sharing options...
stlipa Posted December 14, 2021 Share Posted December 14, 2021 Stlipa #137 Dometic 13.5 Mid 90’s with sun, cooled fine will downsize to smaller unit when the Dometic needs replacement 2 Russ & Mary Caslin 2015 Jeep Grand Cherokee Overland 3.0L diesel 2021 Tundra SR5 Double Cab 5.7 V8 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 14, 2021 Moderators Share Posted December 14, 2021 I think I'm the only Elite I so far. Seadawg, hull # 12 2008 The original 13500 btu Dometic (2008) was overkill. Would freeze us out in a short time. Replacement 9500 btu Houghton has only been used and tested a handful of times in Florida spring, so high 80s to low 90s, and worked fine, cooled quickly, and maintained desired temp easily. I like the dehumidifier function, too. 1 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. Dc compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
CnC Posted December 14, 2021 Share Posted December 14, 2021 CnC, Hull #617, Dom 11K Have yet to use this one. Used the 13.5 K our MB Airstream (Sprinter) twice in 6 years. Note that too frequent cycling usually means the humidity isn't being controlled because the temperature is being satisfied too quickly. Additionally, the slower the fan speed the more humidity is removed. 3 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4 Link to comment Share on other sites More sharing options...
NCeagle Posted December 16, 2021 Share Posted December 16, 2021 NCeagle, 2020, Hull 688 Houghton 13.5K BTU I have run my unit in 90-100 degrees conditions under mostly direct sunlight as well at night in 70-80 degrees. It has cooled and controlled humidity very well. I think given the fact that we live in NC and camp year round (high heat / humidity in the summer) that a bigger 13.5K unit is going to be more efficient than a smaller 11K unit. Given my experience thus far, I really don't think 13.5K is overkill for an Elite II and I'd likely stick with the same size if I had to replace. 4 2020 Elite II, Hull 688 --- 2021 Silverado 2500HD, 6.6L Duramax Diesel Link to comment Share on other sites More sharing options...
Geronimo John Posted December 16, 2021 Author Share Posted December 16, 2021 On 12/14/2021 at 7:03 AM, SeaDawg said: I think I'm the only Elite I so far. LOL. Yep, the survey was for the OEII owners. But we enjoyed your input regardless. In fact, I'll start another thread for the OE1's to respond to as it may be good info for OTT to have. GJ GJ EDIT: Second survey for OE1 (ONE) owners is posted. 🙂 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 16, 2021 Moderators Share Posted December 16, 2021 Since you've now changed the title to oe2 owners, I'll move my post, if you like. do we need two surveys? There aren't that many of us with the smaller Elite. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. Dc compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Geronimo John Posted December 16, 2021 Author Share Posted December 16, 2021 On 12/14/2021 at 7:54 AM, CnC said: Note that too frequent cycling usually means the humidity isn't being controlled because the temperature is being satisfied too quickly. Additionally, the slower the fan speed the more humidity is removed. CNC you are spot on. One additional thought that compliments yours. By running the fan continuously, the dehumidification features is greatly reduced. WHY? Because when the compressor cycles off, it stops cooling the coil. With the fan still running, the gallon or more of water trapped in the coil evaporates off back into the trailer. Resulting in a much higher average humidity in the trailer. The above will likely result in the occupant setting the unit to a cooler temperature. Result: use of more energy and marginal comfort improvement. Bad. But MUCH worse is that by evaporating off all that water, the entrained minerals plate out on to your evap coil. This becomes a rock hard deposit that only strong acid will remove. Not something that 99.5% of us want to be doing. Best solution for humidity control for an oversized A/C is to run the fan on auto and low speed. This also keeps in "solution" the minerals and the majority of it runs out the evap drain tube to the ground. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 17, 2021 Moderators Share Posted December 17, 2021 Interesting. I've not ever heard of an Oliver owner complaining about "rock hard" deposits on the coil. Sometimes, honestly, I think some of us here, as a group, get a bit carried away here, and imagine the very worst outcomes. But then, I could also be accused of 14 year old rose- colored glasses, as well. 😅 Our friend in the luxury yacht industry (naval architect) has explained to me that the new dehumidifier function on marine ac is basically running the ac on a very small temp differential, and fan on low. No problems. Seems to be what our Houghton does. Quite possibly what Truma does. I don't know for sure. For those of you who want to run your ac fan on low, constant, instead of auto, I think there are a bunch of others that do that here. We don't do that with our home ac, because we live in very humid Florida. I personally can't see it being an alarming problem, especially in the arid west, in an rv, used part time, and ac probably even less. That water that runs out of my rv ac is pretty minimal, even in Florida. One of my friends in NC sometimes collects ac and dehumidifier waste water to wash his car, as it's his feeling that it's pretty much rain water, as an ac/dehumidifier byproduct. In a big cabin, he doesn't get a gallon a day. But, of course, I could be wrong. I'll wait to see what others have experienced, as we truly don't use the ac much, at all. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. Dc compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Geronimo John Posted December 18, 2021 Author Share Posted December 18, 2021 On 12/16/2021 at 12:45 PM, Geronimo John said: This becomes a rock hard deposit that only strong acid will remove. Not something that 99.5% of us want to be doing. SeaDog: I can assure you that if you don't use your A/C much, you'll likely never suffer from mineralization of your evap coil regardless of your fan setting. In practice, for even part time A/C use, the fan setting would not cause mineralization for just about any location. The unit will generally die first of old age, electrical shorts or compressor failure....not mineralization. However, for those that rely on their A/C and use if consistently, especially down south where hot and humid humid conditions prevail, the problem of mineralization accumulation primarily caused by coil drying with each cycle (Due to the fan running continuously, climbs significantly. For that group, the removal of calcified deposits requires a strong acid, and THAT is something that most of us would not want to mess with. Sorry I was not more clear. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted December 18, 2021 Moderators Share Posted December 18, 2021 @Geronimo John, its all good. I get your engineer background, and your look ahead mindset for potential problems. My husband is also a retired engineer. Looking ahead to avert problems is never a bad thing. Just don't get carried away, imo. That's sometimes my job, as wife of engineer. 😉 I'm just saying I've yet to hear of anyone with an Oliver having that issue of huge, hard, mineral deposits. Actually, no one else, either. Could it be a potential problem for someone who's a full-timer in Florida? Maybe. But I've never heard of it with even my full timer Florida friends. Something to watch for? Ok. I'll bite. I live on the saltwater, so we clean the outside units at home every year (or so.) That's often just a good long spray with a hose, and sometimes adding a mild solution. What could actually turn to crap is windblown salt, and dirt, mostly. We all know salt air is corrosive, so regular cleaning of pretty much everything is important, in my neck of the woods, and everywhere else, as well. My point was, I've yet to ever, ever hear of someone's ac (including my 14 year old one) locking up with hard deposits. That includes other forums I read. The usual advice in humid Florida is don't run your fan on high, continuous, as it circulates humid air. With units that tend to short cycle (most rv units have only 1 or 2 degree differential in the thermostat), that whole scenario is unlikely to ever occur, imo, especially running fan on low. Just pointing out that some posts, taken without a grain of salt, not understanding personal experience, can alarm folks, unnecessarily. I think you and I can agree to disagree in an amicable fashion, especially for the most of us, who are part timers. I only camped 152 days this year, and probably only ran 10 to 15 days with ac, in the side driveway, non-camping, while setting up, and cleaning up, at beginning and end if season. I see lots of posts about birds' nests and mud daubers, though. It is indeed important to inspect and clean, especially if, like us, your camper is outside 24/7/365. My screen name is seadawg, btw, but you can call me Sherry, too. Putting my virtual hand out there, for the 🤝 handshake. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. Dc compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Geronimo John Posted December 18, 2021 Author Share Posted December 18, 2021 22 minutes ago, SeaDawg said: My screen name is seadog, btw, but you can call me Sherry, too. Putting my virtual hand out there, for the 🤝 handshake. Nice to meet you Sherry. GJ TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DYI’s: BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DYI’s: 2 5/16" Anderson System, Timken Bearings, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all. Link to comment Share on other sites More sharing options...
