Liana Posted October 10, 2022 Posted October 10, 2022 Our two under cabinet Galley lights stopped working. Every other light in the trailer works fine. We haven't moved the trailer in several weeks and Those lights were working just fine until yesterday morning. I'd Suspect A fuse if others were also inop, (I don't see a fuse dedicated to lights, are they on the TV circuit?) Not sure what else to check? 2018 LE2 #333 "the Otter" 2015 Silverado 2500HD
Ralph Mawyer Posted October 10, 2022 Posted October 10, 2022 The touch lights are flakey. Mine over the sink particularly so. You can remove the cover and see if the spring contacts are messed up, but I've not read of any true repair process. I got a few spares from Oliver Service. FWIW, they aren't crazy about them either. 1 2020 Legacy Elite II : Hull 625 - 2013 Lexus LX 570 Factory Upgrades: Truma A/C, 640AH Lithionics, Alcan Springs, 5200 Axle, Bulldog Shocks (June 2025) San Antonio/Boerne - Texas Hill Country
Moderators topgun2 Posted October 10, 2022 Moderators Posted October 10, 2022 Liana - Given your hull number I suspect that you have the "touch" lights (i.e. you touch or push them to turn them on)? If this is the case then about all you can do is get replacements from Service. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
CnC Posted October 10, 2022 Posted October 10, 2022 Ours - over the stove - glows faintly when it's very, very dark. If you close your eyes, you can't see it! Charlie. 1 Arizona | 2020 Oliver Elite II Twin bed Hull #617 | 2021 Ram 1500 e-Hemi 4x4
Hokieman Posted October 10, 2022 Posted October 10, 2022 Oliver sells them for $3.15 each. I’ve lost 2 total in a year and a half. I ordered 6 spares last week. 1 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250
Liana Posted October 10, 2022 Author Posted October 10, 2022 44 minutes ago, Ralph Mawyer said: The touch lights are flakey. We don't Have touch lights. Simple on/off switch 2018 LE2 #333 "the Otter" 2015 Silverado 2500HD
Liana Posted October 10, 2022 Author Posted October 10, 2022 41 minutes ago, topgun2 said: Given your hull number I suspect that you have the "touch" lights No, we don't Have touch lights 2018 LE2 #333 "the Otter" 2015 Silverado 2500HD
CRM Posted October 10, 2022 Posted October 10, 2022 1 minute ago, Liana said: No, we don't Have touch lights Then most likely you just need new bulbs which are probably G4 type. I'd swap the bulbs with one of the working lights to confirm. 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Liana Posted October 10, 2022 Author Posted October 10, 2022 38 minutes ago, CRM said: Then most likely you just need new bulbs which are probably G4 type. I'd swap the bulbs with one of the working lights to confirm. It looks like VERY tiny screws hold a retaining ring to remove them? 2018 LE2 #333 "the Otter" 2015 Silverado 2500HD
bhncb Posted October 10, 2022 Posted October 10, 2022 1 hour ago, Liana said: Our two under cabinet Galley lights stopped working. These are LED lights so more than likely it's the switch. Open the access plate in the cabinet above and reach in behind the switch panel to feel for the switch wires. Count the wire groups over until you've found the one for the kitchen light switch. Wiggling the wire connections slightly will sometimes cause the internal switch contacts to start working. Otherwise, push the switch out of the panel from behind and have Oliver send you a replacement. 3
Liana Posted October 10, 2022 Author Posted October 10, 2022 28 minutes ago, bhncb said: These are LED lights so more than likely it's the switch. This makes More sense since both lights stopped Working At exactly the Same time 2018 LE2 #333 "the Otter" 2015 Silverado 2500HD
Moderator+ ScubaRx Posted October 10, 2022 Moderator+ Posted October 10, 2022 2 hours ago, CnC said: If you close your eyes, you can't see it! Charlie. I like that solution. Simple, easy, cheap and quick. 1 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
