Wow! 😳.   They said they weren’t overloaded because they have a RAM 3500 one-ton truck but that Eagle 1165 truck camper spec sheet lists a dry weight of 4,917 pounds!!!   Add a full fresh tank (66 gallons!) and camping gear, food, etc and the total load would get close to 6,000 lbs.
3 minutes ago, Frank C said:
Wow! 😳.   They said they weren’t overloaded with a RAM 3500 one-ton truck but that Eagle 1165 truck camper spec sheet lists a dry weight of 4,917 pounds!!!
The 2020 Ram 3500 lists a payload capacity of up to 7680 lbs., depending on configuration.  It would be interesting to know what the GVWR sticker on that truck says...
Yeah, the max spec for a gas RAM seems like it should be enough.  The diesel loses quite a bit of max payload but should still be sufficient.  Can’t tell from the photo if that’s a diesel RAM or not.   Like you said, it would be interesting to see the specific ratings for their truck.   It’s a fairly new truck (2020) so you would assume it’s not a frame corrosion issue.   But wow that is still a really heavy camper!  That’s like parking an Elite II in the pickup bed!
Isn't the load rating for within the confines of the truck... and not the cantilevering amount that hangs over the end of it?
Charlie
Charlie
Beyond all the other weight ratings, truck mfgs specify a maximum Cargo Weight Rating for the bed area and a Center of Gravity range for load placement. When both are observed, overhang is accounted for. What they don't specified is a maximum trailer tongue load hanging off an unknown length hitch extension. Suspect neither RAM nor Ford would warranty either of these two failures.
Always load your beer and ammo as far forward of the rear axle as possible.
I'm thinking:
  • Long lever arm from rear of back axle
  • Heavy front loaded trailer
  • Overhanging camper
  • Extended several feet the trailer receiver hitch for trailer
  • Add in possible frame damage due to installer of camper or maybe salt corrosion
  • Maybe high speed
  • Especially Yukon Territories corduroy roads
Combine several elements of the above and .....what goes up, can slam back down real hard.
For the original photo posted by @ScubaRx I've seen some speculation that improper welding of the front tie-down points may have weakened the frame.
