John E Davies Posted April 10, 2023 Posted April 10, 2023 This was posted in the past, I can't find it. Grommet is 3/8" outer hole, 1/4" inner hole, and about 1/16" thick. Steel holder piece is 5/8" diameter. I can buy a big set like this, but that seems like a waste for one grommet... There is a great specialty vendor for o-rings called The O-ring Store, but they don't have a sister company for grommets.. ;( Thanks. John Davies Spokane WA 2 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Moderators topgun2 Posted April 10, 2023 Moderators Posted April 10, 2023 The last set (individual grommets) I purchased was found at Lowe's and the set before that was at Ace. Good luck! Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Galway Girl Posted April 10, 2023 Posted April 10, 2023 Ace,Lowes, Home Depot packages. I’ll look online in a bit. 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Galway Girl Posted April 10, 2023 Posted April 10, 2023 (edited) UPDATED: The 5/16" ID grommet from ACE and Zoro fit our door holders. Available at ACE HW and from Zero online. It has the center hole for the latch at 5/16". The holder on our door has a groove opening (also called the drilled size DIA) of 7/16". Also for specifying grommets I found this on a Grommet MFG site...shows how they specify grommet dimensions. https://rubber-grommet.com/grommet-size-chart/ Metal Part On Body Inside Diameter Groove Diameter Outside Diameter Groove Width Overall Thickness Oliver Measured 6mm or .235" 8.7mm or .343" 16mm or .631" 1.7mm or .066" TBD as needed Edited April 20, 2023 by Galway Girl Changed image 1 1 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Moderators topgun2 Posted April 10, 2023 Moderators Posted April 10, 2023 Galway Girl's advice on measuring is VERY sound - over the years Oliver has used different hardware for the door catches (I'm assuming that this is what JD wants these grommets for). Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Golfnut Posted April 10, 2023 Posted April 10, 2023 JD I have a 2022 LEI. Under warranty one of the grommets went bad , Oliver sent me a couple…. I was at my favorite Ace hardware and looking at the Hillman Drawers and saw those grommets, I didn’t get any , but I think one would fit.. Hillman Headquarters is 10 mins from me.. Try your local hardware store… 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Moderators topgun2 Posted April 10, 2023 Moderators Posted April 10, 2023 Golfnut - Certainly your advice is sound. However, note my post above and I'm reasonably sure that the grommets your Ollie takes are a different size versus the ones that JD's Ollie takes. Bill 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
John E Davies Posted April 15, 2023 Author Posted April 15, 2023 I bought the big super sized Amazon package, now I have 39 extra spares, plus lots of different sizes. InstallGear 180pc Assorted Rubber Grommet Kit - 8 Sizes (1/4", 5/16", 3/8", 7/16", 1/2", 5/8", 7/8", 1") | Car Grommet Kit Assortment Rubber Wire Grommets for Wiring Automotive | Rubber Grommet Kits It's hard to beat $9 for 180 grommets.... delivered 😉 These seem like good quality. John Davies Spokane WA 3 3 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT.
Galway Girl Posted April 20, 2023 Posted April 20, 2023 Found this particular 5/16" ID grommet fit perfectly in my bracket. It's designed for a 7/16" holder hole. (Groove) You can buy this at most ACE HW and also from Zoro online. The grommet hole of 5/16" is big enough to securely hold the latch but not so hard to push the latch into the hole. When I tried the earlier listed 1/4" ID grommet it was simply too tight. The latch would try to push the grommet out when inserting. Again...your holder may be different. Anyone want 99 , 1/4" grommets ...let me know. Craig - Hull 505 2 2 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com Lower 48 + Alaska Achieved in Maine in Aug 2024 on way to Nova Scotia.
Moderators mossemi Posted April 21, 2023 Moderators Posted April 21, 2023 I also end up buying more than I need on Amazon, especially the small stuff. I need to start posting my extras on eBay. Mossey 2 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
MAX Burner Posted April 21, 2023 Posted April 21, 2023 30 minutes ago, mossemi said: I also end up buying more than I need on Amazon Me too, oh well... The extras will come in handy for a future use, I'm sure! 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Moderators mossemi Posted April 21, 2023 Moderators Posted April 21, 2023 7 minutes ago, MAX Burner said: The extras will come in handy for a future use, I'm sure! Yep! At my estate sale and my wife will be cussing about “all my crap”. Mossey 4 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators topgun2 Posted April 21, 2023 Moderators Posted April 21, 2023 1 hour ago, mossemi said: my wife will be cussing about “all my crap”. "will be" You mean she doesn't cuss about it already?😇 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators mossemi Posted April 22, 2023 Moderators Posted April 22, 2023 10 hours ago, topgun2 said: You mean she doesn't cuss about it already?😇 No comment! Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
Moderators SeaDawg Posted April 22, 2023 Moderators Posted April 22, 2023 11 hours ago, topgun2 said: "will be" You mean she doesn't cuss about it already?😇 Is what it is. We occasionally discuss a lot of "stuff" stored that we "should" delete to make life easier for our daughter when we're no longer around. For the most part, she's going to be busy..... not quite ready to part (yet) with all tools/spare parts/ junk/ decorations, etc, etc, etc 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Ollie-Haus Posted April 22, 2023 Posted April 22, 2023 26 minutes ago, SeaDawg said: Is what it is. We occasionally discuss a lot of "stuff" stored that we "should" delete to make life easier for our daughter when we're no longer around. For the most part, she's going to be busy..... not quite ready to part (yet) with all tools/spare parts/ junk/ decorations, etc, etc, etc We've had a number of garage sales over the years in the interest of getting rid of extra "stuff" we really don't need. I'd say we average $400-$500 intake for what amounts to clutter to us. Still seems like there's a lot of extra stuff around here. 2 What's today?............. the most frequently asked question as a retiree 🙄 Chris and Stacie Neuhaus and Cohen the fearless Border Terrier, Greenfield, Indiana 2021 Ford F350 7.3L Tremor (Redzilla) LE2 #1373 - Ordered 10/21/22 - Delivered 05/10/23
Moderators SeaDawg Posted April 22, 2023 Moderators Posted April 22, 2023 22 minutes ago, Ollie-Haus said: We've had a number of garage sales ... ...Still seems like there's a lot of extra stuff around here. Guess that's true, for most of. Best of luck ! 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Moderators mossemi Posted April 22, 2023 Moderators Posted April 22, 2023 9 hours ago, Ollie-Haus said: We've had a number of garage sales over the years We just donate it! I don’t like strangers looking at the “good stuff” that I’m not ready to part with. It does amaze me the stuff people will pick up at the end of the driveway.😁 Mossey 2 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
MAX Burner Posted April 22, 2023 Posted April 22, 2023 10 hours ago, Ollie-Haus said: Still seems like there's a lot of extra stuff around here. We do the same thing occasionally - we call it doing "The Big Purge". It's very satisfying on many levels, IMHO! Ha!😜 1 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) (SOLD) 2022 TUNDRA (SOLD) 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
