routlaw Posted July 10, 2023 Posted July 10, 2023 Hoping someone here can help with this because the Oliver website appears dysfunctional. Tried repeatedly to login/register for the rewards program, but they system returns an invalid username or email address each time. Tried to reset password, same results. It gets worse. Then I tried to send an email to customer support, only to find out I had to check one of the items as a perspective customer. My hull # is 70, so I don't need brochures a tour, or anything else. Does anyone here know how to resolve this issue.? Thanks Rob 2 Legacy Elite II #70
Administrators MDuncan Posted July 10, 2023 Administrators Posted July 10, 2023 Hi Rob! Sorry you are having trouble with it. The login for the website and forum are different. The Rewards Program has a specific registration process. You can find a link here to sign up for the Rewards Program : https://olivertraveltrailers.com/rewards-program/ or go direct at https://olivertraveltrailers.com/rewards-program/signup/. There a few videos we have posted here as well. Let me know if you are still having issues. Matt Duncan 3 Matt Duncan Marketing Consultant, Oliver Travel Trailers
Moderators SeaDawg Posted July 11, 2023 Moderators Posted July 11, 2023 I followed Matt's link, and registered in a matter of a couple minutes. (Even though I don't plan to participate. Just a test. I don't think most people want to see a 2008 trailer, and, frankly, I'll leave it to you folks with newer trailers.) Worked great. Thanks, @MDuncan for the link. I used the 2nd link. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
routlaw Posted July 11, 2023 Author Posted July 11, 2023 Thanks Matt for the link, it worked. Odd this link does not appear to be anywhere on the Oliver Website though, well not that I could locate and it wasn't for lack of looking, only link to sign in. Oh doesn't matter, it's all done now. Thanks 1 Legacy Elite II #70
LeeC Posted March 11 Posted March 11 Hello All, I have been searching the forums trying to find out where I need to go to access the rewards program. I apologize if this has been answered in a different thread. I saw on a different post that you have to register your Oliver to participate in the rewards program. I am not sure where to register. I did complete the information about my trailer when joining the Forum. Is there a specific page where I need to go to register my trailer. I also tried to access the registration for the rewards program with the link above but it is just taking me to the Oliver home page. When accessing the rewards program via the menus on the Oliver site it takes me to a log in but does not show a place to register. Lee - "Once More into the breach, dear friends, once more."
Moderators topgun2 Posted March 11 Moderators Posted March 11 Lee - please see the post above by Matt Duncan dated July 10, 2023. That should answer most of your questions. Bill p.s. if you still have questions - simply send Jason Essary or Matt Duncan a private message (PM) 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
LeeC Posted March 11 Posted March 11 (edited) 1 hour ago, topgun2 said: Lee - please see the post above by Matt Duncan dated July 10, 2023. That should answer most of your questions. Bill p.s. if you still have questions - simply send Jason Essary or Matt Duncan a private message (PM) Thanks Bill. I did try the links posted by Matt above but they are just taking me to the Oliver Home page. I did send Matt a PM just now per your suggestion. Edited March 11 by LeeC Lee - "Once More into the breach, dear friends, once more."
Moderators topgun2 Posted March 11 Moderators Posted March 11 Lee - When you get to that "home page" simply scroll all the way to the bottom of that page and look on the right side of the screen - here you should see "Rewards Login" under the word "Company" that is in white lettering. Hope this helps. Bill p.s. Matt no longer works full time for Oliver - therefore, it may take awhile for him to get back to you. Jason might be able to help sooner. 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
dewdev Posted March 12 Posted March 12 @LeeC Here is a little simplier direction to get to the area to register in the Reward Program. Start at the OTT opening web page. At the top of the page click on the drop down arrow for the Tab called "Resourses", then click on "Rewards Account". The next page should allow you to register. Hope this helps 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
LeeC Posted March 13 Posted March 13 17 hours ago, dewdev said: @LeeC Here is a little simplier direction to get to the area to register in the Reward Program. Start at the OTT opening web page. At the top of the page click on the drop down arrow for the Tab called "Resourses", then click on "Rewards Account". The next page should allow you to register. Hope this helps Unfortunately, there is no option to register. I have tried every step on this page but cannot find a way to register. Below is a screen shot of what I see when I go to rewards program page. Lee - "Once More into the breach, dear friends, once more."
dewdev Posted March 13 Posted March 13 (edited) @LeeC On the page you show, you have to log in again on this page, which I assume you have done. This is a sepeate log in seperate from the Oliver web page login. I did it and it worked for me, but I already had a Rewards Program account. ( I did it on my computer and not on my phone.) If that does not work, you will probably need to contact OTT for help. Good luck Edited March 13 by dewdev 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
LeeC Posted March 14 Posted March 14 20 hours ago, dewdev said: @LeeC On the page you show, you have to log in again on this page, which I assume you have done. This is a sepeate log in seperate from the Oliver web page login. I did it and it worked for me, but I already had a Rewards Program account. ( I did it on my computer and not on my phone.) If that does not work, you will probably need to contact OTT for help. Good luck @dewdev Un able to log in as I have not registered for the rewards program. There is no link or method to register on that page. I have put in a request to OTT in an attempt to get an answer. I am assuming form the directions everyone keeps giving me that at one point there was a link or some way to register from that page. From my previous screen shot, you can see now that there is no registration, only a log in. I have tried using my Forum user name and password, along with my email. I even tried using the forgot password using my email. None of those work. Lee - "Once More into the breach, dear friends, once more."
dewdev Posted March 25 Posted March 25 (edited) @LeeC Did you talk to OTT about signing into the Rewards site? What did they tell you? I think the reason you can not register is because OTT no longer has a rewards point system (with dollars put on a credit card) like they use to. Not sure if still offered, but they used to have a program of paying you if you show show your Ollive to a prospective buyer who than buys a new Oliver. You had to agree to show your OTT by signing up on the web site. Edited Saturday at 05:29 PM by dewdev 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
