Mark Meadows Posted August 14, 2023 Posted August 14, 2023 Hi , I’m basically new here and I’m wondering if there is a way to power my EL2 with an extension cord and adapter from a wall outlet. Thanks all Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Wandering Sagebrush Posted August 14, 2023 Posted August 14, 2023 Sure, you need an adapter to go from the regular household outlet and cord to the 30 amp RV connector. you can get these from Amazon or local RV retailers. I taped a ziplock over the cord/adapter connection to protect from rain when used outside. 4 Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
Mark Meadows Posted August 14, 2023 Author Posted August 14, 2023 Ok that seems simple enough, thank you. I’ll check Amazon Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Steph and Dud B Posted August 14, 2023 Posted August 14, 2023 If you have lithium batteries you'll need to change a setting in the converter (Xantrex) to prevent tripping the 15A breaker at your house. It's setting #28. Change it to 15A or less. 4 Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999:
Frank C Posted August 14, 2023 Posted August 14, 2023 You just need an adapter cable like this and then a standard extension cord. This will let you connect to one of your house 15 amp outlets. But as mentioned above, this does limit you to 15 amps max current draw. Kohree RV Adapter Plug 30 Amp to 15 Amp 110V, RV Power Adapter 15A Male to 30A Female, RV Dogbone Electrical Adapter Cord 12" with Twist Lock & LED Indicator https://a.co/d/2ZZo15P 2 1
Moderators topgun2 Posted August 14, 2023 Moderators Posted August 14, 2023 Or, if you want to go cheap you could always do THIS 3 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted August 14, 2023 Posted August 14, 2023 1 hour ago, topgun2 said: Or, if you want to go cheap you could always do THIS Glow in the dark? 😅 1 1 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John Dorrer Posted August 15, 2023 Posted August 15, 2023 As Steph & Dud B stated. We kept tripping our son's breaker until Oliver provided guidance. #28 down to 15. Don't forget to switch it back. Using the phone app is easier to make the changes, so after unplugging turn on the inverter so you can pull up the phone app. Easy Peasy. 4 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Mark Meadows Posted August 17, 2023 Author Posted August 17, 2023 On 8/14/2023 at 12:24 PM, Steph and Dud B said: If you have lithium batteries you'll need to change a setting in the converter (Xantrex) to prevent tripping the 15A breaker at your house. It's setting #28. Change it to 15A or less. Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Mark Meadows Posted August 17, 2023 Author Posted August 17, 2023 AGM batteries here . his is a little bit more complicated than I thought it would be 2 Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Mark Meadows Posted August 17, 2023 Author Posted August 17, 2023 On 8/15/2023 at 6:28 AM, John Dorrer said: As Steph & Dud B stated. We kept tripping our son's breaker until Oliver provided guidance. #28 down to 15. Don't forget to switch it back. Using the phone app is easier to make the changes, so after unplugging turn on the inverter so you can pull up the phone app. Easy Peasy. thanks, Ill have to investigate. I just picked it up a week ago and I have more to learn Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Mark Meadows Posted August 17, 2023 Author Posted August 17, 2023 On 8/14/2023 at 12:58 PM, Frank C said: You just need an adapter cable like this and then a standard extension cord. This will let you connect to one of your house 15 amp outlets. But as mentioned above, this does limit you to 15 amps max current draw. Kohree RV Adapter Plug 30 Amp to 15 Amp 110V, RV Power Adapter 15A Male to 30A Female, RV Dogbone Electrical Adapter Cord 12" with Twist Lock & LED Indicator https://a.co/d/2ZZo15P I received it in the mail today. Thanks 1 Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
John Dorrer Posted August 17, 2023 Posted August 17, 2023 14 hours ago, Mark Meadows said: thanks, Ill have to investigate. I just picked it up a week ago and I have more to learn I posted an e-mail on another post. I would consult with Oliver as different batteries have different settings. Not exactly sure where to have you look, but Oliver will help. 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
Mark Meadows Posted August 17, 2023 Author Posted August 17, 2023 Ok then I’ll do that. Thank you Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Shawna and Scott Posted August 28, 2023 Posted August 28, 2023 I have mine plugged into a receptacle in the garage. It has a 20amp breaker. We dont turn anything on except the lights occasionally and the heater pad in the winter. I use the adapter to attach to our 30 amp cable Oliver provided. Should I adjust the setting on #28 to 15 since we have a 20 amp breaker? 1 Vincent, Ohio | 2022 Elite ll, Hull #1182, 2019 Ford F150 3.5L EcoBoost
dewdev Posted August 30, 2023 Posted August 30, 2023 On 8/28/2023 at 3:20 PM, Shawna and Scott said: I have mine plugged into a receptacle in the garage. It has a 20amp breaker. We dont turn anything on except the lights occasionally and the heater pad in the winter. I use the adapter to attach to our 30 amp cable Oliver provided. Should I adjust the setting on #28 to 15 since we have a 20 amp breaker? To be on the safe side, check with Oliver. I believe if you have LIthium batteries, yes you need to make the adjustment on #28, and set it to 20 amp in your case. 1 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Kansa Posted September 8, 2023 Posted September 8, 2023 I have tried to use my adapter (Marinco) and an extension cord and I get a popping sound inside the trailer I have 4. 6v AGMs is that the issue. I never had a problem with plugging in my old Jayco trailer 2 2022 Oliver Legacy Elite ll Hull 1267 10/6/22 Solar with AGMs 2015 Ram 2500 HD Cummins B&H Hitch
dewdev Posted September 9, 2023 Posted September 9, 2023 is your inverter turned off? Are your getting a error message on your incoming power Progressive Industries monitor in the attic? 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
