Mark Meadows Posted January 3, 2024 Posted January 3, 2024 One of my (wheel) center caps keeps falling off when the temperature drops. I ordered a set from Amazon that had been suggested here in the forums but they do not fit. Does anyone know what I can do to remedy the situation? My E2 is still under warranty. Thanks, Mark Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Moderators topgun2 Posted January 3, 2024 Moderators Posted January 3, 2024 1 minute ago, Mark Meadows said: My E2 is still under warranty. Contact Service and I'm guessing that they will ship you some new caps. Then, when you install these simply put something like E6000 or any similar product on the backs of the caps and that will keep them from "falling off". Bill 5 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Mark Meadows Posted January 3, 2024 Author Posted January 3, 2024 Ok I’ll give it a try! Thanks Mark Meadows 2023 Oliver Elite II Ford F-150 Powerboost (hybrid)
Geronimo John Posted February 28, 2024 Posted February 28, 2024 More than a few of us, myself included, have found that our trailers look just fine with the eight FOUR center hub caps and their supporting "Cones ???" removed. This is especially true of owners that routinely shoot their hubs with an IR temperature sensor. With the cones and caps installed, it is difficult to get a good bearing/hub temperature readings. This is the topic of several members here on the forum. GJ 1 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
MAX Burner Posted February 28, 2024 Posted February 28, 2024 11 hours ago, Geronimo John said: our trailers look just fine with the eight center hub caps and their supporting "Cones ???" removed. Hey, GJ: Concur 100%, but we've only found 4 hub caps on the Casablanca....🤪 1 3 2 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA 2017 LE II; Hull #226 "Casablanca" HAM call-sign: W0ABX
Geronimo John Posted February 29, 2024 Posted February 29, 2024 Yea I saw that. My slide rule must have needed some grease for that calculation! 🙂 GJ 1 2 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
Moderator+ ScubaRx Posted March 15, 2024 Moderator+ Posted March 15, 2024 On 2/28/2024 at 8:02 AM, MAX Burner said: Hey, GJ: Concur 100%, but we've only found 4 hub caps on the Casablanca....🤪 Sounds like you only have the two axle trailer rather than the four. 3 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
srthomsen Posted December 23, 2024 Posted December 23, 2024 One of mine fell off in our driveway yesterday. No broken tabs and it's not damaged in any other way. I'm going to try some type of adhesive to see if I can make it 'stick'. 2023 Elite #1403--2019 Ford F150--2.7 Ecoboost V6--10 speed auto--without Max Tow
Moderators Mike and Carol Posted December 23, 2024 Moderators Posted December 23, 2024 50 minutes ago, srthomsen said: One of mine fell off in our driveway yesterday. No broken tabs and it's not damaged in any other way. I'm going to try some type of adhesive to see if I can make it 'stick'. I got tired of messing with them last year and, like others, took all four hubs and caps off. Looks fine and now I don’t have to deal with them anymore. Mike 2 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L
Patriot Posted December 23, 2024 Posted December 23, 2024 (edited) I carry a few spares, one is none and two is one. I think the are a whopping $3 a piece plus shipping from Oliver Service. Broken tabs a no go. Spares Edited December 23, 2024 by Patriot 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
Moderators topgun2 Posted December 24, 2024 Moderators Posted December 24, 2024 A little E6000 on the back and tabs is all it takes to keep these puppies in place - broken tabs or not. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Patriot Posted December 24, 2024 Posted December 24, 2024 1 hour ago, topgun2 said: A little E6000 on the back and tabs is all it takes to keep these puppies in place - broken tabs or not. Bill Yep, I did that with the one that broke off. When I accidentally skinned it while torquing my lugs. At $3 a piece its a quick fix. 😊 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina
FloraFauna Posted December 25, 2024 Posted December 25, 2024 On 12/24/2024 at 9:01 AM, Patriot said: Yep, I did that with the one that broke off. When I accidentally skinned it while torquing my lugs. At $3 a piece its a quick fix. 😊 Yeah, super easy to bang those up when torquing the lugs. Mine is hanging in (on) there but is now dented up. I banged one up before learning that lesson. So far, the perfectionist in me has been muffled and I have resisted replacing. 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
Moderators topgun2 Posted December 25, 2024 Moderators Posted December 25, 2024 (edited) 24 minutes ago, FloraFauna said: So far, the perfectionist in me has been muffled and I have resisted replacing. Give in! Give in! Give in! Edited December 25, 2024 by topgun2 1 1 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
