dewdev Posted January 29 Share Posted January 29 I have seen on this forum discussions for torque setting for the Wheel Nuts (90-100 ft-lbs) and the Leveling Jack flange bolt nuts (43 ft-lbs). Are there other fasterners on the Ollie's that we should be checking torque and what setting should they be? 1 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
MAX Burner Posted January 29 Share Posted January 29 We use these values (screenshot from our maintenance and trip log): 5 7 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit 2017 LE II; Hull #226 "Casablanca", 3x Battle Borns; Victron Cerbo S GX, Other Victron Stuff: SmartShunt, MPPT Solar Controller, DC-DC Charger, 12VDC Starlink kit, and Alcan 5-pack Leaf Springs HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
John Welte Posted January 30 Share Posted January 30 7 hours ago, MAX Burner said: We use these values (screenshot from our maintenance and trip log): Very helpful. Thanks. John 2 John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Link to comment Share on other sites More sharing options...
dewdev Posted January 30 Author Share Posted January 30 Thanks MAX Burner. What are you referring to when you say "Shackle Nuts"? 2018 Oliver Elite II, Twin Bed, Hull #354 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio Maine Link to comment Share on other sites More sharing options...
Patriot Posted January 30 Share Posted January 30 2 hours ago, dewdev said: Thanks MAX Burner. What are you referring to when you say "Shackle Nuts"? I will chime in. I believe @MAX Burner is referring to the torque value of the nut that tightens the wet bolt. Comonly referred to as wet bolts due to having a grease zerk on the end. https://www.etrailer.com/Trailer-Leaf-Spring-Suspension/Redline/34007-187-00.html 3 2020 OLEII - Hull #634 aka- “XPLOR” 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor Link to comment Share on other sites More sharing options...
MAX Burner Posted January 30 Share Posted January 30 @Patriot - exactly correct... Thanks for clarifying. 1 Art, Diane, Magnus & Oscar (double-Aaarrf!) 2022 TUNDRA w/Airlift Load Lifter 5000 kit 2017 LE II; Hull #226 "Casablanca", 3x Battle Borns; Victron Cerbo S GX, Other Victron Stuff: SmartShunt, MPPT Solar Controller, DC-DC Charger, 12VDC Starlink kit, and Alcan 5-pack Leaf Springs HAM call-sign: W0ABX Link to comment Share on other sites More sharing options...
jd1923 Posted January 31 Share Posted January 31 However we think our Olivers are special, a bolt is a bolt and torque is based on bolt grade and diameter. I never look at manufacturer's specs, too much time and trouble. Torque-Tension Reference Guide.pdf (fastenal.com) 4 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins! Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted January 31 Moderator+ Share Posted January 31 I believe it is 43 pound/feet. 2 1 Steve, Tali and our dog Rocky plus our beloved Storm, Maggie, Lucy and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
Geronimo John Posted February 19 Share Posted February 19 Art: Some may ponder too long on this one. Suggest add an "en" on Tight and a value. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR). Link to comment Share on other sites More sharing options...
