Very nice mod with a simple approach and excellent results!  Thanks for sharing.
On 2/3/2024 at 12:02 AM, Snackchaser said:
Our 2022 Elite II has the Dometic furnace, but I suspect that other furnace brands could have similar ducting issues and it might be worth taking a look.
Our 2022 Elite II has the Truma Varioheat furnace.  The Truma ducting is smaller, more substantial and, from what I can see in the photos, better installed.
In addition to the mods detailed above, I recommend you consider adding a return air vent from the bath to the underside of the front dinette seat.   Our Truma Varioheat system came with that additional return air vent.  It really helps the flow of heated air.
@Snackchaser were you able to get to or see the "reducer" on the way to the bathroom duct? I guess it just goes to smaller diameter ducting, so nothing you can do about it anyway.
It is "standard" operating procedure, in hot air ducting, to decrease duct size the further it gets from the heat source. The same amount of air in the 4" duct gets put into the 3" duct. This increases the velocity and helps move the heated air along. I just hope the is a direct path out of the bathroom and back to the return duct. Also hope that air is returned through the cabin and not through the basement. The return air is going to suck the air with the least resistance. Hopefully it is not the air from the drain 'scuppers'. That air might be 40°, or more,  cooler than cabin air, and the basement air might be 20° or more. The warmer the return air the more efficient the furnace is at heating.
Edited by Mainiac
Correct type
Yes, it's directly attached to the Tee for the kitchen register.   The 3" duct goes on to the bathroom through some sort of firewall and it's not easily reached.
There was enough slack in the 3" duct to pull the Tee (with attached reducer) out through the access port that's under the forward kitchen drawers.  The space is tight, and you will need to detach the 4" side from the furnace to get enough slack on that side.  You can make most of the new connections while it's out.
You'll need to disconnect the kitchen register first.  The screw holding the duct to the register can be reached through the access port, but it's easier to replace it from the inside of the register, rather than trying to do it blindly from inside the access port.
Cheers, Geoff
 Here's a photo that I forgot to add in the original post:
0E07AA77-E3D6-4DFF-A433-A8A041E1A4A5_1_105_c.thumb.jpeg.d19065c07d237dbf2e93b1b1ea1d99b4.jpeg
  • 2 months later...
I'm in the middle of my conversion. I have removed the Kitchen/Bathroom T and attached the duct to the front of the furnace. I'm going to have a problem putting the T at the bedroom location due to waterlines in the way. (I'll include a photo) I didn't want a plumbing job. thinking of just going to the Kitchen and eliminating the sleeping area. Was your duct restricted like this?
Hull #1238 - Legacy Elite II, TB. TV 2017 Tundra TRD.
States Visited Map
Can you cut the duct, move the blue pex line(s) out of the way (pex lines are fairly flexible), and then reconnect the duct, incorporating the duct Tee?
Thanks, that's exactly what I did, the fix is now completed. Happy with the improved airflow.
States Visited Map
Like the simple design @Snackchaser showed. I will do our mod this summer. I’m also thinking of deleting the bed area duct. We’re camping in colder weather last few days and I have this one shut as much as possible which helps the air flow in the bath. The bed area duct is too close to the return and we like the cabin warm but cooler air where we sleep.
  • 1 month later...
Decided to submit another thread on my complete mod!
Edited by jd1923
I had to read this a couple time to realize yours was OEM installed. I'm trying to figure best location to drill. @Rivernerd could you take a picture from the bath side?
I agree this is a necessary addition. Thank you!
Edited by jd1923
Older thread, but relevant, I think.
Finished up the bathroom vanity yesterday. I had a supply of 1/4" u-clips but the fiberglass is quite thick at the opening and decided that would be too much work, the placement must be extremely accurate.
I merely used thin panhead wood screws with no taper. Measured with a digital caliper to drill just the right size holes. Added a SS washer so the screw head would not drag on the plastic. Thoroughly cleaned off all the old caulk and sealant. This product has just the right size opening and adequate length: uxcell U Channel Edge Trim, 6.5ft Length Rubber Guard Seal Strip Edge Protector Fit for 1.5-2.5mm Edge, (13/64" W x 5/16" H) White - Amazon.com
To-dos left are the bathroom to under dinette vent and the return air filter housing. Waiting for parts...
Thanks again Sherry. Just found the picture I was asking for in the link you supplied. (It appears @Rivernerd has been offline for a week.)
The vent is behind the toilet where you could actually fit a standard drill vs. a 90-angle drill. It does look like a 3" vent in the pic vs. the 4" installed elsewhere. I would not add another vent from under the dinette to the hallway, since the idea is to create air return from the far bathroom vent through the basement and around the rear back to the furnace. This could actually assist in pulling more air out of the bathroom duct too.
Now I merely have to get up the nerve to pick a spot and start drilling! Will start with an 1/8" hole so I can adjust location of the full vent hole as needed. Just noted in the other thread that OTT installed a 2" vent in this location.
Edited by jd1923
Added last sentence
  • 1 year later...
Cheers, Geoff
My Visited North America Map
Geoff,
Did you end up putting a screw into the "Connecting Collar" coming out of the rear of the Truma heater and the start of the rigid duct (180° turn).  Or replace it with a "straight out" " not beveled" connecting collar. I found the design of the existing connecting collar had a slight beveled towards the inside.  I believe this is to allow insertion around it of the flex ducting, which has little weight to it.  but for heavier rigid ducting and the heavier flex ducting there is for lack of a better word more “Torque” on that connecting collar.
My rigid 180 as shown kept sliding off no matter how tight the 4” clamp was cranked down.   So, I went back to a heavier (than supplied by Oliver in 2020) duty flex tubing.  I even had the rigid and heavier flex on the floor to reduce torque, and it would still come off with the slightest of movement.
I liked everything else i saw and it makes sense.  So, I did "phase I" of re-ducting.
Maybe the re-design will be adapted at factory assembly.
B~Out,
Yes screws are necessary on all the fittings, clamps will not compress rigid fittings onto the furnace flange.   But screws are not enough, also use foil tape on all the joints it holds very well and seals too!  I see some remnants of the old foil tape in your picture, and it's readily available at most hardware stores.
Geoff
i was wondering about that.  i did not see any screws, glad I asked. here is a picture of my beveled connector collar.
Did you twist & remove the connector collar to drill that hole?  I accidently removed mine when working the elbow on to it.  Took me 10 mins to get it inserted & locked in just right.  that is why my foil tape is there to stabilize it, in case i go the "Screw the 180" route.
Now i might bring my 180 with me and try to do that mod on the road if things are a bit chilly inside.  Maggie said that she felt a lot of heat coming out of the shower exhaust next to the TP caddie.
i was reading but did not catch if you mentioned,
Did you replace any pex to move the line that is "Right in the WAY!!!" to connect the under the bed exhaust vent?   Boy-h-boy, they sure did want us to have a nice 45 elbow in there.
The way i see it is, if i can move the water line, then i can have a Rigid Tee in there on the way to the Kitchen Exhaust.
You can drill with the collar in place, either a 1/4" self-drilling screw, or drill a hole for a #8 sheet metal screw.  Best to tape it on before screwing, otherwise the holes can be hard to re-align.   Those collars are a pain to install, and you were right to tape it in place.  There was another post today where it looked like the blank hole seal might have fallen off someone's furnace.
The PEX lines are definatly in the way, my duct was squashed to fit through, and the water heater by-pass valve handle had worn a hole in the duct.
While you're in there, take a look at the water heater plumbing.  There is a by-pass loop and valve to isolate/by-pass the water heater.  This was one of the lines interfering with my duct.  I removed it, mostly because I put in a hot water recirculating system, but it opened up space too.  I don't anticipate ever needing to by-pass the water heater like that, and most folks probably don't even know it's an option because the valve is hidden under the duct.  If there is ever a problem during travels, I'm just shutting the water off or bypassing the water heater by other means.
